dherremans Posté(e) le 29 novembre 2016 Signaler Partager Posté(e) le 29 novembre 2016 Hello, My HC2 is running on version 4.101 I installed 3 sonos devices over the weekend. 2 play5 and 1 play-bar. All off them has a IP adres on the internal network. When i create a virutual device i can command the sonos devices. Mhen i install the sonos plugin he want discover the sonos devices. When i put in the IP adress in the plugin same problem. Any ideas what could be the problem with the plugin? Regards, Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cardane Posté(e) le 29 novembre 2016 Signaler Partager Posté(e) le 29 novembre 2016 i tried the fibaro SONOS plugin, and immediately removed it. I use the VD written by Krikoff instead (you can find it on this forum). It's working fine and much more reliable than the fibaro plugin. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dherremans Posté(e) le 29 novembre 2016 Auteur Signaler Partager Posté(e) le 29 novembre 2016 Hi Cardane, I did found the Krikoff VD and tested it. It works great. Thx Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
