Lazer Posté(e) il y a 13 heures Signaler Posté(e) il y a 13 heures Firmware 5.182.27 BETA 30/07/2025 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Devices Adapted the Husqvarna plugin to the new manufacturer API. Other Documents for Privacy Policy and Terms of Service have been separated when updating the Hub. Changelog history added when updating the Hub version. Adapted the appearance of swagger to the new UI design. New look for entering your security PIN. Quick Apps The preview tab is updated on-the-fly after copying the JSON view. Scenes Scene launch optimization. Z-Wave Z-wave engine 3.0 is set as default in the FTI process. Updated parameters template for FGR-224/Roll-Control2 for version 8.2. Added support for class Thermostat Fan Mode version 5. Bug Fixes: Climate Fixed incorrect calculation of the temperature value for thermostats auto mode. Devices Full https support for Nice Cameras and NVRs. UI fixes for parameters values refresh in Z-Wave devices configuration. Fixed Smart Implant device configuration flow when "Other" option is selected. Fixed display of statuses in the Dashboard for colorController and multilevelSwitch devices. Optimised web UI wizards for some devices. Fixed an issue where the device removal process in the mobile app would loop. Fixed issue with loading multiple icons for devices. Gateway connection Fixed device counting in backups for the Master Hub. Nice* Fixed moving to favorite position for mono devices. Other Fixed acceptance of entered login data using Enter on the keyboard. Improved modals appearance for Manage Access and rights edition. Fixed the appearance of system modal windows. Fixed the connection type selector in the Smart Implant device Wizard. Fixed issues for the /api/scenes endpoint in swagger. Fixed SVG icon colors in dark mode for scenes. Fixed the display of days when selecting from the calendar. Changed the size of buttons in the user interface. Changed the appearance of the stepper component. Fixed the visibility of text messages in the interface. Fixed display of device protocol logos. Minor UI/UX fixes. Quick Apps Added support for uploading external icons for Multilevel Sensor device type. Scenes Removed redundant unsaved changes dialog when no changes were made when editing scenarios. Fixed issue with saving default Morning Scenario after making changes. Fixed scenes trigger based on current color for Block Scenes. Z-Wave Fixed the issue of lost Zipato RFID device reports.** Fixed invalid parameters 2,3 value for HeatIt Z-Temp3 device. Fixed a rare issue where learning mode would freeze. UX fixes for Z-wave parameters. Fixed template for Aeon Multisensor 6 device. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. Security: Due to the upcoming new cybersecurity regulations (RED), work has been implemented to improve the product's security level to comply with the EN18301 standard and the latest security guidelines. The user password reset procedure has been changed - user sets a new password himself. The number of required characters in a user password has been increased to 12 - for new users and when changing the password for existing users. Added email notification for administrator regarding unauthorized login attempts when an unknown user logs in. The default login password for the FTI process has been changed for the ones from device label. Improved security for requests from localhost. Increased security for plugins: Husqvarna Mower, Tedee. Cross-Site Scripting vulnerabilities fixed. Additional security for users in the Recovery Mode area. Added protection against PIN brute-force attacks. It is possible to make 3 attempts to disarm alarm partition before the alarm is triggered. The procedure for assigning passwords to new local users has been changed - the user sets his own password in the system. Improved encryption and security in databases. Added the ability to report a security issue has been added as an extension of the Support Department option. Added information for the user when attempting to perform potentially dangerous actions in the interface. Sensitive device data removed from databases. 1
TitiXsi Posté(e) il y a 13 heures Signaler Posté(e) il y a 13 heures Moralité ... Bugfix, zwave 3.0 par défaut mais tout ne fonctionne pas en 3.0, renforcement de la sécurité. Bientôt il faudra une authentification à chaque lancement de scénario 😁
