Hc2 & Hcl 4.082 Beta - 17/05/2016
jojo
Beta software changes list 4.082:
Version 4.082 Beta
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
- #0003605 #0003962 #0003962 Weather is not updating (weather information provider changed to yr.no)
- Trigger information is brought back to the way it operated in 4.080
- #0003094 Alarm panel doesn't record change of alarm state
- #0003958 Virtual Device main loop hangs
- #0003303 Remote Gateway synchronization moves devices to Unassigned
- Protection Command Class not working on devices without template
- 503 error when deleting section in some cases
- Malfunction of RGBW when changing controlled device to RGB
- NaN displayed in device serial number
- Scene Activation not working when triggered multiple times by the same id
- Mobile applications: Change of devices order not possible for non-admin users
Other improvements:
- Added support for Fibaro Button
- #0003844 Confirmation pop-up is now displayed when restoring or deleting backup
- Favicon added
- Satus bar is scrolled with page
- Notification Center is available directly on the status bar
  • Upvote 2
bon bah je me lance j'en ai marre des MAJ qui foirent mes mains loops dans les VD ou autres.
LAZER ton watchdog marche trop bien !!!
verdique dans 30/45 minutes.
A toute a l'heure!
Quid des anciens bugs et autres ?
Chez moi la 4.063 fonctionne pas mal. Qui va trouver les premiers nouveaux bugs.
@jojo peux tu modifier le poste 1 avec le Change log de la 4.082 uniquement
Update toujours en cours me concernant bloquée à9% àvotre avis je restart ? (Cette fois j'aurais attendu)
moi aussi fige a 9% mais après on ferme le browser on le relance on se connecte sur la box puis on vide le cache (Ctrl F5) et c est bon . ca me le fait quasiment àchaque MAJ. (Je ne reboot pas)
Titof je le sais mais encore une fois rien ne bouge 503.
La boite de conserve en alu vient de se prendre un reboot après une heure. Je relance maintenant....
sur le fofo Fibaro, il y en a qui ont débranché physiquement et rebranché pour l'erreur 503 avec success. (àfaire avec précaution et après un certain temps).
Jojo, je me suis aussi ouvert une bonne bouteille sinon je vais pas dormir... ;)
Au final je suis enfin revenu après le reboot et le startupgrade sur une version 4.080 contrairement a mon entre 2 qui était restée la même depuis ce post EDIT 2.
Bref je relance mon problème de ce soir était surement du a cela.
Je vous tiens informé.
