Yohan 492 Signaler ce message Posté(e) 28 novembre 2016 Bonsoir, Si comme moi vous souhaitez piloter votre TV Sony mais que le Plugin Sony développé par Fibaro ne fonctionne pas, , voici une scéne et un VD qui permettont de piloter la TV via notre HC2. Pour commencer : _ Créer une variable globale en la nommant : cmd_sony_tv _ Créer une scène en LUA et copier ce code : --[[ %% autostart %% properties %% globals --]] local ip = 'xxx.xxx.x.xx' local port = '80' local xAuthPSK = '1111' local irCode = json.decode([[ [ {"name":"Num1","value":"AAAAAQAAAAEAAAAAAw=="}, {"name":"Num2","value":"AAAAAQAAAAEAAAABAw=="}, {"name":"Num3","value":"AAAAAQAAAAEAAAACAw=="}, {"name":"Num4","value":"AAAAAQAAAAEAAAADAw=="}, {"name":"Num5","value":"AAAAAQAAAAEAAAAEAw=="}, {"name":"Num6","value":"AAAAAQAAAAEAAAAFAw=="}, {"name":"Num7","value":"AAAAAQAAAAEAAAAGAw=="}, {"name":"Num8","value":"AAAAAQAAAAEAAAAHAw=="}, {"name":"Num9","value":"AAAAAQAAAAEAAAAIAw=="}, {"name":"Num0","value":"AAAAAQAAAAEAAAAJAw=="}, {"name":"Num11","value":"AAAAAQAAAAEAAAAKAw=="}, {"name":"Num12","value":"AAAAAQAAAAEAAAALAw=="}, {"name":"Enter","value":"AAAAAQAAAAEAAAALAw=="}, {"name":"GGuide","value":"AAAAAQAAAAEAAAAOAw=="}, {"name":"ChannelUp","value":"AAAAAQAAAAEAAAAQAw=="}, {"name":"ChannelDown","value":"AAAAAQAAAAEAAAARAw=="}, {"name":"VolumeUp","value":"AAAAAQAAAAEAAAASAw=="}, {"name":"VolumeDown","value":"AAAAAQAAAAEAAAATAw=="}, {"name":"Mute","value":"AAAAAQAAAAEAAAAUAw=="}, {"name":"TvPower","value":"AAAAAQAAAAEAAAAVAw=="}, {"name":"Audio","value":"AAAAAQAAAAEAAAAXAw=="}, {"name":"MediaAudioTrack","value":"AAAAAQAAAAEAAAAXAw=="}, {"name":"Tv","value":"AAAAAQAAAAEAAAAkAw=="}, {"name":"Input","value":"AAAAAQAAAAEAAAAlAw=="}, {"name":"TvInput","value":"AAAAAQAAAAEAAAAlAw=="}, {"name":"TvAntennaCable","value":"AAAAAQAAAAEAAAAqAw=="}, {"name":"WakeUp","value":"AAAAAQAAAAEAAAAuAw=="}, {"name":"PowerOff","value":"AAAAAQAAAAEAAAAvAw=="}, {"name":"Sleep","value":"AAAAAQAAAAEAAAAvAw=="}, {"name":"Right","value":"AAAAAQAAAAEAAAAzAw=="}, {"name":"Left","value":"AAAAAQAAAAEAAAA0Aw=="}, {"name":"SleepTimer","value":"AAAAAQAAAAEAAAA2Aw=="}, {"name":"Analog2","value":"AAAAAQAAAAEAAAA4Aw=="}, {"name":"TvAnalog","value":"AAAAAQAAAAEAAAA4Aw=="}, {"name":"Display","value":"AAAAAQAAAAEAAAA6Aw=="}, {"name":"Jump","value":"AAAAAQAAAAEAAAA7Aw=="}, {"name":"PicOff","value":"AAAAAQAAAAEAAAA+Aw=="}, {"name":"PictureOff","value":"AAAAAQAAAAEAAAA+Aw=="}, {"name":"Teletext","value":"AAAAAQAAAAEAAAA\/Aw=="}, {"name":"Video1","value":"AAAAAQAAAAEAAABAAw=="}, {"name":"Video2","value":"AAAAAQAAAAEAAABBAw=="}, {"name":"AnalogRgb1","value":"AAAAAQAAAAEAAABDAw=="}, {"name":"Home","value":"AAAAAQAAAAEAAABgAw=="}, {"name":"Exit","value":"AAAAAQAAAAEAAABjAw=="}, {"name":"PictureMode","value":"AAAAAQAAAAEAAABkAw=="}, {"name":"Confirm","value":"AAAAAQAAAAEAAABlAw=="}, {"name":"Up","value":"AAAAAQAAAAEAAAB0Aw=="}, {"name":"Down","value":"AAAAAQAAAAEAAAB1Aw=="}, {"name":"ClosedCaption","value":"AAAAAgAAAKQAAAAQAw=="}, {"name":"Component1","value":"AAAAAgAAAKQAAAA2Aw=="}, {"name":"Component2","value":"AAAAAgAAAKQAAAA3Aw=="}, {"name":"Wide","value":"AAAAAgAAAKQAAAA9Aw=="}, {"name":"EPG","value":"AAAAAgAAAKQAAABbAw=="}, {"name":"PAP","value":"AAAAAgAAAKQAAAB3Aw=="}, {"name":"TenKey","value":"AAAAAgAAAJcAAAAMAw=="}, {"name":"BSCS","value":"AAAAAgAAAJcAAAAQAw=="}, {"name":"Ddata","value":"AAAAAgAAAJcAAAAVAw=="}, {"name":"Stop","value":"AAAAAgAAAJcAAAAYAw=="}, {"name":"Pause","value":"AAAAAgAAAJcAAAAZAw=="}, {"name":"Play","value":"AAAAAgAAAJcAAAAaAw=="}, {"name":"Rewind","value":"AAAAAgAAAJcAAAAbAw=="}, {"name":"Forward","value":"AAAAAgAAAJcAAAAcAw=="}, {"name":"DOT","value":"AAAAAgAAAJcAAAAdAw=="}, {"name":"Rec","value":"AAAAAgAAAJcAAAAgAw=="}, {"name":"Return","value":"AAAAAgAAAJcAAAAjAw=="}, {"name":"Blue","value":"AAAAAgAAAJcAAAAkAw=="}, {"name":"Red","value":"AAAAAgAAAJcAAAAlAw=="}, {"name":"Green","value":"AAAAAgAAAJcAAAAmAw=="}, {"name":"Yellow","value":"AAAAAgAAAJcAAAAnAw=="}, {"name":"SubTitle","value":"AAAAAgAAAJcAAAAoAw=="}, {"name":"CS","value":"AAAAAgAAAJcAAAArAw=="}, {"name":"BS","value":"AAAAAgAAAJcAAAAsAw=="}, {"name":"Digital","value":"AAAAAgAAAJcAAAAyAw=="}, {"name":"Options","value":"AAAAAgAAAJcAAAA2Aw=="}, {"name":"Media","value":"AAAAAgAAAJcAAAA4Aw=="}, {"name":"Prev","value":"AAAAAgAAAJcAAAA8Aw=="}, {"name":"Next","value":"AAAAAgAAAJcAAAA9Aw=="}, {"name":"DpadCenter","value":"AAAAAgAAAJcAAABKAw=="}, {"name":"CursorUp","value":"AAAAAgAAAJcAAABPAw=="}, {"name":"CursorDown","value":"AAAAAgAAAJcAAABQAw=="}, {"name":"CursorLeft","value":"AAAAAgAAAJcAAABNAw=="}, {"name":"CursorRight","value":"AAAAAgAAAJcAAABOAw=="}, {"name":"ShopRemoteControlForcedDynamic","value":"AAAAAgAAAJcAAABqAw=="}, {"name":"FlashPlus","value":"AAAAAgAAAJcAAAB4Aw=="}, {"name":"FlashMinus","value":"AAAAAgAAAJcAAAB5Aw=="}, {"name":"AudioQualityMode","value":"AAAAAgAAAJcAAAB7Aw=="}, {"name":"DemoMode","value":"AAAAAgAAAJcAAAB8Aw=="}, {"name":"Analog","value":"AAAAAgAAAHcAAAANAw=="}, {"name":"Mode3D","value":"AAAAAgAAAHcAAABNAw=="}, {"name":"DigitalToggle","value":"AAAAAgAAAHcAAABSAw=="}, {"name":"DemoSurround","value":"AAAAAgAAAHcAAAB7Aw=="}, {"name":"*AD","value":"AAAAAgAAABoAAAA7Aw=="}, {"name":"AudioMixUp","value":"AAAAAgAAABoAAAA8Aw=="}, {"name":"AudioMixDown","value":"AAAAAgAAABoAAAA9Aw=="}, {"name":"PhotoFrame","value":"AAAAAgAAABoAAABVAw=="}, {"name":"Tv_Radio","value":"AAAAAgAAABoAAABXAw=="}, {"name":"SyncMenu","value":"AAAAAgAAABoAAABYAw=="}, {"name":"Hdmi1","value":"AAAAAgAAABoAAABaAw=="}, {"name":"Hdmi2","value":"AAAAAgAAABoAAABbAw=="}, {"name":"Hdmi3","value":"AAAAAgAAABoAAABcAw=="}, {"name":"Hdmi4","value":"AAAAAgAAABoAAABdAw=="}, {"name":"TopMenu","value":"AAAAAgAAABoAAABgAw=="}, {"name":"PopUpMenu","value":"AAAAAgAAABoAAABhAw=="}, {"name":"OneTouchTimeRec","value":"AAAAAgAAABoAAABkAw=="}, {"name":"OneTouchView","value":"AAAAAgAAABoAAABlAw=="}, {"name":"DUX","value":"AAAAAgAAABoAAABzAw=="}, {"name":"FootballMode","value":"AAAAAgAAABoAAAB2Aw=="}, {"name":"iManual","value":"AAAAAgAAABoAAAB7Aw=="}, {"name":"Netflix","value":"AAAAAgAAABoAAAB8Aw=="}, {"name":"Assists","value":"AAAAAgAAAMQAAAA7Aw=="}, {"name":"ActionMenu","value":"AAAAAgAAAMQAAABLAw=="}, {"name":"Help","value":"AAAAAgAAAMQAAABNAw=="}, {"name":"TvSatellite","value":"AAAAAgAAAMQAAABOAw=="}, {"name":"WirelessSubwoofer","value":"AAAAAgAAAMQAAAB+Aw=="} ] ]]) function printIrCode() for i in pairs(irCode) do print(irCode[i].name) end end function irCodeLookup(irName) for i in pairs(irCode) do if (irCode[i].name == irName) then return irCode[i].value end end end -- Escape string to make suitable for embedding in HTML. function htmlize(s) s = s:gsub('&', '&') s = s:gsub('<', '<') s = s:gsub('>', '>') return s end --Helper for priniting nested table function deep_print(tbl) if (type(tbl) == "table") then for i, v in pairs(tbl) do if type(v) == "table" then deep_print(v) else print(i, v) end end else print(htmlize(tbl)); end end local successCallback = function(resp) print('At ' .. os.date() .. ' - status = ' .. resp.status) deep_print(resp.data) end local errorCallback = function(err) print('error = ' .. err) end function sendIrCode(name) local value = irCodeLookup(name) if (value == nil) then print('IR Code not found') return end local httpClient = net.HTTPClient(); httpClient:request('http://'..ip..':'..port..'/sony/IRCC', { success = successCallback, error = errorCallback, options = { method = 'POST', headers = { ['Content-Type'] = 'text/xml; charset=UTF-8', ['X-Auth-PSK'] = xAuthPSK, ['User-Agent'] = 'HC2/537.36 (KHTML, like Gecko)', ['SOAPACTION'] = '"urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"' }, data = [[<?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1"><IRCCCode>]]..value..[[</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>]] } }); end local value = fibaro:getGlobalValue("cmd_sony_tv"); if (string.len(value) > 0) then print(''..value) sendIrCode(value) end _ Renseigner l'adresse IP de votre TV dans la scène. _ Importer le VD : Telecommande_Sony_TV.vfib _ Noter l"ID de la scène créée et renseigner l'id pour chaque bouton du VD dans la ligne : fibaro:startScene(4); Il est possible d'ajouter des boutons supplémentaires (se référer aux commandes qui se trouvent au début de la scène). J'ai mis les fonctions principales dont je me sers le plus souvent donc libre à vous de personnaliser votre télécommande en fonction de vos besoin. Je tiens à remercier @Krikroff pour son aide et sa dispo Toujours prêt à rendre service notre Jc. 1 5 Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 28 novembre 2016 Bon boulot @Yohan et @Krikroff MErci, bon peut-etre qu'un jour je ferai ce genre de choses aussi lol Faut arreter les gars, j'ai envie de changer de TV maintenant, je n'ai pas de Sony ;-) Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 331 Signaler ce message Posté(e) 28 novembre 2016 Moi j'ai une Sony bravia mais pas de démo satellite pour la faire fonctionner et comme la tnt ne passe pas chez moi elle est en décoration dans ma chambre Si j'ai un petit moment je testeraiJoli travail yohanEnvoyé de mon SM-G901F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 28 novembre 2016 Ton débit Adsl ne te permet pas de passer par le net pour recevoir les chaines ? Partager ce message Lien à poster Partager sur d’autres sites
mikael2235 12 Signaler ce message Posté(e) 29 novembre 2016 Je vais tester dans la semaine, A voir s'il n'y a pas de le pb de Request Auth Key ou qqch comme ça ! Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 331 Signaler ce message Posté(e) 29 novembre 2016 Ton débit Adsl ne te permet pas de passer par le net pour recevoir les chaines ?Je suis au fin fond de la campagne environ 4.500kms du point internet débit descendant environ 270koEnvoyé de mon SM-G901F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 29 novembre 2016 Salut. Merci Yohan pour ce partage. Je viens de suivre le tuto et cela ne fonctionne pas pour moi. J'obtiens ce message lorsque je fait un debug de la scène: [DEBUG] 12:34:20: Num1[DEBUG] 12:34:20: At Tue Nov 29 12:34:20 2016 - status = 404[DEBUG] 12:34:20: not found J'ai bien renseigné l'adresse IP de ma TV qui est fixe, bien mis l'ID de la scène dans le VD et bien créé la variable globale mais rien. Peut-être que ma télé n'est pas pris en charge. C'est une Sony BRAVIA KDL-46EX720 Voilà pour mon retour. Est-ce-que d'autres ont des soucis? Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 29 novembre 2016 Salut, essaye ceci dans les options TV : Settings Network Home network setup IP Control Authentication Normal & Preshared Key Preshared Key 1111 <- just choose one> Simple IP Control On Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 29 novembre 2016 Salut je suis la tv pour effectuer les réglages. J'arrive sur Réglages/Réglage du réseau domestique/et pas la suite. Je peux me rendre dans un dossier App. de comm. à distance/Renderer mais rien ne me permet d'avoir accès à l'Authntification. Je pense que mon modèle de tv est peut-être trop vieux pour cela.Envoyé de mon iPhone en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 29 novembre 2016 Voici quelques prints écrans As tu les options disponibles sur ton téléviseur?Envoyé de mon SM-G925F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 30 novembre 2016 Salut. Bon pour le menu jusqu'à la photo 2 j'ai les mêmes réglages avec une interface différente. Par contre après je n'ai pas le même menu que toi. Comme je l'ai dit plus haut je pense que ma télé est "trop" vieille! Le modèle est de 2011 si je ne m'abuse. Voici une image de ma télé. Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 2 décembre 2016 j'ai le même menu, cela ne fonctionne pas non plus Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 2 décembre 2016 Arf ma TV est de 2016 il y a certainement eu des changements depuis 2011. Dans le menu "Réglage renderer", qu'avez vous ? Idem dans le "Controle d'acces renderer" ? Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 3 décembre 2016 Salut. Oui a voir les capture d'écran il y a eu pas mal de changement. Dans le menu "Réglage de Render", il y a: - Autorisation d'accès automatique --> Oui / Non - Sélection Intelligente --> Oui/Non - Nom Renderer --> Le nom par défaut de la tv (Peut être modifié) Voici une capture d'écran. 1 Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 3 décembre 2016 Tout pareil sauf que j'ai l'autorisation des adresses mac et j'ai mis oui bien sûr. Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 3 décembre 2016 @FredricMoi les adresses mac se trouve dans le menu "Contrôle d'accès Renderer". Sinon ta télé est de quelle année? Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 3 décembre 2016 Salut. Je viens de m'apercevoir dans les adresses mac autorisées que celle de ma HC2 est autorisée à contrôler ma tv. Mais je vous rassure, je n'arrive pas à envoyer la moindre commande. Du moins, les commandes sont envoyées mais la tv ne réagit pas. Peut-être une piste? Avec une autorisation automatique sans mettre de code d'appairage. Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 3 décembre 2016 Il y a 2 heures, fredokl a dit : @FredricMoi les adresses mac se trouve dans le menu "Contrôle d'accès Renderer". Sinon ta télé est de quelle année? Oui et 2008 Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 3 décembre 2016 Et dans le "controle d'acces renderer" ? Partager ce message Lien à poster Partager sur d’autres sites
fredokl 422 Signaler ce message Posté(e) 4 décembre 2016 @YohanDans le "Contrôle d'accès Renderer" il y a les adresses MAC des périphériques autorisés à accéder à la TV. Comme je l'ai précisé plus haut, l'adresse MAC de ma HC2 apparaît bien dans cette liste mais le contrôle de la TV est impossible. Voici un screen du menu. 1 Partager ce message Lien à poster Partager sur d’autres sites
Invité Signaler ce message Posté(e) 9 décembre 2016 Yohan, merci milles fois, c'est génial ça me change la vie, bravo super boulot à toi et Krikrof. Dès que j'ai résolu mon problème d'icône, je partage mon VD. Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 11 décembre 2016 Tu as un problème d'icône? Tu peux m'en dire plus? J'ai une galère aussi avec mes icones. Envoyé de mon SM-G925F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Invité Signaler ce message Posté(e) 11 décembre 2016 @Yohan. Ce n'est pas que sur ton VD, c'est partout ! je viens de me rendre compte que dans toutes les librairies auxquelles tu accèdes pour changer l'icône, le premier n'est pas correctement affichés, ce qui fait que tous les icônes ont un décalage de 1. Pour comprendre, voici un exemple : Tu charges un icône ampoule, il n'apparait pas Tu charges un icône poulet, une ampoule apparait tu sélectionnes l'icône ampoule, c'est l'icône poulet qui apparait sur ton device ou ta scène. Il m'a fallu un peu de temps pour comprendre, mais maintenant c'est bon, j'ai pu tout remettre droit. Par contre, ne me demande pas pourquoi j'ai du faire ça !! Partager ce message Lien à poster Partager sur d’autres sites
Fredric 297 Signaler ce message Posté(e) 11 décembre 2016 @MrGoose, comment as tu procédé car j'ai le même problème que toi depuis le passage en V4.100? Partager ce message Lien à poster Partager sur d’autres sites
Invité Signaler ce message Posté(e) 12 décembre 2016 @Frederic, et bien depuis que j'ai compris le problème, j'ai sélectionné mes icônes en tenant compte de ce décalage. Pour faire simple Fréderic, si tu insert un icône, il n'apparaitra pas. Par contre, lorsque tu voudras le sélectionner pour le mettre dans ton VD par exemple, tu prends le dernier qui apparait dans la liste, et c'est le dernier importé qui sera afficher. En clair, le dernier icône importé n'apparait pas dans la liste. Partager ce message Lien à poster Partager sur d’autres sites
