Lazer Posté(e) il y a 5 heures Signaler Posté(e) il y a 5 heures Firmware 5.221.21 BETA 26/10/2026 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements Main features: Added new Sonos plugin. Added a new Sonos plugin with Sonos account sign-in, group and speaker control, album artwork, track seeking, favorites, playlists and scenes support. What's new: Access Changed “Support Access” so that enabling it also selects “Allow Support to access the web interface”, which the user can still clear. Added a button in the general settings to download the hub's encrypted logs, available to administrators, installers and remote support - available also via Remote Access. Climate Disabled the checkboxes in the climate zone edit window when only one thermostat is available and it is already assigned to the zone. Devices Added a tree of main and secondary functions in the binding wizard, where changing a function's room also changes the room of its nested functions. Added support for automatic locking events sent by Danalock V3 locks, including their description in the device history. Gateway connection Added a warning when removing a slave hub that re-adding it makes its existing backups impossible to restore, recommending “Replace device” instead. KNX Improved the KNX Bridge configuration window by moving the “Secure connection” section and keeping “Save” active after a file upload. Added an action that lets a Quick App send a GroupValueRead request to a KNX group address. Nice Improved removal of BiDi-MiniShutter devices from the hub, so they can be bound again without a reset to factory settings. Other Added the missing device type name for DoubleDimmer-Control in the device settings. Added remembering of the filters and sorting on the device list, and of the filters on the scene list, when switching between views. Improved stability when adding, modifying or removing rooms, users, climate zones, notifications and other items. Quick Apps Added the option to collapse and expand the “Builder”, “Code” and “Control” panels in the Quick App editor. Added the ability to send binary data over WebSocket connections from Quick Apps, which allows connecting to MQTT brokers over secure WebSockets. Z-Wave Added a notification that tells the user to reconfigure or re-add a Z-Wave 3 device after a parameter that changes its capabilities is changed.** Removed the “panelService” section from the hub's API documentation when the Z-Wave 3 engine is active, as it is not supported there.** Added support for newer Z-Wave meter versions in Z-Wave 3, including resetting a single meter reading to a chosen value through the API.** Added device and parameter templates for the MCO Home MH5H-2A thermostat with recent firmware, with thermostat, temperature sensor and humidity sensor tiles. Bug Fixes: Access Fixed the wrong tab being marked as active when the Access menu was selected again while the remote access or installer access tab was open. Fixed the external sensor section disappearing from the High Load-Control advanced settings for advanced users without climate zone rights; a message now explains the missing rights. Backup Fixed the sidebar of the hub settings view disappearing after creating a local backup until the page was refreshed or another tab was opened. Fixed the backup list breaking when one of the backups had an empty description, which prevented creating backups. Cameras Fixed the missing “Configured” status in the mobile app camera list for cameras and NVRs added in the web interface without a serial number. Climate Fixed the schedule state not updating correctly after changing climate zone activation for Fibaro The Heat Controller/Nice Heat-Control. Fixed the temperature of a climate zone segment changing continuously when both mouse buttons were pressed on its “+” or “-” button. Devices Fixed the Auto-Off countdown in the device preview, which did not start again after a previous countdown had finished until the preview was reopened. Fixed the hourglass that stayed on the thermostat icon after changing the mode or setpoint of Quick App. Fixed the RGBW Controller (RGBW441) control view in input/output mode, which showed LED controls, programs and Auto-Off options that are not supported in that mode. Fixed mouse wheel scrolling on the “Smart Start” tab when many devices were listed. Added a number of user codes setting for door locks on the Z-Wave 3 engine to synchronize more than 12 PIN codes, up to the lock's limit. Fixed inconsistent wall switch descriptions in the switch type list of the Advanced tab for devices that support such switches. Fixed overlapping icon, description and slat animation in the wizard's button configuration step for Fibaro Roller Shutter 4/Nice Roll-Control 2. Energy panel Fixed power consumption and other device graphs showing a future date range and blocking navigation for devices added with a future hub date. Garden Fixed watering schedules in the “Garden” tab becoming deactivated after expanding their details, and renamed schedules reverting to their old name after saving. KNX Fixed the missing checkmark icon on the selected color tile after setting a specific color on a KNX color control device in the “Preview” section. Nice Fixed Nice VB40 favorite positions not being saved, which made the device icon show a favorite position at 50% instead of the set one. Fixed repeated notifications about a Nice device missing from the hub's radio memory, which now appear only on the device's main tile. Other Fixed the barely visible section name in the “Room/Section” dropdown list of the “Add Device” window. Fixed a problem where custom icons could not be deleted after restoring a backup. Fixed the “Refresh for 14 days” button in the Remote Access section showing a variable name instead of the number of days in Brazilian Portuguese. Scenes Fixed the Profiles option icon showing a white background when adding or editing scenes in the mobile app with the dark theme. Fixed custom icons not being displayed when selecting an icon for a new scene while connected to the hub remotely. Fixed scene triggers set to react to any value change that ran the scene without waiting for the configured duration. Z-Wave Fixed the “Advanced settings” tab of High Load-Control showing default values instead of the device's settings after migration from Z-Wave 2 to Z-Wave 3.** Fixed the migration of MCO Home A8-9 from Z-Wave 2 to Z-Wave 3, which left the device's sensors without readings.** Fixed the Z-Wave 3 engine occasionally stopping after adding a device with S2, leaving the inclusion unfinished and Z-Wave devices unresponsive until a restart.** Fixed an additional generic tile appearing after reinterview of a Linear-GD00Z garage door controller migrated from Z-Wave 2 to Z-Wave 3.** Fixed errors logged in Z-Wave 3 when Wall Plug (FGWPB121 and FGWPG121) devices send meter readings from channels without a USB port.** Fixed door lock tiles showing “open” after the lock locked itself automatically, for locks reporting the automatic locking through notifications in Z-Wave 3.** * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. 2
Nico Posté(e) il y a 48 minutes Signaler Posté(e) il y a 48 minutes Au fait, qqun a migrer en Zwave 3 ? Cela fonctionne bien ?
