couillerot 749 Signaler ce message Posté(e) 26 novembre 2021 (modifié) on prend les mêmes et on recommence ! vous n'en rêviez pas... mais Fibaro l'a quand même fait ! Dear users, Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. A new, user-friendly wizard for adding Elero devices Device configuration within the pairing process. Pairing multiple devices in one process. Redesigned default icons. 2. Configuration of favourite positions in device settings Advanced tab Easy, single-button step-by-step wizard. Possibility to name positions and use them in scenes and profiles.What's new:Access Mobile device status indication.Dashboard Distinction of actions sent on click and hold of the slat rotation button. Support for holding the level change button on device sidebar. Favourite positions buttons available on device sidebar.Devices Possibility of enabling inversion in device Advanced tab for blinds/shutters/gates etc. Improved and unified support of device control types. New default icons for switches, dimmers, shutters, gates, and garage doors. Added icons for missing device states (favourite positions, brightening, dimming, etc.). Devices of the com.fibaro.baseShutter type available in the Blinds linked device. Improved detecting if device is awake and checking its wake-up interval.** Added missing support for FIBARO Roller Shutter 2 FGRM-222.** Reinterview process optimisation.**Elero* Configuration of device name, assignment, and its type as a part of pairing process. Possibility of pairing multiple devices of different types in one process. Testing the device detected during the pairing process to allow its identification. Inversion feature enabled by default for devices detected as awnings. Support for controlling the slats position. Support for alarms and notifications. Possibility of configuring favourite positions. Possibility of changing the device role. Possibility of forcing the device polling. Support for Elero Unio-868, Combio-868 HE, and Combio-868 LI.Energy New Ecology tab for ecu-enthusiasts and everyone who produces energy. Displaying self-sufficiency level, equivalent trees planted, and CO2 reduction. Animated graphs of achievements and their impact on the environment. Possibility of setting the return rate in Panel Settings. Calculation of already returned installation cost including set return rate. Redesigned interface for configuring additional rates in Tariffs.Network Access Point remains enabled after finishing FTI if no network is connected.Nice* Improved and unified support of Nice Mono devices. Global abort for all types of binding procedures. Possibility of configuring favourite positions. Possibility of changing the device role. Possibility of forcing the device polling.Quick Apps Possibility of adding custom icon for all single-state devices (players, remotes, etc.).Bug fixes:Alarm Alarm partitions (com.fibaro.alarmPartition) are not available as zones in alarm panel.Dashboard Holding the button on device sidebar does not work in mobile app.Devices Device properties and its interfaces are removed after the soft reconfiguration. Soft reconfiguration of the device removes it from the linked device. Maximum value reported by the sensor connected to analog input is limited to 4 digits. In some cases, com.fibaro.baseShutter type device lose its configuration. Incorrect setpoint temperature range for some thermostats. Attempt to update firmware of some battery devices always fails. Node provisioning list is not available.** No power charts for power meters (com.fibaro.powerMeter).Elero* Incorrect default polling time interval. Device is too early marked as dead but remains available. Number of devices is not updated after removing the device. In some cases, adding one device after another results in error. In some cases, adding previously removed device is not possible. Device polling is not stopped after performing action. No Notifications tab.Energy No validation for entering negative values of measured energy.Gateway Connection Rebooting the master gateway always results in sending devices model to slaves. Firmware update possibility disappears for devices added to slaves.Nice* In some cases, adding a new device is aborted before finishing the process. Number of devices is not updated after removing the device. No parameters after adding a device with parameters interface. Device added on previous versions has its parameters disabled after performing update. In some cases, clicking on remotes while binding is not always detected. Redundant requests during device creating process. No device calibration for BiDi Dimmer device. Cannot bind new gate using its remote. Incorrect default polling time value.Notifications System migration notification is restored and created after each reboot.Other Some HTTP requests do not require authentication.Plugins Recording feature in FIBARO Intercom plugin does not work.Profiles Some Elero devices are not available in profiles.Scenes No possibility to define multiple values in the date field.Known issues:Z-Wave engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Modifié 26 novembre 2021 par couillerot 3 Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 26 novembre 2021 maj effectuée et pas de crash ! Stef Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 26 novembre 2021 clic clic clic.... pareil ça tourne bien Partager ce message Lien à poster Partager sur d’autres sites
MAM78 407 Signaler ce message Posté(e) 26 novembre 2021 je me lance, c'est l'heure de l'apéro Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 26 novembre 2021 (modifié) done ! nickel. Mais cependant il y a 2 choses qui m'inquiète : -premièrement, sur le snapshot d'hier il y a une usine à gauche et une à droite, mois je n'ai que celle de gauche, j'ai dû payer ma hc3 moins chère bref - la seconde c'est l'heure à laquelle notre ami @MAM78commence à prendre son apéro, 18h30 c'est l'heure du goûter non ? Pour ceux qui n'ont pa suivi l'histoire hier il y a eut la MAJ de HC3 mais aussi la MAJ des FGT (les thermostats), hier la MAJ de la HC3 à été supprimée, ce matin c'était au tour de celle pour les FGT. Sur le fofo officiel il y a plusieurs personnes qui on cramées leur FGT et là c'est une toute autre histoire. J'avais planifié de le faire ce matin car pas le courage hier soir, comme quoi la procrastination à du bon parfois... Modifié 26 novembre 2021 par TonyC 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 26 novembre 2021 C'est vrai ça, la partie droite des 2 images est tronquée. C'est fou tout ce qu'ils arrivent à faire avec une simple mise à jour J'ai toujours un petit bout de l'usine, mais pas entière comme sur mon screenshot d'hier. Et toi tu n'as rien du tout. Ou alors.... tu es plus écologique que moi, tu as réussi à faire disparaitre une usine. Bravo. 1 Partager ce message Lien à poster Partager sur d’autres sites
ROBBEJP 31 Signaler ce message Posté(e) 26 novembre 2021 Il y a 1 heure, TonyC a dit : y a une usine à gauche et une à droite, mois je n'ai que celle de gauche Je vous l'avait dit que ça leur couterait 10 arbres ! Pour le coup ... ça leur a couté une usine ... bon, j'en étais pas loin .. !!!! 2 Partager ce message Lien à poster Partager sur d’autres sites
MAM78 407 Signaler ce message Posté(e) 26 novembre 2021 Il y a 2 heures, TonyC a dit : Sur le fofo officiel il y a plusieurs personnes qui on cramées leur FGT et là c'est une toute autre histoire C'est quoi le problème sur les FGT, j'ai installé la version 4.7 qui étaient intégrée sur ma HC2 du coup ce matin plus de chauffage dans la salle de bain ce matin, la WAF n'a pas apprécié. Du coup migration des FGT aujourd'hui sur la HC3. Partager ce message Lien à poster Partager sur d’autres sites
MAM78 407 Signaler ce message Posté(e) 26 novembre 2021 (modifié) Je suis en cours de lecture du sujet sur le foto officiel pour la version 4.9 Modifié 26 novembre 2021 par MAM78 Partager ce message Lien à poster Partager sur d’autres sites
Dragoniacs 433 Signaler ce message Posté(e) 26 novembre 2021 Bon alors, elle marche bien celle là ?Envoyé de mon M2012K11AG en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 26 novembre 2021 bah, il n'y a jamais de soucis avec les beta Fibaro ! ---> je sors... Stef 1 Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 26 novembre 2021 plus sérieusement... pas de soucis pour le moment Stef Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 26 novembre 2021 il y a 17 minutes, MAM78 a dit : Je suis en cours de lecture du sujet sur le foto officiel pour la version 4.9 J'espère que tu ne l'as pas cramé, après je pense que soit ils trouvent rapidos une soluce par MAJ avec forcément qlqs astuces soit ils font un chèque. ça ne résout pas les soucis waf pout autant. Il y a 1 heure, Lazer a dit : Ou alors.... tu es plus écologique que moi, tu as réussi à faire disparaitre une usine. Mouais c'est vrai, j'suis trop balaise Partager ce message Lien à poster Partager sur d’autres sites
MAM78 407 Signaler ce message Posté(e) 26 novembre 2021 Non plus de peur que de mal, j'ai upgradé hiers soir sur la version 4.7 et non la nouvelle version 4.9 Partager ce message Lien à poster Partager sur d’autres sites
MAM78 407 Signaler ce message Posté(e) 26 novembre 2021 (modifié) De nombreux utilisateurs ont des têtes thermostatiques mortes suite à la mise à jour de la 4.9 J'aime beaucoup leur humour sur le foto officiel au sujet des thermostats morts pas certain que les personnes concernées en rigole autant, surtout avec les températures actuelles. J'espère que personne ici ai été concerné. Modifié 26 novembre 2021 par MAM78 1 1 Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 27 novembre 2021 Avec l'arrivé de l'onglet écologie, il serait super que les données d'injection de surplus en autoconsommation soit gérer pour l'ecodevice et le QA GCE Merci d'avance. Partager ce message Lien à poster Partager sur d’autres sites
couillerot 749 Signaler ce message Posté(e) 27 novembre 2021 (modifié) j'ai bricolé un petit bout de code avec l'arrivée de leur nouveau panneau Ecologie : local mon chauffage if mon chauffage = (poele à pellets = 1) and (radateurs électriques = 0) then Trees Planted = -1 api.put("/energy/ecology/summary", Trees Planted) ils vont finir par me faire culpabiliser chez Fibaro ! pas glop tout ça... Stef Modifié 27 novembre 2021 par couillerot Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 27 novembre 2021 Attendez que je partage le QuickApp EPR v2.00 1 1 Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 27 novembre 2021 (modifié) question bête je voie sauf erreur de ma part que dans les paramètre d'un wallplug par exemple en mode "avancé", il y a uniquement "consommation d'énergie" et que sur un de mes commutateur de puissance 40A AEON Labs j'ai "configuration du compteur" les options sont "consommation" et "production" mais seulement sur la partie ampèremètre Ma question est quel sont les équipement qui permettent de faire une production? Modifié 27 novembre 2021 par flacon030 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 27 novembre 2021 D'après ce que j'ai compris des discussions sur le forum officiel (qui datent du précédent firmware), l'option production est disponible sur les appareils qui ont pour type "energyMetter". Ce n'est pas le cas des Wall Plugs (qui sont de type "binarySwitch", avec des interfaces supplémentaires "power" et "energy"). Je n'ai pas de pince Aeon Labs, mais je suppose qu'elle doit être reconnue comme un energymetter, du coup tu peux la paramétrer en appareil de production d'énergie. Et le panneau d'énergie le prendra en compte. Et tu commenceras à planter des arbres Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 27 novembre 2021 (modifié) Merci pour ce complément d'information Reste a voir comment je vais modifier du coup le QA CGE pour avoir un "energyMetter" sur ma prod solaire pour qu'il soit considérer comme une production et non une consommation Modifié 27 novembre 2021 par flacon030 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 27 novembre 2021 Il me semble qu'on a déjà eu cette conversation... normalement avec le QA GCE il faut choisir le type EnergyMeter justement. Mais ici ce n'est pas le bon endroit pour en discuter. Partager ce message Lien à poster Partager sur d’autres sites
flacon030 146 Signaler ce message Posté(e) 27 novembre 2021 (modifié) Effectivement merci je voulais au départ savoir quel était les modules qui puisse faire de la production d’énergie il serait intéressant de savoir quels sont ceux avec la compatibilité "energyMetter". Modifié 27 novembre 2021 par flacon030 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 27 novembre 2021 (modifié) Alors quand on fait un QuickApp, on choisi le type qu'on veut, donc facile. Pour les vrais modules du commerce, en Z-Wave.... ça dépend... tout est indiqué dans les documents normalement, mais pas toujours facile à trouver. La classe Energy Metter n'a pas été inventée par Fibaro, elle nous vient tout droit du protocole Z-Wave. Un module pouvant avoir plusieurs "endpoints", il faut chercher si l'un d'eux correspond à la classe energymetter, car la HC3 crée autant de modules enfants qu'il y a de endpoints sur un module physique donné au moment de l'inclusion (certains sont cachés) Modifié 27 novembre 2021 par Lazer Partager ce message Lien à poster Partager sur d’autres sites
Massalia 65 Signaler ce message Posté(e) 28 novembre 2021 (modifié) La (Re)Voilà De nouveau sur le réseaux MAJ faite ... sans problème. Modifié 28 novembre 2021 par Massalia Partager ce message Lien à poster Partager sur d’autres sites
