mprinfo 3 332 Signaler ce message Posté(e) 14 avril 2022 (modifié) HC3 & HCL3 - 5.110.15 - Stable - 14/04/2022 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. System supports adding of the Nice, Elero and Z-Wave devices from mobile application Additionally new Z-wave devices adding procedure in webUI is introduced. 2. Introduced new way of controlling devices using dialogs on Favorites screen in mobile application 3. New Scenes category called "Scenarios" for easy control of shutters and blinds according to sunset and sunrise triggers Possibility to configure "morning" and "evening" scenarios with few clicks. System supports altering configuration of those Scenarios via mobile application. 4. Zigbee protocol support (Home Center 3)* First public beta version of Zigbee protocol support now available for tests purpose on HC3. Support for limited types of devices with focus on lighting. Important: Philips TV and Samsung Smart Appliance plugins are no longer supported and have been removed. What's new: Alarm Added checking sensors status before arming the alarm. Dashboard Added translations for thermostat modes on dashboard tiles and sidebar. Added possibility to open device settings directly from device tile. Improved styling of units for sensors on dashboard and sidebar. Changed icon for opening sidebar from device tile. Added logs on device tiles related to transmitting commands for Nice and Elero devices. Devices Updated parameters template for Nice BiDi-Shutter and Nice BiDi-Awning. Added support for Eurotronic Air Quality Sensor. Improved handling of long operations for Color Controllers and Multilevel Switches.** Added support for new revisions of Fibaro devices. Default configuration for RGBW441 set as RGBW after adding device to the system. Added rounding for virtual power consumption values. Added support for Donexon thermostatic valve.** Custom parameters for Z-Wave devices sorted by ID. Support for MCO ZW700 series devices. Improved handling of hold actions on sidebar buttons for shutters and venetian blinds. Elero* Improvements for pairing process. Improved polling mechanism for Elero devices. Improvements for pairing process. Improved support for Elero Dimmer. Modified descriptions for pairing process. Added possibility to pair unknown device type to the system. Energy Warning about unsaved changes in Panel Settings. Added support for declaring fixed cost for a period. General Optimized calculation of sunrise/sunset time. Network Improved changing network settings between DHCP and Static. Nice* Added possibility to Read, Set default and Reset all parameters in devices settings. Changed default role for mono-directional devices from remotes to Blinds/Gates. Added requesting current parameters values during pairing process. Added possibility to configure and use favourite position for mono-directional devices. New styling for Nice devices pairing process. Improvements in protocol auto-detection function. Improved support of BiDi-Shutter and BiDi-Awning devices. Added possibility to calibrate BiDi-Shutter and BiDi-Awning devices from settings. Added notification about issues during device configuration after paring. Added displaying favorite positions states on BiDi devices. Other Improved auto-logging feature. Plugins Thermostat & Heating Zone plugin optimization. Added possibility to set the URL manually for Dahua plugin. Reorganisation of plugins categories. Profiles Support for new "Scenarios" in profiles. Quick Apps Changed function calling format (backwards compatible). Changed auto-complete function for new function format in Lua. Added possibility to edit "secret" variable in QuickApps. Scenes Changed functions calling format (backwards compatible). Changed auto-complete function for new functions format in Lua. Added icons for group actions. Changed font color in dark-mode of Lua editor. Added possibility to enable or disable the scene from edit window. Update Added reconfiguration button for device after successful update.** Z-Wave devices update process improvements. Z-Wave Improved handing of communication errors. Optimized service start-up. Updated certified Z-Wave manufacturers list in Z-Wave engines. Improvements for Z-Wave database size management.** Bug fixes: Alarm Unnecessary notification about wrong pin when trying to disarm the system. Cameras Inactive camera preview tab after saving device settings. Dashboard No automatic refresh of color components on device sidebar.** Missing polish translations for states of simple shutter. No automatic refresh of power consumption on devices sidebar. Fixed issue with displaying states for shutters on devices sidebar. Devices Missing barrier role for simple shutter device type. Issue with adding Fibaro devices (Wall Plug UK, Smart Module, BiDi-ZWave) in Security Mode. Rejected association settings visible on the list until page refresh.** Power graphs in advanced tab do not scale when zooming. Uploading custom icon for Fibaro CO Sensor not possible. Cannot change parameters in Z-Wave devices if "use template for parameters" is disabled. Issue with opening 1P Smart Meter Qubino configuration.** Incorrect devices grouping on settings page for QuickApps and Linked Devices. Additional not applicable icons for devices. Redundant device roles for Walli Roller Shutter and Roller Shutter 3. Inputs state for Smart Implant not reported correctly.** Devices added via Smart Start are not visible in the system until reboot.** Protection settings for Z-Wave devices fixed. Issues with thermostats support when using climate panel.** Diagnostics Issue with starting reconfiguration from Z-Wave tab.** CPU graphs issues. Elero* Wrong device configuration if timeout occurred during binding procedure. Issues with controlling devices after update from 5.072.25 beta. Energy Wrong rounding of percentage consumption on Savings tab. Production devices listed on Top consuming devices and on devices list on Savings tab. Excluding production devices from the Energy Panel does not work. Gateway Connection Changing Fan Mode for thermostats from slave gateway is not possible. General Home location settings change does not alter sunrise/sunset calculation. Location map does not show if longitude/latitude is out of range. History Device icon does not correspond with the state from history. Network No information about possible connection loss after changing network settings. Internet connection status is not stable. Nice* Not migrated device roles for Nice Mono devices added in the system on 5.080. Nice Mono devices added on 5.080 lost the icons after updating to 5.100. Issue with pairing some Nice Mono devices. Not migrated device roles for Nice Mono devices added in the system on 5.080. Notifications Devices icons in wrong states on notifications list. Non-admin user cannot remove notifications. Other Additional credentials popup during log-in in some cases. Text in reboot modal not centered on Safari browser. Rejecting custom icons upload if file extension is in uppercase. Issue with booting up the hub after update to 5.101 Beta. Nice and Elero devices not counted in number of devices in backup. Plugins Removed additional button on sidebar for Fibaro Intercom. Impossible to configure EnvisaLink plugin. Profiles Using Walli devices ring actions causes system crash. Quick Apps Partially white background in mobile view in dark style. Fixed visibility for functions declarations. Scenes Scene does not start in specific configuration when trigger is used in few scenes. Differences between calls in Scenes and QuickApps. Fixed visibility for functions declarations in Lua code. Update No translations of errors for devices update service.** Known issues: Nice* After adding Nice device page refresh is required. Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Modifié 14 avril 2022 par Lazer 1 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 14 avril 2022 T'es sûr que c'est une BETA ? Je la vois en Stable Partager ce message Lien à poster Partager sur d’autres sites
Barelle 167 Signaler ce message Posté(e) 14 avril 2022 Elle n'est pas affichée en Beta : Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 14 avril 2022 Et le contenu on dirait celui d'avant Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 14 avril 2022 Pendant que @mprinfo fait sa sieste, j'ai édité le titre. Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 14 avril 2022 Merci Christophe un soucis de copier coller Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
ericl78 72 Signaler ce message Posté(e) 14 avril 2022 Mise à jour effectuée RAS, nous devons attendre pour découvrir les surprises :=) Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 15 avril 2022 (modifié) Ok, j'attends alors... Par contre : "La première version bêta publique du support du protocole Zigbee est désormais disponible à des fins de test sur HC3. Prise en charge de types limités d'appareils axés sur l'éclairage." Serait-ce à dire que nous allons pouvoir piloter des modules Zigbee comme le suppose cette mention ? (du moins en tests pour le moment) Une possibilité qui n'apparaît pas encore, et qui me désole un peu, est de pouvoir (enfin) commander des modules Wi-Fi. Cela permettrait un action conjointe avec des modules déjà pilotés pas un Google Nest par exemple - je teste actuellement comment faire fonctionner une commande "double" pour l'éclairage des crédences de la cuisine. C'est à dire un FGSnnn accouplé avec un module Wi-Fi (un poil "usine à gaz" comme montage...). Enfin, plutôt une commande "triple" si l'on tient compte de la présence d'un interrupteur classique. Modifié 15 avril 2022 par Sowliny Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 15 avril 2022 Bah les modules Wifi cela ne viendra jamais. C'est à 100% du propriétaire, donc impossible à mettre dans une box type HC3. Par contre derrière tu as souvent une API si tu prends des choses correctes, donc tu peux le piloter depuis un Quickapp. 2 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 15 avril 2022 J'allais le dire, les modules Wi-Fi (ou plutôt IP d'une façon générale) sont déjà gérés au travers des QuickApp, donc intégrés nativement dans la HC3 (ce qui n'était pas exactement le cas sur HC2), comme les modules Z-Wave ou Zigbee. Le truc c'est que Fibaro propose très peu de plugins natifs, c'est à la communauté de développer et partager les implémentations spécifiques de tel ou tel constructeur. Ce qui n'est finalement pas plus mal, on se souvient du plugin Netatmo sur HC2 (natif Fibaro) qui plante tous les 4 matins... 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 15 avril 2022 Attention il y a 2 types de modules wifiCeux qui sont accessibles directement via le LANCeux ou il faut passé via le cloud. Style netatmo. Envoyé de mon BLA-L29 en utilisant Tapatalk 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 598 Signaler ce message Posté(e) 15 avril 2022 semble ok chez moi aussi... Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 15 avril 2022 Merci à @Nico et @mprinfo pour ces éclaircissements bienvenus. Je note bien la gestion déjà intégrée aux QA ! Je fais bien la différence entre les modules LAN et les cloud... Donc, une raison supplémentaire à m'activer pour les QA. Ca va bientôt venir - c'est un peu une arlésienne chez moi, depuis le temps que j'en parle et au vu des travaux qui restent encore. Je finalise ces jours-ci le raccordement de FGSnnn aux interrupteurs "lumière". Pendant que j'y pense, quelqu'un a une marque de modules Wi-Fi (de qualité) en tête ? Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 15 avril 2022 Netatmo Même si Pascal n'aime pas Partager ce message Lien à poster Partager sur d’autres sites
gorn 35 Signaler ce message Posté(e) 15 avril 2022 Faite aussi. Je constate depuis la dernière bêta et sur cette version un spamming des avertissements batterie faible. Auraravent, j'avais un seul message par jour, là c'est toute les heures. Un réglage? 1 Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 598 Signaler ce message Posté(e) 15 avril 2022 il y a 2 minutes, gorn a dit : Je constate depuis la dernière bêta et sur cette version un spamming des avertissements batterie faible. oui moi aussi, ça m'a rendu fou, j'ai désactivé toutes les notifications de tous les device à batterie. Et je me suis fait un petit QA qui tourne 2x par jour pour vérifier l'état. Avec compte rendu par mail. Partager ce message Lien à poster Partager sur d’autres sites
gorn 35 Signaler ce message Posté(e) 15 avril 2022 Merci @jjacques68, je suis pas le seul, ça me rassure un peu! Sur HC2 j'avais le VD batterie, je crois que je vais y revenir en Q.A. 1 Partager ce message Lien à poster Partager sur d’autres sites
Sowliny 225 Signaler ce message Posté(e) 15 avril 2022 il y a 35 minutes, Nico a dit : Netatmo Même si Pascal n'aime pas Merci pour cette info. Cependant je ne m'intéresse qu'aux modules de commutation (comme les FGSnnn)... (à moins que j'aie loupé un truc ? ) Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 15 avril 2022 Netatmo Même si Pascal n'aime pas Je n'ai pas dit que je n'aime pasJe reproche juste à netatmo d'être cloud exclusif.Autre reproche j'aimerai avoir une station ethernet voir POE. Sans devoir passer par le wifi qui pour moi n'est utile que pour les objets mobiles. Envoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 15 avril 2022 @Sowliny pourquoi vouloir mettre des modules Wi-Fi ? Il y a une seule réponse possible en fait... pour le prix. Le "mieux" actuellement c'est Shelly, très populaire, belle gamme, et semble assez sérieux (= fiable) d'après les nombreux retours. Eviter tout ce qui est Sonoff, Tuya, etc, qui est vraiment du low-cost dans le sens péjoratif du terme (low-quality surtout) Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 15 avril 2022 Il y a 7 heures, mprinfo a dit : Attention il y a 2 types de modules wifi Ceux qui sont accessibles directement via le LAN Ceux ou il faut passé via le cloud. Style netatmo. C'est bien pour cela que je parlais d'objets IP, parle de Wi-Fi n'a pas de sens. Et l'IPX800 alors, c'est de l'Ethernet, il serait donc exclus ? il y a 24 minutes, mprinfo a dit : aimerai avoir une station ethernet voir POE Regarde la station météo IP de IQTRONIC https://www.planete-domotique.com/blog/2022/02/16/station-meteo-eedomus-jeedom/ 2 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 15 avril 2022 @Lazer dommage que ce soit du XMLPour l ipx800 j'ai pas compris ta réponseEnvoyé de mon BLA-L29 en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 15 avril 2022 Oui mais du XML basique, très simple à parser, même en LUA. Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 598 Signaler ce message Posté(e) 16 avril 2022 (modifié) alors je viens d'essayer un petit module Zigbee : Xiaomi Mi GZCGQ01LM - Capteur de luminosité (16€ - amazon) en vu de remplacer les capteurs de LUX Everspring ST815 qui vieillissent très mal et qu'on trouve plus... Ben c'est pas mal du tout : le range est de 0-83000 lux (comparé au ST815 qui va que jusqu'à 3000 lux) Par contre, usage intérieur... je l'ai quand même mis dehors pour vois comment il se comporte... après vu le prix... Pas d'options de paramétrage, c'est très rudimentaire. Le changement de valeur met quelques secondes à remonter... Petite erreur, dans l'API, son unité de mesure est en % au lieu d'être en LUX (pourtant "LX" apparait dans l'interface web, alors d'où il sort ça ... ???) Corrigé avec un api.put(). EDIT : ah ben nan, c'est marrant, le "%" reviennent systématiquement dans l'API... Les remontés dans l'API RefreshState() sont nickel, comme un module Zwave ! Plutôt satisfaisant pour un premier contact Modifié 16 avril 2022 par jjacques68 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 16 avril 2022 Il y a 16 heures, gorn a dit : Faite aussi. Je constate depuis la dernière bêta et sur cette version un spamming des avertissements batterie faible. Auraravent, j'avais un seul message par jour, là c'est toute les heures. Un réglage? Il y a 16 heures, jjacques68 a dit : oui moi aussi, ça m'a rendu fou, j'ai désactivé toutes les notifications de tous les device à batterie. Et je me suis fait un petit QA qui tourne 2x par jour pour vérifier l'état. Avec compte rendu par mail. Il faut que vous remonter l'information à Fibaro sinon ils ne risquent pas de corriger ce bug. Et je n'ai rien vu de tel sur le forum pour l'instant. => https://forum.fibaro.com/forum/1357-update-5110/ Partager ce message Lien à poster Partager sur d’autres sites
