Hc2 Et Hc Lite - V4.071 Beta - 02/02/2016
nickrdtp
Attention : Changelogs différents pour HCL et HC2
Home Center Lite
Version 4.071 Beta
WARNING: Beta version is designed for user testing and soon should be released as official.
Resolved issues:
- #0002290 #0003353 Devices with sceneActivation are not available in Block and Magic scenes
- No user icons in Remote Access
- Gateway Connection - devices with polling interface are not being imported
- 503 error when including blind controller from some manufacturers
- Delays in Z-wave network after setting RGBW Controller to desired level
New devices support:
- Z-Wave.Me ZMR WCS 6 v1.4
- Z-Wave.Me On Off Switch
- Z-Wave.Me FB10 v1.1
- Z-Wave.Me Wall Controller v1.1
- Z-Wave.Me TZ68 g v1.0
- NodOn Octan Remote v2.3
- Philio PSM02 4 in 1 Sensor v1.0
- EMINENT EM6570
- EMINENT EM6550
- TKB Home Wall Plug v1.1
- TKBHome TZ67 v1.12
- Reitz Group ZW ESJ v1.0
- Reitz Group ZS 3500 v1.0
- Reitz Group IP44 On Off Switch v1.0
- FortrezZ LLC-SSA03 v2.5
- GreenWave Powernode v4.27
- Qees Remote Controller v0.5
- Jasco Products Wall Outlet v1.16
- Jasco Products ZW3003
- Jasco Products ZW4101
- Everspring HAC01 v2.0
- BeNext-Dimmer
- BeNext-Forest Curtain rail with motor
- wiDom-Universal Power Meter v1.30
- Popp Dimmer v1.0
- Popp On Off Socket v1.0
- CBCC Sarl-Swiidinter
- Aeon Labs SES G2
- Aeon Labs Aeotec Smart Energy Power Strip (DSC11-ZWUS)
- Aeon Labs Micro Smart Energy Switch
- Aeon Labs Recessed Door Sensor
- Aeon Labs DSC26103
- Vision ZR1202 v1.74
- Vision Security ZS5101 v1.65
- Kwikset-Smart Code 916 v3.37
- Yale-T1L v18.128
- Yale Door Lock v80.32
- RTC-CT100 Thermostat v9.1
Other improvements:
- Improved stability
- PIN dfor new user is now set to '1111' by default
- In case of empty user PIN, it is set to default value - '1111'
- filters in /api/devices that allows for filtering out devices that meet some requirements, examples:
            HC IP/api/devices?visible=true returns devices with visible equal to 'true'
            HC IP/api/devices?property=[batteryLevel,100] returns devices with property batteryLevel equal to 100
            HC IP/api/devices?interface=light returns devices with light interface
            Multiple filters can be used together, for example: HC IP/api/devices?visible=true&interface=light returns devices with visible equal to 'true' and with 'light' interface
Home Center 2
Version 4.071 Beta
Resolved issues:
- Lua scenes: inappropriate line number in error debug
- EMINENT EM6570
- EMINENT EM6550
- BeNext-Dimmer
- Popp Dimmer v1.0
- Aeon Labs SES G2
- Yale-T1L v18.128
Other improvements:
- New actions in Lua scenes:
- fibaro:call(ID, 'startLevelIncrease', x, y)
- fibaro:call(ID, 'startLevelDecrease', x, y)
- fibaro:call(ID, 'stopLevelChange')
These calls can be used to start increasing or decreasing Multilevel Switches (like Dimmer 2, RGBW or Roller Shutter 2 modules) value. 'x' and 'y' are optional parameters, used to set respectively time frame in which change should be applied and starting level. 'stopLevelChange' stops previously send action.
- fibaro:getDevicesId(x)
Call used to get table with IDs of devices that meet requirement specified by 'x'.
Examples:
print('All devices with parameter visible equal to "true" and enabled equal to "true":')
ids = fibaro:getDevicesId({visible = true, enabled = true})
print(json.encode(ids))
print('ALl devices with energy interface:')
ids = fibaro:getDevicesId({interfaces ={"energy"}})
print('All devices with 'unit' property (no matter its value):')
ids = fibaro:getDevicesId({properties = {unit="nil"}})
Modifié par Lazer
Bon je lance et vais regarder un film pendant ce temps :)
Edit 1 :Par contre niveau Template ils se lâchent là:)
Edit 2 : Bon j'ai appuyé, go film.
Mais pas un seul qubino.... C voulu vous croyez ? ;)
Sent from my Note4
  • Upvote 5
il y avait donc bien un problème en 4.070 lol
Je confirme mais je vois pas ou p-e le moteur zwave...
je suis passé en 4.070 il y a 4 jours et ce soir en rentrant toutes mes lumières étaient allumées, certaines scènes bug ou se déclenchent hors de leurs scope (gestion horaire) donc je plussoie.
Bref le coté WAF en a encore prit un coup avec cette histoire de lumières.. sans compter des dimmers qui ne répondent plus physiquement (via smartphone ok)
Je vais tenter l'update plus tard ce soir
les stables pas stables et les betas stables. ou l'inverse. Merci Fibaro :13:
On se croirait dans Matrix, bref je prend une pilule et on verra !
Pour moi c'est la bleu de l'upgrade car Madame voit rouge ce soir :15:
  • Upvote 2
Si qu'un fait la mise à  jour et à  une powernode je suis intéressé par
bon j'ai une 4.28 mais le template doit être la maintenant
idem pour
