RS600807
    96
Tout ce qui a été posté par RS600807
  1. RS600807
    MQTT et Fibaro
    Merci @Lazer pour ton retour. J'ai réussi à mettre en place la liaison entre le broker, le QA (en cours de développement) et l'équipement qui diffuse les messages. J'ai une question concernant le message que je récupère : [20.12.2023] [21:05:09] [DEBUG] [DAIKIN ALTHERMA 3 ID:390]: onMessage: {"qos":0,"retain":false,"topic":"espaltherma\/ATTR","payload":"[{\"Operation Mode\":\"Fan Only\",\"Thermostat ON\/OFF\":\"OFF\",\"Defrost Operation\":\"OFF\",\"Error type\":\"Normal\",\"Error Code\":\" 0\",\"Outdoor air temp.(R1T)\":11.5,\"O\/U Heat Exch. Temp.\":0,\"Heat exchanger mid-temp.\":10,\"Liquid pipe temp.(R6T)\":0,\"INV primary current (A)\":0,\"INV secondary current (A)\":0,\"INV frequency (rps)\":0,\"INV frequency 2 (rps)\":0,\"STD Compressor 1\":\"OFF\",\"STD Compressor 2\":\"OFF\",\"Fan 1 (10 rpm)\":0,\"Fan 2 (step)\":0,\"I\/U operation mode\":\"DHW\",\"Thermostat ON\/OFF\":\"OFF\",\"Freeze Protection\":\"OFF\",\"Silent Mode\":\"OFF\",\"Freeze Protection for water piping\":\"OFF\",\"Error Code\":\" 0\",\"Error detailed code\":0,\"Error type\":\"Normal\",\"DHW setpoint\":47,\"LW setpoint (main)\":26.2,\"Benefit kWh rate power supply\":\"OFF\",\"Solar input\":\"OFF\",\"SG 1 contact status\":\"OFF\",\"SG 2 contact status\":\"OFF\",\"3way valve(On:DHW_Off:Space)\":\"OFF\",\"BSH\":\"OFF\",\"BUH Step1\":\"OFF\",\"BUH Step2\":\"OFF\",\"BPH\":\"OFF\",\"Water pump operation\":\"ON\",\"Leaving water temp. before BUH (R1T)\":21.9,\"Leaving water temp. after BUH (R2T)\":22.1,\"Inlet water temp.(R4T)\":21.8,\"DHW tank temp. (R5T)\":44.6,\"Indoor ambient temp. (R1T)\":20.8,\"Reheat ON\/OFF\":\"OFF\",\"Storage eco ON\/OFF\":\"OFF\",\"Storage comfort ON\/OFF\":\"OFF\",\"Powerful DHW Operation. ON\/OFF\":\"OFF\",\"Space heating Operation ON\/OFF\":\"ON\",\"System OFF (ON:System off)\":\"OFF\",\"LW setpoint (add)\":38,\"RT setpoint\":20.5,\"Add. Ext. RT Input Heat.\":\"OFF\",\"Main RT Heating\":\"OFF\",\"Pwr consumption limit 4\":\"OFF\",\"Pwr consumption limit 3\":\"OFF\",\"Pwr consumption limit 2\":\"OFF\",\"Pwr consumption limit 1\":\"OFF\",\"Tank preheat ON\/OFF\":\"OFF\",\"Circulation pump operation\":\"OFF\",\"Space H Operation output\":\"ON\",\"Flow sensor (l\/min)\":22.1,\"Water pressure\":1.9,\"Water pump signal (0:max-100:stop)\":24,\"Boiler DHW Demand\":\"OFF\",\"Add pump\":\"OFF\",\"Main pump\":\"OFF\",\"2nd Domestic hot water temperature\":46.3,\"Target delta T heating\":4,\"M5VIN\":\"5.04V\",\"M5AmpIn\":\"60mA\",\"M5BatV\":\"4.17V\",\"M5BatCur\":\"0mA\",\"M5BatPwr\":\"0mW\",\"WifiRSSI\":\"-75dBm\",\"FreeMem\":\"187284\"}]","dup":false} J'aimerais récupérer chaque paramètre de "payload" pour les mettre dans une table avec le nom du paramètre et la valeur qui lui est attribuée. Existe-t-il une fonction spéciale pour "décoder" l'ensemble de cette liste (jsonDecode)? Ou pas le choix faut-il créer des fonctions pour venir découper la liste et faire la reconnaissance des différents paramètres ? Autre question : est-ce que le fait que les noms des paramètres contiennent des espaces est un pb ?
  2. RS600807
    MQTT et Fibaro
    Salut @Domodial, Aurais-tu avancé dans l'utilisation et l'interfaçage de ta QA avec mqtt? Je demande ça, car je vais devoir me pencher de près dessus pour une utilisation prochaine pour mettre en relation ma PAC Altherma avec la box HC3. Le dialogue avec Daikin a fait l'objet de quelques posts par le passé, mais il est vrai que Daikin a plutôt verrouillé les choses... ou alors ils faut acheter toutes leurs passerelles qui ne transmettent finalement que peu de données! Je devrais ouvrir un topic à ce sujet prochainement afin de présenter mon projet et comment la solution que je souhaite mettre en place permet d'interconnecter le matériel. Je pense qu'il y a plein d'utilisateur que cela pourrait intéresser (mais aussi plein de variantes possibles selon les modèles de PAC). Je sais déjà que je m'aventure dans des terres inconnues (et que c'est largement hors champ de mes compétences), mais j'espère que les "pointures" de ce forum pourront être de bon conseil et éventuellement mettront la main à la patte pour donner un coup de pouce de temps en temps... Peut-être qu'une QA dédiée pour gérer les échanges mqtt entre le broker, les publishers et les suscribers pourrait décomposer les étapes en vue d'une réutilisation dans nos QA respectives ? Ou est-ce que ça alourdirait l'architecture ? des avis @Lazer ? @Nico ? @jojo ?
  3. Salut @minus87 et @andpierard, Je déterre un sujet un peu vieux, mais comme vous, je possède une PAC Daikin Altherma (bibloc BT Altherma 3R). Et comme vous, je suis assez "surpris" (enfin plus vraiment aujourd'hui!) par l'absence de support Daikin sur les problématiques d'interfaçage et de pilotage. Il existe des solutions avec des boitiers BRPxxxx mais de ce que j'ai pu lire sur les forums, ça n'apporte pas grand-chose et surtout ça multiplie les applis pour piloter/lire les infos (ou le peu d'infos finalement) renvoyée par la PAC. J'ai vu également fin novembresur le fibaro market une QA qui est sortie. Elle est payante (et encryptée) et il faut se doter d'une passerelle qui travaille en modbus (qui n'est pas donnée non plus). De mon point de vue, je trouve préférable de pouvoir centraliser les équipements de la maison via la box HC3 sans avoir à utiliser l'appli dédiée à chaque équipement. De nombreux et généreux contributeurs (par le temps qu'ils y consacrent et leur transmission de leurs connaissances) œuvrent largement sur ce forum pour harmoniser tout ce petit monde et optimiser nos différents équipements. Pour celles qui me concernent, j'utilise des QA comme GEA, Enphase, Airzone, Domocharts, Présence, Prévisions Météo, Vigicrues,... qui coexistent parfatiement et me permettent de gérer ma maison sans effort particulier. Aujourd'hui, je n'ai rien trouvé sur le forum qui traite d'un début de QA pour gérer les PAC Daikin Altherma, hormis ces sujets : - https://www.domotique-fibaro.fr/topic/3005-domotiser-sa-pac-daikin/ - https://www.domotique-fibaro.fr/topic/4929-plugin-clim-daikin/?tab=comments#comment-74194 (mais c'est plus pour les clim daikin) - C'est pourquoi il pourrait être intéressant de mutualiser les efforts et les connaissances de chacun pour créer une QA dédiée aux PAC Altherma. Ce sont des équipements performants, qui à l'heure de la transition énergétique, vont devenir de plus en plus courant dans les futurs foyers car bien réglés (c'est un critère évident, mais bien trop souvent sous-estimé !), ils restent peu énergivores. Pour ma part, je n'ai encore jamais fait de QA (seulement "bricoler" quelques adaptations de QA existantes pour mes propres besoins) car je ne maitrise pas les bases lexicales de cette programmation. Mais j'en comprends une bonne partie l'architecture et le fonctionnement. L'idée serait peut-être de s'inspirer des bonnes pratiques de programmation qu'on retrouve dans les QA de @Lazer ou d'autres (il reste notre étoile du berger mais il y a aussi de très bons contributeurs !) pour créer cette applir. D'ici quelques jours, je pense mettre en ligne sur un topic dédié ce que j'ai pu regrouper comme info et comment j'imagine le fonctionnement matériel et son interfaçage avec la QA. En attendant, si ce n'est pas déjà fait, un peu de lecture pour s'inspirer de l'existant :https://github.com/raomin/ESPAltherma et https://github.com/Arnold-n/P1P2Serial . A suivre...
  4. Salut @TitiXsi et @Lazer Merci pour votre super boulot. J'ai hâte de pouvoir tester tout cela très prochainement. Je viens d'opter pour 10 panneaux Trinasolar 425W bi-verre + MO enphase IQ8+ (les IQ7+ sont en rupture partout depuis plus d'un mois...) + GCE ecodevice RT2 pour monitorer les conso de différents appareils, histoire d'optimiser tout ça. Hte de vous partager mon retour donc !
  5. Bonsoir @Dragoniacs et @Lazer, Je rencontre le même souci depuis peu '(alors que le QA fonctionnait correctement jusque-là. J'ai vu que le centre de paquets DSM avait fait une mise à jour il y a peu (mais je ne peux pas confirmer la date exacte vu que je ne me sers que peu de ce QA). Je n'ai pas modifié les droits de l'utilisateur qui est rentré dans les variables du QA. Le message d'erreur affiché est : "Can't list cameras : Permission refusée". E le message de debug est : " Request new Synology SID". Si ca peut mettre sur la voie... A+
  6. Salut @jojo Merci pour ces infos. Je passe également par le nom de domaine que j'ai attribué à la box fibaro. Je suis également derrière un reverse proxy. J'ai donc essayé ce que tu m'as proposé (passer en local sur yubii). Je reçois bien la notification interactive, mais la réponse ne peut être envoyée. La seule différence notable que j'ai observée c'est que je ne reçois plus l'email "suspicious login attempt" que je recevais systématiquement à chaque tentative de démarrage de l'action interactive. Je n'ai pas plus d'explication à ce comportement, et je ne sais plus vraiment où chercher!
  7. Salut @jojo, J'utilise bien le compte admin et et quand j'ai fait des tests complémentaires avec le smartphone de ma compagne, son compte est bien déclaré en tant qu'utilisatrice avec les droits d'accès adéquats. Lorsque je fais ces tests, je suis bien en local. Retour à la case départ je le crois bien...hélas ! Est ce que ce serait une MàJ qui se serait mal effectuée?? un bug de ma box ? j'ai constaté depuis plus d'un an que dans mes notifications sur le dashboard, j'ai 2 messages de reconfiguration d'une prise walli qui ne disparaissent pas! la prise fonctionne pourtant correctement. C'est d'autant plus étonnant que vous ne rencontriez pas ce pb... Et comme il n'y a pas de magie en informatique, c'est bien que je passe à côté de qqchose!
  8. La seule piste que j'ai c'est que je sais la fonctionnalité a eu marché au tout début où j'ai acheté la HC3 (en fev 2021). A ce moment là, je fonctionnais avec le firmware d'usine (v5.050.xx je crois bien). Depuis j'ai fait les MàJ et suis actuellement en version 5.140.17 et la fonctionnalité ne marche plus depuis au moins la version 5.120. C'est surtout le mail automatique que je reçois "suspicious login attempt" qui me fait penser à un pb d'accès ou d'identification (comme si le smartphone n'était pas reconnu comme un appareil connu de la box HC3 - j'ai essayé avec le smartphone de ma compagne, même résultat). Pour le moment, sans connaissance ou compréhension du fonctionnement des messages interactifs, c'est un peu peine perdue...
  9. Salut @Lazer, Y'a pas de mal, tout le monde a le droit d'être pris par autre chose! Je suis quasi sûr que ce n'est pas un bug de GEA car je reçois bien la notification interactive, mais la réponse que je transmets via le smartphone est quant à elle rejetée (par la box domotique ? la box internet?). et j'ai testé également les notifications interactives dans un scénario bloc...et un scenario lua. même pb! J'avoue que par désespoir de cause, j'ai un peu lâché l'affaire depuis... D'autant que j'avais contacté le SAV Fibaro en leur expliquant le pb, mais ils n'ont pas trouvé de solution. Mon intuition me dit que c'est un pb de port ouvert ou non de ma box internet (qui fait office de serveur DHCP). Je n'ouvre que les ports nécessaires. Le pb est que je ne sais pas quel est le mode de fonctionnement utilisé par la HC3 pour transmettre les notifications. J'avais utilisé un scanner de ports et fait un scan de la HC3 mais je n'étais pas plus avancé. Si tu as une config réseau particulière ou si tu as des pistes, je suis prêt à relancer les hostilités :).
  10. merci @Lazer J'ai réinstallé la bdd. Et là tout semble fonctionner. Il y a certainement un fichier qui 'avait pas du être importé correctement dans le dossier du NAS... Il n'y a plus qu'à exploiter les données désormais. Merci de ton aide. Bon week-end!
  11. J'ai ce problème depuis le début. J'ai essayé de chercher si j'avais pu faire une erreur quelque part. Mais là c'est au dessus de mes "compétences" en programmation et en domotique. :))
  12. Bonjour, je rencontre un pb avec domocharts que je viens d'installer depuis quelques jours. Il me retourne le message suivant : DomoCharts:postAPI() https://192.168.1.99:443/domocharts/data.php => /usr/share/lua/5.3/json/decode/util.lua:35: unexpected character @ character: 8282 0:8282 [<] line: J'ai suivi les différentes étapes du tuto et il créé bien les tables dans la bdd sur le serveur web de mon NAS. En passant ne mode debug, je vois les différentes étapes où il interroge ma HC3, et il semble que les valeurs soient correctement relevées...jusqu'à l'apparition de ce message Auriez-vous une piste pour expliquer l'erreur que je rencontre ? Merci à vous.
  13. Bonsoir, Est-ce que quelqu'un rencontre des pb avec la fonction Ask sous GEA? GEA.add(true, 30, "", {{"Ask", 26, "test notif inter", "voulez-vous ouvrir ?", {"Close", 35, 85}}, {"Repeat"}}, "test notification interactive") Je reçois bien le message intercatif. Mais dès que je clique sur le "yes" (j'ai testé aussi avec le "no" au cas où !), je reçois une notif instantanément indiquant : "info: sending action "%@" failed" failed. Je reçois également un email m'indiquant "suspicious login attempt" avec une adresse IP. J'ai vu sur le forum forum.fibaro.com que des personnes ont déjà rencontré ce pb sur des versions antérieures, mais je n'ai pas trouvé de solutions qui résoud le pb... J'ai l'impression qu'il y a comme un filtrage et que la box ne veut pas accepter les messages entrant. Je suis en version 5.111.48 (beta). Je précise que je n'ai aucun soucis avec les notifications push "classiques". J'ai également testé la notification interactive en mode bloc et j'obtiens les mêmes soucis (donc a priori pas un pb lié à GEA) Quelqu'un rencontre-t-il le même pb ? Un bug de la dernière version ? Merci pour vos réponses.
  14. Salut Bloug, Merci pour ta réponse et ton fichier joint. En m'inspirant de ce que j'ai trouvé sur une autre QA, j'ai updaté la QA airzone comme suit: - elle crée 2 child devices (T°C et humidité) - il n'est pas nécessaire de revenir dans le code pour rentrer les ID des devices child, la gestion des classes s'en charge (du moins c'est ce que j'en ai compris) - il y a la possibilité de mettre un indicateur sous le nom du device qui te retourne un commentaire : par exemple si dans tes critères (qui restent paramétrables) tu estimes que la température optimale de ta pièce est comprise entre 21 et 23°C, alors il t'affiche "optimale"). C'est un petit plus que je trouve sympa. Ci-dessous le fichier si ça t'intéresse d'y jeter un oeil. Il y a peut-être moyen d'optimiser les choses ou de faire plus propre. Mais en l'état cela me convient (pour un novice en LUA). A l'occasion dis moi ce que tu en penses. A+ Airzone+Child.lua
  15. Salut @Bloug, Je m'intéresse comme toi à la création des child à partir de la QA Airzone. Même si cette QA est déjà plutôt bien pour pouvoir récupérer les infos avec le système airzone, je trouve effectivement dommage de ne pas pouvoir obtenir plus '"directement" (au lieu d'avoir à cliquer sur l'icone pour voir les infos) la valeur de température et d'humidité. C'ets la que prend tout son sens la notion de child. Débutant dans l'apprentissage du LUA, je m'efforce de lire les tuto et les pages du forum. Pas toujours simple, surtout quand on n'est pas du domaine et que les cours d'informatique sont déjà loin ! Je ne sais pas trop où tu en es dans le développement de ton code, mais je vais m'y pencher dessus. Je suis en train de m'inspirer d'autre QA qui gèrent des child pour pouvoir l'adapter à la QA airzone. Si tu as des choses nouvelles, n'hésite pas à faire signe. Merci de ton retour.
  16. Merci dragoniacs, lazer et jojo pour vos réponses. Il faut en effet apprendre à jongler avec la dimension séquentielle de GEA. Maintenant que j'ai un peu mieux cerner le fonctionnement avec vos différentes explications, le "sleep" prend tout son sens. J'ai donc réussi à mettre en place la gestion de mes différents profils, moyennant un délai de 30s avant activation. Pour ceux à qui ça pourrait aider, voici ce que ca donne avec en plus la gestion des alarmes : -- *** Profils de la box disponibles : 1=HOME / 2=AWAY / 7=NUIT / 5=FRIENDS / 8=MANUEL -- *** Mise en cache du profil GEA.add(true, 30, "", {"VariableCache", "Prev_Profile", "#profile#"}, "Mise en cache du profil") -- *** Activation des profils -- 1=HOME GEA.add({{"VariableCache", "Jour_Nuit", "Jour"}, {"Or", {"VariableQuickApp", 190, "PRES_STEPHANE", true}, {"VariableQuickApp", 201, "PRES_LISE", true}}, {"VariableCache!", "Prev_Profile", "FRIENDS"}}, 30, "", {"Profile", "HOME"}, "Mode HOME activé (par détection de présence)") -- 2=AWAY GEA.add({{"VariableCache", "Jour_Nuit", "Jour"}, {"VariableQuickApp", 190, "PRES_STEPHANE", false}, {"VariableQuickApp", 201, "PRES_LISE", false}}, 30, "", {{"VariableCache", "Prev_Profile", "#profile#"}, {"Sleep", 30, {"Profile", "AWAY"}}}, "Mode AWAY activé (par détection de présence)") -- 7=NUIT GEA.add({{"VariableCache", "Jour_Nuit", "Nuit"}, {"Or", {"VariableCache", "Etat_Steph", true}, {"VariableCache", "Etat_Lise", true}}}, 30, "", {{"VariableCache", "Prev_Profile", "#profile#"}, {"VariableCache", "Etat_Steph", true}, {"VariableCache", "Etat_Lise", true}, {"Sleep", 30, {"Profile", "NUIT"}}}, "Mode NUIT activé (par détection Jour/Nuit)") -- 5=FRIENDS GEA.add({{"VariableCache", "Jour_Nuit", "Jour"}, {"Or", {"VariableQuickApp", 190, "PRES_STEPHANE", true}, {"VariableQuickApp", 201, "PRES_LISE", true}}, {"VariableCache", "Prev_Profile", "FRIENDS"}}, 30, "", {"Profile", "FRIENDS"}, "Mode FRIENDS activé (par restauration mode précédent)") --8=MANUEL --à compléter -- *** Gestion des alarmes *** GEA.add({"Profile", "HOME"}, -1, "", {{"SetDisarmed", {1,3,4}}, {"Portable", "26", "Mode HOME activé à #time# / Alarmes désactivées"}}, "Mode HOME activé / Alarmes désactivées") GEA.add({"Profile", "AWAY"}, -1, "", {{"SetArmed", {1,3,4}}, {"Portable", "26", "Mode AWAY activé à #time# / Alarmes activées :ext., garage & maison"}}, "Mode AWAY activé / Alarmes activées : Extérieur, Maison et Garage") GEA.add({"Profile", "NUIT"}, -1, "", {{"SetArmed", {1,3}}, {"Portable", "26", "Mode NUIT activé à #time# / Alarmes activées : ext. & garage"}}, "Mode NUIT activé / Alarmes activées : Extérieur et Garage") GEA.add({"Profile", "FRIENDS"}, -1, "", {{"SetDisarmed", {1,3,4}}, {"Portable", "26", "Mode FRIENDS activé à #time# / Alarmes désactivées"}}, "Mode FRIENDS activé / Alarmes désactivées") GEA.add({"Profile", "MANUEL"}, -1, "", {{"SetDisarmed", {1,3,4}}, {"Portable", "26", "Mode MANUEL activé à #time# / Alarmes désactivées"}}, "Mode MANUEL activé / Alarmes désactivées")
  17. Merci pour vos premiers retours. Je viens de tester : le fait d'ajouter la tempo permet effectivement de valider l'évènement demandé. A indiquer dans une prochaine mise à jour de GEA ? Néanmoins, après test, je me rends compte qu'il n'initialise pas la variable en cache car lorsque j'appelle mon 2e évènement (retour au mode précédent), il ne revient pas au mode précédent... GEA.add(true, 30, "", {{"VariableCache", "Prev_Profile", "#Profile#"}, {"Sleep", 30, {"Profile", "AWAY"}}}, "Mise en cache du profil") GEA.add({"Time","16:48","18:50"}, 30, "", {"Profile", {"VariableCache", "Prev_Profile"}}, "Activation mode précédent") Est-ce que la mise en cache nécessite d'activer une option dans un GEA ? J'avoue que que je sèche... par ailleurs, en faisant un print(Prev_Profile), il devrait pouvoir m'afficher ce que contient la valeur en cache Prev_Profile, non ?
  18. Bonjour, Je rencontre une difficulté avec GEA 7.37 concernant l'utilisation de VariableCache. Je souhaite récupérer le profil actif avant changement vers un nouveau profil. Voici mon code : GEA.add(true, 30, "", {{"VariableCache", "Prev_Profile", "#profile#"}, {"Profile", "AWAY"}}, "test de verif variable en cache") Voici l'erreur qui apparait : [ERROR] [QA_GEA_205]: Ajout auto #6 : Activation mode précédent Règle exclue : ./include/main.lua:1940: attempt to index a nil value (local 'profileId') j'ai vu sur le forum que Dragoniacs avait rencontrer la même erreur sur la version GEA 6.xx (15 mars 2021). Mais j'ai essayé toutes les solutions proposées et rien ne fonctionne, ça ne s'initialise pas... Je suis novice, je dois rater quelquechose. Si quelqu'un peut m'aiguiller, car là je capitule! Merci.
  19. Bonjour, Je suis Stéphane, je vis sur le bassin d'Arcachon et heureux détenteur d'une HC3 et d'une vingtaine de modules en Zwave (VR, détecteur de mvt, sonde T°C, relais...). Etant tout nouveau, je découvre petit à petit le forum et les informations qui y sont partagées. Il y a encore 1 an, je n'y connaissais rien en domotique et les solutions existantes. Aujourd'hui, je n'y connais pas grand chose de plus, mais je ne désespère pas de faire des progrès notamment en LUA afin d'optimiser les scenarios que j'ai déjà mis en place (qui restent basiques avec le mode "bloc de scène"). J'ai notamment pour "ambition/projet" de : - créer un scenario intelligent permettant de réguler de manière optimale la température à l'intérieur de la maison (actionner les volets roulants en fonction des conditions météo extérieures, de la saison, des retours des capteurs à l'intérieur, de la sonde extérieure,...) - créer un scénario d'arrosage automatisé du jardin (en fonction de la météo passée, actuelle et à venir) - implémenter des fonctions de géolocalisation pour régler de futur scenarii en fonction de la présence - utiliser une autre interface graphique que je déploierai sur mon NAS, car même si les appli et interfaces de pilotage proposées par Fibaro font le job, cela reste assez peu personnalisé et pas tjs bien agencé à mon goût. J'ai notamment vu qu'on pouvait faire des choses beaucoup plus sympa avec des choses comme Home Assistant ou Grafana, mais j'imagine que c'est un niveau au dessus ! J'espère donc trouver sur ce forum les informations, conseils et les bonnes astuces quand cela sera nécessaire; et vous remercie donc par avance de l'aide que vous pourrez m'apporter. A très bientôt. Stéphane.
