HC3 - 5.030.45 - 09/04/2020
jjacques68
What's new:
Backup
Sorting backups by creation date.
Block Scenes
New block in Time category - Date range.
Hints for blocks in the form of tooltips for what they are used for.
Removed hidden devices from the drop-down lists.
Conditions and actions for FIBARO RGBW 2 device (FGRGBW-442).
Conditions and actions for FIBARO Intercom device (FGIC-001).
Conditions (zones, inputs, outputs) and actions (zones, outputs) for Satel Alarm plugin.
Climate
Changed the default mode from Auto to Heating for manually added climate zones.
Dashboard
Drag and drop the device to the room name on the left to move it there.
Icon indicating alarm status in the header with a redirection to list of zones.
Current thermostat mode displayed on the device tile.
Control of thermostat type devices from the right sidebar.
Control of colorController type devices from the right sidebar.
More possibilities to control rollerShutter type devices from the right sidebar.
Changed the ON/OFF switch from toggle switch to 2-buttons switch on the right sidebar.
Displaying alarm zones to which the sensor belongs and their states on the right sidebar.
Closing the right sidebar by clicking outside its area.
Devices
Input/output mode configuration for FIBARO RGBW device (FGRGBWM-441).
Protection against adding an existing or pending association.
Changed range and precision of offset for value measured by temperature sensor.
Favourite roller blind position configurable from device settings.
Displaying parameter values greater than 999 with additional space.
Possibility to force polling for device with switched off polling interface.
More effective navigation through device list using the tabulator.
Notification from heatDetector and rainDetector devices available for activation.
Console log for requesting neighbours when adding a Z-Wave device.
Support of excluding from climate panel for a specified time for all types of thermostats.
Support for MCOHome MH7H-EH and MH7H-WH version 2.7.
Support for MCOHome MH8-FC and MH8-FC4 version 3.2.
Support for MCOHome MH9-CO2-WA and MH9-CO2-WD version 2.4.
Support for MCOHome MH10-PM2.5-WA and MH10-PM2.5-WD version 2.3.
Support for MCOHome MH-F500 version 1.2.
Support for MCOHome MH-3900 version 1.9.
Support for MCOHome MH-3928 version 1.3.
Support for MCOHome MH7-WB version 4.2.
Support for MCOHome A8-9 version 6.2.
Support for Aeotec Siren 6 and Doorbell 6 version 1.4.
Support for Aeotec Heavy Duty Switch version 3.28.
Support for HeatIt Push2, Push4, Push8 version 1.26.
Sound Switch CC support.
General
Report of current system configuration generated as a printout.
History
Marking today's date in the calendar (also applies to notifications).
Lua Scenes
New 'duration' condition - time in seconds for which the device has not changed state.
New 'anyValue' operator - any change of device value.
Notifications
Displaying notifications of backup and update errors.
Other
Brand new console/debugger, common for Z-Wave communication, scenes and Quick Apps.
Searching by the name of entry in the console.
Filtering entries in the console by selected tag and/or type.
Full-screen view of the console available as a separate page.
Notifications in toasts during the addition/deletion/configuration of Z-Wave devices.
Unified display of slider values within the interface.
Protection against user access to unconfigured gateway.
Changed LED indication on the gateway after adding/deleting a Z-Wave device.
Improved stability of Wi-Fi connection.
Completing and improving translations.
Plugins
Improved configuration of Philips Hue plugin.
Added button for reloading configuration of Satel Alarm plugin keeping unchanged IDs.
Profiles
Removed hidden devices and hidden scenes from the list.
Added manual mode of climate zones control.
Quick Apps
Added MQTT client support.
Possibility to create slave devices.
Editing code of controls in main device editor.
Conversion of added Quick Apps to new format (migrating controls to separate functions).
Documentation - https://manuals.fibaro.com/home-center-3-quick-apps
Marketplace - https://marketplace.fibaro.com/items?kind=quick_app
Scenes
Activity of the run button depending on scene restart settings.
Toast notification when trying to restart a running scene.
Sorting scenes by name or type.
Bug fixes:
Alarm
Scene protected from running during the alarm is performed.
Block Scenes
Role of the rollerShutter does not affect the list of available actions.
Using the Sunrise/sunset block prevents the scene from saving.
Calendar is displayed in wrong place and does not fit the screen.
Redundant fields in FIBARO Intercom device blocks.
Condition of running a scene using Satel Alarm disappears after reloading the page.
Push notifications are always sent to all users instead of selected ones.
Cameras
IP camera image preview is visible in the interface from the Installer App.
Climate
Setpoint is not applied to a device without support for Auto mode.
Activating manual or vacation mode always sets a zone in Auto mode.
Unified sets of temperature colours in climate panel and displayed on thermostat icon.
Dashboard
Order of rooms in the list does not match the order from settings.
Icon of the colorController type device is displayed incorrectly.
Devices
Device list does not always load after refreshing the page.
FIBARO Heat Controller (FGT-001) does not support Off and FullPower modes.
Inconsistent display of thermostats on the main screen and in device settings.
Incorrect parameters after changing the role or key type of FIBARO RGBW device.
Interface does not load after migration from HC2/HCL due to no support of some thermostats.
History
Linked device state change is not displayed on the list.
Lua Scenes
No support for fibaro.getDevicesID function.
Network
Access Point switches off by itself after several hours.
Other
LED state on the gateway does not change during addition/deletion of Z-Wave device.
Drop-down list does not close and overlaps when another one is being opened.
Unified content and appearance of e-mails sent from the gateway.
Quick Apps
Modified Quick App view is not saved.
No support of special characters and emojis in Quick App view.
No view update in device edit window after using self:updateView.
Double checkbox section in device Advanced tab.
Scenes
Incorrect operation of reporting unsaved changes.
No window for entering PIN code when trying to run a PIN-protected scene.
  • Thanks 1
il y a 37 minutes, jjacques68 a dit :
donc si je comprends bien, en plus des : ==, >=, <=, !=, ... on a maintenant le "anyValue" ?
si c’est ça c’est parfait pour les true/false...
encore rien dans la doc...
Modifié par jjacques68
C'est quoi des slave pour les quickapp ?
Comme pour les devices zwave tu peux faire des slaves...
Ex: un QA master et plein de petits slaves de tous les types: sensor, switch etc... c’est bon ça
  • Like 2
Attention à vérifier la conversion des QA il y a du changement par rapport à la version précédente au niveau de la gestion des événements pour les composants de l’UI.
Exit le code lua dans les boutons etc tout est centralisé dans le script principal, c’est une très bonne chose
ah oui,tout à fait, il a ajouté le code des objets dans le main.
mais j’ai mal lu, je croyais que l’on pouvait changé le type du QA, mais non ...
du moins pas encore...
Changer le type c’est compliqué, le type conditionne des choses à la création ;)
Bien joué
Le meilleur passage et celui-ci :
Votre remise : 0 %
soit : 1 € d'économie
Mais c’est en stock
Il y a 11 heures, jjacques68 a dit :
je confirme, par exemple pour une action sur le changement d'un WallPug :
    operator = "any",
    conditions = {
        {type = "device", id = 433, property = "value", operator = "anyValue",  isTrigger = true}
alors qu'avant c'était :
    operator = "any",
    conditions = {
		{type = "device", id = 433, property = "value", operator = "==", value = true, isTrigger = true}
		{type = "device", id = 433, property = "value", operator = "==", value = false, isTrigger = true}
et bien ça va alléger certaines scènes ça !!
:60:
