Compteur de contenus
1 674 -
Inscription
Dernière visite
Jours gagnés
36
Tout ce qui a été posté par fredokl
Bienvenu sue lue forum!
Bienvenu sur le forum!
Firmware HC3 & HC3L Version 5.141.59 Beta Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New Z-Wave network diagnostic page The Z-Wave network diagnostics page allows for the identification and resolution of potential issues related to the Z-Wave network. What's new: Access Redesigned the mobile device list under access settings. Access to newly added alarm zones, climate zones, and profiles is automatically granted to a new user if the "all" option is checked. Information when the last cloud service synchronization occurred is now displayed under the Users list. New selection controls for granting access to specific devices, scenes, zones and profiles. Backup Performance improvements for backup list and status requests. Devices Binary rain sensor is now available as an optional device for the sprinkler to prevent from watering. Improvements to device adding visuals. Added the ability to filter system notifications by supported notification channels. Improved support for the Aeotec Multi-Sensor 6 (soft-reconfiguration required). The camera preview tab is available only if a camera device has been configured. Improvements to Roller Shutter linked devices. Improved navigation for scene creation from device advanced settings. Energy Improved selection menu for energy meter configuration under energy panel settings. FTI Added information during FTI if user is not able to change Z-Wave engine version when some devices are already added to the system. Other New tooltips visuals. Added a notification for automatic system restore in case of instability. Limited recovery loop in case of both systems failure. Hidden sensors can now be selected as primary sensors in rooms. Reboot is no longer needed after the first system configuration. Minor UX and UI improvements. Profiles Removed redundant actions for Elero venetian blinds. Quick Apps Improved auto-naming of QuickApp elements and labels. Scenes Added support for custom thermostat modes to the block scene editor. Improved the "True for specified" time option setting for conditions in the block scene editor. Update Added sorting the list of available updates for devices.** Hub update section moved to Settings -> General. Device update section moved to Settings -> Devices. Zigbee Added default naming of newly paired devices. Updated general compatibility with devices on the market. Added possibility to force removing of not working Zigbee devices. Z-Wave Stability improvements.** Improvements in "marking as dead" function.** Bug fixes: Climate Unable to edit climate schedules if a thermostat in that zone is hidden. Dashboard Removed redundant buttons for multilevel switches from the sidebar. Permanent "Transfer Ok" caption on device tile for Elero devices in rare cases. Incorrect presentation of color temperature control for Zigbee devices. Devices Fixed Z-Wave devices parameters values scaling after the "Reset all" action. Hidden tiles for the Smart Implant device no longer stay hidden in certain situations.** Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required). FGT-001 setpoint graph not always correctly drawn. Downloading the device template loops in some cases. Elero* Inversion settings for awning and pergolas does not work correctly. Energy Fixed issues with generating a weekly savings graph incorrectly. Gateway Connection Walli Controller configuration from slave gateway issue. Changing the description of the device added to the slave does not work. Setting favorite position for devices from slave gateway does not work. Nice* After restart of the gateway system overwrites parameters for BiDi-Multi Sensor to default. Other Issues with securely added devices before the migration to HC3. Addressed database overgrowth issues. Corrected language version for status messages in Recovery mode for selected scenarios. Fixed password character count validation to 10 characters. Remote access granted to support extended to 14 days. Minor UX and UI fixes. Plugins Added RTSP stream support in web UI for Dahua plugin. Scenes Addressed issues with lua scenes on autostart that didn't work in selected scenarios. Fixed control for Fan Modes in thermostats when triggered from block scenes. Update Next device target can now be updated from a file without reconfiguration.** Fixed a bug producing incorrect status of the first target file during an update for a sleeping device.** Zigbee The Philips Hue color setting when device is turned off does not work. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
Salut @jluc2808, essai ça. GEA.add({"Value", 84, true},-1,"",{"Property",{452,457,460,463}, "Value", "white"}) GEA.add({"Value", 84, false},-1,"",{"Property",{452,457,460,463}, "Value", "green"})
- 12 138 réponses
- support
- script lua
(et 1 en plus)
Étiqueté avec :
MOTEUR VOLET BSO
fredokl a répondu à un(e) sujet de barnabe dans Actionneurs & Ouvrants (Portail, volets, piscines, ...)
Oui ce n'est pas satisfaisant. Je vais testé ta solution pour voir. -
Administration du forum- Ca bouge !
fredokl a répondu à un(e) sujet de Moicphil dans Annonces et suggestions
Merci à @Moicphil et @Yohan pour tout le travail réalisé durant toutes ces années. Je vous souhaite une bonne continuation sur vos futurs projets. Et maintenant, vive le nouvel administrateur @Lazer! -
MOTEUR VOLET BSO
Salut @jluc2808. Oui j'ai réussi à régler mon BSO. 1/ Après la remonté, il redescend de quelques centimètres et c'est normal. Ça correspond au fait que les lames sont fermées (orientation à 0%). Si on oriente à 100% (ouvert) alors elles remontes dans son coffre car elles ont gagnées en place. Je ne sais pas si je suis très clair. 2/ Avec l'application, j'y arrive sans problème mais avec le bouton, c'est plus compliqué car il faut lors de la monter ou descente appuyer sur le bouton STOP du volet et là, j'avoue ce n'est pas très pratique. J'y arrive une fois sur 10! Chez moi, le BSO est automatisé avec GEA --> Ouverture le matin (Semaine ou week-end et présent ou non à la maison) et fermeture le soir. Le reste du temps on y touche pas sauf dans certains cas si on veux peu de lumière. Dans ce cas, j'ai une tablette avec HomeAssistant à proximité dans le salon avec laquelle je peux monter/descendre et orienter les lames. L'application Yubii est trop longue et pas top. En finalité, le BSO et le FGR223 ce n'est pas si top que ça mais bon avec GEA j'arrive à obtenir ce que je veux. -
Pareille! Toujours pas installé!!!!
Bonne anniversaire @Lazer!
Welcome from Australia
fredokl a répondu à un(e) sujet de gsconsulting dans Nouveau ? Présentez-vous
Welcome to the forum! -
Instalação automatismo moovo
fredokl a répondu à un(e) sujet de José João dans Nouveau ? Présentez-vous
