Rem's 59 Signaler ce message Posté(e) 2 juillet 2017 (modifié) Bonjour à tous, j'utilise cette scène (qui n'est pas de moi), pour allumer progressivement les spots du salon. Je voudrai à l'extinction, utiliser le même principe, seulement voilà, je n'arrive à rien, même en changeant par "outExpo" --[[ %% properties %% globals --]] fibaro:debug("HC2 start script at " .. os.date()); -- LUA - Dawn simulator V1.0.1 -- -- Wake up "naturally", illuminated by a soft light and progressive. -- Based on open source Robert Penner's original easing equations (Copyright © 2001 Robert Penner) -- Copyright © 2013 Jean-christophe Vermandé -- USER SETTINGS : -- Type of equation used to generate the curve (dimming). -- Possible values are: linear, inQuad, inExpo, outExpo, inOutQuad, inOutExpo, outInExpo local curve = "inExpo"; -- Type of equation used to generate the curve (dimming). local debug = false; -- To log in HC2 debug area local devices = {588, 459}; -- IDs of devices to be varied (only dimmable device), eg. {1, 16, 10} local startValue = 0; -- Begin value local endValue = 35; -- End value local duration = 900; -- Execution time in seconds of the scene -- DO NOT EDIT THE CODE BELOW (except to suit your needs) -- dawnSimulatorEngine = { version = "1.0.1" }; function dawnSimulatorEngine:init(startValue, endValue, duration, devices, curve, debug) self._lastValue = 0 self._startValue = startValue or 0; self._endValue = endValue or 100; self._duration = duration or 1; self._devices = devices or {}; self._curve = equations.map[curve or 'linear']; -- require 'equations' to operate self._debug = debug or true; end function dawnSimulatorEngine:_update(value) self._lastValue = value; -- keep in memory the last value to compare later -- loop in deveices local name, id; for i=1, #self._devices do id = tonumber(self._devices[i]); fibaro:call(id, "setValue", value); if (self._debug) then name = fibaro:getName(id); if (name == nil or name == string.char(0)) then name = "Unknown" end fibaro:debug("Device:" .. name .. " setValue: " .. value); end end end function dawnSimulatorEngine:_compute(time) return math.ceil(tonumber(self._curve(time, self._startValue, self._endValue, self._duration))); end function dawnSimulatorEngine:start() local computedValue; local doWhile = true; local time = 0; -- timeline while (doWhile == true) do computedValue = self:_compute(time); -- prevent multiple call with same value if (computedValue ~= self._lastValue) then -- update device value self:_update(computedValue); end time = time + 1; if (time > self._duration) then doWhile = false; if (self._lastValue < self._endValue) then -- force target value self:_update(computedValue); end else fibaro:sleep(1000); end -- do while end end -- Easing function (Penner's Easing Equations) equations = equations or { version = "1.0.1", -- Linear linear = function(t, b, c, d) return c * t / d + b; end, -- InQuad inQuad = function(t, b, c, d) t = t / d; return c * math.pow(t, 2) + b; end, -- InOutQuad inOutQuad = function(t, b, c, d) t = t / d * 2; if t < 1 then return c / 2 * math.pow(t, 2) + b; else return -c / 2 * ((t - 1) * (t - 3) - 1) + b; end end, -- InOutExpo inOutExpo = function(t, b, c, d) if t == 0 then return b end if t == d then return b + c end t = t / d * 2; if t < 1 then return c / 2 * math.pow(2, 10 * (t - 1)) + b - c * 0.0005; else t = t - 1; return c / 2 * 1.0005 * (-math.pow(2, -10 * t) + 2) + b; end end, -- OutInExpo outInExpo = function(t, b, c, d) if t < d / 2 then return equations.outExpo(t * 2, b, c / 2, d); else return equations.inExpo((t * 2) - d, b + c / 2, c / 2, d); end end, -- InExpo inExpo = function(t, b, c, d) if t == 0 then return b; else return c * math.pow(2, 10 * (t / d - 1)) + b - c * 0.001; end end, -- OutExpo outExpo = function(t, b, c, d) if t == d then return b + c; else return c * 1.001 * (-math.pow(2, -10 * t / d) + 1) + b; end end }; -- Equations map equations.map = { ['linear'] = equations.linear, ['inQuad'] = equations.inQuad, ['inExpo'] = equations.inExpo, ['outExpo'] = equations.outExpo, ['inOutQuad'] = equations.inOutQuad, ['inOutExpo'] = equations.inOutExpo, ['outInExpo'] = equations.outInExpo } -- START SIMULATOR ENGINE if (debug) then fibaro:debug("Starting the process"); end --startEngine(equations.map[curve]); dawnSimulatorEngine:init(startValue, endValue, duration, devices, curve, debug); dawnSimulatorEngine:start(); if (debug) then fibaro:debug("End of the process"); end Un p'tit coup de main ....... s'il vous plait ....!!! D'avance merci pour votre aide Modifié 2 juillet 2017 par Rem's Partager ce message Lien à poster Partager sur d’autres sites
pepite 1 272 Signaler ce message Posté(e) 2 juillet 2017 Salut, regarde le proprio 2013 :-) si@krikroff passe par la:-) Envoyé de mon Nexus 5X en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
