mprinfo
    14578
    266
  1. oups dsl moi aussi j'ai voulu dire 1.1 je viens de tester DANFOSS LC13 Firm 1.0 et 1.1 sont tous ok chez moi
  2. @nico ta danfoss etait en firm 2.1 ?
  3. KriKroff : erreur réparer dsl 2 mises a jour en une soirée du jamais vu....
  4. Fibaro Home Center 2 v 4.023 BETA. Beta version is designed for user testing and soon will be released as official. WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window. This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1). If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start. 4.023: New Features Soft Reconfiguration option allows you to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID. Resolved Issues #0001986: Not able to change params #0002126: New Switch reconfigure Problem #0002189: Danfoss LC13 E5 error after few days. Fixed problem with some Z-Wave locks battery reports Fixed problem with controlling blind lamels via web interface Communication with Satel devices improved (response time reduced) Known issues Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code. Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Plugin for Sony TV will not work with newest Sony Firmware Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly
  5. oui la on as tous merdu sur ce coup la il n'y a pas que fibaro qui fait des erreurs .....
  6. il y a du y avoir une erreur de frappe dans le numéro de version lors de la mise en ligne dur dur les soirées en Pologne....
  7. Soirée Vodka chez Fibaro ce soir :60:
  8. Installation en cours
  9. ils nous font quoi chez fibaro pourquoi ne pas l'avoir appeler 4.023 ? ils doivent vouloir sortir la 4.025 pour noël c'est pas possible
  10. @Krikroff Je n ai pas de FGMS Ni de flood sensor J'ai 3 fibaro unversel 1 qui ce trouve au grenier et qui me donne des alerte fire Les 2 autres sont juste a côté de la hc2 est la aucun problème peut il y avoir un problème lorsque les données sont retransmis par d autres modules ?
  11. FGRM222
  12. les remontés de température sont parfois erroné j' utilise ce module juste avec 4 sondes. Si tout fonctionne bien chez toi je te conseil d'attendre encore un peu
  13. Ok merci pour l info benjynet
  14. petit conseil pour les sondes dallas utilisé un fil par pair cela évite les effets de self
  15. pour les problémes avec les modules il serait bien d'indiqué la version du firm du module cela permettra de mieux identifier les problémes car je pense que pas mas de bug sont du a des version différente de firm
  16. j'ai aussi fais un test avec 4 sondes soudées et très peu de distance de fils tout était ok je conseil donc de prendre cable de bonne voir de tres bonne qualité pour connecté les sondes le top serait du cat6 ACOME – Câble Grade 3 Sat, MTVS Acohomemais a 1 euros le mètre ca fait un peu chère. ce qui ma mis la puce a l'oreille j'avais un reste de câble PTT de qualité correcte et pas de soucis, j'ai voulu ajouter des sondes j'ai donc acheté du câble TEL chez bricodépot pour des sondes et un voltage de 3.3v je suis dis ce sera bien bon c'est la ou je me suis trompé et que les problèmes d'alerte feu sont arrivés
  17. Indiqué la ver du firm de votre module cela permettra de mieux identifier les problèmes
  18. Moi j'ai la même chose avec mais sondes dallas je sais pas si cela viens de la sonde du fibaro unversel ou de la v4 mais je pencherai plus a un problème entre la sonde et le module universel
  19. je viens de faire une inclusion exclusion d'une tête LC13 ver1.01 toujours le même problème reconnu comme thermostat alors que ma danfoss en ver1.0 fonctionne très bien
  20. je pense que la v4 a de gros probléme du fait qu il y a plus version de firm pour un meme module il serait bon de préciser le module ainsi que la version du firm lors de nos dialogues pour danfoss ver 1.01 petit soucis sur la boite du module ver 1.01 dans l'interface de la HC2 ver 1.1 encore du boulot chez fibaro je crois que ca va pas être pour noél :(
  21. je précise que j'ai inclus mes danfoss avec la version 4.021 pour la version 1.0 il n' y a aucun probléme l'icone est la bonne on peut donc modifier la température ainsi que la durée
  22. si vous avez cette boite il sagit de la LC13 Ver1.0 pour la lc13 ver1.01 en plus le sigle Zwave ainsi que l'inscription SW 1.01 SPEAKS
  23. comment reconnaitre la danfoss Lc13 v1.0 ou v1.01
  24. Probléme Danfoss LC13 Firm 1.0 la danfoss apparait bien avec la bonne icone Firm 1.1 la danfoss apparait avec l'icone d'un thermostat
  25. @Allan2b j'ai eu la même chose hier mais aujourd’hui' ça fonctionne
