Lazer 8 457 Signaler ce message Posté(e) 17 juillet 2021 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.Important Notices: The following software update removes energy data collected during the use of version 5.071 beta due to a changed strategy for handling reports. For all Z-Wave devices which feature meter capabilities (power, energy, gas, water, etc.) soft-reconfiguration procedure is required due to improvements in support of those device types. Update 5.072 includes a new version of the Z-Wave software (called Z-Wave 3.0). This version features expanded default device support, the ability to add products using Smart Start technology and many other changes. Please note that this is a beta version and its compatibility will be developed with further updates - not all Z-Wave devices are fully supported. ATTENTION - installing version 5.072 does not automatically change the existing Z-Wave 2.0 software to 3.0. In order to run version 3.0, it is necessary to restore the gateway to factory settings, requiring the system to be configured from scratch. In future updates we will work on extended device support and provide a mechanism to migrate your current system configuration to the new Z-Wave engine. Main features: 1. Z-Wave Software 3.0 Extended compatibility of Z-Wave devices (more devices, additional features). 2. Yubii Ecosystem (Home Center 3 & Yubii Home)* Support for configuring device parameters. Redesigned configuration wizard. 3. Energy Panel New Savings tab and Panel Settings window.What's new: Backup Warning before restoring a backup contains the Z-Wave engine version when it differs. Space for cloud backups is increased by 25MB on master HC3 for each connected gateway. Climate Wider range of temperature to be used in schedules. Dashboard Correct scrollbar in the main menu. Live refreshing the value on the right device control panel. Devices Possibility to upload the parameters template to Z-Wave device from .json file (ZW 3.0). Possibility to delete parameters template which overrides the official template (ZW 3.0). Extended list of official templates for Z-Wave devices (ZW 3.0). Support of scale and unit for Z-Wave devices in parameters templates (ZW 3.0). Console log of detecting the Z-Wave device and starting the adding process (ZW 3.0). New mechanism of devices calibration (ZW 3.0). Restoring the default device icon if uploaded icon no longer exists. Changes in energy data component on device advanced tab. Availability of configuration parameters based on device interfaces. Possibility of setting the virtual power metering and using it in energy panel. Support for Heatit Z-Smoke Battery version 4.1/4.2. Support for Qubino 3-Phase Smart Meter. Elero* Dedicated section in the main settings menu for Elero and Nice. Energy Panel Settings window which allows to configure more options related to costs. Possibility to choose the billing period by setting its length and start date. Possibility to set up the tariff by choosing the currency, main rate and additional rates. Possibility to set up the installation cost and installation date. New Savings tab including summary of consumption and energy balance in time. Toggle switch on General and Savings tabs to display data in kWh or using set currency. The interval for storing historical energy data changed from one hour to 15 minutes. Displaying the energy balance from the main energy meter if configured. General Setting the main energy meter available for devices with specified interface and rate type. Nice* Possibility of setting the configuration parameters. Redesigned wizard of adding new devices. Dedicated section in the main settings menu for Nice and Elero. Other Current Z-Wave engine (version 2.0) selected by default on engine selection window.Bug fixes: Access Mobile devices assigned to removed users are not deleted or reassigned. Backup Incorrect Z-Wave engine version in uploaded local backup (ZW 3.0). Dashboard Rebooting the gateway results in resetting the counter of used devices. Devices No possibility to add custom icons after factory reset of the gateway. In some cases, removing the device from the Z-Wave network fails (ZW 3.0). For some devices setting the association fails (ZW 3.0). Incorrect multichannel reports handlings (ZW 3.0). Incorrect descriptions of parameters in Heatit Z-TRM3 device template. Elero* Device after binding is always assigned to default room. Energy Some data is not displayed when using the remote access connection. Gateway Connection Master gateway does not update the device states after rebooting slave gateway. Network Wi-Fi module is always switched on after reboot of the gateway. In some cases, connecting to Wi-Fi network fails. Nice* No possibility to create and edit scene with Nice device. Notifications E-mail notifications for addresses containing a plus character are not sent. Other Z-Wave service status in Installer App is displayed incorrectly. Translations on Yubii Home are not generic and refer to FIBARO Home Center. Performance Problems with gateway start-up on large systems (ZW 3.0). Plugins Fibaro Heat Activator plugin does not work (ZW 3.0). Profiles No actions available for devices (ZW 3.0). Quick Apps Error after updating the quick app file containing a hyphen in its name. Save button is active even though there are no changes. Scenes No possibility to set scene with push notification if user with mobile device was removed. Incorrect property set when selected the disarmed condition block. Incorrect actions in block scenes for FIBARO Intercom. Update Never ending loader on devices update page when no devices to be updated (ZW 3.0).Known issues: Energy The energy data collected during the use of previous beta version (5.071) is removed. The ROI calculation functionality does not include a quantity factor. New Z-Wave engine 3.0 Overriding the temperature set in heating schedule is not possible for FGT-001. The schedule overwrite functionality of Z-Wave thermostats does not work properly. Not all Z-Wave devices are fully compatible with the new version of Z-Wave engine. In some cases, device adding/removing fails - gateway needs rebooting to retry. Gateway connection is not available in the new Z-Wave engine version. No support for FIBARO Heat Controller error notifications. Elero In some cases devices are wrongfully marked as dead (no possibility to control)** * - does not apply to HC3L (Home Center 3 Lite) ** - does not apply to HC3 (Home Center 3) and HC3L (Home Center 3 Lite) 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 17 juillet 2021 Déjà un bon point, le bug de surconsommation CPU lié au panneau d'énergie semble résolu Le graph de CPU de ma box a retrouvé un état normal. 1 Partager ce message Lien à poster Partager sur d’autres sites
Barelle 167 Signaler ce message Posté(e) 17 juillet 2021 Je confirme, passage de 13,2 % de CPU User à 4 %. Partager ce message Lien à poster Partager sur d’autres sites
Fredmas 193 Signaler ce message Posté(e) 17 juillet 2021 (modifié) Bon ben version beta, je passe mon tour Modifié 17 juillet 2021 par Fredmas Partager ce message Lien à poster Partager sur d’autres sites
971jmd 229 Signaler ce message Posté(e) 17 juillet 2021 si je comprend, cette version est très orienté ZW 3.0 Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 18 juillet 2021 attention : pour ma part les QA ne sont plus fonctionnels sur tablettes (Ipad 6th et 5th) ; lorsque je sélectionne un QA sur l'appli, je suis renvoyé sur la page de login du cloiud fibaro (sic!) Stef Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 433 Signaler ce message Posté(e) 18 juillet 2021 Hum je crois que je vais encore laisser passer cette version bêta. Surtout aussi près des vacances Envoyé de mon RMX1993 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 19 juillet 2021 après test toujours de nombreux ralentissement sur l'interface des appareils si non pour le reste cela semblait fonctionner correctement Autre défaut constaté dans l'interface énergie, pas moyen de fixer un prix au KW/h inférieur a 1€ Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 20 juillet 2021 Pour modifier le prix au Kw/h et inférieur à 1€, dans le cadre d'un abonnement HC/HC par exemple, j'ai juste ajouter 2 tarifs supplémentaires ; il semblerait qu'ils sont prioritaires sur le "main" (enfin d'après ce que j'en ai compris...???) Stef Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 20 juillet 2021 merci pour l'info sauf que je n'(ai pas d'heure creuses vu que je suis en auto consommation mais bon je verrais cela a la prochaine version si il ont corriger les problèmes de lenteur Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 20 juillet 2021 Hum, cela fait la 2ème fois de suite que le mécanisme de migration vers Zwave 3 n'y est pas non ? Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 20 juillet 2021 C'est tout à fait normal et conforme à ce qui a été annoncé lors de la beta précédente Pour une fois, ils ne sont pas (encore) en retard ! Partager ce message Lien à poster Partager sur d’autres sites
ericl78 72 Signaler ce message Posté(e) 20 juillet 2021 avez vous refait une configuration douce de vos devices qui remontent des données de consommation. la différence ? Merci Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 20 juillet 2021 Oki Lazer, donc cela me laisse encore du temps Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 20 juillet 2021 (modifié) Oh oui Nico tu as le temps de voir venir. Déjà attendre que le moteur Z-wave passe en stable, ensuite ils ajouteront la possibilité de migrer de v2 vers v3, c'est pas avant la fin de l'année à mon avis (ils annonçaient 3 mois, mais on connait leur gestion des délais) @ericl78 non pas testé de reconfiguration, mais je n'ai pas de devices Z-Wave sur mon HC3 de test qui remontent une énergie, que des QA. Modifié 20 juillet 2021 par Lazer Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 22 juillet 2021 Et toi, tu ne migres pas avant du coup non plus ? Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 22 juillet 2021 ah bah non, je vais pas casser une config qui fonctionne très bien. On verra, peut être dans 1 an, l'été prochain. Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 23 juillet 2021 Oki. Moi je me tate à commencer, mais pas le temps du tout. Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 23 juillet 2021 J'ai un doute, mais je précise que j'ai déjà migré sur HC3. C'est la migration sur le moteur Z-Wave v3 que je ferai plus tard... déjà attendre qu'il sorte de Beta, puis que Fibaro propose la possibilité de migrer, puis qu'ils débuggent encore un peu, puis la fin de l'hiver.... donc l'été prochain, dans 1 an, me semble un délai raisonnable. 1 Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 24 juillet 2021 Ahh okiu, je croyais que tu n'avais pas fini et je voyais encore HC2 dans ta signature Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 24 juillet 2021 Si si j'avais fait ça fait mai, sur une bonne semaine, tranquillement. J'ai mis à jour la signature du coup. Il le reste juste 2 ou 3 modules virtuels sur HC2 que je j'ai pas encore récris sur HC3, du coup elle est toujours allumée. Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 24 juillet 2021 Alors ici il faut ajouter la HC3 Box : Fibaro Home Center 2, FHEM, IPX800 v4 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 24 juillet 2021 Ah ça, j'avais oublié, je vais tout supprimer, ça sera plus simple, car de toute façon je ne le met plus à jour depuis quelques années. Je parlais de la Box indiquée dans le cartouche à gauche, sous l'avatar Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 24 juillet 2021 Yes, celui là je l'avais vu Partager ce message Lien à poster Partager sur d’autres sites
