HC3 - 5.021.11
Krikroff
A venir...
What's new:
   Block Scenes
        Actions on the LED ring for FIBARO Walli series devices.
        Actions for Z-Wave thermostats.
    Cameras
        Redirecting to camera configuration after adding.
        Possibility of setting a custom icon.
    Climate
        Indicating the active mode of climate schedule.
    Dashboard
        Controlling the binarySwitch, multilevelSwitch and rollerShutter devices from the right sidebar.
        Displaying the current set temperature on the thermostat icon.
        Collapsing/expanding the rooms side menu.
    Devices
        Z-Wave removing mode available from the list of all devices.
        Displaying the battery level under the battery icon on the device list.
        Changed the default humidity range to 40-50%.
        Consistent configuration of various types of linked devices.
        Support for pending and failed associations.
        Support for the black box of FIBARO Heat Controller (FGT-001).
        Support for FIBARO RGBW Controller 2 (FGRGBW-442).
        Support for Z-Wave locks.
        Support for Z-Wave thermostats.
        Support for wind and rain sensors.
    General
        Downloading the current location of the gateway in https connection mode.
 Lua Scenes
        Possibility to download a scene trigger using the sourceTrigger object that triggered the scene.
        Added functions os.time, os.date and fibaro.sleep.
    Migration from HC2/HCL
        "Finish migration" button on the welcome screen restoring backup transferred from HC2/HCL.
    Network
        Disabled the possibility to turn off the Wi-Fi during the first configuration.
    Other
        Shorter loading time of device and room lists.
        Added loaders for loading lists in settings.
        Consistent display of entries in the debugger (Lua, Quick Apps) and the Z-Wave console.
        Collapsing/expanding the settings side menu.
        Added Czech language.
    Plugins
        Fixes and improvements regarding the Satel plugin.
        Integration of Satel alarm partitions with the FIBARO alarm.
    Profiles
        Display and control of climate zones.
        Display and control of alarm zones.
        Added icons related to weather and temperature.
    Quick Apps
        Added new device types: com.fibaro.genericDevice and com.fibaro.weather.
    Recovery Mode
        Displaying the inactive system version.
        Progress bar when uploading a local file.
        Displaying the time remaining to automatic reboot of the gateway.
    Rooms
        Indicating the default room on the list of rooms.
    VoIP
        Added the functionality description.
Bug fixes:
    Access
        No refresh after synchronizing users.
        Remote support cannot be enabled via remote access.
    Backup
        The "restore with version" option does not download the correct software version.
        Instead of the selected local backup, the latest local backup is always restored.
        Number of scenes in backup is always equal 0.
    Block Scenes
        Unable to enter the time in the delay block.
        Lists of rooms and sections do not load.
        Active "run scene" button despite unsaved changes.
        Selected triggers disappear after reloading page.
        No suitable options for the type com.fibaro.barrier.
        Redundant fields in blocks for RGBW devices.
        No condition values displayed for Central Scene controllers.
        Forcing the watering from the scene causes a system error.
        Missing translations.
    Cameras
        Cannot display the advanced tab.
        Image path is composed incorrectly and the camera image is not displayed.
        Invalid default image refresh time.
    Climate
        Incorrect limits of minimum and maximum temperature.
        Zone temperature is not displayed in manual mode.
        Restarting the gateway when any partition is in Hold mode causes a system error.
    Dashboard
        Search does not work properly if entered a dot in the search box.
    Devices
        Unable to reconfigure a device added in security mode.
        No device polling button if polling is globally enabled.
        Doubled message about unsaved changes in device parameters.
        Errors in displaying the energy consumption of the device.
        No advanced settings section for Z-Wave locks.
        Changing the role of RGBW device requires page refresh to display properly.
        No icons for several types of sensors connected to the FIBARO Smart Implant.
        Cannot set the minimum and maximum RGBW slider value.
        Cannot reset advanced parameters to the default values.
        Invalid redirection to associated device.
        The Advanced tab is not displayed when added a scene with Central Scene event.
        USB powered device is marked as a battery device.
        The user added icon has an invalid path.
        Changing the device name is not applied in the notifications.
        Lack of support for the FIBARO Smart Implant device.
        Incorrect support of the Danfoss RS device.
    Diagnostics
        Unable to download the device template.
    Garden
        Setting is not displayed correctly on the days that the schedule does not apply to.
        Incorrect operation of sprinklers in a sequence.
    Lua Scenes
        Incorrect loading of the scene editor view.
        Errors in displaying the debugger.
    Network
        Changing the IP address or addressing mode does not work properly.
        Access Point is inactive after the recovery procedure.
    Notifications
        No filtering by type and priority.
        Notifications for linked devices do not work.
    Other
        Checkboxes do not display correctly when viewing on a tablet.
        Inconsistent icons and buttons on warning popups.
    Plugins
        Philips Hue devices are set to default light values after switching off and on.
        No weather data displayed on the YR Weather plugin preview tab.
    Quick Apps
        New device is always assigned to the default room.
        The ID of an existing item changes when adding a new item.
        The device view is not updating.
        No code scrolling possibility.
        Importing an unassigned device results in an error.
        Visual fixes.
    Recovery Mode
        The restore, repair and switch actions do not display statuses.
        Visual fixes.
    Rooms
        The section name does not change when you close the window.
    Update
        Retrying to download the update return an error.
    Z-Wave
        Unable to close the adding controller window.
        The mesh reconfiguration for the Z-Wave devices does not work.
    ... and many more!
  • Thanks 1
@jjacques68 tu as loupé un épisode, la migration entre HCL/HC2 et HC3 arrive... uniquement pour les modules Z-Wave, les VD et Scènes ne pouvant pas être migrées.
Bah dis donc, plus gros change log de l'histoire Fibaro :13:
il y a 26 minutes, Krikroff a dit :
    ... and many more!
Aurait-on là notre nouveau running gag ? :2:
@BenjyNet
Le Node ID va rester, c'est le principe même du transfert de contrôleur Z-Wave (qui reste en ID 1 lui)
Le Device ID, dans la base de données de la box, va surement changer... mais puisqu'il faut réécrire toutes les scènes / QA, j'ai envie de dire qu'on s'en fout un peu au final.
L'intérêt de cette migration c'est de ne pas devoir faire le tour des 100 modules de la maison pour la réinclusion, et reconfiguration des paramètres (mono/bistable, etc etc)
il y a 9 minutes, Lazer a dit :
Ah mais oui je suis tout à fait d'accord, osef ! Sauf que j'aimerai bien savoir ce qu'ils vont faire ! J'ai pas envie que ça sente la corruption de bdd dès le départ !
Ils l'ont dit : transfert de contrôleur, un mécanisme propre au Z-wave, et qui fonctionne aussi vers (et depuis) d'autres marques.
La grande question c'est comment ils vont l'implémenter, ..... il y aura des bugs, déjà ils les ont annoncé à mi-mot.
Je suppose que les modules seront recréés dans la BDD au fur et à mesure de leur découverte en interrogeant le chipset Z-Wave juste après la bascule de contrôleur. Ou même avant, juste après l'inclusion de la HC3 en contrôleur secondaire.
Perso si un jour je migre, je pense que je referai une inclusion de tous les modules... sauf si d'ici là ils ont réussi à parfaitement stabiliser la fonction.
Mais avant tout cela, il faut avoir une HC3, et porter tous les codes LUA des VD et Scènes (surtout GEA). Je ne basculerai pas mes modules Z-Wave avant, ils se sentiraient bien seuls sans aucun scénario pour les piloter !
Et le pire dans cette histoire c'est que sur la hc3 je ne vois pas de maj de dispo ...
quelle quiche je n'avais pas lu que je n'étais pas le seul :)
Je crois qu'elle sera livrée par chronopost donc rdv demain vers 10h30 c'est l"heure ou le facteur passe...
Mais rappelez moi ce n'était pas déjà arrivé il n'y a pas si longtemps sur la hc2 une maj poussée par erreur et retirée presque aussitôt ??
Modifié par TonyC
Je pige pas trop ce qu'il se passe là, et avec le retour des nouvelles fonctions plus besoin de bidouiller dans les QD  pour y détourner des scènes, ppffuuu ça met l'eau à la bouche suis sur les starting blocks  pour migrer mes scènes !
Plus que 48h à attendre
Ça donne le temps de faire un VD pour le compte à rebours [mention=3]krikroff[/mention] tu n'oublieras pas de changer la date dans le titre sinon[mention=133]lazer[/mention] va te piquer ta bière
  • Haha 1
Il y a 2 heures, TonyC a dit :
Et si tu balances un /api/update tu as rien ?
Je ne vois rien non plus :
	"updates": {
		"stable": {
			"available": false,
			"version": "5.020.60"
		"beta": {
			"available": false,
			"version": "5.000.000"
		"alpha": {
			"available": false,
	"conditions": {
		"storage": true,
		"allConditionsMet": true
	"updateStableAvailable": false,
	"updateBetaAvailable": false,
	"newestStableVersion": "5.020.60",
	"newestBetaVersion": "5.000.000",
