V4.024 Béta - 19-12-2014
TonyC
Fibaro Home Center 2 v 4.024 BETA.
Beta version is designed for user testing and soon will be released as official.
WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
4.024:
New Features
Soft reconfiguration status available at Zwave Diagnostics Panel.
Displaying number of system alert information, and improved the user interface clarity.
Resolved Issues
#0001943 Philips HUE adding new devices after plugin restart
#0002251 Philips Hue plugin recreate all lamps each time the plugin is saved
#0001882 [plugin] - slave device is broken if visibility is set to false
#0001881 [plugin] - master device is broken if visibility is set to false
#0002100: Temperature sensor from plugins doesn't work in heating linked device
#0002064: [plugin] - action argc parameter possible bug in "types" xml
#0001716 UBS reconfiguration does not work
#0002069: Add new scene: the buttons names should be "Create" or "New" and not "Save"
Known issues
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
@PITP2
En revanche le SoftReconfigure sur les modules Qubino plante le moteur z-wave, c'est restauration obligatoire :angry:. Moi j'ai le problème que sur Qubino et je pense que Fibaro ne fera pas d'effort sur la prise en compte de ce bug: Qubino/Fibaro c'est la guerre !
Des gens ont le problème avec des modules Fibaro par exemple ?
