Krikroff 1 924 Signaler ce message Posté(e) 6 janvier 2015 Voici la V4.030 Pas de surprises pour les utilisateurs de la bêta. This version mainly concentrate on adding better support and integration for more devices (not only z-wave devices). Important part of software responsible for management z-wave devices was rebuild from the scratch for better support different devices types.New Home Center (HC) software introduces support for plugins. Plugins give support for new devices and new functionalities without modifying HC Firmware. Plugins can be used for controlling devices via different protocols and standards. Plugins have their own user interface and can call all APIs available on HC. Possibility of installing plugins developed by independent developers will be introduced in next versions.New functionalitiesDrag & Drop for devices and scenes – available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.Temperature Panel – allows to see history of temperature changes in rooms and on each device.Diagnostic Panel – general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.Soft Device Reconfiguration - option allows to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID..Mesh Network Reconfiguration - available on Configuration -> Z-Wave NetworkNew Z-Wave engine – redesigned and rewritten from the scratch. Now is faster and has better support for devices.Z-Wave Door Locks support – controlling and PIN settings.Thermostats – extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.Extended tamper for sensors – exclusive information for motion detection and violation of sensors.Fibaro Smoke Sensor extended support – level of smoke and gap to alarm level is reported and visible on charts. Sensitivity level is now easier to set.Fibro Motion Sensor new device – when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.Device hiding – device that is not in use can be hide without removing it.Device deactivation – deactivated device is visible in UI but can’t be controlled.Multithreading added for HC (server and z-wave) – now engines work much faster.Event panel moved – for better usability now is available in menu on right side of screen.Pre-Update Confirmation – installing update will prompt user additional confirmation.Added support for American English (EN-US)User rights management – moved to Configuration.Recovery Memory Health - can be checked on Backup & RecoveryBackups has information about compatibility with current HC versionBlock scenes improvements – for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.Lua Scenes – updated tooltips for devices.Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docsPlugins:Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, OthersPlugins searchNetwork devices search via ARPPlugins category Safety:DSC Alarm – for DSC Alarms,Helios Basic – integration using Basic license,Helios Gold – integration using Gold licenseMobotix – for Mobotix videophone,Satel Alarm – for SATELPlugins category Camerasmore than 100 devices from various manufacturersPlugin category ClimateCarrier FuranceWS Davis VantageNest - plugin for well-known thermostatNetatmo - plugin for thermostat and weather station from netatmoPlugins category MultimediaLG BlurayLG TV*NC + mediaboxXBMC Remote ControlDenon AmplifierLG BlurayOnkyo AmplifierPhilips BlurayPioneer AmplifierSamsung TV*SonosSony BluraySony TV** some TV Sets firmware version may not be supportedPlugins category OtherPhilips HueWake on LANOther changesMany other improvements to the system 3 Partager ce message Lien à poster Partager sur d’autres sites
tanguyj 3 Signaler ce message Posté(e) 6 janvier 2015 Enfin ! Ils ont tenu leur promesse ! Qui tente cette mise àjour tant attendue ? Je vais attendre les premiers retours avant de faire prendre un quelconque risque àmon chauffage en ce jour un peu froid .... Partager ce message Lien à poster Partager sur d’autres sites
maestrea 8 Signaler ce message Posté(e) 6 janvier 2015 Cette version a les ancients bugs du 4.024? P.E: Breached sensor with Arm Delay causes instant alarm after being armed C'est une question. Partager ce message Lien à poster Partager sur d’autres sites
carfnann 34 Signaler ce message Posté(e) 6 janvier 2015 on est sauvé, ils ont clôturé un bug aujourd'hui... Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 6 janvier 2015 je vois rien depuis le homecenter, c'est vraiment dispo ? Partager ce message Lien à poster Partager sur d’autres sites
azer31 5 Signaler ce message Posté(e) 6 janvier 2015 c'est parti pour moi ,j'ai pas grand chose a perdre Partager ce message Lien à poster Partager sur d’autres sites
latoupie 60 Signaler ce message Posté(e) 6 janvier 2015 Je prie pour vous Envoyé avec mes doigts Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 6 janvier 2015 La 4.30 et en dessous la 4.24 beta sont dispo dans l'interface de ma HC2 Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 6 janvier 2015 j'ai redemarré la HC2 mais je vois rien - la 4.24 a disparu - on peut lancer à distance ? je suis au taf la :-) Partager ce message Lien à poster Partager sur d’autres sites
azer31 5 Signaler ce message Posté(e) 6 janvier 2015 error 9 pendant le téléchargement retour a la page principal et puis maintenant je la voit plus Partager ce message Lien à poster Partager sur d’autres sites
Vince 7 Signaler ce message Posté(e) 6 janvier 2015 Bouhhh !!! Ca n'upgrade pas !! Update in progressUpgrade Error: 9 Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 6 janvier 2015 Pas àdistance Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 6 janvier 2015 @Sakkhho, tu peux essayer un redémarrage du HC2 Partager ce message Lien à poster Partager sur d’autres sites
HANSOLO 381 Signaler ce message Posté(e) 6 janvier 2015 Sur le forum officiel aussi des errors 9 Partager ce message Lien à poster Partager sur d’autres sites
Domodial 350 Signaler ce message Posté(e) 6 janvier 2015 lol je touche pas pourtant elle est a porté de doigts Partager ce message Lien à poster Partager sur d’autres sites
Zorro 20 Signaler ce message Posté(e) 6 janvier 2015 moi aussi : Update in progress Upgrade Error: 9 Partager ce message Lien à poster Partager sur d’autres sites
TonyC 450 Signaler ce message Posté(e) 6 janvier 2015 idem error 9 même après redémarrage, je vais réessayer... Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 6 janvier 2015 @Sakkhho,Si si c'est possible àdistance mais je déconseille vivement... Partager ce message Lien à poster Partager sur d’autres sites
Domodial 350 Signaler ce message Posté(e) 6 janvier 2015 J'ai toujours fait a distance, meme la 3.60 Mais j'avoue que celle làheu...non Quoi que je suis chez moi ce soir Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 6 janvier 2015 Prenez un ticket les serveurs vont tomber sinon ... hum c'est peut-être déjàle cas ! Partager ce message Lien à poster Partager sur d’autres sites
Sakkhho 467 Signaler ce message Posté(e) 6 janvier 2015 j'ai pas grand chose à perdre, ma config est plutot en mode test encore :-) c'est bon elle est revenue :-) Gogogogogogo 1 Partager ce message Lien à poster Partager sur d’autres sites
Zorro 20 Signaler ce message Posté(e) 6 janvier 2015 ptain ça sent pas bon .... Partager ce message Lien à poster Partager sur d’autres sites
juke94 5 Signaler ce message Posté(e) 6 janvier 2015 error 9 la même ! sont fort chez fibaro !! moi si je fais ce genre de mise en prod je prend la porte ! Partager ce message Lien à poster Partager sur d’autres sites
azer31 5 Signaler ce message Posté(e) 6 janvier 2015 qui démarre depuis une version stable ? Partager ce message Lien à poster Partager sur d’autres sites
Krikroff 1 924 Signaler ce message Posté(e) 6 janvier 2015 @Domodial, bon je sais que tu en meurs d'envie... Tu me diras Partager ce message Lien à poster Partager sur d’autres sites
