CharlesO
596 -
Tout ce qui a été posté par CharlesO
salut jojo pardon je ne t avais pas compris le zxt ne peut être utiliser que a partir du hc2 donc oublie les 2 premier exemple tu as vue le code lua que je t ai envoyer ? (le dernier)
salut Jojo regard ce code que je vien de uper
--[[ %% autostart %% properties %% globals --]] local sourceTrigger = fibaro:getSourceTrigger(); function tempFunc() local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if ( ( string.format("%04d-%02d-%02d %02d:%02d", currentDate.year, currentDate.month, currentDate.day, currentDate.hour, currentDate.min) == "2015-09-20 19:36" ) ) then fibaro:call(52, "setThermostatSetpoint", "2", "22"); end setTimeout(tempFunc, 60*1000) end if (sourceTrigger["type"] == "autostart") then tempFunc() else local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); if ( startSource["type"] == "other" ) then fibaro:call(52, "setThermostatSetpoint", "2", "22"); end end
il doit manquer un truc dans to code qu il lui dit envoi tout le réglage au boitier
{ id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "18.00", unit: "C", useTemplate: "true", userDescription: "", value: "18.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } a 150 :
{ id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "18.00", unit: "C", useTemplate: "true", userDescription: "", value: "18.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } a 18 :
{ id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "24.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } a 24 :
combien coute le zxt-120 chez toi ? et tu peut l avoir en combien de temp ?
oui en manuel quand je fais un changement ca fait un bip pour info : le boitier imite le signal de la telecommand et a chaque manipulation il renvoi tout les réglage je veux dire par la que si il était sur froid 22 et je le mes a 24 il envoi et froid et 24 si ca peut t aide merci encore (la il fait le changement dans le fibaro mais ne fait pas de bip donc l instruction n ait pas envoyer)
ca n a toujours pas envoyer l instruction au boitier pour le chauffage si tu veux plus tard deja la clim c est super si ca marche avec le nest et qu il envoi l instruction
photo et json { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "15.00", unit: "C", useTemplate: "true", userDescription: "", value: "15.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 }
{ id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "48.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } voila pour le json mais ca na pas envoyer l instruction a mon climatiseur
{ id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "50.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } le json
la photo
ok ca marche a moitié ca change sur le label mais pas sur le combo box du module et donc n envoi pas l instruction au module
ok bos pour le test donc je cree une scene en lua ou je rajout juste apres les 4 lignes par defaut, les tienes c est ca ? comment je verifie si ca marche ?
Jojo pourquoi on regle pas le probleme du nest en premier lieu ? c est juste une question
Mais Jojo comme je te l ai dit plus haut je n ai pas de problem au niveau du zxt car je peut ajouter une scene en utilisant les blocs graphiques mais le probleme est sur le nest car je ne peut pas cree de scene avec lui je voudrais choisir une temperature et un mode apartire du nest et que le fibaro l execute merci Jojo
{"id":52, "name":"ZXT Clim Panel", "roomID":20, "type":"com.fibaro.setPoint", "baseType":"com.fibaro.hvac", "enabled":true, "visible":true, "isPlugin":false, "parentId":51, "remoteGatewayId":0, "interfaces":["battery", "zwave", "zwaveSwitchAll"], "properties":{"parameters":[{"id":25, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}, {"id":26, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}, {"id":27, "lastReportedValue":471, "lastSetValue":471, "size":2, "value":471}, {"id":28, "lastReportedValue":255, "lastSetValue":255, "size":1, "value":255}, {"id":32, "lastReportedValue":255, "lastSetValue":255, "size":1, "value":255}, {"id":33, "lastReportedValue":1, "lastSetValue":1, "size":1, "value":1}, {"id":35, "lastReportedValue":0, "lastSetValue":0, "size":4, "value":0}, {"id":37, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}], "zwaveCompany":"Remotec Technology Ltd", "zwaveInfo":"6,3,42", "zwaveVersion":"1.12", "pollingTimeSec":0, "batteryLevel":"0", "batteryLowNotification":"true", "configured":"true", "dead":"false", "defInterval":"0", "deviceControlType":"0", "deviceIcon":"71", "emailNotificationID":"0", "emailNotificationType":"0", "endPointId":"0", "liliOffCommand":"", "liliOnCommand":"", "log":"", "logTemp":"", "manufacturer":"", "markAsDead":"true", "maxInterval":"0", "minInterval":"0", "mode":"2", "model":"", "nodeId":"6", "parametersTemplate":"417", "productInfo":"82,84,1,1,131,119,1,12", "pushNotificationID":"0", "pushNotificationType":"0", "remoteGatewayId":"0", "saveLogs":"true", "smsNotificationID":"0", "smsNotificationType":"0", "stepInterval":"0", "supportedModes":"1,2,8,10", "switchAllMode":"SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", "targetLevel":"23.00", "unit":"C", "useTemplate":"true", "userDescription":"", "value":"23.00"}, "actions":{"reconfigure":0, "setInterval":1, "setSetpointMode":1, "setThermostatSetpoint":2}, "created":1440263369, "modified":1440263369, "sortOrder":99} Salut et merci !!!! Le voila :
Salut Jojo bon bonne nouvelle je peut Ajouter une scène en utilisant les blocs graphiques sur le zxt 120 la dernier question comment je fais du cote du nest ? merci de ton aide
Re bonjour Jojo si tu veux je te donne un team viewer ou autre. ca sera plus simple non ?
salut je n'arrive pas a ajouter a ce text un print screen ou fichier picture tu peux me dire comment stp ?
ok merci cool
