Compteur de contenus
50 -
Inscription
Dernière visite
Type de contenu
Profils
Forums
Galerie
Calendrier
Tout ce qui a été posté par Floflo42
Qubino ZMNHXD1 3-Phase Smart Meter Pages produit : https://qubino.com/products/3-phase-smart-meter/ https://qubino.com/products/3-phase-smart-meter/smart-meter-3phase-tech/ Main terminals (L1I, L2I, L3I, NO, L1O, L2O, L3O, NO) Contacts capacity: 2.5 ... 16 (25) mm2 Connection screws: M5 Max torque: 3.5 Nm (PZ2) Optional terminals (1,2,4,5) Contact capacity: 1 ... 2.5 mm2 Screws: M3 Max torque: 1.2 Nm Measuring input: Type (connection): three phase (4u) Basic current (Ib): 5 A Maximum current (Imax): 65 A Minimum current (Imin): 0.25 A Starting current: 20 mA Nominal voltage (Un): 3x230 V/400V Power consumption at Un: < 8 VA Nominal frequency (fn): 50 and 60 Hz Accuracy: Active energy and power: Standard EN 62053-21: class 1 Standard EN 50470-3: class B Reactive energy: Standard EN 62053-23: class 2 LED: Colour: red Pulse rate: 1000 imp/kWh LED on: no load indication Optical communication: Type: IR - used to control BICOM432-40-IR Input (16): Rated voltage: 230 V (± 20%) Input resistance: 450 kOhm Safety: LCD: Indoor Meter: yes Degree of pollution: 2 Protection class: II AC voltage test: 4 kV Installation Category: 300 Vrms cat. III AC voltage test: 4 kV Installation Category: 300 VRMS Cat. III Standard: EN 50470 Ambient conditions and EMC: According standards for indoor active energy Meters. Temperature and climatic condition according to EN 62052 11 Ambient conditions and Safety: According standards for indoor active energy Meters. Temperature and climatic condition according to EN 62052 11 Dust/water protection: IP50 Operating temperature: -25 ... 55°C Storage temperature: -40 ... 70°C Enclosure material: self-extinguish complying UL94 V Indoor Meter: yes Degree of pollution: 2 AC voltage test: 4 kV Standard: EN 50470 Distance: up to 30 m indoors (depending on building materials) Weight (with packaging): 220g (240g) Frequency range: 868.4 MHz*, Z-Wave Installation: DIN rail 35mm Dimensions (W x H x D): 53,6 x 84 x 65mm Package dimensions (W x H x D): 58 x 84 x 95mm Colour RAL 7035 ------------------------------------------------------------------------------------------------------------------------------------------------- Bonjour à tous, Je suis en train de refaire (exclure/inclure les modules) l'intégralité de mon réseau domotique maintenant que j'ai ma HC3. Je rencontre quelques petites bizarrerie que j'essaye de comprendre au fur et à mesure. J'ouvre se post/sujet car je n'ai rien trouvé concernant la HC3 & le module Qubino Smart Meter 3-Phase Je l'ai inclus il y a quelques jours mais je n'ai pas de retour des valeurs sur tout les points alors que je les avait sur ma HC2 et se que quelqu'un a déjà eux se problème ??? Voici une capture d'écran ou vous constaterez que je n'ai des retours uniquement sur les Watts .... Merci à tous d'être ici
Hello, j'ouvre se poste à titre informatif et d'échange concernant la serrure connectée Nuki 2.0 (les admins si vous pensez que je suis pas à la bonne place ou que ce poste n'est pas utile faite le moi savoir pour que je puisse au mieux respecter la communauté de se super site) J'avais pas vu que le créateur de la QA l'avait mis à jour en mai du coup maintenant j'ai réussi à l'intégrer dans la HC3 en plus il y a un jolis travail sur le PDF pour la configuration. Alors pour l'instant je n'ai pas encore tester les fonctions de PIN directement dans l'application mais le reste fonctionne y compris le retour d'état de la serrure. Le seul truc qui n'as pas jouer c'est l'icône de la serrure qui ne c'est pas installée. Lien du QA pour ceux que ça intéresse : https://marketplace.fibaro.com/items/nuki-lock-v-1-0
Bonsoir à tous, J'ai chercher et certainement mal mais j'ai mes applications sur mes périphériques IOS qui me mettent la pastille de notifications mais je n'arrivent pas à voir les notifications dans l'application ni réinitialiser la pastille ( ma solution et de redémarrer mon iPhone ) Savez-vous comment faire ? ou éventuellement dans quel partie du Forum je trouverais la réponse ? Salutations
Bonsoir à tous, je viens ici posé une question car ça fait des jours que je patine avec mes modules RGBW mon problème et que j'arrive à l'inclure dans ma HC3 mais il reste en module '' non configuré '' et donc non-utilisable, j'ai essayé de le réinitialiser complètement et essayer avec d'autres mais le résultats et le même PAR CONTRE très étrange si je reprend une ancien modules RGBW ( Fibaro FGR441 ) aucun soucis intégrer parfaitement et fonctionne Avez-vous une idée du problème ? Salutations Romain
Alors je viens de faire la réinitialisation du module ensuite exclusion/inclusion et toujours la même chose .... ... mais ce qui me paraît très bizarre et que j'ai acheté plusieurs modules identique et c'est chaque fois le même résultat catastrophique (j'ai 3 modules )
Bonjour et bienvenue dans le monde de la domotique. Tu risque encore de faire des crises a choisir entre toutes les possibilités que va t'offrir ta HC3.
oui c'est étrange même encore plus étrange c'est que j'ai essayé sur une autre box HC3 et j'arrive au même résultat .... J'ai mon fournisseur de mes box qui as pris contact avec Fibaro mais leurs réponses n'est pas top ... Voici la réponse du support de Fibaro: It's like a first-timer. I haven't see this kind of problem yet. Can your customer try to move his module/home center close to one another? Path to go is: Restore RGBW to the factory defaults Add it once again to your customer's Home Center with close distance Afterwards everything should be up and running. I am adding/removing numbers of RGBW 2 to the HC3 in order to test it out for the customer and I didn't see that problem yet. If described solution won't work, please proceed with the warranty.
ohh je suis jaloux !!! alors oui j'ai attendu un bon moment ... la je suis avec un des modules à 6 jours qu'il est inclu mais rien de modifier. J'ai également exclu / inclu le module cliquer lire la configuration dans les options avancée reconfigurer y softconfiguration .... j'ai également redémarré la box Voilà le texte qu'il me retourne après une inclusion (Et j'oublie de mentionner que mon module et à une distance de 40cm de ma box pour la configuration) : [04.08.2020] [20:54:51] [TRACE] [ZWAVE]: Home Center in learning mode [04.08.2020] [20:54:53] [TRACE] [ZWAVE]: Device was deleted successfully [04.08.2020] [20:54:53] [TRACE] [ZWAVE]: ID 211: Deleting devices successful [04.08.2020] [20:54:54] [TRACE] [ZWAVE]: Slave Device Detected [04.08.2020] [20:54:54] [TRACE] [ZWAVE]: ID 211: Controller was deleted successfully [04.08.2020] [20:54:54] [TRACE] [ZWAVE]: Removing devices finished [04.08.2020] [20:55:06] [TRACE] [ZWAVE]: Home Center in learning mode [04.08.2020] [20:55:11] [TRACE] [ZWAVE]: Device added [04.08.2020] [20:55:11] [TRACE] [ZWAVE]: Requesting neighbours, please wait... [04.08.2020] [20:55:12] [TRACE] [ZWAVE]: Requesting neighbours done. [04.08.2020] [20:55:12] [TRACE] [ZWAVE]: Add node status protocol done [04.08.2020] [20:55:13] [TRACE] [ZWAVE]: Adding devices complete [04.08.2020] [20:57:42] [TRACE] [ZWAVE]: ID 217: Device configuration finished
@Lazer D'accord merci pour l'info et à l'occasion je vais essayé et tiendrais au courant ici mon résultat
@Did Merci pour ta confirmation de l'alimentation est c'est super une seule pour le module et la sonde ! @jjacques68 merci à toi aussi pour tes conseils c'est super sympa d'avoir des retours Maintenant le matériel et commandé je l'attend pour passé à l'étape suivante
Pour donner suite à mon premier poste, le problème n'ai pas encore résolut J'ai racheté des nouveaux modules pour essayer mais malheureusement je me retrouve au même point. Est ce qu'il y a une personne ici qui as déjà installé les FIBARO RGBW Controller 2 sur une HC3 ??
Bonsoir, Superbe travail et surtout très bonne idée mais j'ai une question '' Est ce que cela jouerait sur un NAS Qnap ? '' ou il faudrait faire un nouveau script complet ?
Donc si je suis juste vous avez un Fibaro FGRGBWM-442 ou un smart implant, la dessus vous leurs avez mis une alimentation 24V et la sonde vient se connecter sur le module au sortie Voici l'alimentation que j'ai prévu c'est la Mean Well Alimentation : 85 ~ 264VAC Courant d'entrée : 0.25A/230VAC Tension de sortie : 24VDC Courant de sortie : 0.63A Puissance max : 15.12W (0.63A)
Alors j’ai trouvé peux d’information concernant ses deux sondes mais elles se ressemblent beaucoup Rain bird RSD Bex. 24V 7VA Hunter Mini Click 24V 5A
yes super, je vais voir maintenant ou j'arrive a commander celui ci car malheureusement pour moi le Hunter mini-click j'ai aucun qui livre en Suisse contrairement au Rain Bird.
Tu as acheté la sonde et mis sur un module Fibaro RGBW ou smart implant ? ou tu as passer par une autre méthode ? ça m'intéresse beaucoup ton installation
mhh effectivement ça pourrais être une idée, mais ont est d'accord que si il a plus toute la nuit et que au moment de l'arrosage il ne pleut plus le système se mettra quand même en route avec cette solutions ? J'ai commandé cette sonde pour essayé de faire un montage https://www.reichelt.com/ch/fr/arduino-capteur-d-humidit-pour-l-humidit-du-sol-ard-sen-wet3-p280066.html?&trstct=pos_0&nbc=1
@jjacques68 merci beaucoup pour ta proposition, si je me retrouve vraiment bloquer avec ça au moment venu je reviendrais vers toi ! en attendant j'ai une autre question tu utilise des sondes d'humidités pour le sol ? Si oui tu as quoi ?
ohh mince !! alors jusque la je n'avais pas encore utiliser la deuxième zone (pas encore installé les tuyaux ) je l'avais juste préparé. là je viens d'aller voir et effectivement je ne peux plus cocher les jours. je viens d'essayer de créer de nouvelles pièces et d'autres modules spécifique mais non fibaro nous bloque ... pour l'instant Merci de l'info
AU passage je me demande si ont aura la possibilité de voir le panneau d'arrosage dans l'application mobile ça serais bien prratique pour allumer/eteindre l'arrosage manuellement. (j'ai pour l'instant remis le module qui commande la pompe en visible)
Merci pour le post c'est un petit détail qu'il faut savoir ! Mais en tous cas pour l'instant le panneau arrosage sur la HC3 et fonctionnel. J'aime bien de la façon de pouvoir grouper les zones avec leurs tranches horaires et de modifier facilement le temps d'arrosage. Prochaine étape c'est de réussir à trouver une sonde d'humidité de sol qui marche avec le fibaro FGRGBW-442
J'avais aussi remarqué que ça disparaissais si je restais dans l'application et que je naviguais dedans C'est franchement dommage que nous aillons pas un onglet/un emplacement pour y suivre les notifications sa serait super pratique, car les notifications de l'iPhone disparaissent Merci de ta réponse Maitre Yoda jjaques68
La plus petite caméra ?
Floflo42 a répondu à un sujet de fel-x dans Périphériques et matériels autres
Hello, je trouve trop cool comme idée plus c'est inutile plus ont a envie de faire Alors écoute j'ai fait un projet l'année passée pour surveiller des lapins et ont c'est tourner vers les cameras D-link car elle sont pas trop chère. Par contre attention il y a beaucoup de model et pas tous intégrable dans la HC. (J'avais pris les DCS-932L) Il faut éviter les séries 8000 & 800 sauf erreur c'est à cause de leurs format vidéos qui n'est pas reconnu par Fibaro. Bonne soirée -
Hello Cris81, Désolé j'ai loupé ton post précédent Alors justement c'était le problème que j'avais et c'est pour ça que j'avais créer se post, de mon coté pour y arriver j'ai dû réinitialiser le Qubino et après lui faire l'inclusion puis les valeurs sont remontée. Salutations
Hello les gens, me voici avec un nouveau sujets car je sais pas si j'ai mal cherché où pas mais rien trouvé concernant la combinaison '' HC3 et le Broadlink RM4 Pro '' Est-ce que c'est juste pour l'inclure il faut que je passe par l'ifft ou je pourrais aussi par un module virtuel ? Merci de vos future réponse
