HC3 & HC3L - 5.212.23 - BETA - 26/08/2026
Firmware 5.212.23
BETA
26/08/2026
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
NICE High Load Control- added support for device
What's new:
Z-Wave
Improved detection of device model changes after an update so that the control panel receives current data without restarting it.
Improved S2 Unauthenticated device inclusion by removing the incorrect PIN or DSK confirmation requirement.
Added Zvidar water valve integration with a valve role, parameter template, and default name in Z-Wave 3.
Other
Improved Wizard buttons so longer descriptions are more visible and can be scrolled when selected.
Bug Fixes:
Devices
Improved the preview of scaled parameters to show readable values instead of raw protocol values.
Improved the Wall Keypad template for version 2.x by removing unsupported battery handling.
Fixed enabling the LAPD ring color mode for FGWC-201.
Fixed FGR-224 control after stopping calibration and removing RF protection.
Fixed MCO Home A8-9 sensor installation so the device is correctly recognized and configured.
Fixed real-time clock setup for the Nice Warm Control thermostat after adding it to the gateway.
Fixed the English translations of parameters 22 and 24 for Nice Motion Control and Fibaro Motion Sensor.
Fixed slider-based parameter setting for FGWP-103 and refresh of the read value after changes from other sources.
Improved association behavior for MCO occupancy sensors in Z-Wave 2 to match Z-Wave 3.
Gateway connection
Fixed inactive “Update and restore” buttons for Gateway Connection backups created with a newer software version.
KNX
Fixed an incorrect KNX device type when the “Open/Close” state is configured.
Nice*
Added pergola role support for bidi-awning in Yubii, including migration of existing configurations.
Improved Nice Engine compatibility when updating the gateway from version 5.020 to 5.210.
Fixed the OFF action for Revio SW so it sends the STOP command instead of DOWN.
Other
Fixed the missing border and styling of the “Upload Backup” button.
Fixed missing filters on the dashboard.
Improved Smart Start QR code scanning on iOS to make codes easier to capture with the camera.
Fixed intermittent interface loading issues when switching tabs that previously required a page refresh.
Added a push notification for the administrator when the system automatically rolls back to the previous software version.
Added name filtering and sorting to the global variables list.
Fixed mixed German and English text when creating scenes in the Yubii app.
Added automatic launch of the NICE Cameras Wizard after adding the camera plugin.
Quick Apps
Improved the default icon for QA Device Controller and Generic Device
Fixed the first HVAC mode override from a block scene so it respects the duration configured in the scene.
Improved Quick App list behavior for single and multiple selection.
Fixed the Nice Camera plugin room resetting to “Default” after adding another camera from the mobile app.
Z-Wave
Fixed potential S0 communication error for newly added devices after migrating a old engine to new engine  Z-Wave.
Improved Z-Wave device compatibility after the Z-Wave 3 engine update, including reporting and configuration for affected devices.
Fixed migration of FGBS-321 devices from Z-Wave 2 to Z-Wave 3.
Fixed missing serial numbers for child devices added with the Z-Wave 3 engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Like 3
