V4.040 Hot Fix - 26-03-2015
Krikroff
This version is hot fixing version addressing some of issues reported by users.
4.040
> New Features:
Device adding from iPhone/Android Phone application (requires newest app and 4.040)
> Resolved Issues:
Satel support
Slow communication between mobile apps and Home Center
No icons on mobile devices
Impossible to control Linear Dimmer
Magic Scenes conditions for Dimmer
Alarm Fibaro - not showing time to arm when arm delayed
Polling - please check your configuration.
#0003027: Z-wave network configuration don't save changes
#0001956: Outputs of Satel Intgera alarmsystem cannot be controled anymore via the scene (bloks)
#0002145: Warning satel partition
#0002316: 4.024 If you are going to keep the RAM diagnostic, please explain the meaning of used and free
#0003016: HC2 out of memory after a few hours of operation
#0003034: 4.037 - Memory Utilization Shoots-up with each Backup run
#0001992: FGK-101 with a DS18B20
#0002920: Danfoss sw1.01 doesn't follow the morning setting of heating panel
#0002575: Universal Binary Sensor (UBS) lacks "sceneActivation"
#0001727: Trying to set parameter on Everspring SP814 Motion detecto
#0002590: Everspring AN145 Bulb Reconfiguration Problem
#0002450: Motion Sensor always engaged
#0003032: Waking up dead nodes.
> Device Support:
D-Link DCS-932L
Improved Fibaro Smoke Sensor
> Known issues:
Android version of the Fibaro mobile app does not display icons for following devices properly:
- NetAtmo Thermostat
- NetAtmo Weather Station
- Sonos
Global polling interval is set to a fixed value (120s), this may cause a delay in operation of large Z-Wave networks.
Inconsistencies in Satel interface.
> We advise:
Reconfiguration of Satel alarm.
Avoiding local polling interval smaller than 30s. This may cause high network traffic and block communication.
  • Upvote 2
Bon bin, j'ai deux HC2 que j'ai passé en 040 : la slave avec peu de devices, ok. La master, j'ai perdu visuellement tous les devices (scènes OK).
Clear de la cache et reboot ne font rien
Ils sà»rement là  au niveau système, car dans la page Devices, ils sont présents dans le navigateur à  gauche. C'est l'affichage sur la page principale qui pose problème
donc....
avec internet explorer, en francais, j ai tout, avec chrome, j ai quasi rien.
ca vient donc pas de la box, je dois faire koi?
En effet, je ne pense pas que ça vienne de la box. Réinitialise le cache de chrome, ça devrait résoudre ton problème je pense.
Je viens de mettre à  jour l'appli iOS en plus de cette v4.040 sur la HC2, la communication entre les 2 semble beaucoup plus rapide. Ca confirme la ligne "Slow communication between mobile apps and Home Center", dans la partie Resolved issues. Je suis passé de 37 secondes à  moins de 7secondes en 3G (remote access en passant par leur proxy). Un truc qui progresse, c'est cool  :60:
Ils ont mis l'appli IOS et le firmware à  jour en même temps en sachant que certaines nouvelles fonctionnalités ont besoin d'au minimum des dernières versions  :o
Sachant que Fibaro n'a pas la main sur la date de déploiement par Apple de l'applis IOS, la v4.040 devait attendre depuis un petit moment déjà  pour pouvoir sortir de concert.
Cela explique pourquoi, le bugzilla n'affiche aucun nouveau bug résolu depuis le 20/03. Ca devrait bouger aujourd'hui.
Mise à  jour faite, rien à  signaler.
Par contre, j'espère que l'application iPhone va évoluer. Vu les captures d'écran, la version tablette a l'air bien meilleure, mais le vieille iPad 1 qui traine ici n'est pas éligible.
@akrobat, Oui toujours l'avertissement ;)
Sinon:
- Le chargement des données dans l' application iPhone est vraiment plus rapide maintenant, bonne nouvelle !
- Toujours un problème avec le Plugin SATEL, la suppression du plugin ne supprime pas de la bd du HC2 les modules de l'installation SATEL: bd de nouveau corrompue donc :angry:
- Après installation un module RGBW c'est allumé tout seul, mais marqué off sur l'interface avec pourtant une conso..
