Cmoi20 Posté(e) le 13 octobre 2025 Signaler Posté(e) le 13 octobre 2025 Firmware 5.190.36 STABLE 13/10/2025 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Important notice This version contains updated Privacy Policy according to the new Data Act regulation. Fixed an issue with the use of an outdated password reset email template for some languages. Main features: 1. New interface design. A new, refreshed user interface design that will make using the interface even more enjoyable. 2. New Smart Implant / Smart-Control device pairing wizard. A new, dedicated device pairing process in the Yubii mobile application and web interface, where you can easily add and configure your device. 3. Improved security. Application of cybersecurity guidelines in accordance with the new regulations (RED) and the Data Act. What's new: Access Added the ability to delete a user yourself in user settings. Devices Added new sets of icons for roller shutters. Improved curtain behavior when controlled via interface. Adapted the Husqvarna plugin to the new manufacturer API. Elero Support for Elero Bi-rec device (Veinor). Support for Elero RGBW device (Veinor). Reduced polling for the VarioTec-868 device. Improved the type definition for the Revio4M device from a light to roller blinds and venetian blinds. Improved the name and icon for the Sun Motion 868 device. Add new device types for new RolAir motors. DuoSON-868 device integration. AstroSON-868 device integration. Energy panel Added the ability to set quarterly rates for tariff in the energy panel. Nice* Support for TTDW and TTDRGB LED strips devices controllers. Improvements in binding procedures using already memorized transmitter. Improved communication with the radio chip. Group actions are now handled simultaneously for quicker reaction to commands. Added generic support for devices with unknown product types. Reduced polling for battery-powered devices. Support for the ERA Inn Li-ion battery-powered device. Cleaned up the system devices model for monodirectional devices by removing redundant device's roles. Other Documents for Privacy Policy and Terms of Service have been separated when updating the Hub. Changelog history added when updating the Hub version. Changed graphics for Energy Panel charts. Added Swagger documentation for /api/mobile/settings. Quick Apps The preview tab is updated on-the-fly after copying the JSON view. Scenes Performance improvements in scenes execution in large systems. Scene launch optimization. Possibility to send e-mails to Installer from LUA and block scenes. Z-Wave Improvements for handling the reports in Alarm V2 Command Class. Z-wave engine 3.0 is set as default in the FTI process. Updated parameters template for FGR-224/Roll-Control 2 for version 8.2. Added support for class Thermostat Fan Mode version 5. Bug Fixes: Access Improved display of full screen camera view for advanced user. Climate Fixed incorrect calculation of the temperature value for thermostats auto mode. Devices Fixed assigment of the whole device to specific room when adding devices from the mobile app. Added the ability to manually enter values for Multilevel sensors when pairing devices in the mobile app. Fixed the slider display when the thermostat is set to the maximum value in the device preview. Fixed the control dialog for the Nice BiDi-Shutter device as a Venetian blind. Missing source information in DeviceActionRanEvent. Fixed the display of long device names in modal windows. Full https support for Nice Cameras and NVRs. Fixed display of statuses in the Dashboard for colorController and multilevelSwitch devices. Optimised web UI wizards for some devices. Fixed an issue where the device removal process in the mobile app would loop. Fixed issue with loading multiple icons for devices. Fixed a screen freeze in the device removal process in IOS mobile apps. Fixed slider performance in advanced device settings. Added missing toggle action for MultiPositionSwitch devices. Fixed the issue of displaying a message disconnected when the camera preview was working properly. Fixed saving of advanced settings when changing tabs in the device list. Fixed display of the "on" status for devices inheriting from the colorController type in the interface Unlocked the process of adding devices when Z-wave learning mode is enabled in the interface. Fixed display of device statuses in the history panel. Elero Improved the connection process when grouping Elero devices. Gateway Connection Fixed an issue with reverting to the schedule for MCOHome MH8 devices on a slave Hub. Removed duplication for Support and Installer users in the database after updating from version 5.161.15 or higher with gateway connection setup. Fixed device counting in backups for the Master Hub. Nice* Fixed moving to favorite position for mono devices. Improved wake-up from the Hub for the Climatic sensor battery-powered device. Other Fixed selection of devices on the Reset Elero network dropdown list. Fixed the 8-character limit for entering Wi-Fi passwords during the FTI process. Improved handling of the /api/scenes endpoint in Swagger. Fixed SVG icon colors in dark mode for scenes. Access Point is available again in Recovery Mode. The save button is active again after setting a new location from the map. Minor UI/UX fixes. Quick Apps Improved refreshing in the setColorComponent function for Quick Apps. Added support for uploading external icons for Multilevel Sensor device type. Scenes Removed redundant unsaved changes dialog when no changes were made when editing scenarios. Fixed issue with saving default Morning Scenario after making changes. Fixed scenes trigger based on current color for Block Scenes. When creating a new scene from the Scenes Dashboard, the editing screen opens. Users The "Continue" button is not active during the user deletion process. Z-Wave Improved node id (associations) handling when controller has different NodeID that 1.** Fixed the issue of lost Zipato RFID device reports.** Fixed invalid parameters 2,3 value for HeatIt Z-Temp3 device. Fixed a rare issue where learning mode would freeze. Fixed template for Aeon Multisensor 6 device. Fixed an issue where the “Check for updates” button was inactive after adding a Z-Wave device. Console opened in new windows does not scroll automatically when ZW3.0 is used. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. Security: The option to use only the HTTP protocol in network settings has been removed. Log security has been improved through additional security measures for private user data. Security actions have been separated into separate, additionally secured Hub logs. Secure communication for the Z-Wave device update service has been added. The master Hub communicates with the slave Hub only via a secure https connection. Restricted unauthorized API and backup file requests. Updated some low-level libraries. Database protections against storing private data. Fixed error codes returned for authentication errors. Fixed potential RCE vulnerabilities. Removed information regarding the existence of usernames in the system for the password reset mechanism. Reduced vulnerability to DoS attacks. Improved log file encryption. Due to the upcoming new cybersecurity regulations (RED), work has been implemented to improve the product's security level to comply with the EN18301 standard and the latest security guidelines. The user password reset procedure has been changed - user sets a new password himself. The number of required characters in a user password has been increased to 12 - for new users and when changing the password for existing users. Added email notification for administrator regarding unauthorized login attempts when an unknown user logs in. The default login password for the FTI process has been changed for the ones from device label. Improved security for requests from localhost. Increased security for plugins: Husqvarna Mower, Tedee. Cross-Site Scripting vulnerabilities fixed. Additional security for users in the Recovery Mode area. Added protection against PIN brute-force attacks. It is possible to make 3 attempts to disarm alarm partition before the alarm is triggered. The procedure for assigning passwords to new local users has been changed - the user sets his own password in the system. Improved encryption and security in databases. Added the ability to report a security issue has been added as an extension of the Support Department option. Added information for the user when attempting to perform potentially dangerous actions in the interface. Sensitive device data removed from databases. Due to the EU Data Act regulation, changes have been introduced to enable the download Hub data and user data - from the Hub settings level - from the user settings level. The Privacy Policy and Terms of Service are accepted by every user, not just the administrator. Data submitted for analytics is available in Swagger for administrators. Improved crash dump encryption method. 2 1
Cmoi20 Posté(e) le 13 octobre 2025 Auteur Signaler Posté(e) le 13 octobre 2025 Firmware 5.190.36 STABLE 13/10/2025 Français Merci d'utiliser notre passerelle ! Assurez-vous de télécharger la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Avis important Cette version contient une politique de confidentialité mise à jour conformément au nouveau règlement Data Act. Correction d'un problème avec l'utilisation d'un modèle d'e-mail de réinitialisation de mot de passe obsolète pour certaines langues. Caractéristiques principales : 1. Nouvelle conception de l'interface. Une nouvelle conception d'interface utilisateur rafraîchie qui rendra l'utilisation de l'interface encore plus agréable. 2. Nouvel assistant de couplage d'appareils Smart Implant / Smart-Control. Un nouveau processus de couplage d'appareils dédié dans l'application mobile et l'interface Web Yubii, où vous pouvez facilement ajouter et configurer votre appareil. 3. Sécurité améliorée. Application des lignes directrices en matière de cybersécurité conformément à la nouvelle réglementation (RED) et à la loi sur les données. Quoi de neuf: Accéder Ajout de la possibilité de supprimer vous-même un utilisateur dans les paramètres utilisateur. Appareils Ajout de nouveaux ensembles d'icônes pour les volets roulants. Comportement du rideau amélioré lorsqu'il est contrôlé via l'interface. Adaptation du plugin Husqvarna à la nouvelle API du fabricant. Ingénieur Prise en charge du périphérique Elero Bi-rec (Veinor). Prise en charge du périphérique Elero RGBW (Veinor). Interrogation réduite pour l'appareil VarioTec-868. Amélioration de la définition de type pour l'appareil Revio4M d'une lumière aux stores enrouleurs et aux stores vénitiens. Amélioration du nom et de l'icône de l'appareil Sun Motion 868. Ajoutez de nouveaux types d’appareils pour les nouveaux moteurs RolAir. Intégration de l'appareil DuoSON-868. Intégration du dispositif AstroSON-868. Panneau énergétique Ajout de la possibilité de définir des tarifs trimestriels pour le tarif dans le panneau énergétique. Bon* Prise en charge des contrôleurs de périphériques à bandes LED TTDW et TTDRGB. Améliorations des procédures de liaison utilisant un émetteur déjà mémorisé. Communication améliorée avec la puce radio. Les actions de groupe sont désormais gérées simultanément pour une réaction plus rapide aux commandes. Ajout d'un support générique pour les appareils avec des types de produits inconnus. Interrogation réduite pour les appareils alimentés par batterie. Prise en charge de l'appareil alimenté par batterie Li-ion ERA Inn. Nettoyage du modèle de périphériques système pour les périphériques monodirectionnels en supprimant les rôles de périphériques redondants. Autre Les documents relatifs à la politique de confidentialité et aux conditions d'utilisation ont été séparés lors de la mise à jour du Hub. Historique des modifications ajouté lors de la mise à jour de la version Hub. Graphiques modifiés pour les tableaux du panneau énergétique. Ajout de la documentation Swagger pour /api/mobile/settings. Applications rapides L'onglet d'aperçu est mis à jour à la volée après la copie de la vue JSON. Scènes Améliorations des performances dans l’exécution des scènes dans les grands systèmes. Optimisation du lancement de la scène. Possibilité d'envoyer des e-mails à l'installateur depuis LUA et de bloquer des scènes. Z-Wave Améliorations pour la gestion des rapports dans la classe de commande Alarm V2. Le moteur Z-wave 3.0 est défini par défaut dans le processus FTI. Modèle de paramètres mis à jour pour FGR-224/Roll-Control 2 pour la version 8.2. Ajout de la prise en charge du mode ventilateur du thermostat de classe version 5. Corrections de bugs : Accéder Affichage amélioré de la vue caméra plein écran pour les utilisateurs avancés. Climat Correction du calcul incorrect de la valeur de température pour le mode automatique des thermostats. Appareils Affectation fixe de l'ensemble de l'appareil à une pièce spécifique lors de l'ajout d'appareils à partir de l'application mobile. Ajout de la possibilité de saisir manuellement des valeurs pour les capteurs multiniveaux lors de l'association d'appareils dans l'application mobile. Correction de l'affichage du curseur lorsque le thermostat est réglé sur la valeur maximale dans l'aperçu de l'appareil. Correction de la boîte de dialogue de contrôle du dispositif Nice BiDi-Shutter en tant que store vénitien. Informations source manquantes dans DeviceActionRanEvent. Correction de l'affichage des noms d'appareils longs dans les fenêtres modales. Prise en charge https complète pour les caméras et NVR Nice. Affichage fixe des statuts dans le tableau de bord pour les appareils colorController et multilevelSwitch. Assistants d'interface Web optimisés pour certains appareils. Correction d'un problème où le processus de suppression de l'appareil dans l'application mobile se déroulait en boucle. Problème résolu avec le chargement de plusieurs icônes pour les appareils. Correction d'un blocage de l'écran lors du processus de suppression de l'appareil dans les applications mobiles IOS. Correction des performances du curseur dans les paramètres avancés de l'appareil. Ajout de l'action de bascule manquante pour les appareils MultiPositionSwitch. Correction du problème d'affichage d'un message de déconnexion lorsque l'aperçu de la caméra fonctionnait correctement. Sauvegarde fixe des paramètres avancés lors du changement d'onglets dans la liste des appareils. Affichage fixe de l'état « on » pour les périphériques héritant du type colorController dans l'interface Débloqué le processus d'ajout d'appareils lorsque le mode d'apprentissage Z-wave est activé dans l'interface. Affichage fixe des statuts des appareils dans le panneau d'historique. Ingénieur Amélioration du processus de connexion lors du regroupement des appareils Elero. Connexion à la passerelle Correction d'un problème de retour à la planification pour les appareils MCOHome MH8 sur un hub esclave. Suppression de la duplication pour les utilisateurs de support et d'installation dans la base de données après la mise à jour à partir de la version 5.161.15 ou supérieure avec la configuration de la connexion de passerelle. Comptage des appareils fixes dans les sauvegardes pour le Master Hub. Bon* Correction du déplacement vers la position favorite pour les appareils mono. Réveil amélioré depuis le Hub pour l'appareil alimenté par batterie du capteur climatique. Autre Sélection fixe des appareils dans la liste déroulante Réinitialiser le réseau Elero. Correction de la limite de 8 caractères pour la saisie des mots de passe Wi-Fi pendant le processus FTI. Gestion améliorée du point de terminaison /api/scenes dans Swagger. Couleurs d'icônes SVG fixes en mode sombre pour les scènes. Le point d'accès est à nouveau disponible en mode de récupération. Le bouton Enregistrer est à nouveau actif après avoir défini un nouvel emplacement à partir de la carte. Corrections mineures de l'interface utilisateur/UX. Applications rapides Rafraîchissement amélioré dans la fonction setColorComponent pour les applications rapides. Ajout de la prise en charge du téléchargement d'icônes externes pour le type d'appareil Capteur multiniveau. Scènes Suppression de la boîte de dialogue des modifications redondantes non enregistrées lorsqu'aucune modification n'a été apportée lors de la modification des scénarios. Problème résolu avec l'enregistrement du scénario matinal par défaut après avoir apporté des modifications. Déclenchement de scènes fixes en fonction de la couleur actuelle pour les scènes de bloc. Lors de la création d'une nouvelle scène à partir du tableau de bord des scènes, l'écran d'édition s'ouvre. Utilisateurs Le bouton « Continuer » n'est pas actif pendant le processus de suppression de l'utilisateur. Z-Wave Gestion améliorée des identifiants de nœud (associations) lorsque le contrôleur possède un identifiant de nœud différent de 1.** Correction du problème des rapports de perte d'appareils RFID Zipato.** Correction de la valeur des paramètres non valides 2,3 pour l'appareil HeatIt Z-Temp3. Correction d'un problème rare où le mode d'apprentissage se bloquait. Modèle fixe pour l'appareil Aeon Multisensor 6. Correction d’un problème où le bouton « Vérifier les mises à jour » était inactif après l’ajout d’un appareil Z-Wave. La console ouverte dans de nouvelles fenêtres ne défile pas automatiquement lorsque ZW3.0 est utilisé. Problèmes connus : Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. Sécurité: L'option permettant d'utiliser uniquement le protocole HTTP dans les paramètres réseau a été supprimée. La sécurité des journaux a été améliorée grâce à des mesures de sécurité supplémentaires pour les données privées des utilisateurs. Les actions de sécurité ont été séparées dans des journaux Hub distincts et sécurisés en plus. Une communication sécurisée pour le service de mise à jour des appareils Z-Wave a été ajoutée. Le Hub maître communique avec le Hub esclave uniquement via une connexion https sécurisée. Demandes d'API et de fichiers de sauvegarde non autorisées restreintes. Mise à jour de certaines bibliothèques de bas niveau. Protections de bases de données contre le stockage de données privées. Codes d'erreur fixes renvoyés pour les erreurs d'authentification. Correction de vulnérabilités potentielles RCE. Suppression des informations concernant l'existence de noms d'utilisateur dans le système pour le mécanisme de réinitialisation du mot de passe. Vulnérabilité réduite aux attaques DoS. Cryptage amélioré du fichier journal. En raison des nouvelles réglementations en matière de cybersécurité (RED) à venir, des travaux ont été mis en œuvre pour améliorer le niveau de sécurité du produit afin de se conformer à la norme EN18301 et aux dernières directives de sécurité. La procédure de réinitialisation du mot de passe utilisateur a été modifiée : l'utilisateur définit lui-même un nouveau mot de passe. Le nombre de caractères requis dans un mot de passe utilisateur a été augmenté à 12 - pour les nouveaux utilisateurs et lors du changement de mot de passe pour les utilisateurs existants. Ajout d'une notification par e-mail pour l'administrateur concernant les tentatives de connexion non autorisées lorsqu'un utilisateur inconnu se connecte. Le mot de passe de connexion par défaut pour le processus FTI a été modifié pour celui de l'étiquette de l'appareil. Sécurité améliorée pour les requêtes provenant de localhost. Sécurité renforcée pour les plugins : Husqvarna Mower, Tedee. Vulnérabilités de script intersite corrigées. Sécurité supplémentaire pour les utilisateurs dans la zone Mode de récupération. Protection supplémentaire contre les attaques par force brute par code PIN. Il est possible de faire 3 tentatives pour désarmer la partition d'alarme avant que l'alarme ne se déclenche. La procédure d'attribution de mots de passe aux nouveaux utilisateurs locaux a été modifiée : l'utilisateur définit son propre mot de passe dans le système. Cryptage et sécurité améliorés dans les bases de données. La possibilité de signaler un problème de sécurité a été ajoutée en tant qu'extension de l'option Service d'assistance. Informations ajoutées pour l'utilisateur lorsqu'il tente d'effectuer des actions potentiellement dangereuses dans l'interface. Données sensibles des appareils supprimées des bases de données. En raison de la réglementation de l'UE sur les données, des modifications ont été introduites pour permettre le téléchargement des données du Hub et des données utilisateur - depuis le niveau des paramètres du Hub - à partir du niveau des paramètres utilisateur. La politique de confidentialité et les conditions d'utilisation sont acceptées par chaque utilisateur, pas seulement par l'administrateur. Les données soumises à des fins d’analyse sont disponibles dans Swagger pour les administrateurs. Méthode de cryptage de vidage sur incident améliorée. 2
Cmoi20 Posté(e) le 13 octobre 2025 Auteur Signaler Posté(e) le 13 octobre 2025 nouvelle mise à jour une semaine après la précédente. celle d'avant fonctionne bien pour moi. je n'ai pas de boxe de test. je laisse les plus téméraires tester et je vais attendre quelques jours de mon coté.
TitiXsi Posté(e) le 13 octobre 2025 Signaler Posté(e) le 13 octobre 2025 C'est curieux... Le log est très similaire... Et comme tu dis à quels jours d'intervalle..
jjacques68 Posté(e) le 13 octobre 2025 Signaler Posté(e) le 13 octobre 2025 mise à jour réalisée. RAS pour le moment...
Mickaelkael Posté(e) le 14 octobre 2025 Signaler Posté(e) le 14 octobre 2025 MàJ effectuée : RAS pour le moment
Sowliny Posté(e) le 14 octobre 2025 Signaler Posté(e) le 14 octobre 2025 (modifié) Belle mise à jour, effectuée sans problème. Nous avons quitté la période "orange" pour revenir vers le bleu originel... Et une foule de choses à bien éplucher (comme d'habitude je dirais - mais c'est une très bonne chose !). Il y a (bien) longtemps que je n'étais pas revenu sur le forum. Mais mon projet (non domotique) est désormais abouti et en cours de production du premier exemplaire, après un démonstrateur en activité. Modifié le 14 octobre 2025 par Sowliny ajout 2
Sowliny Posté(e) le 15 octobre 2025 Signaler Posté(e) le 15 octobre 2025 (modifié) Il me semble en avoir parlé il y a quelques temps (mois ?). C'est un simulateur de flux sanguin et aérien (pulmonaire) destiné aux salles de formation hospitalières, et de toute institution ou association proposant ce type de formation aux gestes d'urgence (plaies artérielles, veineuses, brèches pulmonaires) nécessaires lors d'accidents, etc... La V1 "tourne" déjà depuis plus d'un an, et le premier exemplaire de la V2 sera livré dans quelques semaines. Version basée cette fois sur un ATtiny84. Actuellement, je travaille à rendre "industrialisable" le PCB, ainsi que les éléments du boîtier (par exemple l'apparence du boîtier, surtout la face avant, n'est déjà plus la même, afin d'en simplifier et faciliter l'impression). Évolution de la face avant : Modifié le 15 octobre 2025 par Sowliny ajout 8
Sowliny Posté(e) le 15 octobre 2025 Signaler Posté(e) le 15 octobre 2025 (modifié) En ce qui concerne la HC3 (ou devrais-je dire Yubii Home Pro ?), hé bien elle ronronne... Aucun souci (ce qui m'arrange bien...). Sa seule implication dans le projet est la gestion de température/humidité de mon labo, et le pilotage de mon banc de gravure aux UV pour les PCB. Merci à @Cmoi20 pour la traduction ! Modifié le 15 octobre 2025 par Sowliny
Nico Posté(e) le 16 octobre 2025 Signaler Posté(e) le 16 octobre 2025 Top ! J'ai du raté ce topic, sacré projet, top !
Sowliny Posté(e) le 16 octobre 2025 Signaler Posté(e) le 16 octobre 2025 (modifié) @Nico , "il me semble" en avoir parlé... Au cours d'un sujet sur un "Feu tricolore indicateur de tranche de facturation électrique" dans la section DIY. Mais je n'ai ait fait qu'évoquer le projet. Seul lien avec la domotique, le pilotage du bac de gravure UV par la HC3 - lien éloigné s'il en est.. En attendant, merci pour l'appréciation ! Modifié le 16 octobre 2025 par Sowliny correction
