Lazer Posté(e) il y a 2 heures Signaler Posté(e) il y a 2 heures Firmware 5.202.54 BETA Hotfix 11/03/2026 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Important notice: Version 5.202.54 is a hotfix for version 5.202.51. The update resolves: Fixed problem of the system hanging on Starting Services in rare cases when Thermostat Linked Device is used. Fixed problem that migration may fail when device model does not contain information about security level when devices were added in legacy versions. Main features: Migration of Z-Wave engine from 2.0 to 3.0 version (BETA) In this version of the software, it is possible to migrate the Z-Wave engine to version 3.0. Migration will allow you to take advantage of all the features of the new Z-Wave engine, including using Smart Start, better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home. Smart Start From now on, you can use the Smart Start function using QR Scanner in Yubii App. This function will allow you to add devices to the system even faster using binding process.*** What's new: Devices Added thermostatOperatingState interface for Linked thermostats. Added direct access to KNX communication (both sending and recieving packets) from the API. Gateway connection Enabling Support Access and Remote Access on the Master hub also enables access on slave hubs. Nice* Added the option to disable the sun impact (setting the value to 0 lux in parameter 10) for the Domi WSC device v3.9.0. The default values of parameters 1, 3, and 10 have been changed for all versions of DOMI WSC devices. Other Verification of the checksum when downloading the update file at the beginning of the process instead of at the end. Bug Fixes: Climate Fixed an issue where an added temperature sensor was removed from the climate panel when editing other settings in that panel. Fixes an error occurs after deleting a device in the climate schedule. Devices Fixed a problem with KNX device configuration caused by the lack of support for diacritical marks in device names. Fixed an issue with function settings for Z-Wave devices with an empty template during the binding process in the mobile application. Fixed incorrect KNX Bridge connection status after IP change. Restored missing temperature graphs on FGT device version 4.10. Fixed the appearance of the dialog in the user interface for BiDi-Awning and AV Controller. Elero Fixed color component values for the Elero Lighting RGBW device. Fixed the appearance and behavior of the Elero Lighting RGBW device icon in the user interface. Fixed invalid settings for temperature color in profiles for the Elero Lighting RGBW device. Gateway connection Fixed errors and incorrect display of options in association settings. Fixed IP address validation in the Gateway Connection tab. Nice* Fixed keep-alive support for Domi WSR/WS device, which caused the device to be shown as disconnected in the system. Other Fixed handling of events from the NICE camera plugin when devices are added via NVR. Fixed icons for Sonos and XBMC plugins. Fixed errors displayed in the Z-wave tab of the Master hub when using the interface via Remote Access. Fixed the input validator for variables. Fixed non-functioning group actions in profiles. Quick Apps Added support for climate zone control functions in QuickApps. Fixed restarting the Quick App process when editing it. Fixed Heat Activator which stopped working in rare cases. Fixed an issue with saving the Quick Apps view to a file when encrypting (applies to QA exported from version 5.191 or later). Scenes Fixed refreshing of the scene activity switch in the interface when calling activation/deactivation action from the scene level. Fixed inactive color temperature slider for device Elero Lighting TW in scenarios created in the mobile app. Known issues: Z-Wave Engine 2.0 to 3.0 migation Device updates from both the server and the file are not working, reconfiguration of the device resolves the issue. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. *** - Fully supported in the upcoming Yubii v2.5.3 application
Lazer Posté(e) il y a 1 heure Auteur Signaler Posté(e) il y a 1 heure C'est un Hotfix de la précédente Beta, donc pas vraiment de nouveautés.
