HC3 & HC3L - 5.202.51 - BETA - 26/02/2026
Firmware 5.202.51
BETA
26/02/2026
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
Migration of Z-Wave engine from 2.0 to 3.0 version (BETA)
    In this version of the software, it is possible to migrate the Z-Wave engine to version 3.0. Migration will allow you to take advantage of all the features of the new Z-Wave engine, including using Smart Start, better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home.
Smart Start
    From now on, you can use the Smart Start function using QR Scanner in Yubii App. This function will allow you to add devices to the system even faster using binding process.***
What's new:
Devices
    Added thermostatOperatingState interface for Linked thermostats.
    Added direct access to KNX communication (both sending and recieving packets) from the API.
Gateway connection
    Enabling Support Access and Remote Access on the Master hub also enables access on slave hubs.
Nice*
    Added the option to disable the sun impact (setting the value to 0 lux in parameter 10) for the Domi WSC device.
    The default values of parameters 1, 3, and 10 have been changed for all versions of DOMI WSC devices v3.9.0.
Other
    Verification of the checksum when downloading the update file at the beginning of the process instead of at the end.
Bug Fixes:
Climate
    Fixed an issue where an added temperature sensor was removed from the climate panel when editing other settings in that panel.
    Fixes an error occurs after deleting a device in the climate schedule.
Devices
    Fixed a problem with KNX device configuration caused by the lack of support for diacritical marks in device names.
    Fixed an issue with function settings for Z-Wave devices with an empty template during the binding process in the mobile application.
    Fixed incorrect KNX Bridge connection status after IP change.
    Restored missing temperature graphs on FGT device version 4.10.
    Fixed the appearance of the dialog in the user interface for BiDi-Awning and AV Controller.
Elero
    Fixed color component values for the Elero Lighting RGBW device.
    Fixed the appearance and behavior of the Elero Lighting RGBW device icon in the user interface.
    Fixed invalid settings for temperature color in profiles for the Elero Lighting RGBW device.
Gateway connection
    Fixed errors and incorrect display of options in association settings.
    Fixed IP address validation in the Gateway Connection tab.
Nice*
    Fixed keep-alive support for Domi WSR/WS device, which caused the device to be shown as disconnected in the system.
Other
    Fixed handling of events from the NICE camera plugin when devices are added via NVR.
    Fixed icons for Sonos and XBMC plugins.
    Fixed errors displayed in the Z-wave tab of the Master hub when using the interface via Remote Access.
    Fixed the input validator for variables.
    Fixed non-functioning group actions in profiles.
Quick Apps
    Added support for climate zone control functions in QuickApps.
    Fixed restarting the Quick App process when editing it.
    Fixed Heat Activator which stopped working in rare cases.
    Fixed an issue with saving the Quick Apps view to a file when encrypting (applies to QA exported from version 5.191 or later).
Scenes
    Fixed refreshing of the scene activity switch in the interface when calling activation/deactivation action from the scene level.
    Fixed inactive color temperature slider for device Elero Lighting TW in scenarios created in the mobile app.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
*** - Fully supported in the upcoming Yubii v2.5.3 application
Modifié par Lazer
Correction date
  • Like 2
En français
Merci d’utiliser notre passerelle !
Assurez-vous de mettre à jour vers la dernière version afin de profiter des nouvelles fonctionnalités et améliorations.
Fonctionnalités principales
Migration du moteur Z-Wave de la version 2.0 vers la version 3.0 (BETA)
Dans cette version du logiciel, il est possible de migrer le moteur Z-Wave vers la version 3.0.
La migration vous permettra de profiter de toutes les fonctionnalités du nouveau moteur Z-Wave, notamment :
  • l’utilisation de Smart Start
  • une meilleure compatibilité générique avec les appareils Z-Wave Plus
  • la disponibilité de Security S2, qui peut être considérée comme la première méthode de communication entièrement sécurisée pour la maison intelligente.
Smart Start
Désormais, vous pouvez utiliser la fonction Smart Start via le scanner QR dans l’application Yubii.
Cette fonction vous permettra d’ajouter des appareils au système encore plus rapidement grâce au processus d’association.***
Nouveautés
Appareils
  • Ajout de l’interface thermostatOperatingState pour les thermostats liés.
  • Ajout d’un accès direct à la communication KNX (envoi et réception de paquets) via l’API.
Connexion à la passerelle
  • L’activation de Support Access et Remote Access sur le hub maître active également l’accès sur les hubs esclaves.
Nice*
  • Ajout de l’option permettant de désactiver l’impact du soleil (en réglant la valeur à 0 lux dans le paramètre 10) pour l’appareil Domi WSC.
  • Les valeurs par défaut des paramètres 1, 3 et 10 ont été modifiées pour toutes les versions des appareils DOMI WSC v3.9.0.
Autres
  • Vérification du checksum lors du téléchargement du fichier de mise à jour au début du processus au lieu de la fin.
Corrections de bugs
Climat
  • Correction d’un problème où un capteur de température ajouté était supprimé du panneau climat lors de la modification d’autres paramètres.
  • Correction d’une erreur après suppression d’un appareil dans la planification climatique.
Appareils
  • Correction d’un problème de configuration des appareils KNX dû à l’absence de prise en charge des caractères accentués dans les noms d’appareils.
  • Correction d’un problème avec les paramètres de fonction des appareils Z-Wave avec modèle vide pendant l’association dans l’application mobile.
  • Correction d’un statut de connexion incorrect du KNX Bridge après changement d’IP.
  • Restauration des graphiques de température manquants sur l’appareil FGT version 4.10.
  • Correction de l’affichage de la fenêtre de dialogue dans l’interface utilisateur pour BiDi-Awning et AV Controller.
Elero
  • Correction des valeurs de composantes de couleur pour l’appareil Elero Lighting RGBW.
  • Correction de l’apparence et du comportement de l’icône dans l’interface utilisateur.
  • Correction des paramètres invalides de couleur de température dans les profils.
  • Correction d’erreurs et d’un affichage incorrect des options dans les paramètres d’association.
  • Correction de la validation de l’adresse IP dans l’onglet Gateway Connection.
Nice*
  • Correction du support keep-alive pour les appareils Domi WSR/WS, qui apparaissaient comme déconnectés dans le système.
Autres
  • Correction de la gestion des événements du plugin caméra NICE lorsque les appareils sont ajoutés via NVR.
  • Correction des icônes pour les plugins Sonos et XBMC.
  • Correction d’erreurs affichées dans l’onglet Z-Wave du hub maître lors de l’utilisation via Remote Access.
  • Correction du validateur d’entrée pour les variables.
  • Correction des actions de groupe non fonctionnelles dans les profils.
Quick Apps
  • Ajout du support des fonctions de contrôle de zone climatique dans Quick Apps.
  • Correction du redémarrage du processus Quick App lors de l’édition.
  • Correction du Heat Activator qui cessait de fonctionner dans de rares cas.
  • Correction d’un problème d’enregistrement de la vue Quick Apps dans un fichier lors du chiffrement (concerne les QA exportées depuis la version 5.191 ou plus récente).
Scènes
  • Correction du rafraîchissement du commutateur d’activité de scène dans l’interface lors de l’activation/désactivation depuis le niveau scène.
  • Correction du curseur de température de couleur inactif pour l’appareil Elero Lighting TW dans les scénarios créés dans l’application mobile.
Problèmes connus
Moteur Z-Wave 3.0
  • Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
* Ne s’applique pas à HC3L (Home Center 3 Lite)
** S’applique uniquement au moteur Z-Wave 3.0
*** Pris entièrement en charge dans la prochaine application Yubii v2.5.3
Qui va être le premier à tester la migration, ok pour lui payer une bière :=)
Modifié par ericl78
  • Haha 1
j'aime bien la bière,mais pas au point d'être le premier à tester en bêta la migration vers un moteur z-wave en beta depuis TRES longtemps :77:
  • Haha 1
  • Lazer a modifié le titre en HC3 & HC3L - 5.202.51 - BETA - 26/02/2026
J'avoue que.... tout pareil :2:
Mais quand même, je suis impressionné par les dernières mises à jour Fibaro / Nice : ajout du KNX, enfin la tant attendue migration Z-Wave v2 vers v3, on se demande quelle sera la prochaine étape. Allez rêvons un peu, un support amélioré du Zigbee, ou même du Bluetooth Low Energy comme annoncé initialement :lol:
  • Haha 1
il y a 26 minutes, Lazer a dit :
ou un z-wave v3  stable ?????
Après la mise à jour, on a une nouvelle notification qui nous conseille de préparer la migration vers le moteur Z-Wave v3 car le moteur v2 ne sera bientôt plus mis à jour :
Citation
Since version 2.0 of the Z-wave engine will soon be no longer developed, we invite you to perform the migration procedure. If you would like to help us improve the system, please go to the Z-Wave settings page where you can learn more and run the migration.
Quand on clique sur le bouton on arrive au panneau Z-Wave qui nous propose de lancer la migration :
Citation
Migration from engine 2.0 to engine 3.0
beta
Migration will allow you to take advantage of all the features of the new Z-Wave engine, including better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home.
Migration may cause some devices to stop working properly and those will require reconfiguration. Details of the migration results will be available on the Z-Wave diagnostics page once the process is complete.
Since the procedure is in beta and may still contain bugs, you can always undo the migration procedure by simply restoring a pre-migration backup.
Mais, comme le rappelle @jojo, c'est pas comme si le moteur v3 était vraiment stable, comme le mentionne encore le Changelog :
Citation
Known issues:
Z-Wave Engine 3.0
Du coup.... faire la migration pour passer d'un moteur non maintenu à un moteur non finalisé.
C'est jouer aux équilibristes !
Bon, le message sur la box nous dit qu'on peut toujours revenir à une sauvegarde précédente, c'est un peu rassurant... en effet, la configuration des différents modules dans le réseau Z-Wave ne devrait théoriquement pas être affectée par cette mise à jour coté box / contrôleur.
J'ai 2 modules Z-Wave sur ma box de test, j'attends la sortie de la version Stable du firmware puis je tenterai alors la migration Z-Wave.
Pour ma box de prod, rendez-vous dans.... euh..... bah..... on verra :o
