deanrparry
    5
Tout ce qui a été posté par deanrparry
  1. use the code below with a scene... if user is > distance away then press button 1 of virtual device... you could make 5 buttons each with a different tracking number the one below sets you to 60 minutes. good luck... ------------------------- HC2 = Net.FHttp("127.0.0.1",11111); local payload = '{"tracking": 60}'; response ,status, errorCode = HC2:PUT("/api/users/2", payload); if tonumber(status) == 200 then fibaro:debug("tracking is now set to 60 minutes"); else fibaro:debug("Status = "..status); fibaro:debug("Error code = "..errorCode); end
  2. pouvons-nous avoir tentative automatique si la connexion au serveur de JSON est perdu ? Merci tramslated au français via Google
  3. deanrparry
    Netatmo Welcome
    You will need to change VD from 705 to your own... and create a few labels in the VD... change NAME1 to the name you put to the face on Netatmo Android/IOS app. It works have fun... I am NOT a coder a lot fo this is copied and just changed to work! I found 15 secs the lowest I could hit API before it started to drop out. Create a scene and call it every 15 seconds or main loop? but main loop can be bad as my coding skills are rubbish! PHP: http://pastebin.com/9Z56gyc2 Virtual Device: http://pastebin.com/aGrtg1nr Create a variable called 'Seen'
  4. Dean here from the UK thanks to Google Translate I get to see what a wonderful community you guys have here! Thank you in advance for any hints and tips I learn on my journey! HC2 owner and very happy
