HC3 & HC3L - 5.220.19 HotFix - STABLE - 03/11/2026
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important notice:
    Version 5.220.19 is a hotfix for version 5.220.15.
    The update resolves:
Core components of the central system have been updated to improve security.
Main features:
NICE cameras Wizard in the mobile binding
Adding your NICE cameras has never been easier. The brand-new setup Wizard, now available directly in the mobile binding, guides you through the whole process step by step - no hassle.
Nice High-Load Control support
Added support for a new product, featuring a dedicated setup wizard for easy configuration and seamless switching between Switch and Thermostat modes.
What's new:
Device
           Added Smart Start support for DoubleDimmer-Control and On/Off-Control 2 devices.
Only one NICE camera plugin instance can be running in the system.
Gateway connection
Added the ability to assign user defined names to slave hubs from within the interface.
KNX
Added dynamic IP address handling for the KNX Bridge - changing the address does not cause a loss of connection.
Added routing support.
Added support for secure connections using certificates in the tunneling and routing options.
Nice*
Added the option to disable sun impact by setting 0 lux value in Domi WS/WSR device parameters.
Added a new Nice Home device pairing flow with the correct protocol selection and a separate instruction for tubular motors.
Other
Improved system stability.
Improved Wizard buttons so longer descriptions are more visible and can be scrolled when selected.
Plugins
Update the Tedee Lock integration to the new API.
Users
Added the ability to change the hub interface language for installers and support users without having to change the client interface language globally.
Z-Wave
Z-Wave migration process optimization.
Optimized reinteview of various devices after migration from Z-Wave 2.0 to Z-Wave 3.0.*
Improved detection of device model changes after an update so that the control panel receives current data without restarting it.
Improved S2 Unauthenticated device inclusion by removing the incorrect PIN or DSK confirmation requirement.
Added Zvidar water valve integration with a valve role, parameter template, and default name in Z-Wave 3.
Bug Fixes:
Devices
Fixed a problem that caused information about a different device to be displayed when adding multiple devices sequentially using Smart Start.
Fixed a problem where scrolling through the device settings view would delete unsaved changes.
Fixed the behavior of the hide function in the device binding Wizard.
Fixed search functionality in the device binding Wizard - searching within categories.
Improved the preview of scaled parameters to show readable values instead of raw protocol values.
Improved the Wall Keypad template for version 2.x by removing unsupported battery handling.
Fixed enabling the LAPD ring color mode for Walli Controller/Nice Walli Controller.
Fixed Fibaro Roller Shutter 4 / Nice Roll-Control 2 after stopping calibration and removing RF protection.
Fixed MCO Home A8-9 sensor installation so the device is correctly recognized and configured.
Fixed real-time clock setup for the Nice Warm Control thermostat after adding it to the gateway.
Fixed the English translations of parameters 22 and 24 for Nice Motion-Control and Fibaro Motion Sensor.
Fixed slider-based parameter setting for Plug-Control 2 and refresh of the read value after changes from other sources.
Improved association behavior for MCO occupancy sensors in Z-Wave 2 to match Z-Wave 3.
Fixed the gate status display for Fibaro Smart Implant / Nice Smart-Control controllers so it correctly shows the open and closed states.
Gateway connection
Fixed auto-logout functionality from all open windows when controller becomes a slave.
Restored some of the device status notifications for the slave hub.
Fixed inactive “Update and restore” buttons for Gateway Connection backups created with a newer software version.
Fixed displaying the Slave hub name in Gateway Connection.
KNX
Disabled favorite position control for roller shutters without positioning.
Fixed an incorrect KNX device type when the “Open/Close” state is configured.
Nice*
Fixed misalignment in the translations of the open/close event notifications for the BiDi-Zwave device.
Incomplete screen temporarily displayed in the Nice device configuration window.
Added pergola role support for BiDi-Awning in Yubii, including migration of existing configurations.
Improved Nice Engine compatibility when updating the gateway from version 5.020 to 5.210.
Fixed the OFF action for Revio SW so it sends the STOP command instead of DOWN.
Other
Added small corrections to the translations.
Fixed visibility of inactive tabs in the dark user interface theme.
Fixed an issue where the creation and modification dates of a variable would change after the system was restarted.
Minor UI/UX fixes.
Fixed the missing border and styling of the “Upload Backup” button.
Fixed missing filters on the dashboard.
Improved Smart Start QR code scanning on iOS to make codes easier to capture with the camera.
Added a push notification for the administrator when the system automatically rolls back to the previous software version.
Added name filtering and sorting to the global variables list.
Fixed mixed German and English text when creating scenes in the Yubii app.
Added automatic launch of the NICE Cameras Wizard after adding the camera plugin.
Fixed Error 502 in the Diagnostics > Z-Wave tab for Z-Wave 2 devices.
Quick Apps
Fixed a rare issue with Quick Apps that use a PIN code for locks following the migration from Z-Wave 2 to Z-Wave 3.*
Improved the default icon for QA Device Controller and Generic Device
Fixed the first HVAC mode override from a block scene so it respects the duration configured in the scene.
Improved Quick App list behavior for single and multiple selection.
Fixed the Nice Camera plugin room resetting to “Default” after adding another camera from the mobile app.
Z-Wave
Fixed device synchronization following the migration from Z-Wave 2 to Z-Wave 3.*
Other fixes to the Z-Wave 2 to Z-Wave 3 migration process.*
Fixed default tile visibility in the interface for ZW300 switches in version 2.x.*
Fixed potential S0 communication error for newly added devices after migrating a old engine to new engine  Z-Wave.
Improved Z-Wave device compatibility after the Z-Wave 3 engine update, including reporting and configuration for affected devices.
Fixed migration of FGBS-321 devices from Z-Wave 2 to Z-Wave 3.
Fixed missing serial numbers for child devices added with the Z-Wave 3 engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Security:
Added the ability to enter longer passwords when connecting to Wi-Fi (up to 128 characters).
Added additional protection for password visibility in the logs of internal services.
Limited access to some KNX logs for users other than the administrator.
