781 -
38
Tout ce qui a été posté par TitiXsi
TitiXsi a répondu à un(e) sujet de Lazer dans Mon installation domotique
Tu nous diras si on a toujours accès aux données Via nos hc3- 1077 réponses
On vient juste de terminer l'enduit de l'année dernière... V5 vers v7... Bon de toute manière, on aura pas le choix, ça sera fait un soir à 23h et ça va gueuler sur tous les forums... Tu as eu cette information de quel biais ?- 1077 réponses
Quick App - Enphase Envoy (Fork from TitiXsi)
TitiXsi a répondu à un(e) sujet de TitiXsi dans Quick App Developpeur
Hello , Your english seems nice and dont worry, my english is not wonderfull I have facing some issue when my Envoy was linked in Wifi, A lots of tatency was cumumlated and somthimes, the Envoy was saturated... Since I have pluggued it in RJ45, I have less issue, but some occurnece are present : Have your respected the order ? 1. Added the QuickApp 2. Added the Icons png 3. Set the ID of the icon into the Local variables > SAVE IT 4. Set the login and password of your account > SAVE IT 5. Follow the QA gui to then push the Button to generate the first Childs (the ID of the Icons are taken at this time) By definition the Balance is PROD - Consumed , so if you have produced 10kwh and consumed 10kwh, your balance is ZERO. It's the same in LIVE, today of Lifetime I think You are lookign for the part of auto-consumption, which is not computed here. The management of the Units is a problem, if not found how to change it, because it was defined at the creation of the Child. And after the creation, the update of the unit is not taken into account. You can add your childs of developp a QA which is using the value of the QAenphase Seems a very nice Country, but unknown from my side :'( I hope you have a better Sun than us in France in this end of April ... -
Servomoteur pour actionner un bouton rotatif
TitiXsi a répondu à un(e) sujet de vravolta dans Actionneurs & Ouvrants (Portail, volets, piscines, ...)
Hello, J'ai piloté ma VMC double Flux qui a une entrée à potentiomètre rotatif pour sélectionner la vitesse. J'ai simplement relevé les tensions à l'entrée et à la sortie du potentiomètre. 0-12v. J'ai supprimé le bouton et mis un gradateur zwave 0-10v (je perds 2v qui correspond à la vitesse maxi, qui est très très très peu utilisée chez moi). Ca foncitonne depuis 1an, c'était ma première domotisation. Le fil est ici : Si ca peut t'aider -
Ici, je serai un peu plus modéré surtout sur le Zwave (je n'ai pas de Zigbee). Mes devices sont de plus en plus loin de la HC3 en terme de noeuds.. Avant j'avais 1 ou 2 devices qui était à 4 noeuds, aujourd'hui j'en ai 8... (Ne pas tenir compte de mes Télécommande Nodon qui ne renvoient pas ces infos) Est-ce que quelqu'un à constaté quelque chose de similaire ?
En fait c'était déjà dispo depuis quelques versions. Je m'en sers quand je me dis tiens ça serai bien de... En 1min c'est créé. Ensuite je la reprends via l'administration et la paufine en l'UA comme les autres. Mais le code généré en lua est très condensé.
Cette merdouille ... Il y a plusieurs version de Chipset sur ces HC3 ?
No clamp, no live detection Sorry, I have enough time to check the code. I let you trying to comment the corresponding line of the detection and force it to true. -
https://enphase.com/store/communication/consumption-ct They are very Big 5cmx3cm Each clamp allow the report of ampers and the computation of power -
On Enlighten application, have you the report of the production ? have you a Ampermetric Clamp into your Electic Board ? -
You have a envoy metered or normal ? Which version ? Which clamps (consumprion and production) ? Can you redo the import fromage scratch? Can you show us only the dedicated room where the qa is placed (enphase)? Can you show us the view of the Quick app AT each step? -
Hello. Have you see the movie describing the installation and usage ? All chlids are created when you click on the button. But you need to be register with your credentials in local variables. Then follow the qa status icon and processes into the gui. -
FW 5.160.30 Upgrade fait, tout en restant sur yubbi 1.21.1. Premier retour, Design des QA assez sympa. Le nouveau jeu d'icones est également sympa avec plus de cohérence entre eux. A suivre !
Wahou, un client !
Hello, je suis en train d'améliorer une QA que j'ai écrite qui m'envoie un push quand j'ai des devices dead, ca fonctionne tr_s bien depuis 6mois, mais là j'ai des shelly qui par moment sur déconnecté, il suffit de faire un reveil et ils reviennent... je veux du coup faire un réveil automatique pour les devices dead dans ma QA, mais je ne trouve pas la commande lua qui correspond ... auriez vous une piste ? Merci Edit : j'ai peut-être pas assez cherché hub.wakeUpDeadDevice(<ID>)
Compatible V3-V4-Lite Aeon Labs - Aeotec - Heavy Duty Switch - ZW078
TitiXsi a répondu à un(e) sujet de Shyrka973 dans Aeon Labs / Aeotec
Hello, je viens de rencontrer un "bug" sur celui qui gère mon cumulus... Depuis 2jours il m'indiquait 1,945w éteint, comme allumé. Le switch fonctionnait bien, seule la remonté d'info de puissance qui était figée. J'ai débranché puis rebranché et toujours idem, j'ai recommencé en laissant 10sd avant de le rebrancher et la puissance est re-venue ok. EDIT : Je n'ai pas de souci avec les 2 autres (plaque à induction et four), mais c'est le seul que j'utilise en commutation. Aviez vous déjà rencontré ce genre de "bug" ? Si oui avez vous pu automatiser un "reset" via une commande ? Merci- 72 réponses
- compatible v3-v4-lite
- zw078
Là on est bien d'accord... Surtout si la garantie de trouver des pièces est de 10ans... Bon, c'est pas uniquement valable pour les volets roulants... On a le même problème avec les voitures d'aujourd'hui. Tellement spécifiques que faire réparer une voiture qui aura 15ans en 2030, sera impossible... Avant les pièces d'usure étaient partagées, à minima dans la marque, voir dans le réseau de la marque ou des fabriquants de pièces, Valeo, Lucas, ... J'ai 2 voitures, 260 000 km et 450 000 km, elles respirent la santé moteur et grimpent tous les jours 700m de dénivelés à 15%. Oui elles sont vielles, polluent un peu plus à l'instant T. Mais combien de déchets on élimine en ne fabriquant pas de nouvelles voitures ou en évitant de les recycler avant terme... Bref, j'avais envie de me lâcher.
Alors, non, je pense que je vais prendre l'elec dehors vu que le moteur sera dehors. Donc soit, - je me passe de commande manuelle, ce qui peut être merdique surtout quand on débute avec un nouveau module - Soit je trouve une solution tierce
C'est un peu différent chez moi. Maison ossature bois. Je m'interdit un trou qui traverserait extérieur/ intérieur. Enfin de garantir mon étanchéité à l'air. Du coup, va falloir réfléchir un peu pour la liaison filaire télécommande vers le moteur (qui sera côté extérieur abrité).
Effectivement vu comme ça, Donc en gros, faut miser sur la qualité de la motorisation, avec commande filaire et monter un Roller Shutter dessus Bon, ca va me faire des trous de partout cette histoire
Hello, j'envisage l'installation de volets roulants. Vu que je suis équipé en HC3 depuis 1 an, je me pose la question de savoir quoi prendre pour avoir une bonne compatibilité avec cette box. Il y a surement plusieurs solutions possible, du natif NICE au passage en roller Shutter ... Bref, si vous avez des conseils et retour d'expérience sur le sujet, je suis ouvert, car n'ayant encore aucune installation, tout est possible (moyennant le porte feuille :). Merci la team !
Application mobile pour smartphone et tablette Yubii Home
TitiXsi a répondu à un(e) sujet de Lazer dans Applications Smartphones et Tablettes
Réponse ... -
TitiXsi a répondu à un(e) sujet de fredokl dans Applications Smartphones et Tablettes
Hello. Vu qu'une nouvelle app a vue le jour, voici la réponse du support pour l'ancienne Hello Remi, Currently, we have no detailed information about how long the older app (Yubii Home Center) will be supported, but I can assure you it will be as long as possible because many Fibaro users still use it. Have a nice day! -
Effectivement, mais si les updated de FW nécessite la nouvelle appli, je suis coincé... D'ailleurs, je n'ai toujours pas de réponse officiel du support sur ce point -
Réponse du support Fibaro :
