TonyC Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 EDIT LE 09/10/2020 Suite à de trop nombreux problèmes, cette mise à jour à été suspendue et ne peut donc plus être installée. Note peso: Je ne rencontre pas de problèmes majeurs dans mon cas d'usage, hormis l'interface ARP qui était déjà down en 5.041.50 le reste est stable donc je ne downgrade pas et attends bien sagement la prochaine version ... En cours d'installation Thank you for using the FIBARO Home Center 3! Our constant improvements are to make your experience better. Be sure to update to the latest version to enjoy new features. What's new (5.050): Plugins Fibaro Heat Activator plugin known from HC2/HCL as Warming Prioritizer. Bug fixes (5.050): Devices Configuration endpoint is not automically hidden when finished adding a new Z-Wave device. Notifications The Nice EEPROM notification does not contain a translation and cannot be deleted. Plugins Broken api/networkDiscovery/arp request resulting in a failed network scan. What's new (5.041 Beta): Block Scenes Selecting user or device in Notification/Push action block. Simplified conditions for Z-Wave door locks. Climate Brand new climate zones control dashboard, available to any user: Setting selected zone or whole house to manual or vacation mode. Going back to schedule from manual or vacation mode. Dashboard Control of door lock type devices from the right sidebar. Devices Nice BiDi-ZWave notifications of obstacle detection, force exceeding, and hardware failure: Inactive by default in device notifications settings. To be displayed in system notifications panel or sent as push or e-mail messages. Generate relevant events to history panel. Available as conditions in block scenes. Improved time shifter with four different timespans under device charts. Possibility of copying the Z-Wave configuration parameters settings from another device. New linked device - Multilevel Sensor with four possible statistical functions. Notification when any device belonging to linked device was removed. Possibility to set theoretical power consumption for devices without power metering. Increased the maximum number of digits in Z-Wave door locks pin codes to eight. Support for Era Inn Edge Tubular Motor version 1.1 or higher. Support for REHAU RE.GUARD Smart water control system. Support for Steinel RS LED D2 Z-Wave. Garden Displaying name of the weekday for a next watering sequence. History Added button to quickly go back to the top of the list. Improved readability of events related to device reconfiguration. Lua Scenes Blocked the possibility of sending an empty push/interactive-push message. Network Improved the responsiveness of network settings page for mobile devices. Nice Support for Nice bi-directional devices using PLN2+ communication protocol. Possibility to force the Nice device synchronization if the device does not respond. Assigning default device category based on its type when adding a new Nice device. Backup and restore of Nice mono-directional devices. Other Redesigned order of items in the left sidebar. Indication of sortable columns in the tables. Minor fixes to the dark theme of the interface. Unified behaviour of drop-down lists. Two new language versions: Chinese simplified and Portuguese BR. Improving the performance of the interface. Quick Apps Displaying the complete view of the Quick App in the FIBARO Home Center mobile app. Autocompletion of global variables names in getGlobal() and getVariables() functions. Prompting for a list of actions and device properties in the left sidebar. Possibility to set a role of the roller shutter device type. Improved closing and removing of edited control. Added support for WebSockets. Scenes Brand new scenes control dashboard, available to any user: Running a scene with one click on the tile. Scenes divided into active and inactive. Displaying when the scene was recently launched. Filtering scenes by categories or using a search bar. Possibility of showing scenes which are hidden. Added search engine in scene settings. Unified order of scene categories. Update Possibility of cancelling the downloaded update before its installation. Improved displaying of current and available software version. Bug fixes (5.041 Beta): Block Scenes Action block for a group of devices is not available. Editing any block scene results in an excess of requests that overload the interface. Dashboard Showing and hiding hidden rooms results in the wrong devices being displayed. Devices No icon of an unconfigured device when adding a new Z-Wave device. Removing a device belonging to a climate zone from a linked device results in system crash. No camera image preview for a video gate linked device. No notifications from devices are sent when set to active by default in the latest update. Values on device charts are not sorted according to timestamp. General No possibility to set date and time manually. History Incorrect icons for FIBARO RGBW 2 (FGRGBW-442). Nice Internal server error when adding a new Nice device. Other Services are not restarted automatically when restoring the backup was cancelled. Plugins No camera image preview for FIBARO Intercom when using a remote access. Profiles Enabling any profile that runs the block scene results in an excess of requests. The profile to which the user has no access does not refresh automatically. Recovery Resetting the network settings requires a manual reboot of the gateway. Scenes Copying a few scenes one by one makes the interface unavailable for several minutes. Scenes based on user's location are not triggered properly. Update Error 409 when trying to cancel an ongoing update download process. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 32 minutes après … Toujours en cours d'installation ? 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 Ah enfin [HC3] Quick Apps – WebSocket client Je vais regarder ça ce soir 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 8 octobre 2020 Auteur Signaler Partager Posté(e) le 8 octobre 2020 il y a 57 minutes, Krikroff a dit : 32 minutes après tu avais passé la 5.041? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 Méfiance, au premier reboot après la mise à jour, la box avait démarré tous les QuickApps en double (oui oui, il y avait bien 2 instances de tous les QuickApps qui tournaient en parallèle). Un reboot manuel plus tard, tout est rentré dans l'ordre. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 Autre chose, ce bug de label doit être particulièrement compliqué à corriger, vu que ça fait 3 firmwares qu'on se le tape .... Pas le temps de jouer avec les WebSockets, mais ça a l'air bien foutu, ça va être chouette, maintenant que j'ai terminé mon QuickApp pour Kodi, je pourrais faire une nouvelle version avec les Websockets, ça serait chouette, même plus besoin de l'addon pour remonter le statut en temps réel sur la HC3 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 tu avais passé la 5.041? Oui et je n’avais pas rencontré ton problème alors que j’ai également le plugin SATEL pour mon intégra, peut-être un coup de chance Envoyé de mon iPhone en utilisant Tapatalk 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 Websocket ?! Si c'est ce que je crois, je sens que je vais y passer de nouveau quelques heures Lien vers le commentaire Partager sur d’autres sites More sharing options...
jjacques68 Posté(e) le 8 octobre 2020 Signaler Partager Posté(e) le 8 octobre 2020 ah mais ça fait pas serveur de websocket, mais juste client !! Zut ça va pas m'arranger Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 (modifié) A priori trop de problèmes avec cette version, j'ai cru comprendre que la 5.050.10 allait être supprimée donc plus dispo pour ceux qui n'ont pas encore effectué la mise à jour. source : https://forum.fibaro.com/topic/52234-update-5050-do-not-work-dont-update/?do=findComment&comment=217906 Modifié le 9 octobre 2020 par TonyC Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 J'ai vu la mise à jour hiers soir. Ce matin, elle avait disparu - strange isn't it ??? PS : malgré reboot, etc... Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 @Sowliny jettes un oeil sur le post juste avant le tiens Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 beta-stable ou stable-beta, Fibaro retrouve ses vieux démons Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 @TonyC , Je suis "descendu" trop vite en bas de la page, vu les commentaires (très) mitigés que j'avais vu avant. Je m'attendais à quelque chose du genre... (suppression). 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 J'ai mis à jour le titre pour éviter de nouvelles confusions. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 Comme dab les stable sont des bêta et les bêta sont des stables. C'est du Fibaro tout cracher. J'ai l'impression que l'on est au début de la V4 Je ne regrette pas d'avoir été sage en restant sur hc2. On verra dans 1 an ou 2 pour mettre la HC3 en prod. A priori elle sera disponible lundi soir au plus tôt selon socha Envoyé de mon BLA-L29 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 5.050.13 disponible... Soit la 5.050.10 mais sans les bugs 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 Mince en plein backup avant mon départ pour 15 jours !! Dès que le système est up j'envoie la sauce !! Merci @Krikroff ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 Installation en cours... Je pense que tu peux modifier le titre du sujet Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 (modifié) Yep, done ! Mise à jour faite, je l'ai vu 10 " et gros reboot, commence bien cette histoire Modifié le 9 octobre 2020 par TonyC Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 Installation sans souci Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 cool tout nickel après ce reboot tout bizarre. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 La mienne a rebooté immédiatement tout de suite après le 1er reboot, je l'ai repéré aux diodes car elle est posée sur mon bureau, mais c'est allé très vite, elle n'a pas démarré les services entre les 2 reboots. ça fait surement partie du process de mise à jour normal. En tout cas je n'ai pas eu besoin de faire un reboot manuel, comme hier quand il m'avait démarré tous les QuickApps en double, il y avait bien plusieurs problèmes avec la mise à jour d'hier. Moi je m'en fous, c'est une box de développement, mais quand elle sera en prod, ça sera comme la HC2, on attend toujours quelques jours avant de faire les mises à jour. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 9 octobre 2020 Signaler Partager Posté(e) le 9 octobre 2020 Autre chose, ça a été remonté sur le forum officiel, mais soit les backups sont trop gros, soit l'espace cloud est beaucoup trop petit, mais avec seulement 5 backups dans le cloud, je suis presque arrivé à saturation de mon espace disponible : 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
TonyC Posté(e) le 9 octobre 2020 Auteur Signaler Partager Posté(e) le 9 octobre 2020 Je n'ai pas eu le temps de m'en occupé, mais perso je fais 1 seul backup et tout l'espace est occupé, enfin 1 backup = > 29.6Mb. J'ai skrinké tous les events (api.delete("/events/history?shrink=X") (x=nombre d'events restant après purge, alors attention à ce que vous faite ...)), mais nada ça m'a juste libéré qlq ko. Bref je suis bon pour le support car quelque chose à dû merder quelque par mais où??? et oui je suis d'accord ils sont un peu raide sur l'espace aloué, les temps sont durs Lien vers le commentaire Partager sur d’autres sites More sharing options...
