Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 (modifié) 4.018: Resolved Issues: #0001566 All versions of FIBARO cannot support the switch state to return to the "Multilevel Switch Command Class, version 2" #0001576 Untranslated text in Satel input/zone page #0001578 Cannot change label value #0001618 HSP02 no longer has parameters #0001624 no different color for slave devices #0001630 Reconfiguration did not run on a dimmer, resulting in no "sceneactivation" #0001631 Roller Shutter 2 scene won't close #0001711 Danfos LC13 and older model are dead or E5 on the danfos itself #0001773 Danfoss LC13 no Icon displayed #0001747 Weather display wrong place #0001834 Get error 502 and 503 after virtual device import #0001836 Lili #0001853 After upgrade web interface is slow when changing views #0001873 No push messages possible on iPad/iPhone with 4.017 #0001880 Not able to set Variable manually anymore many other fixes Known Issues: - Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code. - Important! Remote access is NOT available for this version. - Gateway Connection - status of dead device between master and slave controller may be different - Devices not properly configured on 3.X may not be converted properly - Reconfiguration may not work properly in some cases - On mobile clients devices may be visible in different categories than configured - Advanced settings for some imported devices may not work properly - Plugin for Sony TV will not work with newest Sony Firmware - Event Panel- some issues with scrolling - LUA functions fibaro:log("") i fibaro:call(id, "setproperty", "") may have some issues - Horstmann Switch HRT4-ASR-ZW is not fully supported - Horstmann Thermostat HRT4-ZW- higher battery usage and incorrect reports in some cases - Doorlocks- some functions may not work properly - Thermostats Setpoint- are not fully supported Ca mer de tellement avec la 4.017, que je saute sur la 4.018.. go Modifié 16 octobre 2014 par moicphil Modification du titre et ajout des Maj dans le post Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 surtout pour mes têtes danfoss... je commençais àme les cailler Partager ce message Lien à poster Partager sur d’autres sites
Bouliboule 6 Signaler ce message Posté(e) 16 octobre 2014 Alors les gars ? Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 Installé, je fais un petit tour de mes modules... Chauffage dans un premier temps, mais bug corrigé de ce coté (plus d'erreur E5)... C'est déjàça de pris Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 142 Signaler ce message Posté(e) 16 octobre 2014 Alors les news ?? Partager ce message Lien à poster Partager sur d’autres sites
azer31 5 Signaler ce message Posté(e) 16 octobre 2014 pas de problèmes pour moi ,c'est déjà beaucoup plus utilisable a voir par la suite Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 ok pour toutes mes danfoss Je continue la tournée Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 142 Signaler ce message Posté(e) 16 octobre 2014 Hum, pas de bug, bonnes nouvelles, peut être enfin une installation ce week-end Partager ce message Lien à poster Partager sur d’autres sites
adrien92 5 Signaler ce message Posté(e) 16 octobre 2014 Salut Bonne nouvelle de la journée Si il y a beaucoup de bug corrigés et que ça semble stable on peut espérer la version stable bientôt. En attente de vos retours sur cette nouvelle beta. Bonne soirée Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 inclusion de mes fgk en defaut depuis 4.017, no problemo... je continu Partager ce message Lien à poster Partager sur d’autres sites
Bouliboule 6 Signaler ce message Posté(e) 16 octobre 2014 Nvince tu as du rein lire tes fil avec la 4.018? Partager ce message Lien à poster Partager sur d’autres sites
Bouliboule 6 Signaler ce message Posté(e) 16 octobre 2014 Pardon il fallait lire ré-inclure les fgk Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 heureusement que tu as retraduit derrière car là...moi pas comprendre. Non, seulement un fgk très éloigné qui merdait depuis la 4.017 pas de problème pour les 7 autres Partager ce message Lien à poster Partager sur d’autres sites
Bouliboule 6 Signaler ce message Posté(e) 16 octobre 2014 Attention ne faire "rconfigurer" les périphériques zWaves sous peine de tout planter. Je retourne sur l'autobackup 4.018... Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 16 octobre 2014 C'est un conseil comme un autre mais après avoir fait la mise àjour, laissez respirer votre HC2 surtout si vous avez beaucoup de périphériques histoire que les tâches en arrière plan fassent le job (il doit bien y en avoir) ! Sauf si il y a un gros plantage pas de reboot avant 15 - 20 minutes ni de "reconfigurer les ..." Partager ce message Lien à poster Partager sur d’autres sites
q.philippe 30 Signaler ce message Posté(e) 16 octobre 2014 Message de Fibaro : s'il vous plaît CACHE toujours claire après la mise à jour Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 16 octobre 2014 Oui il faut bien vider le cache du navigateur pour éviter des comportements parfois étranges Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 142 Signaler ce message Posté(e) 16 octobre 2014 Et Krikroff, migration faite ? Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 16 octobre 2014 Oui migration faite... mais pas en prod . Bien plus stable visiblement que la v4.017 Partager ce message Lien à poster Partager sur d’autres sites
RedAlan 3 Signaler ce message Posté(e) 16 octobre 2014 J'attends ce week-end pour faire la mà j. Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 Coté détecteur de fumées, je n'avais pas vu cela sur les versions précédentes...maintenant il y une courbe d'évolution des fumées détectées et température, une sorte de boite noire Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 Nouvelle fonctionnalité 'Modules liés'?? ou je n 'avais pas les yeux en fassent des trous lors de la 4.017? c'est possible aussi Partager ce message Lien à poster Partager sur d’autres sites
Bouliboule 6 Signaler ce message Posté(e) 16 octobre 2014 Les modules liés étaient deja présents sur la 4.017. @krikoff : le plugin netatmo ne marche toujours pas chez toi aussi ? Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 16 octobre 2014 A vous lire ça donne envie mais si je plante tout, ça craint pour le chauffage. Partager ce message Lien à poster Partager sur d’autres sites
Nvince76 35 Signaler ce message Posté(e) 16 octobre 2014 Slt Yohan, moi c'etait planté avec la 40017 (toute les têtes en E5... Làtout est ok chez moi Partager ce message Lien à poster Partager sur d’autres sites
