TonyC 457 Signaler ce message Posté(e) 28 mai 2020 Changelog : (je vais le mettre un peu en forme ds qlqs minutes) ... Access Dark Theme - come to the dark side! Possibility to switch active theme automatically based on sunrise and sunset. Alarm Added column with zone ID and missing labels. Block Scenes Option to set time for which triggering device has not changed its state. Shorter loading time for items in the drop-down lists. Dashboard Displaying camera image preview on the right sidebar. Displaying both temperatures on the device tile for thermostat in auto or away mode. Enlarged area on the device tile which opens the right sidebar. Possibility to control slats of rollerShutter devices from the right sidebar. Displaying device ID on the right sidebar. Displaying humidity measured by humidifier on the device tile. Devices Temperature history charts for temperature sensors in device Advanced tab. Smoke history charts for FIBARO smoke sensors in device Advanced tab. Added possibility not to hide included devices when creating linked device. Possibility of moving to hidden device from linked devices family view. Support for Dome Siren (DMS01). Support for Dome Water Main Shut-Off (DMWV1). Support for Eurotronics Spirit TRV. Support for Sensative Strips Comfort. Support for Sensative Strips Drip. Early Access Features Support for Nice mono-directional devices using Flor and Opera communication protocols. Displaying Nice devices on system dashboard with control from the right sidebar. Nice devices available as actors in scenes and profiles. General Deactivated possibility of changing time zone when using manual time setting. Improved readability of current system configuration report. Improved layout and readability of the map displayed in Location. Lua Scenes Added HTTP and HTTPS clients support. Other Swagger and full-screen console available in remote access. Default console filters applied automatically depending on from where has been opened. Quick Apps Displaying generic and custom device view together on the right sidebar. Autocompletion of used functions and variables. Asynchronous sending of actions to prevent blocking the interface by awaiting requests. Added fibaro.clearTimeout function. Added three thermostat device types (auto, cool, heat). Plugins Support for IP Cameras using Digest authentication. Recovery Mode Eight new languages (de, fr, es, it, nl, no, sv, cs). Scenes Copied or converted scene keeps the same running mode as source scene. Scene view is expanded after its copying or converting. Added column with scene ID. Bug fixes: Backup Backup is not saved if its name contains special characters. Block Scenes No conditions and actions for FIBARO Walli Roller Shutter (FGWREU-111). Redundant fields in Philips Hue plugin blocks. Dashboard Multi-digit values do not fit the device tile and display incorrectly. No weather data when using external weather provider. Devices Sprinkler linked device is assigned to Lights category instead of Climate. Lua Scenes Function fibaro.getGlobalVariable does not work properly. Notifications E-mail notifications are sent to previous admin after transferring role to another user. Rejecting \n, \t and ' in notifications content. Other Time in backups, diagnostics, notifications, and general settings ignores set time zone. User can see events from devices without sufficient access rights. Plugins Incorrect state of devices belonging to Philips Hue plugin. Cannot remove YR Weather plugin. Quick Apps Incorrect operation of autocompletion. Switching to https results in console errors when using localhost (127.0.0.1). Code of large Quick App disappears after performing update. Update No reboot after performing update in some cases. Trying to install downloaded update in some cases results in error 502. Z-Wave Energy data is not removed from all endpoints of the device. 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 tricheur Dark Theme - come to the dark side! Possibility to switch active theme automatically based on sunrise and sunset. Lua Scenes Added HTTP and HTTPS clients support. 1 Partager ce message Lien à poster Partager sur d’autres sites
TonyC 457 Signaler ce message Posté(e) 28 mai 2020 tricheur toi même Puis maintenant faut se cogner la mise en page ou attendre la publication sur le fofo officiel qui prend toujours des plombes! 1 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 @tonyc ajoute cela ca fera plus jolie alors Stable ou Beta faut préciser Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 Ce n'est pas un souci, mprinfo va nous développer un QA qui poste automatiquement le changelog de chaque nouvelle mise à jour sur le forum, avec le formatage qui va bien Voilà, mise à jour effectuée Le dark theme a changé par rapport au firmware précédent, faut aimer l'orange.... bizarre, comme la couleur cuivrée des LED. Je préférais le bleu perso 5 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 28 mai 2020 Oh con ça va finir par ressembler à la livebox 1 Partager ce message Lien à poster Partager sur d’autres sites
fredokl 432 Signaler ce message Posté(e) 28 mai 2020 (modifié) MAJ effectué avec succès et rapidement avec ça! Je viens de tester le mode dark que j'attendais depuis le début mais finalement je trouve assez bof ce mélange de noir et orange. Et vous vous en pensez quoi? Modifié 28 mai 2020 par fredokl Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 Ah, ils ont remis la fenêtre de débug en dark theme, tu vas être content Pascal Voici un aperçu du dashboard : au moins on peut dire qu'ils ont assorti le theme avec l'apparence physique de la box 1 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 28 mai 2020 Ah ! Ça va, ça fait chicos, genre doré/noir. Une box d'élites ! Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 bling bling 1 Partager ce message Lien à poster Partager sur d’autres sites
TonyC 457 Signaler ce message Posté(e) 28 mai 2020 il y a 7 minutes, mprinfo a dit : ajoute cela ca fera plus jolie alors Stable ou Beta faut préciser Chef oui chef, c'est fait chef ! Plus de notion de stable ou béta n'existe plus dans le jargon tout est STABLE maintenant ! Partager ce message Lien à poster Partager sur d’autres sites
TonyC 457 Signaler ce message Posté(e) 28 mai 2020 il y a 7 minutes, fredokl a dit : Et vous vous en pensez quoi? Pas encore regardé je faisais de la mise en page en attendant le plugin de @mprinfo Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 28 mai 2020 y a pas le multi instance de scènes Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 Passé l'effet de surprise orange, je dois dire que je préfère (je change d'avis en 5 minutes moi ) Les couleurs choisies sont plus contrastées et bien lisibles, ça donne une interface plus claire en fin de compte. PS : à quand un theme dark sur le forum Toujours pas de bouton pour changer l'icone des Quick Apps. 1 Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 28 mai 2020 Est-ce que vous l'avez testée avec Alexa cette box ? Moi c'est plus que primordial ! Edit : Les cartons sont toujours d'actualité ? C'est moche ça sur l'interface. Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 28 mai 2020 avec google home c'est nickel Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 il y a 1 minute, jjacques68 a dit : y a pas le multi instance de scènes tu as deja cela toi le fan du timeout Ajout de la fonction fibaro.clearTimeout. Partager ce message Lien à poster Partager sur d’autres sites
BenjyNet 1 200 Signaler ce message Posté(e) 28 mai 2020 Merde, j'ai l'autre Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 28 mai 2020 il y a 1 minute, mprinfo a dit : tu as deja cela toi le fan du timeout oui ok mais c'est pas pareil... suis déçu. Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 il y a 2 minutes, Lazer a dit : Passé l'effet de surprise orange, je dois dire que je préfère (je change d'avis en 5 minutes moi ) Les couleurs choisies sont plus contrastées et bien lisibles, ça donne une interface plus claire en fin de compte. PS : à quand un theme dark sur le forum Toujours pas de bouton pour changer l'icone des Quick Apps. combien de fois il faut que je te dise que tu dois avoir des gênes de femme entre râler après les livreurs et la j'ai plus aucun doute 2 Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 il y a 2 minutes, BenjyNet a dit : Edit : Les cartons sont toujours d'actualité ? C'est moche ça sur l'interface. Je n'ai pas caché tous les devices sans intérêt. Les cartons que tu vois, ce sont les QA de type générique... dont on ne peux toujours pas changer l'icone (enfin si, mais faut passer par l'API, Fibaro n'a pas encore codé le bouton qui va bien) Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 il y a 1 minute, jjacques68 a dit : oui ok mais c'est pas pareil... suis déçu. tu veux un câlin Partager ce message Lien à poster Partager sur d’autres sites
jjacques68 602 Signaler ce message Posté(e) 28 mai 2020 Partager ce message Lien à poster Partager sur d’autres sites
mprinfo 3 342 Signaler ce message Posté(e) 28 mai 2020 il y a 1 minute, Lazer a dit : Je n'ai pas caché tous les devices sans intérêt. Les cartons que tu vois, ce sont les QA de type générique... dont on ne peux toujours pas changer l'icone (enfin si, mais faut passer par l'API, Fibaro n'a pas encore codé le bouton qui va bien) pour changer l’icône c'est possible tu fais comme avec la HC2 il faut juste recéper le numéro de icone self:updateProperty("deviceIcon", 1001) Partager ce message Lien à poster Partager sur d’autres sites
Lazer 8 486 Signaler ce message Posté(e) 28 mai 2020 Bah merci c'est ce que je dis... et l'astuce a déjà été partagée Je m'en fous moi des icones, c'est une box de dév, et ça va le rester quelques mois Graph de température : Partager ce message Lien à poster Partager sur d’autres sites
