HC3 & HC3L - 5.183.63 - BETA - 11/09/2025
Firmware 5.183.63
BETA
11/09/2025
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Elero
DuoSON-868 device integration.
AstroSON-868 device integration.
Nice*
Cleaned up the system devices model for monodirectional devices by removing redundant device's roles.
Other
Changed graphics for Energy Panel charts.
Added Swagger documentation for /api/mobile/settings.
Scenes
Possibility to send e-mails to Installer from LUA and block scenes.
Z-Wave
Changed font colors in the Z-wave console for better readability.
Bug Fixes:
Climate
Fixed issues when changing the temperature in cooling mode in the Climate Panel.
Fixed time display in seconds for schedules.
Fixed mode change from off to automatic after zone data change.
Devices
Fixed a screen freeze in the device removal process in IOS mobile apps.
Fixed slider performance in advanced device settings.
Fixed the update of port settings and the operation of the save button in the interface when changing the protocol for cameras and NVRs.
Fixed the interface appearance for the Association tab in the advanced device settings.
Fixed display of device "families" in the device list.
Aligned the Add Device and Remove Device modals.
Fixed the appearance and readability of the Device Updates tab.
Added missing toggle action for MultiPositionSwitch devices.
Fixed the add DSK code button for Smart Start.
Fixed the issue of displaying a message disconnected when the camera preview was working properly.
Fixed saving of advanced settings when changing tabs in the device list.
Fixed display of the "on" status for devices inheriting from the colorController type in the interface Unlocked the process of adding devices when Z-wave learning mode is enabled in the interface.
Fixed display of device statuses in the history panel.
Fixed display of device "families" division on the device list.
Energy
Improved the readability of information in the Energy Panel in dark theme.
Other
Fixed interface behavior when restoring Cloud Backup.
Access Point is available again in Recovery Mode.
Fixed errors when changing the language on the first screen of the FTI process.
Removed redundant password entry attempt counter in FTI process.
Removed redundant display of acceptance of Terms of service and Privacy Policy in the FTI process.
Fixed display of the drop-down list in the profile menu. Adjusted the appearance of drop-down lists on the Network tab.
Fixed the appearance and readability of schemes in Swagger Fixed redundant pop-up login screen after going through the FTI process in the interface.
The save button is active again after setting a new location.
Adapting the appearance of steppers to the new design.
Fixed the appearance of the Update tab.
Added missing icons for weather conditions.
Minor UX/UI fixes.
Quick Apps
Dropdowns in the Quick Apps preview are not expanded by default and it is possible to close them.
Fixed text wrapping for labels.
Adjusted QuickApp edit modal view and console icons to the new designs.
Scenes
Fixed the appearance of the LUA editor.
When creating a new scene from the Scenes Dashboard, the editing screen opens.
Users
The "Continue" button is not active during the user deletion process.
Fixed scrollbar functionality when editing user settings.
Z-Wave
Fixed an issue where the “Check for updates” button was inactive after adding a Z-Wave device.
Adapting the view of the Z-Wave 3 device update tab and Z-wave Diagnostics to the new design.
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Devices
The device "family" division on the device list does not work correctly in dark theme.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Security:
Due to the EU Data Act regulation, changes have been introduced to enable the download Hub data and user data
- from the Hub settings level
- from the user settings level.
The Privacy Policy and Terms of Service are accepted by every user, not just the administrator.
Data submitted for analytics is available in Swagger for administrators. Improved crash dump encryption method.
  • Like 3
Firmware 5.183.63
BETA
11/09/2025
Traduction (google):
Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et améliorations.
Quoi de neuf :
Elero
Intégration du dispositif DuoSON-868.
Intégration du dispositif AstroSON-868.
Nice*
Nettoyage du modèle de périphériques système pour les périphériques monodirectionnels en supprimant les rôles du périphérique redondant.
Autre
Modification des graphiques pour les graphiques Energy Panel.
Ajout de la documentation Swagger pour /api/mobile/settings.
Scènes
Possibilité d'envoyer des e-mails à l'installateur à partir de LUA et de bloquer les scènes.
Z-Wave
Changement des couleurs de police dans la console Z-wave pour une meilleure lisibilité.
Corrections de bugs :
Climat
Correction de problèmes lors de la modification de la température en mode de refroidissement dans le panneau Climat.
Affichage de l'heure fixe en secondes pour les horaires.
Changement de mode fixe de désactivé à automatique après le changement de données de zone.
Appareils
Correction d'un gel d'écran dans le processus de suppression de l'appareil dans les applications mobiles IOS.
Correction des performances du curseur dans les paramètres avancés de l'appareil.
Correction de la mise à jour des paramètres du port et du fonctionnement du bouton d'enregistrement dans l'interface lors du changement de protocole pour les caméras et les NVR.
Correction de l'apparence de l'interface pour l'onglet Association dans les paramètres avancés de l'appareil.
Correction de l'affichage des "familles" d'appareils dans la liste des appareils.
Aligné les modalités Ajouter un appareil et Supprimer un appareil.
Correction de l'apparence et de la lisibilité de l'onglet Mises à jour de l'appareil.
Ajout d'une action de bascule manquante pour les appareils MultiPositionSwitch.
Correction du bouton d'ajout de code DSK pour Smart Start.
Correction du problème d'affichage d'un message déconnecté lorsque l'aperçu de la caméra fonctionnait correctement.
Correction de l'enregistrement des paramètres avancés lors du changement d'onglets dans la liste des appareils.
Correction de l'affichage de l'état "on" pour les appareils héritant du type colorController dans l'interface A débloqué le processus d'ajout d'appareils lorsque le mode d'apprentissage Z-wave est activé dans l'interface.
Correction de l'affichage des statuts de l'appareil dans le panneau d'historique.
Correction de l'affichage de la division des "familles" d'appareils sur la liste des appareils.
Énergie
Amélioration de la lisibilité des informations dans le panneau de l'énergie dans le thème sombre.
Autres
Correction du comportement de l'interface lors de la restauration de Cloud Backup.
Le point d'accès est à nouveau disponible en mode de récupération.
Correction d'erreurs lors du changement de la langue sur le premier écran du processus FTI.
Suppression du compteur de tentative de saisie de mot de passe redondant dans le processus FTI.
Suppression de l'affichage redondant de l'acceptation des conditions d'utilisation et de la politique de confidentialité dans le processus FTI.
Correction de l'affichage de la liste déroulante dans le menu du profil. Ajustement de l'apparence des listes déroulantes dans l'onglet Réseau.
Correction de l'apparence et de la lisibilité des schémas dans Swagger Correction de l'écran de connexion pop-up redondant après avoir passé par le processus FTI dans l'interface.
Le bouton Enregistrer est à nouveau actif après avoir défini un nouvel emplacement.
Adapter l'apparence des steppers au nouveau design.
Correction de l'apparence de l'onglet Mise à jour.
Ajout d'icônes manquantes pour les conditions météorologiques.
Corrections UX/UI mineures.
QuickApps
Les listes déroulantes dans l'aperçu Quick Apps ne sont pas développées par défaut et il est possible de les fermer.
Correction de l'emballage de texte pour les étiquettes.
Ajustement de QuickApp modifier la vue modale et les icônes de la console aux nouveaux designs.
Scènes
Correction de l'apparence de l'éditeur LUA.
Lors de la création d'une nouvelle scène à partir du tableau de bord des scènes, l'écran d'édition s'ouvre.
Utilisateurs
Le bouton "Continuer" n'est pas actif pendant le processus de suppression de l'utilisateur.
Correction de la fonctionnalité de la barre de défilement lors de la modification des paramètres utilisateur.
Z-Wave
Correction d'un problème où le bouton "Vérifier les mises à jour" était inactif après l'ajout d'un appareil Z-Wave.
Adaptation de la vue de l'onglet Mise à jour de l'appareil Z-Wave 3 et des diagnostics Z-wave au nouveau design.
Problèmes connus :
Moteur Z-Wave 3.0
Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
Appareils
La division "famille" des appareils sur la liste des appareils ne fonctionne pas correctement dans le thème sombre.
* - Ne s'applique pas à HC3L (Home Center 3 Lite).
** - S'applique uniquement au moteur Z-Wave 3.0.
Sécurité :
En raison de la réglementation de la loi sur les données de l'UE, des changements ont été introduits pour permettre le téléchargement des données du hub et des données utilisateur
- À partir du niveau des paramètres Hub
- À partir du niveau des paramètres utilisateur.
La politique de confidentialité et les conditions d'utilisation sont acceptées par tous les utilisateurs, pas seulement par l'administrateur.
Les données soumises pour analyse sont disponibles dans Swagger pour les administrateurs. Méthode de cryptage de vidage de crash améliorée.
Mise à jour effectué aussi sur box de test
Dans la beta précédente 5.82.27 il est mentionné :
Z-Wave
    Z-wave engine 3.0 is set as default in the FTI process.
Dans cette Beta ??
Y a t'il un moyen de savoir quelle version Z-wave est installée ?
      Dans le menu 11- Zwave on trouve version 4.33
      Dans Diagnostique Zwave Rien
Pas sûr de comprendre ta remarque.
Toi tu es sur une box existante, donc tu conserves ton moteur Z-Wave.
Le moteur Z-Wave v3 se met par défaut sur les nouvelles installations, comme indiqué dans le changelog.
FTI doit vouloir dire First Time Initialization ou un truc dans le genre, c'est l'assistant de configuration initial.
