Allan2b Posté(e) 18 janvier 2016 Signaler Share Posté(e) 18 janvier 2016 Bonjour je viens de lire un article sur http://fibarolife.com sur les widgets, je savais que c'était possible depuis la dernier version sur Android mais je l'ignorais sur IOS. mois qui suis sur IOS ça marche très bien. Source : http://fibarolife.com/fibaro-mobile-app-install-widgets/# How to create a widgets Android OS Follow the instructions below to create a new widget for an Android device:1) Launch the FIBARO mobile application.2) Login to the FIBARO Home Center.3) Open the home screen of your smartphone.4) Press and hold on the home screen that you want to place the scene widget on. Depending on your device, you may need to tap Apps and Widgets, or a similarly-named menu option.5) Press and hold on the Fibaro widget, then drag it to the home screen. There will need to be space on the home screen to successfully add a new widget.6) Select one of the listed scenes.*7) In case of an error message, go back to step 1.8) Run the scene’s widget by tapping its icon (successful triggering of the scene will be confirmed with a message). * – You can add as many scene’s widgets as you want to your home screen, as you like, but only it must be done one widget after at a time.another. Remarks:– Each widget may be resized to meet the user’s needs.– You can add the widgets on as many different home screens as you wishwant.– The current version of the FIBARO application app allows to run only widgets to only run from the connected gateway.– There is no possibility to add the widget for a Magic scene or for scene protected by the a PIN code. iOS Follow the instructions below to create a new widget for an Apple device:1) Swipe down from the top of the screen of your iPhone to open the Notification Center.*2) Tap on “Today†if it isn’t already selected.3) Scroll down to the bottom of the screen.4) Tap on the “Edit†button.5) Under the “Do Not Include†section, tap on the green plus sign next to the Fibaro FIBARO widget to include it in your Today view.6) Tap “Done†in the top right corner. The Fibaro FIBARO widget will appear in the Notification Center with other Today widgetsin the Today section.7) Tap “Configure†to adjust the widget -– the Fibaro FIBARO app will be opened.8) Select the scenes you would like to add from the list shown.**9) Click the “Save†button to confirm your selection. Saving without any no scenes selected will results in removing of previously added scenes.***10) Correct A successful addition of the widget will results in the screen looking like the below screenshot. setting the widget like on the attached screenshot. ClickTo launch the scene, tap the icon. the icon of the scene to launch it. * – iPhone running iOS 8 or higher is required.** – iOS app allows for adding max. 4 different scenes to the ‘Today’ tab.*** – In such case the appropriate message will be displayed. Remarks:– Scenes must be run one at a time and cannot happen all at once. During the startup of the scene, possibility to run another scene is locked.– Widgets may be also configured through the FIBARO applicationapp. To do so, launch the app, go to Settings and click Configure to select scenes for the widget.– The current version of the FIBARO app allows widgets to only run from the connected gateway.The current version of the application allows to run only widgets from the connected gateway.– There is no possibility to add the widget for a Magic scene or for scene protected by a PIN code.There is no possibility to add the widget for Magic scene or for scene protected by the PIN code. 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sakkhho Posté(e) 18 janvier 2016 Signaler Share Posté(e) 18 janvier 2016 Cool je viens de regarder; Valable que pour les scenes, c'est dommage, un petit VD ca aurait été sympathique Lien vers le commentaire Partager sur d’autres sites More sharing options...
Domodial Posté(e) 19 janvier 2016 Signaler Share Posté(e) 19 janvier 2016 Oui pareil je ne connaissais pas, c'est assez génial ! Dommage que cela ne s'applique qu'aux scènes. Je ne savais pas non plus qu'il était possible de réorganiser l'ordre des icons dans l'appli elle meme. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Allan2b Posté(e) 19 janvier 2016 Auteur Signaler Share Posté(e) 19 janvier 2016 Il me semble que quand tu ouvre ton appli les icônes reviennent en position, ça ne garde pas en mémoire les changements . sur iPhone en tout cas c'est comme ça Lien vers le commentaire Partager sur d’autres sites More sharing options...
MasterBT Posté(e) 19 janvier 2016 Signaler Share Posté(e) 19 janvier 2016 C'est un bon rappel ce post! GG. Aprés faut juste faire des scène qui pointe vers le VD qui va bien. Ps: moi les icons reste à leur place même aprés reboot. Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) 19 janvier 2016 Signaler Share Posté(e) 19 janvier 2016 Allan, merci pour ton topo donnant vue sur ces dernières fonctionnalités Lien vers le commentaire Partager sur d’autres sites More sharing options...
Domodial Posté(e) 20 janvier 2016 Signaler Share Posté(e) 20 janvier 2016 Il me semble que quand tu ouvre ton appli les icônes reviennent en position, ça ne garde pas en mémoire les changements . sur iPhone en tout cas c'est comme ça Elles restent bien en place de mon coté même après avoir killed l'appli. Lien vers le commentaire Partager sur d’autres sites More sharing options...
MasterBT Posté(e) 20 janvier 2016 Signaler Share Posté(e) 20 janvier 2016 Par contre j'ai connection Error, que ca soit en Wifi ou 4G. Lien vers le commentaire Partager sur d’autres sites More sharing options...
djtic Posté(e) 20 janvier 2016 Signaler Share Posté(e) 20 janvier 2016 Bonjour, j'ai le même problème --> connection error ! à chaque essai, et quelque soit le type de connexion. Lien vers le commentaire Partager sur d’autres sites More sharing options...
MasterBT Posté(e) 20 janvier 2016 Signaler Share Posté(e) 20 janvier 2016 On va attendre la V5, et on aura le Gps de l'appli qui va marcher Lien vers le commentaire Partager sur d’autres sites More sharing options...
