UniFi OS - Dream Machines 4.0.18
Important Notes
Bundled application
Improvements
  • Added support for Shadow Auto Failover with DS-Lite connections.
  • Improved Remote Access connection resiliency.
  • Improved username validation when creating a UI Account through the setup wizard.
  • Improved compatibility with some 3rd party SFP modules.
  • Improved device stability.
Bugfixes
  • Fixed gateway configuration issues in rare cases.
  • Fixed incorrect elapsed time when restoring backups.
  • Fixed an issue where remote logging stops working in rare cases.
  • Fixed RADIUS issues when a username contains a space.
  • Fixed PPPoE connection issues in rare cases.
  • [UDM] Fixed an issue where you couldn't completely delete all characters when configuring the WiFi name in the setup wizard.
  • [UDM] Fixed an issue where the WiFi channel and width changed after an RF scan.
UniFi Network Application 8.4.57
Improvements
  • Added ability to specify NAS ID in WiFi Settings.
  • Added custom server option for DNS Shield.
  • Requires a UniFi (Cloud) Gateway with firmware version 4.0 or newer.
  • Improved Packet Capture user experience.
  • Improved default filtering for the Clients page.
  • Now defaults to Online.
  • Improved application performance on large setups.
  • Improved user experience on the Topology page on larger setups.
  • Now defaults to not showing clients if there are more than 50 devices when opening the page for the first time.
  • Removed max capture size setting for Packet Captures.
  • Reduced the mDNS network limit for the UniFi Express to a maximum of 2 networks.
  • Moved Channelization to WiFi settings.
Bugfixes
  • Fixed an issue where VLAN settings from profiles were incorrectly applied on LAN ports on UniFi Gateways and Enterprise Fortress Gateways.
  • Fixed an issue where deleting a site also removes admins from all other sites in rare cases.
  • Fixed an issue where auto backups were failing on setups that were set up with UniFi Network 8.2 or newer.
  • Fixed an issue where the new WiFi Password requirements for Brazil were also applied on Access Points.
UniFi Network Application 8.4.59
Bugfixes
  • Fixed the inability to start a Packet Capture on APs with a Network Override configured.
  • Fixed an issue where Column re-ordering was not saved in the Clients page.
  • Fixed the inability to load Network Settings in rare cases.
  • 5 mois après...
  • 10 mois après...
Malheureusement c'est comme au Black Friday, peu de produits concernés, et surtout des anciens produits, évidemment pas les produits les plus intéressants.
Ils faisaient mieux certaines années précédentes.
  • 9 mois après...
La version Early Access de UNIFI OS viens de sortir
La version actuelle est la version 6.0.11
Voici ce que l IA donne comme information
UniFi OS 6 représente la prochaine évolution du système d'exploitation et de gestion des appareils et applications de réseau d'Ubiquiti, s'inscrivant dans la continuité des versions précédentes (comme les branches 4.x et 5.x) et l'arrivée progressive des versions bêta/avancées de la gamme. [1, 2, 3]
Nouveautés et caractéristiques principales
Gestion centralisée unifiée : Il pilote l'ensemble de l'infrastructure réseau (bornes Wi-Fi, routeurs, commutateurs et caméras) depuis une interface unique. [1]
Évolution du UniFi OS Server : Permet l'auto-hébergement (self-hosting) sur des machines Linux, Windows ou macOS pour gérer des équipements ou des sites ne disposant pas d'un contrôleur matériel intégré. [1, 2]
Amélioration des sauvegardes : Introduction de plannings de sauvegarde configurables, de destinations multiples et d'une gestion locale simplifiée. [1]
Sécurité et accès : Ajustement des durées de session pour la connexion locale et prise en charge élargie des certificats. [1]
Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
Il y a 2 heures, mprinfo a dit :
Si vous le souhaitez, dites-moi :
c'est l'IA Google qui t'a donné cette réponse ?
Oui l'intégration Matter est l'une des nouveautés de la v11 du contrôleur UniFi :)
Pleins d'autres nouveautés aussi, ils se bougent bien chez UniFi, c'est impressionnant l'évolution de la partie logicielle, de plus en plus complet.
