BenjyNet 1 200 Signaler ce message Posté(e) 16 mars 2014 T'as quoi dans le debug du main loop ? Active le àtrue dans le code. Tu peux aussi regarder dans le debug du bouton power voir ce qu'il se passe. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 16 mars 2014 @Domodial J'ai trouvé une boucle infinie dans le main loop qui plante l'ampli. Donc tu dois dans l'ordre : modifier le code du main loop avec celui-ci, éteindre l'alimentation complète de ton ampli (tu débranches) et tu rebranches. ------------------------------------------------------------- -- Plugin for Onkyo TX-NR626 receiver -- Use port 60128 -- Version 1.1.1 (04-16-2014) -- Author : Jean-christophe Vermandé modified by BenjyNet ------------------------------------------------------------- -- Change log 1.1.0 to 1.1.1 : -- Infinite loop in main loop rectified --------------------------------------------------------c[_]- fibaro:debug('Start process Main Loop v1.1.1'); local _deviceIp = fibaro:get(fibaro:getSelfId(), "IPAddress"); local _devicePort = fibaro:get(fibaro:getSelfId(), "TCPPort"); local _maxRetryProcess = 5; local _trace = false; -- Polling time (here = 1 min), you can change this local _polling = 1*60*1000; -- Name of your inputs, you can change this input = { [00] = "VIDEO1 - VCR/DVR", [01] = "VIDEO2 - CBL/SAT", [02] = "VIDEO3 - GAME/TV - GAME", [03] = "VIDEO4 - AUX", [04] = "VIDEO5 - AUX2", [05] = "VIDEO6 - PC", [16] = "BD/DVD", [34] = "PHONO", [35] = "TV/CD", [36] = "TUNER - FM", [37] = "TUNER - AM", [38] = "TUNER", [41] = "FRONT USB", [42] = "REAR USB", [43] = "NET", [46] = "BLUETOOTH" }; -- Name of your listenning modes, you can change this mode = { [00] = "STEREO", [01] = "DIRECT", [02] = "SURROUND", [03] = "GAME-RPG", [04] = "THX", [05] = "GAME-ACTION", [06] = "GAME-ROCK", [08] = "ORCHESTRA", [09] = "UNPLUGGED", [10] = "STUDIO-MIX", [11] = "TV LOGIC", [12] = "ALL CH STEREO", [13] = "THEATER-DIMENSIONAL", [14] = "GAME-SPORT", [15] = "MONO", [17] = "PURE AUDIO", [19] = "FULL MONO", [22] = "AUDISSEY DSX", [23] = "WHOLE HOUSE MODE", [35] = "STAGE", [37] = "ACTION", [38] = "MUSIC", [46] = "SPORTS", [64] = "STRAIGHT DECODE", [65] = "DOLBY EX", [66] = "THX CINEMA", [67] = "THX SURROUND EX", [68] = "THX MUSIC", [69] = "THX GAMES", [80] = "THX CINEMA 2, U2/S2/II/S CINEMA", [81] = "THX MUSIC MODE, THX U2/S2/II/S MUSIC", [82] = "THX GAMES MODE, THX U2/S2/II/S GAMES", [128] = "PLII/PLIIx MOVIE", [129] = "PLII/PLIIx MUSIC", [130] = "NEO:6 CINEMA/NEO:X CINEMA", [131] = "NEO:6 MUSIC/NEO:X MUSIC", [132] = "PLII/PLIIx THX CINEMA", [133] = "NEO:6/NEO:X THX CINEMA", [134] = "PLII/PLIIx GAME", [137] = "PLII/PLIIx THX GAMES", [140] = "NEO:6/NEO:X THX GAMES", [141] = "PLII/PLIIx THX MUSIC", [142] = "NEO:6/NEO:X THX MUSIC", [144] = "PLIIz HEIGHT", [148] = "PLIIz HEIGHT + THX CINEMA", [149] = "PLIIz HEIGHT + THX MUSIC", [150] = "PLIIz HEIGHT + THX GAMES", [151] = "PLIIz HEIGHT + THX U2/S2 CINEMA", [152] = "PLIIz HEIGHT + THX U2/S2 MUSIC", [153] = "PLIIz HEIGHT + THX U2/S2 GAMES", [154] = "NEO:X GAME", [160] = "PLIIx/PLII MOVIE + AUDISSEY DSX", [161] = "PLIIx/PLII MUSIC + AUDISSEY DSX", [162] = "PLIIx/PLII GAME + AUDISSEY DSX", [167] = "DOLBY EX + AUDISSEY DSX" }; -- Device parameters device = device or { id = fibaro:getSelfId(), power = 0, mute = 0, volume = 0, source = "unknown", lst_mode = "unknown" }; -- Functions' declarations ------------------------------------ function trace(value) if (_trace) then return fibaro:debug(tostring(value)); end end function split(pString, pPattern) local Table = {} local fpat = "(.-)" .. pPattern local last_end = 1 local s, e, cap = pString:find(fpat, 1) while s do if s ~= 1 or cap ~= "" then table.insert(Table,cap) end last_end = e+1 s, e, cap = pString:find(fpat, last_end) end if last_end <= #pString then cap = pString:sub(last_end) table.insert(Table, cap) end return Table end function getPowerState(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request Power STATUS, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1PWRQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Power STATUS command successufully transmited."); fibaro:sleep(50); -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "PWR%d%d"); if (cmd ~= nil) then trace(cmd); local pwr_value = tonumber(cmd:sub(4,5)); trace("Result OK : PWR" .. pwr_value); return pwr_value; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return nil; else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getPowerState(retry + 1); end return nil; end end function getVolumeLevel(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request Volume LEVEL, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1MVLQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Request Volume LEVEL command successufully transmited."); fibaro:sleep(50); retry = 0; -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "MVL.."); if (cmd ~= nil) then local vol_value = tonumber(cmd:sub(4, 5), 16); trace("Result OK : MVL" .. vol_value .. cmd); return vol_value; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return getVolumeLevel(0); else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getVolumeLevel(retry + 1); end return nil; end end function getSource(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request SOURCE, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1SLIQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Request SOURCE command successufully transmited."); fibaro:sleep(50); -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "SLI.."); if (cmd ~= nil) then local src_value = tonumber(cmd:sub(4, 5), 16); trace("Result OK : SLI" .. src_value .. cmd); return src_value; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return getSource(0); else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getSource(retry + 1); end return nil; end end function getMute(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request MUTE, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1AMTQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Request MUTE command successufully transmited."); fibaro:sleep(50); -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "AMT.."); if (cmd ~= nil) then local mute_value = tonumber(cmd:sub(4,5)); trace("Result OK : AMT" .. mute_value .. cmd); return mute_value; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return getMute(0); else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getMute(retry + 1); end return nil; end end function getLstMode(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request LISTENING MODE, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1LMDQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Request LISTENING MODE command successufully transmited."); fibaro:sleep(50); -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "LMD.."); if (cmd ~= nil and cmd ~= "LMDN/") then local mode_value = tonumber(cmd:sub(4,5), 16); trace("Result OK : LMD" .. mode_value .. cmd); return mode_value; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return getLstMode(0); else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getLstMode(retry + 1); end return nil; end end function getAudioOutMode(retry) local retry = retry or 0; local cmd = nil; --notify user trace("Request AUDIO OUT MODE, #" .. retry .. " please wait..."); --send packet bytes, errorCode = _tcpSocket:write("ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1IFAQSTN\0x1A\r\n"); -- check for error if errorCode == 0 then trace("Request AUDIO OUT MODE command successufully transmited."); fibaro:sleep(50); -- amplifier sould return the string sent if success while (cmd == nil and retry < _maxRetryProcess) do local result = _tcpSocket:read(); -- check if result is equal than command to confirm success trace("Result's lenght : " .. result:len() .. " " .. type(result)); cmd = string.match(result, "IFA(.+)\n"); if (cmd ~= nil and cmd:len() > 5) then trace(cmd .. cmd:len()); local audio_value = split(cmd,","); trace("Result OK : LMD" .. audio_value[5] .. cmd); return audio_value[5]; else trace("Result fail, retry process, #" .. retry .. " please wait..."); retry = retry + 1; end end return "STRAIGHT DECODE"; else if retry < _maxRetryProcess then trace("Retry process, please wait..."); fibaro:sleep(2000); return getAudioOutMode(retry + 1); end return nil; end end function refreshInterface() if (device.power == true) then local label = fibaro:getValue(device.id, "ui.lblPowerStatus.value"); if (label == "OFF") then fibaro:call(device.id, "setProperty", "ui.lblPowerStatus.value", "ON"); end -- update UI volume if (device.volume ~= nil) then fibaro:call(device.id, "setProperty", "ui.VolumeSlider.value", device.volume); end -- update UI input if (device.source ~= nil) then fibaro:call(device.id, "setProperty", "ui.lblInput.value", input[device.source]); end -- update UI mute if (device.mute ~= nil) then if (device.mute == 1 and label:match("Mutting") == nil) then local labelUpdated = label .. " - Mutting"; fibaro:call(device.id, "setProperty", "ui.lblPowerStatus.value", labelUpdated); elseif (device.mute == 0 and label:match("Mutting") == "Mutting") then local labelUpdated = label:gsub("%s[-]%sMutting", ""); fibaro:call(device.id, "setProperty", "ui.lblPowerStatus.value", labelUpdated); end end -- update UI mode if (device.lst_mode ~= nil) then fibaro:call(device.id, "setProperty", "ui.lblCurrentMode.value", device.lst_mode); end else fibaro:call(device.id, "setProperty", "ui.lblPowerStatus.value", "OFF"); fibaro:call(device.id, "setProperty", "ui.lblInput.value", "unknown"); fibaro:call(device.id, "setProperty", "ui.VolumeSlider.value", "0"); fibaro:call(device.id, "setProperty", "ui.lblCurrentMode.value", "unknown"); end return true; end function main() -- prepare a global counter if (_count == nil) then fibaro:debug("HC2 start script at " .. os.date()); _count = 0; end --notify begin of process fibaro:debug("Start process #".._count..", please wait..."); --open the socket if (_tcpSocket == nil) then _tcpSocket = Net.FTcpSocket(_deviceIp, _devicePort); --set the read timeout _tcpSocket:setReadTimeout(1000); end -- Query power status local power = getPowerState(); if (power == 1) then device.power = true; fibaro:debug("Power is ON "); fibaro:sleep(55); -- Query volume device.volume = getVolumeLevel(); fibaro:debug("Volume is "..device.volume); fibaro:sleep(55); -- Query source device.source = getSource(); fibaro:debug("Source selected is "..input[device.source]); fibaro:sleep(55); -- Query mute device.mute = getMute(); fibaro:debug("Mute is set to "..device.mute); fibaro:sleep(55); -- Query mode local temp = getLstMode(); fibaro:debug("Listenning Mode is set to "..mode[temp]); if (temp == 64) then fibaro:sleep(55); device.lst_mode = getAudioOutMode(); else device.lst_mode = mode[temp]; end elseif (power == 0) then device.power = false; fibaro:debug("Power is OFF "); else fibaro:debug("No Response... check later..."); end -- call refresh interface to repaint UI refreshInterface(); -- dispose socket if (_tcpSocket ~= nil) then -- close socket _tcpSocket:disconnect(); -- destroy object _tcpSocket = nil; end --notify end of process fibaro:debug("Process #".._count.." is finish!"); -- increment global counter _count = _count + 1; end -- Start main loop process main(); -- Sleep fibaro:sleep(_polling); -- EOF Main loop Partager ce message Lien à poster Partager sur d’autres sites
Domodial 351 Signaler ce message Posté(e) 17 mars 2014 Merci Ben ! Je test ce soir ! Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 17 mars 2014 Ok, par contre attend un peu lorsque tu l'auras débranché genre 5 min quoi. Puis tu rebranches, tu le rallumes et tu attends que les infos remontent correctement au VD. S'il y a encore des soucis, je pense qu'il faudra augmenter le polling jusqu'àtrouver un comportement optimum. Partager ce message Lien à poster Partager sur d’autres sites
Domodial 351 Signaler ce message Posté(e) 17 mars 2014 Bon, j'ai déjà injecté le code a distance. Reste plus qu'a tester ce soir. Encore merci Partager ce message Lien à poster Partager sur d’autres sites
Domodial 351 Signaler ce message Posté(e) 17 mars 2014 Ben, Fonctionne pas Mais qu'est-ce que tu as touché dans ton VD punaise ça fonctionnait avant ! Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 19 mars 2014 Arf moi aussi ça vient de me planter l'ampli. Il faut que je regarde le code, j'ai un Socket connection time out. Partager ce message Lien à poster Partager sur d’autres sites
Domodial 351 Signaler ce message Posté(e) 19 mars 2014 Etrange tout ça. Et en plus je ne trouve pas le passthroug dans les parametres de l'ampli.. ^^ Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 353 Signaler ce message Posté(e) 27 mars 2014 bonsoir merci pour ce bon boulot les premiers test sont ok sur mon ONKYO TX-NR717 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 28 mars 2014 @mprinfo Il y a quelques soucis, il manque des tests dans certains boutons. Je dois corriger mais j'ai pas le temps pour le moment, une future v1.1.1 Je vous tiens au courant. Faites moi remonter vos bugs s'il y en a. Partager ce message Lien à poster Partager sur d’autres sites
Moicphil 1 118 Signaler ce message Posté(e) 2 avril 2014 Benjy en tète d'affiche!!! http://blog.domadoo.fr/2014/04/02/controle-dun-ampli-onkyo-depuis-la-box-domotique-fibaro-hc2/ Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 2 avril 2014 Oh con ! Moi qui ait arrété de me prendre la tête sur les quelques bugs restant en attendant les plugins, par respect pour la communauté il va falloir que je me lance dedans après un article pareil. En tout cas merci àDomadoo et àMaximin. Partager ce message Lien à poster Partager sur d’autres sites
Maximin 0 Signaler ce message Posté(e) 3 avril 2014 Salut, Aucuns soucis, merci à toi pour ce superbe plugin qui valait bien un article Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 3 avril 2014 Oui bravo Benjy, c'est mérité Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 3 avril 2014 Huhu tu parles ! A côté de ce que tu fais c'est du pipi de chat Partager ce message Lien à poster Partager sur d’autres sites
Shad 315 Signaler ce message Posté(e) 3 avril 2014 Rohh, bravo même moi j'ai pas d'article Partager ce message Lien à poster Partager sur d’autres sites
Yohan 492 Signaler ce message Posté(e) 14 avril 2014 Petit Benjy deviendra grand ! Bravo ben Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 25 juillet 2014 J'ai installé ce device pour contrôler mon TX-NR709 mais rien qu'en testant le power on/off j'ai: [DEBUG] 21:29:23: Cannot send command ! Si quelqu'un a une idée je suis preneur Merci en tout cas pour ce device, même si ça ne marche pas chez moi. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 29 juillet 2014 Salut Icek, T'as bien paramétré le VD en mettant l'IP et le port correctement ? Si tu as ce message d'erreur c'est que ton ampli est injoignable. Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 29 juillet 2014 Salut Benjynet, Oui c'est le premier truc que j'ai fait. J'arrive d'ailleurs bien à la page web de l'Onkyo en tapant son IP. Le port est bien 60128. Je me demande si le problème ne vient pas de la chaine "ISCP\0\0\0\16\0\0\0\12\1\0\0\0\!1PWRQSTN\0x1A\r\n" qu'il ne comprendrait pas. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 29 juillet 2014 Bon alors dans le code de ton bouton power met àla ligne 9 local _trace = true; Et tu cliques sur le bouton power et tu pastes le résultat du debug ci-dessous... ou tu viens me voir sur le tchat Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 29 juillet 2014 ok. Alors j'ai: [DEBUG] 19:08:18: Start process POWER ON/OFF v1.1.0 [DEBUG] 19:08:18: Request Power STATUS, #0 please wait... [DEBUG] 19:08:18: Power STATUS command successufully transmited. [DEBUG] 19:08:18: Result's lenght : 110 string [DEBUG] 19:08:18: Result fail, retry process, #0 please wait... [DEBUG] 19:08:18: Result's lenght : 27 string [DEBUG] 19:08:18: Result fail, retry process, #1 please wait... [DEBUG] 19:08:20: Result's lenght : 0 string [DEBUG] 19:08:20: Result fail, retry process, #2 please wait... [DEBUG] 19:08:21: Result's lenght : 27 string [DEBUG] 19:08:21: Result fail, retry process, #3 please wait... [DEBUG] 19:08:21: Result's lenght : 27 string [DEBUG] 19:08:21: Result fail, retry process, #4 please wait... [DEBUG] 19:08:21: Cannot send command ! Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 29 juillet 2014 Bon déjà , la commande est bien transmise mais le résultat n'est pas bon. Il faudrait utiliser un logiciel pour observer ce qu'il passe sur les trames réseaux. Normalement dans la réponse on doit avoir un truc du genre PWR01 ou PWR00. Fait un telnet sur l'ip/port de ton ampli et clique sur mon bouton power. Regarde dans la fenêtre si tu vois passer un truc du genre : Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 29 juillet 2014 Je te file la version 1.0.2 pour tester les commandes de base. On verra déjàs'il réagit VD_Onkyo_TX-NR626_v1.0.2.zip Partager ce message Lien à poster Partager sur d’autres sites
Icek 3 Signaler ce message Posté(e) 29 juillet 2014 Ca marche! Maintenant, je vais regarder le code de près pour voir où ça coince avec la dernière version. Merci beaucoup pour le coup de main. Partager ce message Lien à poster Partager sur d’autres sites
