Capteur Http Eedomus -> HC3
Inkew
Super, merci beaucoup!!
Si je peux me permettre (je ne veux pas abuser!), tu aurais une idée sur ce qui ne va pas là-dedans:
local requestBody = {
        action = "create",
        params = {
            --type = "local",
            data = 'lIHUqzUSmWfiC9n',
            description = description
self.http = net.HTTPClient({timeout=3000})
self.http:request("http://192.168.0.11/api/eedomushue/groups/0/action", {
        options = {
            data = json.encode(requestBody),
            method = "PUT",
[{"error":{"type":6,"address":"/groups/0/action/action","description":"parameter, action, not available"}},{"error":{"type":6,"address":"/groups/0/action/params","description":"parameter, params, not available"}}]
j'ai déjà testé en remplacant "data" par "scene" et j'obtenais cette erreur :
[QUICKAPP275]: [{"error":{"type":6,"address":"/groups/0/params","description":"parameter, params, not available"}},{"error":{"type":6,"address":"/groups/0/action","description":"parameter, action, not available"}}]
C'est pas grave, merci déjà pour tout ton aide.
Apparemment c'est le format de ma requête qui ne va pas, je vais essayer de trouver pourquoi:
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: requestbody = {"scene":"lIHUqzUSmWfiC9n","method":"PUT"}
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: 200
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: {"name":"Lightset 0","lights":["1","13","15","19","20","21","22","25","26","27","28","29","30","31","32","33","34","35","36","46","47","48","49","50","51","52","53","54","55","56","57","58","59","60","61","62"],"sensors":["1","7","8","9","10","13","14","15","16","17","18","19","30","31","32","33","34","35"],"type":"LightGroup","state":{"all_on":false,"any_on":true},"presence":{"state":{"presence":false,"presence_all":false,"lastupdated":"2020-12-26T20:14:16"}},"lightlevel":{"state":{"dark":true,"dark_all":true,"daylight":false,"daylight_any":false,"lightlevel":0,"lightlevel_min":0,"lightlevel_max":0,"lastupdated":"2020-12-26T20:19:16"}},"recycle":false,"action":{"on":false,"bri":127,"hue":54718,"sat":150,"effect":"none","xy":[0.3775,0.2460],"ct":366,"alert":"none","colormode":"ct"}}
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: response status: 200
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: headers: application/json
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: any_on = false
[26.12.2020] [21:26:11] [DEBUG] [QUICKAPP275]: all_on = false
j'avais oublié un /action derrière la requête, je dois zapper quelque chose car quand je lance (avec l'outil développeur Hue) ce genre de commande ça fonctionne :
Mon code est le suivant :
        --action = "create",
        --params = {
        --    type = "local",
            scene = "lIHUqzUSmWfiC9n",
            method = "PUT",
         --   description = description
self:debug("requestbody =", json.encode(requestBody))
        options = {
            data = json.encode("requestBody"),
        success = function(response)
            self:debug(response.status)
            self:debug(response.data)
        end,
        error = function(message)
            self:debug("error:", message)
et mon debug :
onAction: {"deviceId":275,"actionName":"turnOn","args":[275,"turnOn"]}
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: requestbody = {"method":"PUT","scene":"lIHUqzUSmWfiC9n"}
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: 200
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: [{"error":{"type":2,"address":"/groups/0/action","description":"body contains invalid json"}}]
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: response status: 200
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: headers: application/json
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: any_on = true
[26.12.2020] [21:42:49] [DEBUG] [QUICKAPP275]: all_on = false
J'ai l'impression de ne plus être très loin!!
Il fallait juste que que mette le method="put" dans les options de la requête, et non dans les paramètres.. Level Up! Merci infiniment de m'avoir aidé!! Trop content!!
Un coup de nettoyage, pour ceux que ça intéresse :
        --params = {
        --    type = "local",
            --method = "PUT",
        options = {
            method = "PUT"
        end,
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: requestbody = {"scene":"lIHUqzUSmWfiC9n"}
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: 200
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: [{"success":{"/groups/0/action/scene":"lIHUqzUSmWfiC9n"}}]
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: response status: 200
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: headers: application/json
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: any_on = true
[26.12.2020] [21:46:46] [DEBUG] [QUICKAPP275]: all_on = false
C'est à ce moment qu'on doit faire un petit tuto?!?
Mais je l'ai vu avant toi ;-)
en tout cas merci de ton aide, je n'y serai jamais arrivé sans toi!
PS1 : désolé pour la réponse tardive!
PS2 : Meilleurs voeux pour cette nouvelle année!
