fredokl Posté(e) le 6 octobre 2025 Signaler Posté(e) le 6 octobre 2025 Firmware 5.183.63 STABLE 06/10/2025 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New interface design. A new, refreshed user interface design that will make using the interface even more enjoyable. 2. New Smart Implant / Smart-Control device pairing wizard. A new, dedicated device pairing process in the Yubii mobile application and web interface, where you can easily add and configure your device. 3. Improved security. Application of cybersecurity guidelines in accordance with the new regulations (RED) and the Data Act. What's new: Access Added the ability to delete a user yourself in user settings. Devices Added new sets of icons for roller shutters. Improved curtain behavior when controlled via interface. Adapted the Husqvarna plugin to the new manufacturer API. Elero Support for Elero Bi-rec device (Veinor). Support for Elero RGBW device (Veinor). Reduced polling for the VarioTec-868 device. Improved the type definition for the Revio4M device from a light to roller blinds and venetian blinds. Improved the name and icon for the Sun Motion 868 device. Add new device types for new RolAir motors. DuoSON-868 device integration. AstroSON-868 device integration. Energy panel Added the ability to set quarterly rates for tariff in the energy panel. Nice* Support for TTDW and TTDRGB LED strips devices controllers. Improvements in binding procedures using already memorized transmitter. Improved communication with the radio chip. Group actions are now handled simultaneously for quicker reaction to commands. Added generic support for devices with unknown product types. Reduced polling for battery-powered devices. Support for the ERA Inn Li-ion battery-powered device. Cleaned up the system devices model for monodirectional devices by removing redundant device's roles. Other Documents for Privacy Policy and Terms of Service have been separated when updating the Hub. Changelog history added when updating the Hub version. Changed graphics for Energy Panel charts. Added Swagger documentation for /api/mobile/settings. Quick Apps The preview tab is updated on-the-fly after copying the JSON view. Scenes Performance improvements in scenes execution in large systems. Scene launch optimization. Possibility to send e-mails to Installer from LUA and block scenes. Z-Wave Improvements for handling the reports in Alarm V2 Command Class. Z-wave engine 3.0 is set as default in the FTI process. Updated parameters template for FGR-224/Roll-Control 2 for version 8.2. Added support for class Thermostat Fan Mode version 5. Bug Fixes: Access Improved display of full screen camera view for advanced user. Climate Fixed incorrect calculation of the temperature value for thermostats auto mode. Devices Fixed assigment of the whole device to specific room when adding devices from the mobile app. Added the ability to manually enter values for Multilevel sensors when pairing devices in the mobile app. Fixed the slider display when the thermostat is set to the maximum value in the device preview. Fixed the control dialog for the Nice BiDi-Shutter device as a Venetian blind. Missing source information in DeviceActionRanEvent. Fixed the display of long device names in modal windows. Full https support for Nice Cameras and NVRs. Fixed display of statuses in the Dashboard for colorController and multilevelSwitch devices. Optimised web UI wizards for some devices. Fixed an issue where the device removal process in the mobile app would loop. Fixed issue with loading multiple icons for devices. Fixed a screen freeze in the device removal process in IOS mobile apps. Fixed slider performance in advanced device settings. Added missing toggle action for MultiPositionSwitch devices. Fixed the issue of displaying a message disconnected when the camera preview was working properly. Fixed saving of advanced settings when changing tabs in the device list. Fixed display of the "on" status for devices inheriting from the colorController type in the interface Unlocked the process of adding devices when Z-wave learning mode is enabled in the interface. Fixed display of device statuses in the history panel. Elero Improved the connection process when grouping Elero devices. Gateway Connection Fixed an issue with reverting to the schedule for MCOHome MH8 devices on a slave Hub. Removed duplication for Support and Installer users in the database after updating from version 5.161.15 or higher with gateway connection setup. Fixed device counting in backups for the Master Hub. Nice* Fixed moving to favorite position for mono devices. Improved wake-up from the Hub for the Climatic sensor battery-powered device. Other Fixed selection of devices on the Reset Elero network dropdown list. Fixed the 8-character limit for entering Wi-Fi passwords during the FTI process. Improved handling of the /api/scenes endpoint in Swagger. Fixed SVG icon colors in dark mode for scenes. Access Point is available again in Recovery Mode. The save button is active again after setting a new location from the map. Minor UI/UX fixes. Quick Apps Improved refreshing in the setColorComponent function for Quick Apps. Added support for uploading external icons for Multilevel Sensor device type. Scenes Removed redundant unsaved changes dialog when no changes were made when editing scenarios. Fixed issue with saving default Morning Scenario after making changes. Fixed scenes trigger based on current color for Block Scenes. When creating a new scene from the Scenes Dashboard, the editing screen opens. Users The "Continue" button is not active during the user deletion process. Z-Wave Improved node id (associations) handling when controller has different NodeID that 1.** Fixed the issue of lost Zipato RFID device reports.** Fixed invalid parameters 2,3 value for HeatIt Z-Temp3 device. Fixed a rare issue where learning mode would freeze. Fixed template for Aeon Multisensor 6 device. Fixed an issue where the “Check for updates” button was inactive after adding a Z-Wave device. Console opened in new windows does not scroll automatically when ZW3.0 is used. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. Security: The option to use only the HTTP protocol in network settings has been removed. Log security has been improved through additional security measures for private user data. Security actions have been separated into separate, additionally secured Hub logs. Secure communication for the Z-Wave device update service has been added. The master Hub communicates with the slave Hub only via a secure https connection. Restricted unauthorized API and backup file requests. Updated some low-level libraries. Database protections against storing private data. Fixed error codes returned for authentication errors. Fixed potential RCE vulnerabilities. Removed information regarding the existence of usernames in the system for the password reset mechanism. Reduced vulnerability to DoS attacks. Improved log file encryption. Due to the upcoming new cybersecurity regulations (RED), work has been implemented to improve the product's security level to comply with the EN18301 standard and the latest security guidelines. The user password reset procedure has been changed - user sets a new password himself. The number of required characters in a user password has been increased to 12 - for new users and when changing the password for existing users. Added email notification for administrator regarding unauthorized login attempts when an unknown user logs in. The default login password for the FTI process has been changed for the ones from device label. Improved security for requests from localhost. Increased security for plugins: Husqvarna Mower, Tedee. Cross-Site Scripting vulnerabilities fixed. Additional security for users in the Recovery Mode area. Added protection against PIN brute-force attacks. It is possible to make 3 attempts to disarm alarm partition before the alarm is triggered. The procedure for assigning passwords to new local users has been changed - the user sets his own password in the system. Improved encryption and security in databases. Added the ability to report a security issue has been added as an extension of the Support Department option. Added information for the user when attempting to perform potentially dangerous actions in the interface. Sensitive device data removed from databases. Due to the EU Data Act regulation, changes have been introduced to enable the download Hub data and user data - from the Hub settings level - from the user settings level. The Privacy Policy and Terms of Service are accepted by every user, not just the administrator. Data submitted for analytics is available in Swagger for administrators. Improved crash dump encryption method. 1 1
fredokl Posté(e) le 6 octobre 2025 Auteur Signaler Posté(e) le 6 octobre 2025 Firmware 5.183.63 STABLE 06/10/2025 Français Merci d'avoir utilisé notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et améliorations. Caractéristiques principales : 1. Nouvelle conception d'interface. Une nouvelle conception d'interface utilisateur rafraîchie qui rendra l'utilisation de l'interface encore plus agréable. 2. Nouvel assistant de couplage d'appareils Smart Implant / Smart-Control. Un nouveau processus d'appariement d'appareils dédié dans l'application mobile Yubii et l'interface Web, où vous pouvez facilement ajouter et configurer votre appareil. 3. Sécurité améliorée. Application des directives de cybersécurité conformément aux nouvelles réglementations (RED) et à la loi sur les données. Quoi de neuf : Accès Ajout de la possibilité de supprimer vous-même un utilisateur dans les paramètres utilisateur. Appareils Ajout de nouveaux ensembles d'icônes pour les volets roulants. Amélioration du comportement du rideau lorsqu'il est contrôlé via l'interface. Adapté le plugin Husqvarna à la nouvelle API du fabricant. Elero Prise en charge de l'appareil Elero Bi-rec (Veinor). Prise en charge de l'appareil Elero RGBW (Veinor). Sondage réduit pour l'appareil VarioTec-868. Amélioration de la définition du type pour l'appareil Revio4M d'une lumière aux stores enrouleurs et aux stores vénitiens. Amélioration du nom et de l'icône de l'appareil Sun Motion 868. Ajoutez de nouveaux types d'appareils pour les nouveaux moteurs RolAir. Intégration de l'appareil DuoSON-868. Intégration des appareils AstroSON-868. Panneau d'énergie Ajout de la possibilité de fixer des tarifs trimestriels pour le tarif dans le panneau d'énergie. Nice* Prise en charge des contrôleurs de périphériques de bandes LED TTDW et TTDRGB. Améliorations des procédures de liaison à l'aide d'un émetteur déjà mémorisé. Communication améliorée avec la puce radio. Les actions de groupe sont désormais traitées simultanément pour une réaction plus rapide aux commandes. Ajout d'une prise en charge générique pour les appareils avec des types de produits inconnus. Réduction des sondages pour les appareils alimentés par batterie. Prise en charge de l'appareil alimenté par batterie ERA Inn Li-ion. Nettoyage du modèle de périphériques système pour les périphériques monodirectionnels en supprimant les rôles des périphériques redondants. Autre Les documents relatifs à la politique de confidentialité et aux conditions d'utilisation ont été séparés lors de la mise à jour du Hub. Historique du journal des modifications ajouté lors de la mise à jour de la version du Hub. Modification des graphiques pour les graphiques du panneau d'énergie. Ajout de la documentation Swagger pour /api/mobile/settings. Quick Apps L'onglet d'aperçu est mis à jour à la volée après avoir copié la vue JSON. Scènes Améliorations des performances dans l'exécution des scènes dans les grands systèmes. Optimisation du lancement de scène. Possibilité d'envoyer des e-mails à l'installateur de LUA et de bloquer des scènes. Z-Wave Améliorations pour la gestion des rapports dans la classe de commande Alarm V2. Le moteur Z-wave 3.0 est défini par défaut dans le processus FTI. Mise à jour du modèle de paramètres pour FGR-224/Roll-Control 2 pour la version 8.2. Ajout de la prise en charge de la classe Thermostat Fan Mode version 5. Corrections de bugs : Accès Affichage amélioré de la vue de la caméra plein écran pour un utilisateur avancé. Climat Correction d'un calcul incorrect de la valeur de température pour le mode automatique des thermostats. Appareils Correction de l'assignation de l'ensemble de l'appareil à une pièce spécifique lors de l'ajout d'appareils à partir de l'application mobile. Ajout de la possibilité de saisir manuellement des valeurs pour les capteurs à plusieurs niveaux lors du jumelage d'appareils dans l'application mobile. Correction de l'affichage du curseur lorsque le thermostat est réglé sur la valeur maximale dans l'aperçu de l'appareil. Correction de la boîte de dialogue de contrôle pour l'appareil Nice BiDi-Shutter en tant que store vénitien. Informations sources manquantes dans DeviceActionRanEvent. Correction de l'affichage des noms d'appareils longs dans les fenêtres modales. Prise en charge https complète pour Nice Cameras et NVR. Correction de l'affichage des statuts dans le tableau de bord pour les appareils colorController et multilevelSwitch. Assistants d'interface utilisateur Web optimisés pour certains appareils. Correction d'un problème où le processus de suppression de l'appareil dans l'application mobile se boucle. Correction d'un problème de chargement de plusieurs icônes pour les appareils. Correction d'un gel d'écran dans le processus de suppression de l'appareil dans les applications mobiles IOS. Correction des performances du curseur dans les paramètres avancés de l'appareil. Ajout d'une action à bascule manquante pour les appareils MultiPositionSwitch. Correction du problème d'affichage d'un message déconnecté lorsque l'aperçu de la caméra fonctionnait correctement. Correction de l'enregistrement des paramètres avancés lors du changement d'onglets dans la liste des appareils. Correction de l'affichage de l'état "on" pour les appareils héritant du type colorController dans l'interface Déverrouillé le processus d'ajout d'appareils lorsque le mode d'apprentissage Z-wave est activé dans l'interface. Correction de l'affichage des statuts de l'appareil dans le panneau d'historique. Elero Amélioration du processus de connexion lors du regroupement des appareils Elero. Connexion à la passerelle Correction d'un problème de retour au calendrier pour les appareils MCOHome MH8 sur un hub esclave. Suppression de la duplication pour les utilisateurs de support et d'installateur dans la base de données après la mise à jour à partir de la version 5.161.15 ou supérieure avec la configuration de la connexion de la passerelle. Comptage d'appareils fixes dans les sauvegardes pour le Master Hub. Nice* Correction du passage à la position préférée pour les appareils mono. Amélioration du réveil du Hub pour le capteur climatique alimenté par batterie. Autre Correction de la sélection des appareils dans la liste déroulante Réinitialiser le réseau Elero. Correction de la limite de 8 caractères pour la saisie des mots de passe Wi-Fi pendant le processus FTI. Amélioration de la gestion du point de terminaison /api/scenes dans Swagger. Correction des couleurs de l'icône SVG en mode sombre pour les scènes. Le point d'accès est à nouveau disponible en mode de récupération. Le bouton d'enregistrement est à nouveau actif après avoir défini un nouvel emplacement à partir de la carte. Corrections mineures de l'interface utilisateur/de l'expérience utilisateur. Quick Apps Amélioration du rafraîchissement dans la fonction setColorComponent pour les applications rapides. Ajout de la prise en charge du téléchargement d'icônes externes pour le type d'appareil à capteur multiniveaux. Scènes Suppression de la boîte de dialogue redondante des modifications non enregistrées lorsqu'aucune modification n'a été apportée lors de l'édition de scénarios. Correction d'un problème avec l'enregistrement du scénario du matin par défaut après avoir apporté des modifications. Correction du déclencheur de scènes en fonction de la couleur actuelle pour les scènes de bloc. Lorsque vous créez une nouvelle scène à partir du tableau de bord des scènes, l'écran d'édition s'ouvre. Utilisateurs Le bouton "Continuer" n'est pas actif pendant le processus de suppression de l'utilisateur. Z-Wave Amélioration de la gestion de l'identifiant des nœuds (associations) lorsque le contrôleur a un NodeID différent de 1. ** Correction du problème des rapports d'appareils RFID Zipato perdus. ** Correction de la valeur 2,3 des paramètres non valides pour le périphérique HeatIt Z-Temp3. Correction d'un problème rare où le mode d'apprentissage se figeait. Modèle corrigé pour l'appareil Aeon Multisensor 6. Correction d'un problème où le bouton "Vérifier les mises à jour" était inactif après l'ajout d'un périphérique Z-Wave. La console ouverte dans de nouvelles fenêtres ne défile pas automatiquement lorsque ZW3.0 est utilisé. Problèmes connus : Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas à HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. Sécurité : L'option d'utiliser uniquement le protocole HTTP dans les paramètres réseau a été supprimée. La sécurité des journaux a été améliorée grâce à des mesures de sécurité supplémentaires pour les données privées des utilisateurs. Les actions de sécurité ont été séparées en journaux Hub séparés et sécurisés en plus. Une communication sécurisée pour le service de mise à jour de l'appareil Z-Wave a été ajoutée. Le hub maître communique avec le hub esclave uniquement via une connexion https sécurisée. Demandes d'API et de fichiers de sauvegarde non autorisées restreintes. Mise à jour de certaines bibliothèques de bas niveau. Protections de base de données contre le stockage de données privées. Correction des codes d'erreur renvoyés pour des erreurs d'authentification. Correction des vulnérabilités potentielles du RCE. Suppression des informations concernant l'existence de noms d'utilisateur dans le système pour le mécanisme de réinitialisation du mot de passe. Réduction de la vulnérabilité aux attaques DoS. Amélioration du cryptage des fichiers journaux. En raison de la prochaine nouvelle réglementation en matière de cybersécurité (RED), des travaux ont été mis en œuvre pour améliorer le niveau de sécurité du produit afin de se conformer à la norme EN18301 et aux dernières directives de sécurité. La procédure de réinitialisation du mot de passe de l'utilisateur a été modifiée - l'utilisateur définit lui-même un nouveau mot de passe. Le nombre de caractères requis dans un mot de passe utilisateur a été augmenté à 12 - pour les nouveaux utilisateurs et lors du changement de mot de passe pour les utilisateurs existants. Ajout d'une notification par e-mail pour l'administrateur concernant les tentatives de connexion non autorisées lorsqu'un utilisateur inconnu se connecte. Le mot de passe de connexion par défaut pour le processus FTI a été modifié pour ceux de l'étiquette de l'appareil. Amélioration de la sécurité pour les demandes de l'hôte local. Sécurité accrue pour les plugins : Husqvarna Mower, Tedee. Correction des vulnérabilités de script intersite. Sécurité supplémentaire pour les utilisateurs dans la zone du mode de récupération. Ajout d'une protection contre les attaques par force brute par code PIN. Il est possible de faire 3 tentatives pour désarmer la partition d'alarme avant que l'alarme ne soit déclenchée. La procédure d'attribution de mots de passe aux nouveaux utilisateurs locaux a été modifiée - l'utilisateur définit son propre mot de passe dans le système. Amélioration du cryptage et de la sécurité dans les bases de données. Ajout de la possibilité de signaler un problème de sécurité en tant qu'extension de l'option du service d'assistance. Ajout d'informations pour l'utilisateur lorsqu'il tente d'effectuer des actions potentiellement dangereuses dans l'interface. Données d'appareils sensibles supprimées des bases de données. En raison du règlement de la loi sur les données de l'UE, des changements ont été introduits pour permettre le téléchargement des données du Hub et des données utilisateur - à partir du niveau des paramètres du Hub - à partir du niveau des paramètres de l'utilisateur. La politique de confidentialité et les conditions d'utilisation sont acceptées par chaque utilisateur, pas seulement par l'administrateur. Les données soumises pour l'analyse sont disponibles dans Swagger pour les administrateurs. Amélioration de la méthode de cryptage crash dump. 2
Lazer Posté(e) le 6 octobre 2025 Signaler Posté(e) le 6 octobre 2025 Ah c'est donc pour ça que j'ai vu la diode clignoter sur ma box ce soir en rentrant Bon bah on va regarder tout ça...
jojo Posté(e) le 6 octobre 2025 Signaler Posté(e) le 6 octobre 2025 et toujours avec du texte illisible ?
TitiXsi Posté(e) le 6 octobre 2025 Signaler Posté(e) le 6 octobre 2025 (modifié) Il y a 18 heures, jojo a dit : et toujours avec du texte illisible ? Le fond du log est bleu pastelle 😁 Modifié le 7 octobre 2025 par TitiXsi 1
flacon030 Posté(e) le 7 octobre 2025 Signaler Posté(e) le 7 octobre 2025 (modifié) mise a jour fait depuis deux jours, RAS pour le moment Modifié le 7 octobre 2025 par flacon030
