Compteur de contenus
1 667 -
Inscription
Dernière visite
Type de contenu
Profils
Forums
Galerie
Calendrier
Tout ce qui a été posté par fredokl
Bienvenu sur le forum!
Firmware HC3 & HC3L Version 5.141.59 Beta Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New Z-Wave network diagnostic page The Z-Wave network diagnostics page allows for the identification and resolution of potential issues related to the Z-Wave network. What's new: Access Redesigned the mobile device list under access settings. Access to newly added alarm zones, climate zones, and profiles is automatically granted to a new user if the "all" option is checked. Information when the last cloud service synchronization occurred is now displayed under the Users list. New selection controls for granting access to specific devices, scenes, zones and profiles. Backup Performance improvements for backup list and status requests. Devices Binary rain sensor is now available as an optional device for the sprinkler to prevent from watering. Improvements to device adding visuals. Added the ability to filter system notifications by supported notification channels. Improved support for the Aeotec Multi-Sensor 6 (soft-reconfiguration required). The camera preview tab is available only if a camera device has been configured. Improvements to Roller Shutter linked devices. Improved navigation for scene creation from device advanced settings. Energy Improved selection menu for energy meter configuration under energy panel settings. FTI Added information during FTI if user is not able to change Z-Wave engine version when some devices are already added to the system. Other New tooltips visuals. Added a notification for automatic system restore in case of instability. Limited recovery loop in case of both systems failure. Hidden sensors can now be selected as primary sensors in rooms. Reboot is no longer needed after the first system configuration. Minor UX and UI improvements. Profiles Removed redundant actions for Elero venetian blinds. Quick Apps Improved auto-naming of QuickApp elements and labels. Scenes Added support for custom thermostat modes to the block scene editor. Improved the "True for specified" time option setting for conditions in the block scene editor. Update Added sorting the list of available updates for devices.** Hub update section moved to Settings -> General. Device update section moved to Settings -> Devices. Zigbee Added default naming of newly paired devices. Updated general compatibility with devices on the market. Added possibility to force removing of not working Zigbee devices. Z-Wave Stability improvements.** Improvements in "marking as dead" function.** Bug fixes: Climate Unable to edit climate schedules if a thermostat in that zone is hidden. Dashboard Removed redundant buttons for multilevel switches from the sidebar. Permanent "Transfer Ok" caption on device tile for Elero devices in rare cases. Incorrect presentation of color temperature control for Zigbee devices. Devices Fixed Z-Wave devices parameters values scaling after the "Reset all" action. Hidden tiles for the Smart Implant device no longer stay hidden in certain situations.** Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required). FGT-001 setpoint graph not always correctly drawn. Downloading the device template loops in some cases. Elero* Inversion settings for awning and pergolas does not work correctly. Energy Fixed issues with generating a weekly savings graph incorrectly. Gateway Connection Walli Controller configuration from slave gateway issue. Changing the description of the device added to the slave does not work. Setting favorite position for devices from slave gateway does not work. Nice* After restart of the gateway system overwrites parameters for BiDi-Multi Sensor to default. Other Issues with securely added devices before the migration to HC3. Addressed database overgrowth issues. Corrected language version for status messages in Recovery mode for selected scenarios. Fixed password character count validation to 10 characters. Remote access granted to support extended to 14 days. Minor UX and UI fixes. Plugins Added RTSP stream support in web UI for Dahua plugin. Scenes Addressed issues with lua scenes on autostart that didn't work in selected scenarios. Fixed control for Fan Modes in thermostats when triggered from block scenes. Update Next device target can now be updated from a file without reconfiguration.** Fixed a bug producing incorrect status of the first target file during an update for a sleeping device.** Zigbee The Philips Hue color setting when device is turned off does not work. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
tempo QuickApp - Suivi Abonnement TEMPO (EDF)
fredokl a répondu à un sujet de mprinfo dans Quick App Developpeur
@triossrfLe "false" sert à envoyer le push sans demande de confirmation de l'utilisateur. -
@triossrf Tu peux faire une règle GEA pour les notifications de Tempo en utilisant les variables globales (Tempo_DAY, Tempo_DAY1 et TempoHPHC). Sinon, ajouter le code ci-dessous à la ligne 137 pour envoyer un push: hub.alert('simplePush', {[1] = 20, }, 'Tempo EDF - '..'Couleur du Jour: '..string.sub(data.couleurJourJ, 7)..' - Couleur demain: '..string.sub(data.couleurJourJ1, 7), false, '') 20 correspond à l'ID de ton téléphone. -
Salut @Manu31. Oui le calcul est simple, d'ailleurs la plus part des piscinistes l'utilisent. Un autre mode de calcul serait du type: (volume eau / débit pompe) x coefficient. Ce coefficient peut être du type: local cycleLayout = {} cycleLayout[0]=0.1 cycleLayout[1]=0.2 cycleLayout[8]=0.2 cycleLayout[10]=0.25 cycleLayout[14]=0.5 cycleLayout[19]=1 cycleLayout[23]=2 cycleLayout[25]=3 cycleLayout[26]=3.5 cycleLayout[30]=4 cycleLayout[35]=4 entre les [] il y a les températures et ensuite le coefficient multiplicateur. Certains ont fait des VD à l'époque de la HC2 sur ce modèle. Je te mets le lien: https://www.domotique-fibaro.fr/topic/4432-virtual-device-gestionnaire-filtration-piscine/?page=4 Je ne sais pas si c'est la bonne méthode mais pas mal de pro préconise ce type de calcul pour avoir un filtration parfaite en fonction de la température de l'eau. De plus, j'y vois aussi un possible économie d'énergie.
Je pensais qu'en étant maintenant chez Nice, ils auraient booster la box en la rendant plus attractive (compatibilité, UI, etc...). Mais plus le temps passe, plus je me dis qu'ils ont l'air dépassés par la concurrence. J'y croit de moins en moins à Fibaro.
D'accord avec @Nico, 15h c'est beaucoup je trouve. J'ai une piscine 10x5x1,50 et en faisant les calculs volume/pompe j'obtiens environ 3h pour un cycle de filtration complet. Pour une température de 29°C (ce que j'obtiens en moyenne en été), je dois faire 4 cycles de 3h soit 12h de filtration sur la journée au maximum. Bien sûr au-delà de 29°C je passe en filtration continue. Jusqu'à ce que je domotise le système récemment, c'est la règle que je m'était fixé et j'avais une eau parfaite. D'où ma demande afin d'ajuster au plus juste les cycles en fonction du volume/pompe. Bien entendu, il n'y a pas le feu, la saison est fini (enfin...vu la météo, on sait plus!).
- 44 réponses
- domotiser piscine
- hc3
(et %d en plus)
Étiqueté avec :
@Manu31Merci encore pour le QA, il fonctionne bien. En lien avec l'autre post: https://www.domotique-fibaro.fr/topic/15358-domotiser-sa-piscine/?page=2&tab=comments#comment-256430 serait-il possible d'ajouter dans le calcul, le volume d'eau de la piscine et le débit de la pompe pour encore plus affiner la filtration? Peut-être ajouter une variable volume_piscine et une variable debit_pompe?
Pour ce que j'en ai vu sur les différents sites des piscinistes pro, la grande tendance est de diviser la T° par 2. Tous confirment la règle de la T° mais certains ajoutent en plus le volume d'eau de la piscine et le débit de la pompe dans le calcul. Pour une piscine de 10x5x1,5 avec une pompe de 23m3/h la filtration sera forcément différente d'une piscine plus petite ou plus grande. Je vais faire une demande à @Manu31 pour ajouter quelques options à son superbe QA. Lien du QA: https://www.domotique-fibaro.fr/topic/15918-quick-app-regulation-piscine/?tab=comments#comment-256417
- 44 réponses
- domotiser piscine
- hc3
(et %d en plus)
Étiqueté avec :
@Manu31 peut-on avoir le fichier lua pour éviter de tout ré-importer?
@jluc2808Merci pour le boulot!
Ça y est je suis passé à Tempo. Vu le prix de l'énergie en ce moment, je pense que c'est une bonne chose. Le problème c'est que je n'ai pas d'autre alternative pour le chauffage. Je pense que pour les jours "Rouge", je vais prendre un chauffage au gaz pour avoir un semblant de chaleur en attendant qu'on installe un poêle à bois. Sinon, je viens d'installer le QA et l'utiliser via GEA pour la gestion de mes chauffages électriques et mes clims réversibles. -
topic unique Fibaro RGBW Controller 2
fredokl a répondu à un sujet de couillerot dans Modules Fibaro
Cool! Plus qu'à faire un petit QA avec tout pleins de programme! -
Je ne me suis pas pencher sur un QA pour créer ses propres scénarios RGBW, un jour peut-être... à moins que Fibaro remette cette fonction... -
Cette fonction n'existe plus sur la HC3 depuis son lancement. Pour créer un programme personnaliser, il faut passer par le swagger --> Select a definition " RGBPrograms" et choisir la méthode POST pour écrire ton programme. j'ai testé, ça marche mais c'est fastidieux! -
@Manu31 Merci pour le schéma. Finalement, mon frangin qui était de passage à la maison m'a donné un coup de main et à deux on réussi à faire le montage un peu différent du tiens. Ça fonctionne bien, c'est cool! Dès que j'ai 5 minutes, je mettrai un schéma du montage pour ceux à qui ça intéresse.
- 44 réponses
- domotiser piscine
- hc3
(et %d en plus)
Étiqueté avec :
@Manu31 J'ai mis la photo des boutons en façade. Je veux tout dogmatiser, pompe et lampe. Je l'avais déjà fait sur ma précédente piscine avec un boitier identique à celui que j'avais à l'époque mais là rien de ressemblant sur le forum et donc galère pour moi. Merci du coup de main.
- 44 réponses
- domotiser piscine
- hc3
(et %d en plus)
Étiqueté avec :
Salut à tous. Ma piscine est enfin fini. Je vais maintenant tenter de la domotiser (pompe et lampe). Après avoir chercher un peu de partout, je n'arrive pas à comprendre le schéma pour monter un FGS 223 qui me reste en stock. Merci de votre coup de main. Je vous met une photo du tableau. Toute aide sera la bienvenu.
- 44 réponses
- domotiser piscine
- hc3
(et %d en plus)
Étiqueté avec :
Nouveau venu dans le monde de la domotique
fredokl a répondu à un sujet de BiggyB dans Nouveau ? Présentez-vous
Bienvenu sur le forum! -
Quick App - Gestionnaire d'Événements Automatique - GEA pour HC3
fredokl a répondu à un sujet de Lazer dans Quick App Developpeur
@Lazer, je laisse une trace concernant le bug abordé dans le support GEA concernant sunset et sunrise. Merci. -
Ben non, j'ai déjà testé et voici le push reçu: "Le levé du soleil est prévu é #sunrise# et le couché à #sunset#" En fait, il ne met pas de valeur mais garde la syntaxe "sunset" et "sunrise" dans le message.
- 12 138 réponses
Salut, je relance ce post car je n'ai pas trouvé de réponse. En parcourant le fichier syntaxe 7.38, j'ai vu cette ligne et j'ai voulu la tester. J'obtiens la même chose que @Domodial soit la valeur 1 et non les heures du sunsrise et sunset. Quelqu'un a une explication?
- 12 138 réponses
