J'ai commencé à basculer ma domotique de X10 vers Zwave (meme si je conserve des modules Chacon, pas besoin de retour d'état)
Je suis sous Homeseer HS3 (Bascule de HS2 vers HS3 en cours)
J' ai 1 Z-Wave Z-STICK-2 comme controleur , 4 FGS221 en version 2.1, 1 FGD221 en version 2.2, 1 dimmer Benext, et enfin 2 FGSD-002
dont un vient de l'offre Homelive.
Les switchs sont bien reconnus et fonctionnent correctement.
Le probleme vient du dernier Smoke Sensor que j'ai acheté
Celui de la Homelive est en version 3.1
Full Name: Node 18 Z-Wave Fibaro Notification Sensor Node 18 Root RDC Polling: Polling Disabled Manufacturer: Fibaro System Type: 0xC02 ID: 0x1002 Listens: No Version: 3.99 (ZDK 6.51.3)Firmware: 3.1 Neighbor Count: 7 Speed: 40.0Kbps Neighbors: 1, 4, 6, 8, 11, 12, 17 Uses Interface: Z-STICK-2 (1) Basic Type: ROUTING SLAVE, Generic Type: SENSOR NOTIFICATION, Specific Type: NOTIFICATION SENSOR Command Classes: Supported: Zwaveplus Info, Version, Manufacturer Specific, Device Reset Locally, Association Grp Info, Association, Powerlevel, Wake Up, Battery(V 1), Notification(V 5), Crc 16 Encap, Configuration, Sensor Multilevel(V 8), Multi Instance Association, Application Status(V 1), Sensor Alarm(V 1), Firmware Update Md Controlled: Mark, Basic, Time Parameters Child Device: Smoke Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Heat Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Home Security CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Power Management Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: System Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Application Status CC: Application Status Polling: Polling Disabled Child Device: Battery CC: Battery Polling: Polling Interval: 12h, 0m, 0s Child Device: General Purpose Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 22s Child Device: Smoke Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 24s Child Device: Heat Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 26s Child Device: Temperature CC: Sensor Multilevel Ver: 8 Polling: Polling Interval: 20m, 28s
Il est bien reconnu par HS3 et fonctionne correctement .
Le dernier acheté est en version 3.2
Full Name: Node 20 Z-Wave Fibaro Notification Sensor Node 20 Root Etage Polling: Polling Disabled Manufacturer: Fibaro System Type: 0xC02 ID: 0x1002 Listens: No Version: 4.05 (ZDK 6.51.6)Firmware: 3.2 Neighbor Count: 7 Speed: 40.0Kbps Neighbors: 1, 4, 6, 8, 11, 12, 17 Uses Interface: Z-STICK-2 (1) Basic Type: ROUTING SLAVE, Generic Type: SENSOR NOTIFICATION, Specific Type: NOTIFICATION SENSOR Command Classes: Supported: Zwaveplus Info, Version, Manufacturer Specific, Device Reset Locally, Association Grp Info, Association, Powerlevel, Wake Up, Battery(V 1), Notification(V 5), Crc 16 Encap, Configuration, Sensor Multilevel(V 8), Multi Instance Association, Application Status(V 1), Sensor Alarm(V 1), Security, Firmware Update Md Controlled: Basic, Time Parameters Supported Secure: Basic, Device Reset Locally, Association, Wake Up, Notification(Ver 5), Configuration, Multi Instance Association, Sensor Alarm(Ver 1) Child Device: Smoke Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Heat Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Home Security CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Power Management Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: System Notification CC: Notification Ver: 5 Polling: Polling Disabled Child Device: Application Status CC: Application Status Polling: Polling Disabled Child Device: Battery CC: Battery Polling: Polling Interval: 12h, 0m, 0s Child Device: General Purpose Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 40s Child Device: Smoke Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 42s Child Device: Heat Alarm CC: Sensor Alarm Polling: Polling Interval: 20m, 44s Child Device: Temperature CC: Sensor Multilevel Ver: 8 Polling: Polling Interval: 20m, 46s
Là , j'ai des problemes avec la configuration:
Le dernier FGSD-002 supporte du
Est ce une nouveauté du firmware 3.2?
Si quelqu'un d'autre utilise des Smoke sensor avec HS3, peux t'il me dire ce qu'il en ait de sa configuration.
Si le support Fibaro passe par ici.....
Merci de votre aide.
Jean-francois.
PS : je confirme la forte consommation de pile de la part de la HOMELIVE, le premier sensor n'est plus qu'à 30% de pile , le module a été installé en février 2015.
