785 -
Tout ce qui a été posté par q.philippe
Tester aussi impeccable. simple et sympa, bien ses allemands lol Mr BoomX. traduction : copier/coller/allumer copier script en scène lua, mettre Mdp id ...sur les 4 premières lignes. il te sort une adresse ip, celle de la cam welcome. script de BoomX propriétaire de l'intelligence : --[[ %% properties %% globals --]] -- Mr BoomX création -- -- DIESE DATEN ANPASSEN local client_id = '563a7XXX69f74027aXXXX' local client_secret = 'OmHqQ551M6WXXXbTgGMWNYfiT1lZxHXXXXX' local username = 'boomx@siio.de' local password = 'XXX' local language = 'german' -- german/english -- AB HIER NICHTS MEHR ANPASSEN local token = '' local request_body = '' Debug = function ( color, message ) if (debug == 1) then fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span")) elseif (debug == 0) then end end DebugChange = function ( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span")) end DebugError = function ( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span")) end fibaro:debug('netatmo welcome cam finder v1.0b') if (language == 'german' or language == 'english') then DebugError( "green", "Debug: " ..language) else DebugError( "red", "Please choose a language for debug") fibaro:abort(); end local sourceTrigger = fibaro:getSourceTrigger(); function oAuth(nextFunction) local request_body = 'grant_type=password&client_id=' .. client_id .. '&client_secret=' .. client_secret .. '&username=' .. username .. '&password=' .. password .. '&scope=read_camera access_camera' getResponseData('https://api.netatmo.net/oauth2/token', request_body, function(data) if (data.access_token ~= nil) then token = data.access_token gethomedata() else if (language == 'german') then DebugError( "red", "oAuth-API-Call konnte nicht durchgefà¼hrt werden! oAuth 2.0 lieferte keinen Wert zurà¼ck") elseif (language == 'english') then DebugError( "red", "oAuth-API-Call Error. oAuth 2.0 returns nothing.") end end end ) end function getResponseData(url, body, func) local http = net.HTTPClient() http:request(url, { options = { method = 'POST', headers = { ['Content-Type'] = 'application/x-www-form-urlencoded;charset=UTF-8' }, data = body }, success = function(response) func(json.decode(response.data)) end }) end function gethomedata() request_body_cam = 'access_token=' ..token.. '' getResponseData('https://api.netatmo.net/api/gethomedata', request_body_cam, function(getData) --fibaro:debug(request_body_cam) if (getData.body ~= nil) then if (language == 'german') then DebugError( "green", "API-Call durchgefà¼hrt.") elseif (language == 'english') then DebugError( "green", "API-Call was done.") end for w, v in pairs(getData.body.homes) do for a, b in pairs(v.cameras) do if (b.is_local) then if (language == 'german') then DebugError( "green", "Lokale IP der Kamera gefunden.") elseif (language == 'english') then DebugError( "green", "Local IP of cam was found.") end findLocalWelcome(b.vpn_url) else if (language == 'german') then DebugError( "green", "Lokale IP der Kamera NICHT gefunden.") elseif (language == 'english') then DebugError( "green", "Local cam NOT found.") end end end end else if (language == 'german') then DebugError( "red", "API-Call fehlgeschlagen") elseif (language == 'english') then DebugError( "red", "API-Call Error") end end end ) end function findLocalWelcome(url) local selfhttp = net.HTTPClient({timeout=2000}) url = url..'/command/ping' selfhttp:request(url, { options={ headers = selfhttp.controlHeaders, method = 'GET', timeout = 5000 }, success = function(status) if status.status == 200 then if status.data ~= nil then --print(json.decode(status.data)) for k,v in pairs(json.decode(status.data)) do if (k == 'local_url') then local cam_url = v local url_new = string.sub(cam_url, 8, #cam_url) one, two = url_new:match("([^,]+)/([^,]+)") fibaro:debug('Cam-IP: '..one) fibaro:debug('JPG-Stream: /'..two.. '/live/snapshot_720.jpg') DebugError( "green", "coded 4 siio.de/siio.com") end end end else print ("failed") print(status.data) end end, error = function(error) print "ERROR" print(error) end }) end oAuth() restes a savoir si sur syno on peut récupérer l'ip interne, ou celle de hc2.
Topic unique Boîtier Connecté Pour Voiture Xeeconnect
q.philippe a répondu à un(e) sujet de tibahut dans Périphériques et matériels autres
welcome D'autant plus, hc2 est le seul a ne pas avoir de plugin xee encore lol -
Intéressant , Je vois qu'il prend chacon , donc prise Di-o et peut être Myfox. Dites moi, On ne peut vraiment additionner un meme module sur deux box différentes avec le z-wave ? (Sauf passer par l'api de l'une) Cloud=Clown [emoji35] surtout qu'ils sont responsable de la securite du site, Localement ca repose sur le domicile, moins de responsabilité ...brrr
En discutant avec support, il test des fonctions autres tels que : ouverture des portes, ... Le mieux est de vous mettre la discussion : Je vous remercie pour ce message. L'ouverture et fermeture des portes ou des feux nécessitent un outil répondant au protocole OBD. Le XeeConnect procède àla lecture des informations disponibles sur le bus CAN d'un véhicule, il repose donc sur le protocole CAN seulement. De ce fait, et àl'heure actuelle, le XeeConnect ne pourra pas procéder àce type d'action, seul un outil reposant sur le protocole OBD le peut. Je reste àvotre disposition. Cordialement, Mehdi Support Xee -
ÇA vaut le coup, l'application est bien, pratique, d'où aller plus loin,,, différentier positionnement smart différent de la voiture donc différent scenario possible ou cas Mr ET Mme utilisé meme voiture mais un est encore àla Maison , tu multiplies la précision de tes scènes ! A part l'api rien àdire sur CE boîtier : rempli mes attentes ! -
Magin--> tu l'as toi, CA a marcher? Ha ha . pour quand pour quand. -
J'ai fais une box Jeedom Pour justement Xee en juin. Meme pas connectée dessus ... comment te dire. Balot [emoji322] -
Merci magin. Le plugin je l'ai (Pas si naze) . Mais impossible de le relier a Xee est mon problème justement. Avec Jeedom ou script sur server php de Tibahut.... je ne remets pas en cause le plugin mais sûrement la façon de se connectée sur API Xee. -
Mon envoie. On est plusieurs àne pas réussir àLE connectée se boîtier. Pour vous répondre : c'est a la fin , sur l'authentification sur le serveur Xee que 404. Jeedom--> je suis sur docker syno, mon port est déjàredirectionner autre que '80'. Deux : je suis en Jeedom Basic donc Pas de DNS Jeedom (exclu en basic) mais j'ai une freebox ET j'ai un DNS interne. Sur Fibaro : j'ai dépose un script sur server php, et apparemment pas de redirection de port a faire. Si vous voulez POUR un échange cordiale plus sympa, joignez vous au forum, les retours de chacun sont très utile . Moi c'est philippe, Pas Mr reseau de l'email lol. Nos échanges seront plus rapide et vos ventes aussi lololol que d'argument Hihihi. -
A savoir une : je suis en Jeedom docker syno donc une mon port est déjàrediriger autre que 80. ET je suis en Basic Jeedom donc pas de DNS jeedom. De deux : meme problème avec script php ,,, mais la je crois , Pas de port direct puisque c'est le php qui fait la liaison interne.???! 'Tibahut'. AVIS pour retour . Brrrrr -
Bon... plusieurs essayé sur Jeedom , hc2 en script php sur server. ERREUR 404 Lors de la demande authentification du script sur les serveurs xeeconnect. Demande d'aide au support Xee : support@xee.com ---> a l'attention de Mr julien Leconte ( vu le message, très gentil ) Réponse amicale : Support Xee (Support Xee) 26 oct. 17:05 CEST Bonjour M. Reseau Je me présente, Julien, Customer Happiness Officer chez Xee, en charge de la qualité produit et également utilisateur Jeedom àtitre personnel Je vais essayer de comprendre votre soucis car, j'ai rencontré la même erreur cette semaine avec le plugin XeeCloud et Jeedom. Ce plugin n'étant pas développé chez nous, je ne peux pas m'assurer qu'il s'agit du même problème que le mien. J'ai par ailleurs posté ma problématique dans le forum mais n'ai pas reçu de réponse. Toutefois, j'ai réussi àle faire fonctionner entre temps. Le lien vers le forum àtitre d'info : https://www.jeedom.com/forum/viewtopic.php?f=28&t=11248&p=388197 J'ai constaté qu'en passant par la redirection DNS de Jeedom, j'avais d'énorme soucis (et pas qu'avec ce plugin) en recevant des erreurs 500 et, quand j'arrivais finalement àla passer, des erreurs 404 sur la page Xee. J'ai donc modifié la config Jeedom pour écouter également le port http "82", que j'ai pu rediriger dans ma box Internet. De ce fait, j'utilise désormais un autre DNS (celui de mon NAS Synology) pour accéder àma Jeedom. Sous Jeedom dans le paramétrage réseau externe, j'ai entré mon nouveau domaine HTTP : MaBox.Synology.me port 82 J'ai ensuite récupéré le lien de redirection du plugin Xeecloud, àfournir dans l'espace Dev type : http://Mabox.synology.me:82/plugins/XeeCloud/3rdparty/oauth.php J'ai ensuite recréé une app sur l'espace Dev.Xee.com en y entrant ce lien et rentré de nouveau mes clés dans le plugin. Ensuite cela fonctionne comme avant. Je viens de le refaire àl'instant et, la première fois j'ai récupéré une 404 (peut être une mauvaise manip de ma part). La seconde fois c'est passé, j'ai pu ajouter mon véhicule ainsi que le second dans la foulée sans soucis. Je ne sais pas si ces recommandations vous permettrons de trouver la solution, mais si vous passez par les DNS Jeedom, c'est peut être làque ce situe le problème. N'hésitez pas àme remonter les informations Cordialement, Julien Leconte Plus on sera plusieurs mieux serait ce ! Nico [emoji14] -
salut Ou en est le vd et script ? faut il avoir un serveur web ouvert de l'extérieur ? donc fichier ouvert ? ou stocker le script de l'extérieur ? merciiii ((im envoyer a tibahut)) V2 = j'ai une erreur line 75 ::: doctor---adresse du patch? la redirection url : ip/web/Script/xee ou ip/web/xee/index.php ? -
Commander L'hc2 (Et Hcl) Via Homekit Et Siri
q.philippe a répondu à un(e) sujet de kiwi dans Domoticz
je parle de plusieurs programme sur un même rpi avec le même os. faire tourner , bridge, jeedom par ex ou autre sur le même rpi? -
Petite demande, sur un RPi avec Homebridge sd peut on utiliser le raspberry avec un deuxième système dessus en meme temps ? Possible de faire tourner deux ou trois systèmes avec un rpi simultanément ? armv61 -
Tuto HC2 Modes Éclairage Auto/manuel Waf
q.philippe a répondu à un(e) sujet de sebcbien dans Tutoriels
salut j'ai fais cela (sans se rendu) pour la fermeture baie . si je veux la baie ouverte plus tard que prévu (jardinage tardif), max a une heure défini je passe par dessus manuel. ( idem pour la détection mouvement et l'éclairage ) pour un mode manuel. après c'est un module type variables qui te reprend toutes tes variantes mode. (mode baie, mode détection,mode présence lolol) -
pas besoin de traduction pour réussir ,,,, : Pour raspberry la video du dessus nickel : 2h de boulot ( 1h de téléchargement env module (lib, homebridge ) et fonctionnel après tout celà . (((((( plugin-fibaro-hc2 , user--->: admin sans non operationnel )))) Intégration Domicile (iOs) nickel. Pour Mac os : j'essayerai le même procéder -
Bon, Apres prendre le poul de tous les retours des users ici présent : Homebridge Non fonctionnel ( sur LA durée ). Raspi image v2-maconly: problème deamon Docker: bug nas. Je vais réessayer sur Mac OS. -
moi ça tourne sur syno docker et je referai une installe sur raspi. j'avais suivi l'image poster mais ne marche pas pour moi donc je repartirai a la base. dites moi : j'ai un problème pour intégrer une appli .((xeecloud).. (je n'ai pas créer de HTTPS) quelqu'un a t il réussi a créer un auto-signé ? process !
salut MaJ 4.100 faite ras, par contre dans mes scènes pas possible d'accéder au notification par user ? aucun user dans les notification ,,vide? because
Plugin Developer Installer Un Plugin Utilisateur En 4.0.x
q.philippe a répondu à un(e) sujet de darklite44 dans Plugins Developpeur
Comme ca un a la fois, tu passes pas par un fichier zip ? Tu es en quel firmware ? -
Meme problème que jossalf, LSB Start deamon a boot Time . ??? Homebridge.service start. Rpi B - sd de 16. -
/root/.homebridge/config.json ------ PERMISSION denied ,,,bizarre et en sudo ! -
Master, ben je mis remets en se moment justement! j'etais sur docker (40% process),,,, j'essaye l'image sur raspberry. today install l'image sur carte (16Go), je viens de changer passwd, ip config dhcp,! me reste le fichier homebridge. -
pour info tardif. j ai une Vision ZM 1702 EU de vision security que j'ai branche en usb (5v au lieu de 6 donc 67%) et pile rechargeable dessus en cas de coupure edf. point faible : bruit mais pas gênant démontable en 3 min. ou un coup de marteau. point fort : verrouiller une porte . bref lol
