fredokl Posté(e) vendredi à 22:45 Signaler Posté(e) vendredi à 22:45 (modifié) Firmware 5.210.14 Hotfix STABLE 22/07/2026 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Important notice: Version 5.210.14 is a hotfix for version 5.210.12. The update contains changes: Adapted the software to work with the new component revision being introduced in manufacturing. Main features: KNX integration From now on, your KNX system can work even smarter thanks to integration with our Yubii Home Pro and Home Center 3 hubs. Gain full control over lighting, switches, RGBW controllers, blinds, shutters and sensors within one unified ecosystem. Migration of Z-Wave engine from 2.0 to 3.0 version (BETA) In this version of the software, it is possible to migrate the Z-Wave engine to version 3.0. Migration will allow you to take advantage of all the features of the new Z-Wave engine, including using Smart Start, better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home. Smart Start From now on, you can use the Smart Start function using QR Scanner in Yubii App. This function will allow you to add devices to the system even faster using binding process.*** What's new: Devices Improved display of device families on the device list so that child devices are always located under their parent device. Added Operating State indicator for Linked thermostats. Added direct access to KNX communication (both sending and recieving packets) from the API. Elero Integration with ELERO Lighting Receivers: TTDTW-E (Combio-868 LI W), TTDRGBW-E (Combio-868 LI RGBW), TTDW-E (Combio-868 LI PW). Energy Panel Integration with Tibber monitor to allow automatic rates update for Energy Panel (Available only for addresses located in Germany, Norway, Sweden or the Netherlands). Gateway connection When the Slave hub is turned off or there is no connection, the devices added to it are visible as inactive (dead) in the Master hub. Enabling Support Access and Remote Access on the Master hub also enables access on slave hubs. Nice* Upgraded NICE chip firmware version to the newest one. Added the option to disable the sun impact (setting the value to 0 lux in parameter 10) for the Domi WSC device v3.9.0. The default values of parameters 1, 3, and 10 have been changed for all versions of DOMI WSC devices. Other Added the information about the zone where the alarm occurred. Verification of the checksum when downloading the update file at the beginning of the process instead of at the end. Removed PKO Assistance plugin from the system due to official termination of cooperation. Scenes Added a new scene activation/deactivation block as an action in block scenes. Added possibility to enable/disable local and remote device protection via scenes and profiles. Z-Wave Adjusted parameters templates for sensors to reduce number of reports for various devices. Fixed setting of parameter 5 for the MCO Home MH7H-EH device. Improved clearing Z-Wave network reset procedure. The ability to manually add parameters at each endpoint. Improved Z-wave3 engine resilience to communication issues in Security S0.** Support for Z-Wave 3.0 in Installer App.** Bug Fixes: Backups Fixed an issue where the “Update and restore” buttons for backups with higher software versions were inactive. Climate Fixed an issue where the schedule was not cleared from the Heat-Control/Fibaro Heat Controller when it was removed from the climate zone. Fixed an issue where an added temperature sensor was removed from the climate panel when editing other settings in that panel. Fixes an error occurs after deleting a device in the climate schedule. Fixed issue with saving climate zones in some cases. The FGT thermostatic heads are not synchronised with the schedule. Devices Fixed an issue where the Color component view was not updating correctly. Fixed an issue with changing icon for Dahua cameras. Improved performance for the DoubleDimmer-Control binding Wizard. Fixed a problem with KNX device configuration caused by the lack of support for diacritical marks in device names. Fixed an issue with function settings for Z-Wave devices with an empty template during the binding process in the mobile application. Fixed incorrect KNX Bridge connection status after IP change. Restored missing temperature graphs on FGT device version 4.10. Fixed the appearance of the dialog in the user interface for BiDi-Awning and AV Controller. Fixed the display of svg icons in the mobile app for Sprinkler and NICE Siren devices. Fixed problem with CoolAutomation plugin to receive correct feedback/status in mobile application. Fixed UI for Advanced Configuration for the Keyfob lock button and unlock sequence. RGBW device doesn't control properly the color setting in specific actions sequence using the picker. Elero Fixed color component values for the Elero Lighting RGBW device. Fixed the appearance and behavior of the Elero Lighting RGBW device icon in the user interface. Fixed invalid settings for temperature color in profiles for the Elero Lighting RGBW device. It is not possible to control Elero Lighting RGBW after pairing it with the system if the LED output is turned off during finishing binding procedure. Gateway connection Fixed errors and incorrect display of options in association settings. Fixed IP address validation in the Gateway Connection tab. Wrong backup type while software update for slave hubs. Devices from different phisical networks are listed as a target destinations in associations. KNX Fixed a KNX connection error that occurred when reconnecting after a long period of time. Fixed problem with reconnecting the KNX bridge after performing a 'clear configuration' action. Nice* Fixed setting favorite position for the screen devices which does not support this natively. Fixed keep-alive support for Domi WSR/WS device, which caused the device to be shown as disconnected in the system. Fixed issues with Nice PLN2+ motors controlled as a group using Linked Device. Fixed the operation of some group actions causing i.a. malfunctions in scenes. Fixed an issue with removing device Domi WSR when the device is inactive. Other Removed a non-functional option (checkbox) for sending notifications on the list of mobile devices. Fixed visibility of device name when adding Z-wave devices in the mobile application. Fixed tooltips positioning in the interface. Fixed the message screen displayed after using the factory reset option in Recovery mode. Fixed handling of events from the NICE camera plugin when devices are added via NVR. Fixed icons for Sonos and XBMC plugins. Fixed errors displayed in the Z-wave tab of the Master hub when using the interface via Remote Access. Fixed the input validator for variables. Fixed non-functioning group actions in profiles. Added real-time refreshing of history entries for Z-Wave Central Scene events and scene-related events. Fixed an issue where the reboot sometimes didn't work properly. Minor UI/UX fixes. Profiles Fixed problem with triggering changes via profiles. Quick Apps Allowed additional parameters to hub.alert function in QuickApp to keep backward compatibility with old code. Variable edit box character limit has been increased from 1024 to 2048. Added support for climate zone control functions in QuickApps. Fixed restarting the Quick App process when editing it. Fixed Heat Activator which stopped working in rare cases. Fixed an issue with saving the Quick Apps view to a file when encrypting (applies to QA exported from version 5.191 or later). Fixed problem that HTTP responses other than 2xx (300 and higer) don't return response body. Corrected validation of variable names to allow editing of existing variable values. Fixed an issue with the display of custom icons for remote controllers in Quick Apps. Scenes Fixed an issue that icons other than the default ones are not displayed when selecting profiles in scenarios. Fixed refreshing of the scene activity switch in the interface when calling activation/deactivation action from the scene level. Fixed inactive color temperature slider for device Elero Lighting TW in scenarios created in the mobile app. Fixed problem that net.HTTPClient strips query string parameters in LUA scenes. Fixed the behavior of sliders in block scenes for the setColor action, sliders now function independently. Fixed an error that block scene with setting Manual mode to "Hold" does not work on HC3L/YH hubs. Optimization of scene running. Fixed an issue with saving a predefined scenario when some devices are selected. Update Moved the setting related to system version information from the final stage of startup to the earliest possible point in order to reduce incorrect version data in recovery mode. Changed the order in which services start during initialization to avoid issues during updates. Fixed the behavior of the progress bar when canceling an update download; the progress bar is now hidden. Z-Wave Fixed redundant stopping of Z-Wave3 engine.** Fixed the visibility of updates for Z-Wave devices on both engine versions. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. *** - Fully supported in the upcoming Yubii v2.5.3 application Security: Angular vulnerabilities update. Updated Rust toolchain version. Modifié il y a 17 heures par Lazer 1
fredokl Posté(e) vendredi à 22:51 Auteur Signaler Posté(e) vendredi à 22:51 (modifié) Version française: Firmware 5.210.14 STABLE 25/08/2026 Merci d'avoir utilisé notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et améliorations. Avis important : La version 5.210.14 est un correctif pour la version 5.210.12. La mise à jour contient des modifications : Adapté le logiciel pour qu'il fonctionne avec la nouvelle révision des composants introduite dans la fabrication. Principales caractéristiques : Intégration KNX À partir de maintenant, votre système KNX peut fonctionner encore plus intelligemment grâce à l'intégration avec nos hubs Yubii Home Pro et Home Center 3. Prenez un contrôle total sur l'éclairage, les interrupteurs, les contrôleurs RGBW, les stores, les volets et les capteurs au sein d'un seul écosystème unifié. Migration du moteur Z-Wave de la version 2.0 à la version 3.0 (BETA) Dans cette version du logiciel, il est possible de migrer le moteur Z-Wave vers la version 3.0. La migration vous permettra de profiter de toutes les fonctionnalités du nouveau moteur Z-Wave, y compris l'utilisation de Smart Start, une meilleure prise en charge générique pour les appareils Z-Wave Plus et la disponibilité de Security S2, qui peut être considérée comme la première méthode de communication entièrement sécurisée pour la maison intelligente. Smart Start À partir de maintenant, vous pouvez utiliser la fonction Smart Start à l'aide du scanner QR dans l'application Yubii. Cette fonction vous permettra d'ajouter des appareils au système encore plus rapidement à l'aide du processus de liaison. *** Quoi de neuf : Appareils Affichage amélioré des familles d'appareils sur la liste des appareils afin que les appareils enfants soient toujours situés sous leur appareil parent. Ajout d'un indicateur d'état de fonctionnement pour les thermostats liés. Ajout d'un accès direct à la communication KNX (envoi et réception de paquets) à partir de l'API. Elero Intégration avec les récepteurs d'éclairage ELERO : TTDTW-E (Combio-868 LI W), TTDRGBW-E (Combio-868 LI RGBW), TTDW-E (Combio-868 LI PW). Panneau d'énergie Intégration avec le moniteur Tibber pour permettre la mise à jour automatique des tarifs pour le panneau d'énergie (disponible uniquement pour les adresses situées en Allemagne, en Norvège, en Suède ou aux Pays-Bas). Connexion à la passerelle Lorsque le hub esclave est désactivé ou qu'il n'y a pas de connexion, les périphériques qui y sont ajoutés sont visibles comme inactifs (morts) dans le hub principal. L'activation de l'accès au support et de l'accès à distance sur le hub principal permet également l'accès aux hubs esclaves. Nice* Mise à niveau de la version du firmware de la puce NICE vers la plus récente. Ajout de l'option pour désactiver l'impact solaire (réinitialisant la valeur à 0 lux dans le paramètre 10) pour le dispositif Domi WSC v3.9.0. Les valeurs par défaut des paramètres 1, 3 et 10 ont été modifiées pour toutes les versions des appareils DOMI WSC. Autre Ajout des informations sur la zone où l'alarme s'est produite. Vérification de la somme de contrôle lors du téléchargement du fichier de mise à jour au début du processus au lieu de la fin. Suppression du plugin PKO Assistance du système en raison de la résiliation officielle de la coopération. Scènes Ajout d'un nouveau bloc d'activation/désactivation de scène en tant qu'action dans les scènes de bloc. Ajout de la possibilité d'activer/désactiver la protection des appareils locaux et distants via des scènes et des profils. Z-Wave Modèles de paramètres ajustés pour les capteurs afin de réduire le nombre de rapports pour divers appareils. Correction du paramètre 5 pour l'appareil MCO Home MH7H-EH. Amélioration de la procédure de réinitialisation du réseau Z-Wave. La possibilité d'ajouter manuellement des paramètres à chaque point de terminaison. Amélioration de la résilience du moteur Z-wave3 aux problèmes de communication dans Security S0. ** Prise en charge de Z-Wave 3.0 dans l'application Installer.** Corrections de bugs : Sauvegardes Correction d'un problème où les boutons « Mettre à jour et restaurer » pour les sauvegardes avec des versions logicielles supérieures étaient inactifs. Climat Correction d'un problème où le calendrier n'était pas effacé du contrôleur de chaleur/Fibaro Heat Control lorsqu'il était retiré de la zone climatique. Correction d'un problème où un capteur de température ajouté était supprimé du panneau climatique lors de la modification d'autres paramètres de ce panneau. Corrige une erreur qui se produit après la suppression d'un appareil dans le calendrier climatique. Correction d'un problème avec la sauvegarde des zones climatiques dans certains cas. Les têtes thermostatiques FGT ne sont pas synchronisées avec l'horaire. Appareils Correction d'un problème où la vue du composant Couleur ne se mettait pas à jour correctement. Correction d'un problème avec le changement d'icône pour les caméras Dahua. Amélioration des performances pour l'assistant de liaison DoubleDimmer-Control. Correction d'un problème avec la configuration de l'appareil KNX causé par le manque de prise en charge des marques diacritiques dans les noms des appareils. Correction d'un problème avec les paramètres de fonction pour les appareils Z-Wave avec un modèle vide pendant le processus de liaison dans l'application mobile. Correction d'un état de connexion KNX Bridge incorrect après le changement d'IP. Restauration des graphiques de température manquants sur l'appareil FGT version 4.10. Correction de l'apparence de la boîte de dialogue dans l'interface utilisateur pour BiDi-Awning et AV Controller. Correction de l'affichage des icônes svg dans l'application mobile pour les appareils Sprinkler et NICE Siren. Correction d'un problème avec le plugin CoolAutomation pour recevoir des commentaires/état corrects dans l'application mobile. Correction de l'interface utilisateur pour la configuration avancée du bouton de verrouillage du porte-clés et de la séquence de déverrouillage. Le périphérique RGBW ne contrôle pas correctement le paramètre de couleur dans une séquence d'actions spécifiques à l'aide du sélecteur. Elero Correction des valeurs des composants de couleur pour l'appareil Elero Lighting RGBW. Correction de l'apparence et du comportement de l'icône du périphérique Elero Lighting RGBW dans l'interface utilisateur. Correction des paramètres invalides pour la couleur de température dans les profils pour l'appareil Elero Lighting RGBW. Il n'est pas possible de contrôler Elero Lighting RGBW après l'avoir couplé avec le système si la sortie LED est éteinte lors de la procédure de reliure de finition. Connexion à la passerelle Correction d'erreurs et affichage incorrect des options dans les paramètres d'association. Validation de l'adresse IP corrigée dans l'onglet Connexion à la passerelle. Mauvais type de sauvegarde lors de la mise à jour du logiciel pour les hubs esclaves. Les appareils de différents réseaux physiques sont répertoriés comme destinations cibles dans les associations. KNX Correction d'une erreur de connexion KNX qui se produisait lors de la reconnexion après une longue période de temps. Correction d'un problème de reconnexion du pont KNX après avoir effectué une action de "configuration claire". Nice* Correction du paramètre de position préférée pour les périphériques d'écran qui ne le prend pas en charge nativement. Correction de la prise en charge du maintien en vie pour l'appareil Domi WSR/WS, ce qui faisait que l'appareil s'affiche comme déconnecté dans le système. Correction de problèmes avec les moteurs Nice PLN2+ contrôlés en tant que groupe à l'aide d'un périphérique lié. Correction de l'opération de certaines actions de groupe causant, entre autres, des dysfonctionnements dans les scènes. Correction d'un problème avec la suppression de l'appareil Domi WSR lorsque l'appareil est inactif. Autre Suppression d'une option non fonctionnelle (case à cocher) pour l'envoi de notifications sur la liste des appareils mobiles. Correction de la visibilité du nom de l'appareil lors de l'ajout de périphériques Z-wave dans l'application mobile. Correction du positionnement des info-bulles dans l'interface. Correction de l'écran de message affiché après avoir utilisé l'option de réinitialisation d'usine en mode de récupération. Correction de la gestion des événements à partir du plugin de caméra NICE lorsque des appareils sont ajoutés via NVR. Icônes fixes pour les plugins Sonos et XBMC. Correction des erreurs affichées dans l'onglet Z-wave du hub principal lors de l'utilisation de l'interface via l'accès à distance. Correction du validateur d'entrée pour les variables. Correction des actions de groupe non fonctionnelles dans les profils. Ajout d'un rafraîchissement en temps réel des entrées d'historique pour les événements Z-Wave Central Scene et les événements liés à la scène. Correction d'un problème où le redémarrage ne fonctionnait parfois pas correctement. Corrections mineures de l'interface utilisateur/de l'expérience utilisateur. Profils Correction d'un problème de déclenchement des changements via les profils. Applications rapides Paramètres supplémentaires autorisés à la fonction hub.alert dans QuickApp pour maintenir la rétrocompatibilité avec l'ancien code. La limite de caractères de la boîte d'édition variable a été augmentée de 1024 à 2048. Ajout de la prise en charge des fonctions de contrôle de la zone climatique dans QuickApps. Correction du redémarrage du processus d'application rapide lors de sa modification. Correction de l'activateur de chaleur qui a cessé de fonctionner dans de rares cas. Correction d'un problème d'enregistrement de la vue des applications rapides dans un fichier lors du cryptage (s'applique à l'assurance qualité exportée à partir de la version 5.191 ou ultérieure). Correction du problème selon lequel les réponses HTTP autres que 2xx (300 et plus) ne renvoient pas le corps de la réponse. Validation corrigée des noms de variables pour permettre l'édition des valeurs de variables existantes. Correction d'un problème avec l'affichage des icônes personnalisées pour les télécommandes dans Quick Apps. Scènes Correction d'un problème où les icônes autres que celles par défaut n'étaient pas affichées lors de la sélection de profils dans les scénarios. Correction du rafraîchissement du commutateur d'activité de la scène dans l'interface lors de l'appel de l'action d'activation/désactivation à partir du niveau de la scène. Correction du curseur de température de couleur inactif pour l'appareil Elero Lighting TW dans les scénarios créés dans l'application mobile. Correction du problème que net.HTTPClient supprime les paramètres de chaîne de requête dans les scènes LUA. Correction du comportement des curseurs dans les scènes de blocs pour l'action setColor, les curseurs fonctionnent désormais indépendamment. Correction d'une erreur selon laquelle la scène de blocage avec le réglage du mode manuel sur "Hold" ne fonctionne pas sur les hubs HC3L/YH. Optimisation de l'exécution de la scène. Correction d'un problème avec l'enregistrement d'un scénario prédéfini lorsque certains appareils sont sélectionnés. Mise à jour Déplacer le paramètre lié aux informations sur la version du système de l'étape finale du démarrage au point le plus tôt possible afin de réduire les données de version incorrectes en mode de récupération. Modification de l'ordre dans lequel les services commencent pendant l'initialisation pour éviter les problèmes lors des mises à jour. Correction du comportement de la barre de progression lors de l'annulation d'un téléchargement de mise à jour ; la barre de progression est maintenant masquée. Z-Wave Correction de l'arrêt redondant du moteur Z-Wave3. ** Correction de la visibilité des mises à jour pour les appareils Z-Wave sur les deux versions du moteur. * - Ne s'applique pas à HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. *** - Entièrement pris en charge dans la prochaine application Yubii v2.5.3 Sécurité : Mise à jour des vulnérabilités angulaires. Mise à jour de la version de la chaîne d'outils Rust. Modifié vendredi à 23:04 par fredokl
mprinfo Posté(e) il y a 9 heures Signaler Posté(e) il y a 9 heures Installer ce jour chez moiEnvoyé de mon Pixel 8 Pro en utilisant Tapatalk
