TonyC 450 Signaler ce message Posté(e) 20 mai 2019 Version 4.542 BETA New improvements: Optimized and reduced amount of data processed when adding Z-Wave devices. Optimized and reduced amount of data processed when booting the system. Optimized communication between services to speed up the operation of the gateway. Added geofencing events to be used in scenes. Added possibility of setting radius around the point in localization panel. Added notification recommending users to edit scenes based on location to ensure their proper operation in the next version of FIBARO Home Center app. Optimized response time of scenes setting brightness and color of the LED ring for FIBARO Walli series. Optimized the pin codes synchronization process for Z-Wave locks by reducing their maximum limit. Added possibility of assigning virtual devices to categories to be used in FIBARO Home Center app. Added possibility of hiding the virtual device. Added possibility of creating global variables with predefined values. Resolved issues: The map in location configuration is not displayed correctly and the location cannot be set by entering coordinates. Gateway in DHCP mode does not automatically establish a connection in case of temporary network shortage. Parameters cannot be changed for devices without templates. Setting the decimal separator affects values after the decimal point for temperature sensors. List of backups does not load correctly. Specific configuration of sprinklers panel results in no connection with the gateway. Remote support does not work after losing and restoring the connection to remote access. FIBARO Walli devices do not properly support all actions available in scenes. Actions set in the configuration of FIBARO Walli devices are not hidden after changing the value of responsible parameter. The output status of the FIBARO Smart Implant changes automatically after rebooting the gateway. Leviton devices do not report the status correctly. CoolMasterNet Universal HVAC Bridge loses configuration after rebooting the gateway. Other minor fixes. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 20 mai 2019 Oula il y a du lourd là ! Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 20 mai 2019 Yep ça update de mon coté, à suivre ... Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 456 Signaler ce message Posté(e) 20 mai 2019 Hum, une mise à jour un lundi matin..... ils vont la retirer dans 1h ! Vite vite je l'installe 1 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 20 mai 2019 Moi j'aime bien le mot geofancing, c'est à la mode.... Mais est-ce que ça marche ? Depuis le temps qu'ils le prometent. Partager ce message Lien à poster Partager sur d’autres sites
speedoxx007 26 Signaler ce message Posté(e) 20 mai 2019 Mise à jour en cours sur ma HC2 et HCL... Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 20 mai 2019 C'est fait ... pas de problème a priori ;-) Partager ce message Lien à poster Partager sur d’autres sites
schwinny 252 Signaler ce message Posté(e) 20 mai 2019 install en cours afin de voir si le soucis d'alerte incendie est bien reglé. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 456 Signaler ce message Posté(e) 20 mai 2019 il y a 22 minutes, BenjyNet a dit : geofancing, c'est à la mode.... Mais est-ce que ça marche ? Depuis le temps qu'ils le prometent ça dépend des jours :/ j'ai fait la mise à jour sur ma box de test, on peut enfin cacher les VD Par contre, je ne vois pas les templates Qubino Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 20 mai 2019 Et les infos sur le geofencing on les trouve ou ? Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 20 mai 2019 (modifié) @Massalia Édite une scène bloque et vas dans GPS, tu vas vite trouver EDIT: Petit complément d'info dans le panel LOCALISATION on peut directement paramétrer le radius de localisation. Modifié 20 mai 2019 par TonyC Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 20 mai 2019 Ok, trouver ! Il n'y as pas grand chose. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 20 mai 2019 il y a 10 minutes, Lazer a dit : Par contre, je ne vois pas les templates Qubino Ah oui, moi non plus, c'est curieux 1 Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 20 mai 2019 il y a 4 minutes, Massalia a dit : Ok, trouver ! Il n'y as pas grand chose. Si si quand même, je n'ai pas encore trop jouer avec, mais on peu définir n'importe où des points avec un radius et les tester en tant que zones d'entrées/sorties. Si c'est précis et sans tuer les batteries du téléphone alors ça peut être pas mal pour certaines fonctions. Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 20 mai 2019 Ok, je vais regarder aussi, on se teins au courant ! Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 456 Signaler ce message Posté(e) 20 mai 2019 il y a 29 minutes, TonyC a dit : Si c'est précis et sans tuer les batteries du téléphone On en avait discuté il y a pas mal de temps, pour ça l'astuce consiste à écrire une scène, qui peut modifier la fréquence de raffraichissement via l'API. Ainsi, fréquence élevée quand tu es à proximité pour fiabiliser (pas nécessaire d'ouvrir automatiquement le portail si tu passe la soirée/apéro chez le voisin) Et fréquence faible quand tu es au boulot/vacances/chez la maitresse (à supposer que ça ne soit pas la voisine, justement) 2 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 20 mai 2019 il y a 1 minute, Lazer a dit : Et fréquence faible quand tu es au boulot/vacances/chez la maitresse Moi j'y suis tous les soirs chez la maîtresse J'ai de la chance hein 3 Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 20 mai 2019 Oui a condition que cela ne sois pas la voisine Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 20 mai 2019 Merci pour l'info @Lazer, j'avoue que quant à la fiabilité/utilisabilité du geoloc avant cette version, je n'y prêtais pas trop attention. Mais je vais rechercher le topic car si ça s'est amélioré alors je compte l'utiliser. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 456 Signaler ce message Posté(e) 20 mai 2019 Je crois que c'était ce sujet : 1 Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 20 mai 2019 @Lazer Merci pour le lien ! je vais regarder tout ça. Partager ce message Lien à poster Partager sur d’autres sites
jmg38 26 Signaler ce message Posté(e) 20 mai 2019 MAJ faite RAS. Vous avez vu la traduction de date de sauvegarde?= Rendez-vous amoureux Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 20 mai 2019 Il y a 4 heures, TonyC a dit : Added possibility of assigning virtual devices to categories to be used in FIBARO Home Center app. Added possibility of hiding the virtual device. tout arrive !! Allez on clique ;-) PS : Tenez nous au courant pour la geolocalisation ;-) Partager ce message Lien à poster Partager sur d’autres sites
ericl78 72 Signaler ce message Posté(e) 20 mai 2019 et voilà, maj effectuée ! A vous tous, regardez votre conso cpu, diminution importante autrement, RAS Partager ce message Lien à poster Partager sur d’autres sites
PdB 22 Signaler ce message Posté(e) 20 mai 2019 AIE... Chez moi depuis la maj, je n'arrive plus à activer des scènes depuis Alexa. Avez-vous le même problème? Partager ce message Lien à poster Partager sur d’autres sites
