nickrdtp 5 Signaler ce message Posté(e) 2 février 2016 (modifié) Attention : Changelogs différents pour HCL et HC2 Home Center Lite Version 4.071 Beta WARNING: Beta version is designed for user testing and soon should be released as official. Resolved issues: - #0002290 #0003353 Devices with sceneActivation are not available in Block and Magic scenes - No user icons in Remote Access - Gateway Connection - devices with polling interface are not being imported - 503 error when including blind controller from some manufacturers - Delays in Z-wave network after setting RGBW Controller to desired level New devices support: - Z-Wave.Me ZMR WCS 6 v1.4 - Z-Wave.Me On Off Switch - Z-Wave.Me FB10 v1.1 - Z-Wave.Me Wall Controller v1.1 - Z-Wave.Me TZ68 g v1.0 - NodOn Octan Remote v2.3 - Philio PSM02 4 in 1 Sensor v1.0 - EMINENT EM6570 - EMINENT EM6550 - TKB Home Wall Plug v1.1 - TKBHome TZ67 v1.12 - Reitz Group ZW ESJ v1.0 - Reitz Group ZS 3500 v1.0 - Reitz Group IP44 On Off Switch v1.0 - FortrezZ LLC-SSA03 v2.5 - GreenWave Powernode v4.27 - Qees Remote Controller v0.5 - Jasco Products Wall Outlet v1.16 - Jasco Products ZW3003 - Jasco Products ZW4101 - Everspring HAC01 v2.0 - BeNext-Dimmer - BeNext-Forest Curtain rail with motor - wiDom-Universal Power Meter v1.30 - Popp Dimmer v1.0 - Popp On Off Socket v1.0 - CBCC Sarl-Swiidinter - Aeon Labs SES G2 - Aeon Labs Aeotec Smart Energy Power Strip (DSC11-ZWUS) - Aeon Labs Micro Smart Energy Switch - Aeon Labs Recessed Door Sensor - Aeon Labs DSC26103 - Vision ZR1202 v1.74 - Vision Security ZS5101 v1.65 - Kwikset-Smart Code 916 v3.37 - Yale-T1L v18.128 - Yale Door Lock v80.32 - RTC-CT100 Thermostat v9.1 Other improvements: - Improved stability - PIN dfor new user is now set to '1111' by default - In case of empty user PIN, it is set to default value - '1111' - filters in /api/devices that allows for filtering out devices that meet some requirements, examples: HC IP/api/devices?visible=true returns devices with visible equal to 'true' HC IP/api/devices?property=[batteryLevel,100] returns devices with property batteryLevel equal to 100 HC IP/api/devices?interface=light returns devices with light interface Multiple filters can be used together, for example: HC IP/api/devices?visible=true&interface=light returns devices with visible equal to 'true' and with 'light' interface Home Center 2 Version 4.071 Beta WARNING: Beta version is designed for user testing and soon should be released as official. Resolved issues:- #0002290 #0003353 Devices with sceneActivation are not available in Block and Magic scenes- No user icons in Remote Access- Gateway Connection - devices with polling interface are not being imported- 503 error when including blind controller from some manufacturers- Delays in Z-wave network after setting RGBW Controller to desired level- Lua scenes: inappropriate line number in error debug New devices support:- Z-Wave.Me ZMR WCS 6 v1.4- Z-Wave.Me On Off Switch- Z-Wave.Me FB10 v1.1- Z-Wave.Me Wall Controller v1.1- Z-Wave.Me TZ68 g v1.0- NodOn Octan Remote v2.3- Philio PSM02 4 in 1 Sensor v1.0- EMINENT EM6570- EMINENT EM6550- TKB Home Wall Plug v1.1- TKBHome TZ67 v1.12- Reitz Group ZW ESJ v1.0- Reitz Group ZS 3500 v1.0- Reitz Group IP44 On Off Switch v1.0- FortrezZ LLC-SSA03 v2.5- GreenWave Powernode v4.27- Qees Remote Controller v0.5- Jasco Products Wall Outlet v1.16- Jasco Products ZW3003- Jasco Products ZW4101- Everspring HAC01 v2.0- BeNext-Dimmer- BeNext-Forest Curtain rail with motor- wiDom-Universal Power Meter v1.30- Popp Dimmer v1.0- Popp On Off Socket v1.0- CBCC Sarl-Swiidinter- Aeon Labs SES G2- Aeon Labs Aeotec Smart Energy Power Strip (DSC11-ZWUS)- Aeon Labs Micro Smart Energy Switch- Aeon Labs Recessed Door Sensor- Aeon Labs DSC26103- Vision ZR1202 v1.74- Vision Security ZS5101 v1.65- Kwikset-Smart Code 916 v3.37- Yale-T1L v18.128- Yale Door Lock v80.32- RTC-CT100 Thermostat v9.1 Other improvements:- PIN dfor new user is now set to '1111' by default- In case of empty user PIN, it is set to default value - '1111'- New actions in Lua scenes: - fibaro:call(ID, 'startLevelIncrease', x, y)- fibaro:call(ID, 'startLevelDecrease', x, y)- fibaro:call(ID, 'stopLevelChange') These calls can be used to start increasing or decreasing Multilevel Switches (like Dimmer 2, RGBW or Roller Shutter 2 modules) value. 'x' and 'y' are optional parameters, used to set respectively time frame in which change should be applied and starting level. 'stopLevelChange' stops previously send action. - fibaro:getDevicesId(x) Call used to get table with IDs of devices that meet requirement specified by 'x'. Examples: print('All devices with parameter visible equal to "true" and enabled equal to "true":')ids = fibaro:getDevicesId({visible = true, enabled = true})print(json.encode(ids)) print('ALl devices with energy interface:')ids = fibaro:getDevicesId({interfaces ={"energy"}})print(json.encode(ids)) print('All devices with 'unit' property (no matter its value):')ids = fibaro:getDevicesId({properties = {unit="nil"}})print(json.encode(ids)) - filters in /api/devices that allows for filtering out devices that meet some requirements, examples: HC IP/api/devices?visible=true returns devices with visible equal to 'true'HC IP/api/devices?property=[batteryLevel,100] returns devices with property batteryLevel equal to 100HC IP/api/devices?interface=light returns devices with light interface Multiple filters can be used together, for example: HC IP/api/devices?visible=true&interface=light returns devices with visible equal to 'true' and with 'light' interface Modifié 3 février 2016 par Lazer 1 Partager ce message Lien à poster Partager sur d’autres sites
nickrdtp 5 Signaler ce message Posté(e) 2 février 2016 J'ai bien envie de me lancer, vu les bons retour de la v4.70 sur hc2.... Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 2 février 2016 il y avait donc bien un problème en 4.070 lol Partager ce message Lien à poster Partager sur d’autres sites
klael 5 Signaler ce message Posté(e) 2 février 2016 Oh. Elle est déjàdispo, mais je vais patienter jusqu’àce week end pour l'installer... Partager ce message Lien à poster Partager sur d’autres sites
Moicphil 1 109 Signaler ce message Posté(e) 2 février 2016 Mise à jour faite...tout est Ok, Partager ce message Lien à poster Partager sur d’autres sites
nickrdtp 5 Signaler ce message Posté(e) 2 février 2016 c'est parti, ça ne sera pas pire que la 4.058.... Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 2 février 2016 Je vais attendre demain car ce soir pas trop envi lol Envoyé de mon SM-G900F en utilisant Tapatalk Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 2 février 2016 Bon je lance et vais regarder un film pendant ce temps Edit 1 :Par contre niveau Template ils se lâchent là Edit 2 : Bon j'ai appuyé, go film. Partager ce message Lien à poster Partager sur d’autres sites
nickrdtp 5 Signaler ce message Posté(e) 2 février 2016 Update error... Et depuis je ne peux plus faire l'update. Plus de bouton malgré relance, vidage cache, changement de pc... Je verrai demain. Un petit film aussi... Partager ce message Lien à poster Partager sur d’autres sites
Alexcane 1 Signaler ce message Posté(e) 2 février 2016 j'ai eu le même problème sur HCL, on verra plus tard.... Partager ce message Lien à poster Partager sur d’autres sites
Nico 2 148 Signaler ce message Posté(e) 2 février 2016 Moi c'est passé, toujours assez long, mais propre au reboot. Film encours, je laisse et reviendrai voir après les news. Partager ce message Lien à poster Partager sur d’autres sites
sebcbien 1 508 Signaler ce message Posté(e) 2 février 2016 Bon je lance et vais regarder un film pendant ce temps Edit 1 :Par contre niveau Template ils se lâchent là Edit 2 : Bon j'ai appuyé, go film. Mais pas un seul qubino.... C voulu vous croyez ? Sent from my Note4 5 Partager ce message Lien à poster Partager sur d’autres sites
Jayce74 37 Signaler ce message Posté(e) 2 février 2016 il y avait donc bien un problème en 4.070 lol Je confirme mais je vois pas ou p-e le moteur zwave... je suis passé en 4.070 il y a 4 jours et ce soir en rentrant toutes mes lumières étaient allumées, certaines scènes bug ou se déclenchent hors de leurs scope (gestion horaire) donc je plussoie. Bref le coté WAF en a encore prit un coup avec cette histoire de lumières.. sans compter des dimmers qui ne répondent plus physiquement (via smartphone ok) Je vais tenter l'update plus tard ce soir Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 2 février 2016 Mais pas un seul qubino.... C voulu vous croyez ? Sent from my Note4 J'ai pas osé la faire cela lolEnvoyé de mon SM-G900F en utilisant Tapatalk 1 Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 2 février 2016 Cliqué Partager ce message Lien à poster Partager sur d’autres sites
Rocketlud 286 Signaler ce message Posté(e) 2 février 2016 Je passe mon tour, sont trop stable les bêtas !!!!!!! Je préfère le pile ou face dès stables LOL 3 Partager ce message Lien à poster Partager sur d’autres sites
Jayce74 37 Signaler ce message Posté(e) 2 février 2016 les stables pas stables et les betas stables. ou l'inverse. Merci Fibaro On se croirait dans Matrix, bref je prend une pilule et on verra ! Pour moi c'est la bleu de l'upgrade car Madame voit rouge ce soir 2 Partager ce message Lien à poster Partager sur d’autres sites
nickrdtp 5 Signaler ce message Posté(e) 2 février 2016 finalement le bouton est revenu et la mise est jour est faite. reste plus qu'àtester!!! Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 2 février 2016 Madame ne s'est rendue compte de rien (pourvu que ça dure) 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 2 février 2016 Tu vies dans le noir lol Finalement j'ai craqué J'ai fais la mise àjour via mon tel J'avais la flemme de bouger de ma banquette lol Envoyé de mon SM-G900F en utilisant Tapatalk 2 Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 2 février 2016 Non, mais j'ai un avantage quand elle râle je ne comprends rien (en Japonais) 4 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 332 Signaler ce message Posté(e) 2 février 2016 Tu sais même en français une femme qui rale c'est difficile àcomprendre. Je me dis tout va bien lol Envoyé de mon SM-G900F en utilisant Tapatalk 3 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 2 février 2016 ah làlàlàje suis grave tenté d'installer une beta stable, car ma stable pas stable me gave comme vous le savez 3 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 457 Signaler ce message Posté(e) 2 février 2016 les nouveautés sur l'API sont super !!!! rien que pour ça, la mise àjour vaut le coup Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 2 février 2016 Si qu'un fait la mise à jour et à une powernode je suis intéressé par - GreenWave Powernode v4.27 bon j'ai une 4.28 mais le template doit être la maintenant idem pour - CBCC Sarl-Swiidinter Partager ce message Lien à poster Partager sur d’autres sites
