ericl78 Posté(e) lundi à 11:38 Signaler Posté(e) lundi à 11:38 (modifié) Firmware 5.210.12 STABLE 18/05/2026 Changelog Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: KNX integration From now on, your KNX system can work even smarter thanks to integration with our Yubii Home Pro and Home Center 3 hubs. Gain full control over lighting, switches, RGBW controllers, blinds, shutters and sensors within one unified ecosystem. Migration of Z-Wave engine from 2.0 to 3.0 version (BETA) In this version of the software, it is possible to migrate the Z-Wave engine to version 3.0. Migration will allow you to take advantage of all the features of the new Z-Wave engine, including using Smart Start, better generic support for Z-Wave Plus devices and the availability of Security S2, which can be considered the first fully secure communication method for the Smart Home. Smart Start From now on, you can use the Smart Start function using QR Scanner in Yubii App. This function will allow you to add devices to the system even faster using binding process.*** What's new: Devices Improved display of device families on the device list so that child devices are always located under their parent device. Added Operating State indicator for Linked thermostats. Added direct access to KNX communication (both sending and recieving packets) from the API. Elero Integration with ELERO Lighting Receivers: TTDTW-E (Combio-868 LI W), TTDRGBW-E (Combio-868 LI RGBW), TTDW-E (Combio-868 LI PW). Energy Panel Integration with Tibber monitor to allow automatic rates update for Energy Panel (Available only for addresses located in Germany, Norway, Sweden or the Netherlands). Gateway connection When the Slave hub is turned off or there is no connection, the devices added to it are visible as inactive (dead) in the Master hub. Enabling Support Access and Remote Access on the Master hub also enables access on slave hubs. Nice* Upgraded NICE chip firmware version to the newest one. Added the option to disable the sun impact (setting the value to 0 lux in parameter 10) for the Domi WSC device v3.9.0. The default values of parameters 1, 3, and 10 have been changed for all versions of DOMI WSC devices. Other Added the information about the zone where the alarm occurred. Verification of the checksum when downloading the update file at the beginning of the process instead of at the end. Removed PKO Assistance plugin from the system due to official termination of cooperation. Scenes Added a new scene activation/deactivation block as an action in block scenes. Added possibility to enable/disable local and remote device protection via scenes and profiles. Z-Wave Adjusted parameters templates for sensors to reduce number of reports for various devices. Fixed setting of parameter 5 for the MCO Home MH7H-EH device. Improved clearing Z-Wave network reset procedure. The ability to manually add parameters at each endpoint. Improved Z-wave3 engine resilience to communication issues in Security S0.** Support for Z-Wave 3.0 in Installer App.** Bug Fixes: Backups Fixed an issue where the “Update and restore” buttons for backups with higher software versions were inactive. Climate Fixed an issue where the schedule was not cleared from the Heat-Control/Fibaro Heat Controller when it was removed from the climate zone. Fixed an issue where an added temperature sensor was removed from the climate panel when editing other settings in that panel. Fixes an error occurs after deleting a device in the climate schedule. Fixed issue with saving climate zones in some cases. The FGT thermostatic heads are not synchronised with the schedule. Devices Fixed an issue where the Color component view was not updating correctly. Fixed an issue with changing icon for Dahua cameras. Improved performance for the DoubleDimmer-Control binding Wizard. Fixed a problem with KNX device configuration caused by the lack of support for diacritical marks in device names. Fixed an issue with function settings for Z-Wave devices with an empty template during the binding process in the mobile application. Fixed incorrect KNX Bridge connection status after IP change. Restored missing temperature graphs on FGT device version 4.10. Fixed the appearance of the dialog in the user interface for BiDi-Awning and AV Controller. Fixed the display of svg icons in the mobile app for Sprinkler and NICE Siren devices. Fixed problem with CoolAutomation plugin to receive correct feedback/status in mobile application. Fixed UI for Advanced Configuration for the Keyfob lock button and unlock sequence. RGBW device doesn't control properly the color setting in specific actions sequence using the picker. Elero Fixed color component values for the Elero Lighting RGBW device. Fixed the appearance and behavior of the Elero Lighting RGBW device icon in the user interface. Fixed invalid settings for temperature color in profiles for the Elero Lighting RGBW device. It is not possible to control Elero Lighting RGBW after pairing it with the system if the LED output is turned off during finishing binding procedure. Gateway connection Fixed errors and incorrect display of options in association settings. Fixed IP address validation in the Gateway Connection tab. Wrong backup type while software update for slave hubs. Devices from different phisical networks are listed as a target destinations in associations. KNX Fixed a KNX connection error that occurred when reconnecting after a long period of time. Fixed problem with reconnecting the KNX bridge after performing a 'clear configuration' action. Nice* Fixed setting favorite position for the screen devices which does not support this natively. Fixed keep-alive support for Domi WSR/WS device, which caused the device to be shown as disconnected in the system. Fixed issues with Nice PLN2+ motors controlled as a group using Linked Device. Fixed the operation of some group actions causing i.a. malfunctions in scenes. Fixed an issue with removing device Domi WSR when the device is inactive. Other Removed a non-functional option (checkbox) for sending notifications on the list of mobile devices. Fixed visibility of device name when adding Z-wave devices in the mobile application. Fixed tooltips positioning in the interface. Fixed the message screen displayed after using the factory reset option in Recovery mode. Fixed handling of events from the NICE camera plugin when devices are added via NVR. Fixed icons for Sonos and XBMC plugins. Fixed errors displayed in the Z-wave tab of the Master hub when using the interface via Remote Access. Fixed the input validator for variables. Fixed non-functioning group actions in profiles. Added real-time refreshing of history entries for Z-Wave Central Scene events and scene-related events. Fixed an issue where the reboot sometimes didn't work properly. Minor UI/UX fixes. Profiles Fixed problem with triggering changes via profiles. Quick Apps Allowed additional parameters to hub.alert function in QuickApp to keep backward compatibility with old code. Variable edit box character limit has been increased from 1024 to 2048. Added support for climate zone control functions in QuickApps. Fixed restarting the Quick App process when editing it. Fixed Heat Activator which stopped working in rare cases. Fixed an issue with saving the Quick Apps view to a file when encrypting (applies to QA exported from version 5.191 or later). Fixed problem that HTTP responses other than 2xx (300 and higer) don't return response body. Corrected validation of variable names to allow editing of existing variable values. Fixed an issue with the display of custom icons for remote controllers in Quick Apps. Scenes Fixed an issue that icons other than the default ones are not displayed when selecting profiles in scenarios. Fixed refreshing of the scene activity switch in the interface when calling activation/deactivation action from the scene level. Fixed inactive color temperature slider for device Elero Lighting TW in scenarios created in the mobile app. Fixed problem that net.HTTPClient strips query string parameters in LUA scenes. Fixed the behavior of sliders in block scenes for the setColor action, sliders now function independently. Fixed an error that block scene with setting Manual mode to "Hold" does not work on HC3L/YH hubs. Optimization of scene running. Fixed an issue with saving a predefined scenario when some devices are selected. Update Moved the setting related to system version information from the final stage of startup to the earliest possible point in order to reduce incorrect version data in recovery mode. Changed the order in which services start during initialization to avoid issues during updates. Fixed the behavior of the progress bar when canceling an update download; the progress bar is now hidden. Z-Wave Fixed redundant stopping of Z-Wave3 engine.** Fixed the visibility of updates for Z-Wave devices on both engine versions. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. *** - Fully supported in the upcoming Yubii v2.5.3 application Security: Angular vulnerabilities update. Updated Rust toolchain version. Modifié lundi à 12:01 par ericl78 2
ericl78 Posté(e) lundi à 11:41 Auteur Signaler Posté(e) lundi à 11:41 En Français Journal des modifications (Changelog) Merci d’utiliser notre passerelle ! Assurez-vous de mettre à jour vers la dernière version afin de profiter des nouvelles fonctionnalités et améliorations. Principales fonctionnalités Intégration KNX Désormais, votre système KNX peut fonctionner encore plus intelligemment grâce à l’intégration avec nos hubs Yubii Home Pro et Home Center 3. Obtenez un contrôle complet de l’éclairage, des interrupteurs, des contrôleurs RGBW, des stores, volets roulants et capteurs au sein d’un écosystème unifié. Migration du moteur Z-Wave de la version 2.0 vers 3.0 (BÊTA) Dans cette version du logiciel, il est possible de migrer le moteur Z-Wave vers la version 3.0. Cette migration permet de profiter de toutes les fonctionnalités du nouveau moteur Z-Wave, notamment : Smart Start Meilleure prise en charge générique des appareils Z-Wave Plus Disponibilité de la sécurité S2, considérée comme la première méthode de communication totalement sécurisée pour la maison connectée. Smart Start Vous pouvez désormais utiliser la fonction Smart Start via le scanner QR dans l’application Yubii. Cette fonction permet d’ajouter des appareils au système encore plus rapidement grâce au processus d’appairage automatisé.*** Nouveautés Appareils Amélioration de l’affichage des familles d’appareils dans la liste afin que les appareils enfants soient toujours placés sous leur appareil parent. Ajout d’un indicateur d’état de fonctionnement pour les thermostats liés. Ajout d’un accès direct à la communication KNX (envoi et réception de paquets) via l’API. Elero Intégration des récepteurs d’éclairage ELERO : TTDTW-E (Combio-868 LI W) TTDRGBW-E (Combio-868 LI RGBW) TTDW-E (Combio-868 LI PW) Panneau Énergie Intégration avec le moniteur Tibber afin de permettre la mise à jour automatique des tarifs dans le panneau Énergie (disponible uniquement pour les adresses situées en Allemagne, Norvège, Suède ou Pays-Bas). Connexion des passerelles Lorsque le hub esclave est éteint ou inaccessible, les appareils qui y sont ajoutés apparaissent comme inactifs (dead) sur le hub maître. L’activation des accès Support et Accès distant sur le hub maître active également ces accès sur les hubs esclaves. Nice* Mise à jour du firmware de la puce NICE vers la dernière version. Ajout de l’option permettant de désactiver l’impact du soleil (valeur 0 lux dans le paramètre 10) pour l’appareil Domi WSC v3.9.0. Modification des valeurs par défaut des paramètres 1, 3 et 10 pour toutes les versions des appareils DOMI WSC. Autres Ajout d’informations concernant la zone où l’alarme s’est déclenchée. Vérification de la somme de contrôle (checksum) dès le début du téléchargement du fichier de mise à jour. Suppression du plugin PKO Assistance suite à l’arrêt officiel du partenariat. Scènes Ajout d’un nouveau bloc d’activation/désactivation de scène dans les scènes blocs. Possibilité d’activer/désactiver la protection locale et distante des appareils via les scènes et profils. Z-Wave Ajustement des modèles de paramètres pour les capteurs afin de réduire le nombre de rapports. Correction du paramètre 5 pour l’appareil MCO Home MH7H-EH. Amélioration de la procédure de réinitialisation du réseau Z-Wave. Possibilité d’ajouter manuellement des paramètres sur chaque endpoint. Amélioration de la robustesse du moteur Z-Wave 3 face aux problèmes de communication avec la sécurité S0.** Support du Z-Wave 3.0 dans l’application Installer.** Corrections de bugs Sauvegardes Correction d’un problème où les boutons « Mettre à jour » et « Restaurer » étaient inactifs pour des sauvegardes issues de versions logicielles supérieures. Climat Correction d’un problème où le planning n’était pas supprimé du Heat-Control/Fibaro Heat Controller lorsqu’il était retiré d’une zone climatique. Correction d’un problème où un capteur de température ajouté était supprimé du panneau climatique lors de la modification d’autres paramètres. Correction d’une erreur après suppression d’un appareil dans le planning climatique. Correction de problèmes de sauvegarde des zones climatiques. Synchronisation corrigée des têtes thermostatiques FGT avec le planning. Appareils Correction de l’actualisation du composant Couleur. Correction du changement d’icône pour les caméras Dahua. Amélioration des performances de l’assistant d’association DoubleDimmer-Control. Correction d’un problème de configuration KNX lié aux caractères accentués. Correction des paramètres fonctionnels des appareils Z-Wave avec modèle vide pendant l’association mobile. Correction du statut de connexion KNX Bridge après changement d’adresse IP. Restauration des graphiques de température manquants pour les appareils FGT v4.10. Correction de l’apparence des dialogues pour BiDi-Awning et AV Controller. Correction de l’affichage des icônes SVG dans l’application mobile pour Sprinkler et NICE Siren. Correction du plugin CoolAutomation pour le retour d’état dans l’application mobile. Correction de l’interface de configuration avancée pour la télécommande Keyfob. Correction du contrôle des couleurs sur les appareils RGBW dans certaines séquences d’actions. Elero Correction des valeurs de couleur pour les appareils Elero Lighting RGBW. Correction de l’apparence et du comportement des icônes RGBW dans l’interface. Correction des paramètres de température de couleur dans les profils. Correction d’un problème empêchant le contrôle RGBW après appairage si la sortie LED était désactivée pendant la procédure. Connexion des passerelles Correction d’erreurs et d’affichages incorrects dans les paramètres d’association. Correction de la validation des adresses IP. Correction du mauvais type de sauvegarde lors de mises à jour de hubs esclaves. Correction des associations entre appareils de réseaux physiques différents. KNX Correction d’une erreur de connexion KNX après une longue période de déconnexion. Correction du reconnect après l’action « clear configuration ». Nice* Correction de la position favorite sur certains appareils écran. Correction du support keep-alive pour Domi WSR/WS. Correction des moteurs Nice PLN2+ contrôlés en groupe. Correction de certaines actions de groupe causant des dysfonctionnements dans les scènes. Correction de la suppression de Domi WSR lorsqu’il était inactif. Autres Suppression d’une option non fonctionnelle d’envoi de notifications. Correction de la visibilité du nom des appareils lors de l’ajout Z-Wave dans l’application mobile. Correction du positionnement des info-bulles. Correction de l’écran affiché après un reset usine en mode Recovery. Correction des événements du plugin caméra NICE via NVR. Correction des icônes Sonos et XBMC. Correction des erreurs dans l’onglet Z-Wave du hub maître via accès distant. Correction du validateur des variables. Correction des actions de groupe dans les profils. Actualisation en temps réel des événements Z-Wave Central Scene. Correction de certains redémarrages défaillants. Corrections mineures UI/UX. Profils Correction du déclenchement des changements via profils. Quick Apps Compatibilité rétroactive améliorée pour hub.alert. Augmentation de la limite des variables de 1024 à 2048 caractères. Ajout du support des fonctions de contrôle des zones climatiques. Correction du redémarrage des Quick Apps lors de l’édition. Correction du Heat Activator. Correction de la sauvegarde des vues Quick Apps chiffrées. Correction des réponses HTTP > 2xx ne retournant pas le body. Correction de la validation des noms de variables. Correction des icônes personnalisées des télécommandes. Scènes Correction de l’affichage des icônes personnalisées dans les scénarios. Correction du rafraîchissement de l’état d’activation des scènes. Correction du curseur de température de couleur pour Elero Lighting TW. Correction du problème où net.HTTPClient supprimait les paramètres de requête en LUA. Correction du comportement des sliders setColor. Correction du mode manuel « Hold » sur HC3L/YH. Optimisation de l’exécution des scènes. Correction de la sauvegarde des scénarios prédéfinis. Mise à jour Déplacement des informations de version système au tout début du démarrage. Modification de l’ordre de démarrage des services pour éviter des problèmes pendant les mises à jour. Correction de la barre de progression lors de l’annulation d’un téléchargement. Z-Wave Correction de l’arrêt redondant du moteur Z-Wave3.** Correction de la visibilité des mises à jour des appareils Z-Wave sur les deux moteurs. Sécurité Mise à jour des vulnérabilités Angular. Mise à jour de la toolchain Rust. * Ne s’applique pas au HC3L (Home Center 3 Lite). ** S’applique uniquement au moteur Z-Wave 3.0. *** Support complet prévu dans la future application Yubii v2.5.3. 5
mprinfo Posté(e) hier à 06:32 Signaler Posté(e) hier à 06:32 Qui ce lance ?Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
ericl78 Posté(e) hier à 07:05 Auteur Signaler Posté(e) hier à 07:05 Moi, je l'ai installée hier soir, ras ce matin :=) 1
Lazer Posté(e) il y a 23 heures Signaler Posté(e) il y a 23 heures Installée sans souci sur ma box de test
Lazer Posté(e) il y a 5 heures Signaler Posté(e) il y a 5 heures Il y a un article intéressant et bien détaillé concernant les nouveautés de l'API liées au nouveau moteur Z-Wave v3 sur le forum officiel : [forum.fibaro.com] Z-Wave engine 2.0 -3.0 Migration. Changes in API
TitiXsi Posté(e) il y a 2 heures Signaler Posté(e) il y a 2 heures Hello lazer, comment ça se passe pour les devices sans modèle qu'on a forcés comme le qubino fil pilote ?
Lazer Posté(e) il y a 1 heure Signaler Posté(e) il y a 1 heure Aucune idée.... mais l'absence de template/modèle, ce n'est pas le problème. Le problème, particulièrement avec les modules Qubino Fil Pilote, c'est le firmware buggé qui ne répond pas correctement aux requêtes lors de l'interview initiale (inclusion). Donc j'ai quelques doutes sur la prise en charge de ces modules... là est la question.
