PITP2
Spirit vanne thermostatique
Smart Radiator Thermostat for Z-Wave ­
by
SPIRIT Z-Wave PLUS for integration in smart home systems:
The new EUROtronic energy-saving radiator thermostat series represents a completely new design concept. Thanks to its exchangeable design panels (optionally available), the clever radiator thermostat can be customised to individual interior design tastes.
­ The new Spirit-Z-Wave offers a variety of new features. ­
Perfectly adjustable to design-oriented homes
LED signals for
interactive operation
Energy-efficient control of radiators from anywhere
­ Equipped with FLiRS (Frequently Listening Receiver Slave)
...the radiator thermostat responds to incoming commands with a particularly short latency time (e.g. temperature changes).
Its colored display
...is particularly easy to read and boasts an extra large temperature display.
The central multicolor LED button
...offers intuitive user guidance as the colored flash sequences encourage users to interact with the device.
The Spirit Z-Wave Plus is supplied with silver design panels for the battery compartment, a decorative ring and neutral white design panel.
Various colors for the battery cover and decorative ring are available as optional accessories.
Striking colors are particularly popular in children's rooms..
­ Besides the attractive design that can be customised to a design-oriented living environment the new Spirit line offers a particularly intuitive operation and remarkably simple and quick assembly. So it provides everything that is expected of a modern radiator thermostat.
EURESPIRIT
EAN: 4260012711301
Supply Voltage:
2 x 1,5V LR6/Mignon/AA
Radio Frequency: 868,42 MHz
Connection: M30 x 1,5 mm
Dimensions: (W x H x D): 56 x 68 x 89 mm
Yeah, le come back de@Pitp2 en trombe.
Tu les as testés ces vannes ?
Salut @pepite,
non pas encore :(
Mais j'aime bien le Flirs et la position de l'afficheur digital que je trouve extra par rapport à l'emplacement sur les Danfoss
La présentation est belle dommage qu'elle soit en anglais
Effectivement, top l'écran et le flirs... Faudrait que je change toutes mes Danfoss :)
La position de l'afficheur des Danfoss peut avoir un avantage : dans mon cas, certaines têtes sont en hauteur (radiateurs verticaux).
Et l'afficheur frontal est lisible depuis le sol...
Par contre, ces nouvelles têtes ont-elles un retour de la mesure de la température ?
perso j'avais essayé des vannes de cette marque il y a quelques années et retour expéditeur vite fait (je ne sais plus pourquoi, mais elles ne devaient pas répondre à mon besoin). Mainteant, j'ai 11 LC-13, dont je suis content
mais le FLIRS, c'est tantant ...
Hello,
Je remonte le sujet. Quelqu'un l'a t-il testé ?
J'ai une Danfoss qui vient de tomber en rade (erreur E1)... je dois la remplacer rapidos..
Hello,
Ce texte est traduit par Google, donc désolé pour les erreurs.
J'ai vew de ces thermostats. En général, ils sont ok, pour moi bien mieux que danfoss.
Seul probleme que j'ai observé - la durée de vie de la batterie est 2 a 3 fois plus courte que sur Danfoss. Jusqu'a présent, je vais rester avec eux, l'alternative en ce moment est le thermostat Fibaro, mais pour moi, il est moche et ne montre aucune information a côté du changement de couleur en fonction de
Température.
Chris
