[HC3] Piloter sa climatisation Mitsubishi via MelCloud
Dragoniacs
Le 07/02/2024 à 09:47, Dragoniacs a dit :
Ce matin, toujours impossible d'accéder via l'application ou le QA.
J'essaye de ralentir les sollicitation en modifiant la boucle à toutes les 5 min ald toutes les minutes.
Si vous voulez faire de même, c'est dans la page "main", la boucle function QuickApp:Get_Split_Data() -> à la fin de la fonction
fibaro.setTimeout(5*60*1000function() self:Get_Split_Data() end-- Recupérations toutes les 5 min
sur HC2 c'est cette ligne ?
    if major_loop then setTimeout(function() Main_Loop() end, 30 * 1000) end
Que je passe 2*60 pour 2mn
Modifié par Sakkhho
Greetings from Czech Republic and many thanks for the QuickApp provided. I got the conection working, let me add here:
- for people with diacritics in their language as in czech, it seems you cannot use charcters like "ý, ž, í, č" etc. in MELCloud setup, otherwise Fibaro QA will not find it and it will quite quicky disable your MELCloud probably due to many connection attempts.
- On top of that, if you already added your split with the use of such characters, be sure to remove from MELCloud nad add it once again. Simple renaming was not working for me.
after that
- I can confirm 2 minutes timeout works well
The only issue I came across currently is:
- I cannot set the Vane horizontaly or vertically, what it does is it sends the command to MELCloud, even MELCloud app shows the change of the vane position for a while, but AirCon unit does nothing and after while MELCloud status changes back to previous state. Other way around everything works fine, when I change vane position from MELCloud, Fibaro QA gets it correctly.
Any ideas?
Hi !
You're perfectly right... I did not see that since I do not use this functionality during winter.
Thanks for that !
Let me check...
Envoyé de mon M2012K11AG en utilisant Tapatalk
Bonjour à tous
Mise à jour importante à faire sur ce QA pour assurer la mise à jour des split.
Le système de communication avec le MELCLOUD ayant évolué (merci Yoxxx :) )
Vous pouvez simplement mettre à jour les fichier MAIN et TOOLS sans importer de nouveau le QA complet, si vous êtes actuellement en V2 ou V3.
Il y a 3 heures, Dragoniacs a dit :
Bonjour à tous
You are welcome, many thanks on my side. I have modified my QA with adjustments and everything works fine. Just a question, is there a reason why you don't allow "Auto" in thermostat modes?
I made it available as well as other minor things (Set_Split_Data("VaneHorizontal",8) for units which can split the Vanes to both sides etc.
Not sure about Auto mode in general, thats why I am asking. I just wanted to have all the MELCloud options in Fibaro as well.
j'ai installé la QA V3_1 et remplis les variables pour la connexion mais rien ne se passe. Pas de réaction des splits
Lorsque je met en mode chauffage ou froid puis définir cela revient de suite sur off
Est-ce que tu as bien utilisé le nom du Split tel que défini dans le melcloud ?
Split_Name : MonSPlit -> le nom du split tel que défini dans l'interface MelCloud, que ce QA viendra piloter
Est-ce que tes splits sont déclarés dans des étages ou pièces différentes dans le melcloud ?
Dernier point : Mitsubishi a limité les appels sur son serveur, alors il faut patienter 2 min pour que la consigne soit prise en compte.
Envoyé de mon 23078PND5G en utilisant Tapatalk
