Code Lua Avec Plage Horaire
Rem's
Bonsoir a tous,
J'essaye de faire fonctionner cette scène, mais je dois avoir une erreur quelque part ... :(
Help Please ...  :rolleyes:
%% properties
%% globals
local currentDate = os.date("*t");
if (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "22:49") )
then
	fibaro:call(131, "turnOn");
	fibaro:call(43, "turnOn");
    fibaro:call(2, "sendDefinedSMSNotification", "3366162XXXX", "10");
      fibaro:debug("Allumage lumières")
if (
 ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "22:50") )
then
	fibaro:call(131, "turnOff");
	fibaro:call(43, "turnOff");
    fibaro:call(2, "sendDefinedSMSNotification", "33661620092", "9");
      fibaro:debug("Extinction limières")
fibaro:sleep(60*1000);
%% autostart
%% properties
%% globals
fibaro:debug("HC2 start script at " .. os.date());
if (fibaro:countScenes() > 1) then
fibaro:debug("Script already running.");
fibaro:abort();
while true do
-- START CODE
-- END CODE
fibaro:sleep(60 * 1000);
