Afficher model du module
melinm
Merci,
Mais je ne trouve pas l'info. Ni dans les params du module ni dans le json:
{ "id": 310, "name": "Studio", "roomID": 300, "type": "com.fibaro.binarySwitch", "baseType": "com.fibaro.actor", "enabled": true, "visible": true, "isPlugin": false, "parentId": 309, "remoteGatewayId": 0, "interfaces": [ "deviceGrouping", "fibaroFirmwareUpdate", "light", "power", "zwave" ], "properties": { "parameters": [ { "id": 1, "lastReportedValue": 255, "lastSetValue": 255, "size": 1, "value": 255 }, { "id": 3, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 4, "lastReportedValue": 0, "lastSetValue": 0, "size": 2, "value": 0 }, { "id": 6, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 13, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 14, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 15, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 16, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 30, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 31, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 32, "lastReportedValue": 0, "lastSetValue": 0, "size": 1, "value": 0 }, { "id": 33, "lastReportedValue": 1, "lastSetValue": 1, "size": 1, "value": 1 }, { "id": 39, "lastReportedValue": 600, "lastSetValue": 600, "size": 2, "value": 600 } ], "pollingTimeSec": 0, "zwaveCompany": "Fibargroup", "zwaveInfo": "3,3,52", "zwaveVersion": "2.2", "configured": "true", "dead": "false", "deviceControlType": "2", "deviceGroup": "[]", "deviceGroupMaster": "0", "deviceIcon": "1", "emailNotificationID": "0", "emailNotificationType": "0", "endPointId": "0", "firmwareUpdate": "{\"info\":\"\",\"progress\":0,\"status\":\"UpToDate\",\"updateVersion\":\"2.2\"}", "isLight": "true", "liliOffCommand": "", "liliOnCommand": "", "log": "", "logTemp": "", "manufacturer": "", "markAsDead": "true", "model": "", "nodeId": "51", "parametersTemplate": "363", "power": "0.00", "powerConsumption": "66", "productInfo": "1,15,4,2,16,2,2,2", "pushNotificationID": "0", "pushNotificationType": "0", "remoteGatewayId": "0", "saveLogs": "true", "serialNumber": "", "showEnergy": "true", "smsNotificationID": "0", "smsNotificationType": "0", "updateVersion": "", "useTemplate": "true", "userDescription": "", "value": "false" }, "actions": { "reconfigure": 0, "turnOff": 0, "turnOn": 0, "updateFirmware": 1 }, "created": 1498337740, "modified": 1498337740, "sortOrder": 183 }
J'ai inclu un FGR 222 le week-end dernier, je suis en 4.120 sur la box, et je ne vois pas non plus le modèle du module dans l'interface Web ni dans le JSON du module.
Donc ça n'y figure pas toujours... encore un mystère made in Poland !
