Widgets Android Et Ios
Allan2b
Bonjour je viens de lire un article sur http://fibarolife.com sur les widgets, je savais que c'était possible depuis la dernier version sur Android mais je l'ignorais sur IOS.
mois qui suis sur IOS ça marche très bien.
Source : http://fibarolife.com/fibaro-mobile-app-install-widgets/#
How to create a widgets
Follow the instructions below to create a new widget for an Android device:
1) Launch the FIBARO mobile application.
2) Login to the FIBARO Home Center.
3) Open the home screen of your smartphone.
4) Press and hold on the home screen that you want to place the scene widget on. Depending on your device, you may need to tap Apps and Widgets, or a similarly-named menu option.
5) Press and hold on the Fibaro widget, then drag it to the home screen. There will need to be space on the home screen to successfully add a new widget.
6) Select one of the listed scenes.*
7) In case of an error message, go back to step 1.
8) Run the scene’s widget by tapping its icon (successful triggering of the scene will be confirmed with a message).
Screenshot_20160113-154759-576x1024.pngScreenshot_20160113-154604-576x1024.pngScreenshot_20160113-161148-576x1024.png
* – You can add as many scene’s widgets as you want to your home screen, as you like, but only it must be done one widget after at a time.another.
Remarks:
– Each widget may be resized to meet the user’s needs.
– You can add the widgets on as many different home screens as you wishwant.
– The current version of the FIBARO application app allows to run only widgets to only run from the connected gateway.
– There is no possibility to add the widget for a Magic scene or for scene protected by the a PIN code.
Follow the instructions below to create a new widget for an Apple device:
1) Swipe down from the top of the screen of your iPhone to open the Notification Center.*
2) Tap on “Today†if it isn’t already selected.
3) Scroll down to the bottom of the screen.
4) Tap on the “Edit†button.
5) Under the “Do Not Include†section, tap on the green plus sign next to the Fibaro FIBARO widget to include it in your Today view.
6) Tap “Done†in the top right corner. The Fibaro FIBARO widget will appear in the Notification Center with other Today widgetsin the Today section.
7) Tap “Configure†to adjust the widget -– the Fibaro FIBARO app will be opened.
8) Select the scenes you would like to add from the list shown.**
9) Click the “Save†button to confirm your selection. Saving without any no scenes selected will results in removing of previously added scenes.***
10) Correct A successful addition of the widget will results in the screen looking like the below screenshot. setting the widget like on the attached screenshot. ClickTo launch the scene, tap the icon. the icon of the scene to launch it.
* – iPhone running iOS 8 or higher is required.
** – iOS app allows for adding max. 4 different scenes to the ‘Today’ tab.
*** – In such case the appropriate message will be displayed.
Remarks:
– Scenes must be run one at a time and cannot happen all at once. During the startup of the scene, possibility to run another scene is locked.
– Widgets may be also configured through the FIBARO applicationapp. To do so, launch the app, go to Settings and click Configure to select scenes for the widget.
– The current version of the FIBARO app allows widgets to only run from the connected gateway.The current version of the application allows to run only widgets from the connected gateway.
– There is no possibility to add the widget for a Magic scene or for scene protected by a PIN code.There is no possibility to add the widget for Magic scene or for scene protected by the PIN code.
  • Upvote 3
Il me semble que quand tu ouvre ton appli les icônes reviennent en position, ça ne garde pas en mémoire les changements .
sur iPhone en tout cas c'est comme ça
Elles restent bien en place de mon coté même après avoir killed l'appli.
