1484 -
29
Tout ce qui a été posté par TonyC
Faut jamais écouter mon petit doigt Tu as raison, faudra espérer que si investissement il y a eut sur zigbee, ils pourront capitaliser dessus au passage sur thread, enfin s'ils y vont, ce dont je doute pas (ça me rassure de dire ça) .
Peut-être est il déjà là et on ne le sait pas. Qui sait Plaisanteries mis à part, je pense que ça ne devrait plus trop tarder, mais ce n'est que mon avis, je pensais vraiment que cette version allait l'embarquer, mais me suis trompu .
Update passé RAS, pour le moment ...
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Alarm Added checking sensors status before arming the alarm. Dashboard Added translations for thermostat modes on dashboard tiles and sidebar. Added possibility to open device settings directly from device tile. Improved styling of units for sensors on dashboard and sidebar. Changed icon for opening sidebar from device tile. Devices Updated parameters template for Nice BiDi-Shutter and Nice BiDi-Awning. Added support for Eurotronic Air Quality Sensor. Improved handling of long operations for Color Controllers and Multilevel Switches.** Added support for new revisions of Fibaro devices. Default configuration for RGBW441 set as RGBW after adding device to the system. Added rounding for virtual power consumption values. Added support for Donexon thermostatic valve.** Custom parameters for Z-Wave devices sorted by ID. Elero* Improvements for pairing process. Improved polling mechanism for Elero devices. Energy Warning about unsaved changes in Panel Settings. Added support for declaring fixed cost for a period. General Optimized calculation of sunrise/sunset time. Network Improved changing network settings between DHCP and Static. Nice* Added possibility to Read, Set default and Reset all parameters in devices settings. Changed default role for mono-directional devices from remotes to Blinds/Gates. Added requesting current parameters values during pairing process. Added possibility to configure and use favourite position for mono-directional devices. Other Improved auto-logging feature. Plugins Thermostat & Heating Zone plugin optimization. Added possibility to set the URL manually for Dahua plugin. Quick Apps Changed function calling format (backwards compatible). Changed auto-complete function for new function format in Lua. Scenes Changed functions calling format (backwards compatible). Changed auto-complete function for new functions format in Lua. Added icons for group actions. Changed font color in dark-mode of Lua editor. Update Added reconfiguration button for device after successful update.** Z-Wave devices update process improvements. Z-Wave Improved handing of communication errors. Optimized service start-up. Bug fixes: Alarm Unnecessary notification about wrong pin when trying to disarm the system. Cameras Inactive camera preview tab after saving device settings. Dashboard No automatic refresh of color components on device sidebar.** Missing polish translations for states of simple shutter. Devices Missing barrier role for simple shutter device type. Issue with adding Fibaro devices (Wall Plug UK, Smart Module, BiDi-ZWave) in Security Mode. Rejected association settings visible on the list until page refresh.** Power graphs in advanced tab do not scale when zooming. Uploading custom icon for Fibaro CO Sensor not possible. No possibility to change parameters in Z-Wave devices if "use template for parameters" is disabled. Issue with opening 1P Smart Meter Qubino configuration.** Incorrect devices grouping on settings page for QuickApps and Linked Devices. Additional not applicable icons for devices. Redundant device roles for Walli Roller Shutter and Roller Shutter 3. Diagnostics Issue with starting reconfiguration from Z-Wave tab.** CPU graphs issues. Energy Wrong rounding of percentage consumption on Savings tab. Production devices listed on Top consuming devices and on devices list on Savings tab. Gateway Connection Changing Fan Mode for thermostats from slave gateway is not possible. General Home location settings change does not alter sunrise/sunset calculation. Location map does not show if longitude/latitude is out of range. History Device icon does not correspond with the state from history. Network No information about possible connection loss after changing network settings. Nice* Not migrated device roles for Nice Mono devices added in the system on 5.080. Nice Mono devices added on 5.080 lost the icons after updating to 5.100. Issue with pairing some Nice Mono devices. Notifications Devices icons in wrong states on notifications list. Non-admin user cannot remove notifications. Other Additional credentials popup during log-in in some cases. Text in reboot modal not centered on Safari browser. Rejecting custom icons upload if file extension is in uppercase. Plugins Removed additional button on sidebar for Fibaro Intercom. Scenes Scene does not start in specific configuration when trigger is used in more than one scene. Differences between calls in Scenes and QuickApps. Update No translations of errors for devices update service.** Known issues: Nice* After adding Nice device page refresh is required. Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0
Quick App - UnifiOS Switch port POE auto/off
TonyC a répondu à un(e) sujet de mprinfo dans Quick App Developpeur
la tempo c'est dans le script qui fera appel au QA child POE. Yep j'ai mis 60s c'est largement suffisent. -
C'est très très bien comme ça @mprinfo, dans l'automatisation que je n'ai pas encore mis en place, je comptais mettre une petite tempo entre chaque commande pour justement ne pas trop bombarder. Edit : Le poutou attendra mais encore un grand merci !! -
@mprinfo j'allais justement te donner des nouvelles J'ai fait pas mal de tests et n'ai eu strictement aucun problème. Tu as vraiment fait du beau boulot J'ai maintenant pas mal de switches la config à bien grossi depuis 1 mois et des brouettes ou j'ai mis le doigt dans de l'ubiquiti. J'ai des cams sur différents switches, j'ai donc configuré plusieurs instances du QA pour pouvoir les piloter distinctement et tout fonctionne à merveille !! Merci pour tout ce temps passé. -
Quick App - Xiaomi Roborock Vacuum
TonyC a répondu à un(e) sujet de Lazer dans Quick App Developpeur
Merci @Lazer prends ton temps. -
Bonjour @Lazer, j'en profite si tu mets les mains dans le cambouis, lorsque je lance la commande suivante : fibaro.call(2593, "cleanRoom", {20,19,18,17}) pour effectuer un nettoyage sélectif, seule la première pièce est prise en compte le reste est ignoré. Ce n'ai pas la bonne syntaxe ou il y a t-il un problème au niveau du QA? Merci pour ton aide. -
tu sais quoi @mprinfo, tu serais à mes cotés je te ferai un gros poutou j'ai très rapidement testé mais ça à l'air de très bien marcher! ça ne reset plus la config et ça gère bien les ports. Que dire ??? un GRAND MERCI !!! Je continuerai de tester durant le WE et te dirai si je vois qlq chose d'anormal. Merci encore !! -
Bonjour @mprinfo, désolé pas trop eu le temps ces derniers jours, je fais un backup de ma config car elle a beaucoup évolué et je fais un test et un retour dans le weekend. -
quick app Quick App - Monitoring UDM Pro SE et Pro
ça a l'air d'avoir bien évolué tout ça, dès que tu as une version partageable suis toujours preneur merci @mprinfo ! -
Désolé @mprinfo, je n'ai pas trop eu le temps ce WE. Merci pour ton retour j'attends avec impatience la prochaine version, prends ton temps ! -
Chapeau bas maitre @mprinfo ! je vais me le tester tranquilou ce WE. Bravo d'être allé jusqu'au bout -
ok je vois ce que tu veux dire, merci au grand manitou de l'UDM -
@mprinfo Merci mon ami! malheureusement ça crash toujours avec le même problème de POE, je t'assure que mon 24-PRO POE est bien POE sur tout ses ports c'est vraiment étrange que ce QA fonctionne chez toi et pas sur mon UDM, je ne pense pas qu'il y ait de différence d'api entre l'UDM et l'UDM SE mais sait on jamais, ma version fonctionne chez moi mais pas chez toi et inverse! Trop bizarre comme comportement. -
c'est ce que j'ai fait dans le QA que je n'est pas posté -
Oui @mprinfo c'est ce que je t'ai dit plus haut tu fetches la table override, puis dedans tu insert la nouvelle valeur en ne changeant que la position on/off. Bon on dirait qu'on dit la même chose mais pas de la même façon, on va y arriver. Je viens de mon coté de faire la petite modif, c'est bon, tu as beaucoup plus de fonction dans ta version, je pense de mn coté déjà faire qlq chose d'utilisable pour cette petite partie qu'est la gestion des port. Je continuerai ce we tranquillou. -
ça sent le zigbee à plein nez pour la prochaine version.
J'étais à 10000 lieux du multilevelswitchs. Merci pour la précision.
quiche un jour quiche toujours la loose et tu ne m'as pas raté.
done sorry! c'est pas comme si on ne l'avait jamais dit. -
0.62 ça se rapproche de la 1.00 Je download et je teste dans la foulée. Edit AÏE ça crache au démarrage [01.02.2022] [19:41:01] [TRACE] [QUICKAPP2907]: --------------------------------------------------------------------- [01.02.2022] [19:41:01] [TRACE] [QUICKAPP2907]: Demarrage du Quick App - UnifiOS Switch port POE auto/off [01.02.2022] [19:41:01] [TRACE] [QUICKAPP2907]: --------------------------------------------------------------------- [01.02.2022] [19:41:02] [TRACE] [QUICKAPP2907]: X-CSRF-Token = 7a3874ff-5cbb-4da4-9c1b-8ca06f9bf6bb [01.02.2022] [19:41:05] [ERROR] [QUICKAPP2907]: QuickApp crashed [01.02.2022] [19:41:05] [ERROR] [QUICKAPP2907]: main.lua:194: attempt to compare number with nil vu où sa crash va falloir qlqs minutes pour piger pourquoi il n'arrive pas à valoriser "poe_power". -
@Lazer je me permets de te donner mes log, je vais voir de mon coté s'il y a moyen de récupérer les id des pièces d'une manière ou d'une autre mais ça ne me donnera pas la solution j'ai bien peur. debug.lua -
Je vais don essayer de ce pas ! enfin quand tu auras poster ta nouvelle version
