Yaps - Présence Simulator, Un De Plus
sebcbien
  • 8 mois après...
Hello guys, sorry for write in english on french forum but my french is not good :) and you are my only hope :)
Regarding this script, for me works fine, but when i terminate the script (set Simu_presence value to 0) script terminate but lights that is used into simulations stay ON.
Is something that i need to setup in order to turn OFF all the lights used into script when terminate?
Thank you
  • 4 semaines après...
Hello,
J'ai une erreur à la fin de la simulation (Désactivation):
[DEBUG] 09:29:52: Mon 07/10 Reverse converted Unix Time of End_simulation_time : 1570491000 To: 01:30
[DEBUG] 09:29:52: Mon 07/10 Reverse converted Unix Time of End_simulation_time_with_random_max_TurnOff : 1570491300 To: 01:35
[DEBUG] 09:29:52: Mon 07/10 Presence Simulation started. Will stop at: 01:30 + rand(25min) : 01:35
[DEBUG] 09:29:53: Mon 07/10 light HUE ID:Lampe TV Jeux status:0
[DEBUG] 09:29:53: Mon 07/10 light ID:Eclairage table status:1
[DEBUG] 09:29:53: Mon 07/10 Entering loop of 6.94 minutes
[DEBUG] 09:30:33: Scene already active! Aborting this new instance !!
[DEBUG] 09:30:35: Mon 07/10 Exiting loop of 6.94 minutes
[DEBUG] 09:30:35: 2019-10-07 09:30:35.354810 [ fatal] Unknown exception: /opt/fibaro/scenes/73.lua:262: attempt to compare number with nil
Donc sur la ligne 262:
function YAPS_Engine:EndSimulation()
    if Lights_always_on[1] ~= nil then YAPS_Engine:TurnOff(Random_lights,Lights_always_on); end
    -- test pepite
    for i= 1, Number_of_lights_hue do
        if tonumber(lightstatushue) > 0 then
            fibaro:call(Random_Lights_Hue, "turnOff")
    -- fin test pepite --
    Debug("red","Presence Simulation deactivated");
Comment je peu résoudre?
il y a 4 minutes, speedoxx007 a dit :
j'imagine que c'est  celle-ci la ligne 262 ?
Ta variable  Lights_always_on[1] est-elle bien définie (tableau) ?
même question : est-ce que la variable lightstatushue existe ?
Il y a peut-être une instruction LUA pour tester l'existence d'une variable ? Autrement regarde dans le code oùu elle est définie, et s'il n'y a pas un cas particulier où elle ne le serait pas. (ou lui mettre une valeur par défaut en début de code ?)
  • 1 an après...
Hello,
YAPS fonctionne bien, mais je ne comprends pas pourqoui à la fin de la simulation vers 1h30 il n'éteint pas les lampes allumé de la simulation. Voici mon code:
%% autostart
%% properties
%% globals
Simu_presence
local version = "3.6.1";
-- YAPS Presence Simulation by SebcBien
-- August 2015
--V3.6.1 -- added new notifications engine (sms, freesms, push, email)
-- fixed bug "attempt to concatenate local 'deviceID' (a nil value)"
--V3.5.2 - start push sent by email
--V3.5.1
-- Fixed launch between midnight and endtime (if endtime is after midnight)
-- clean up code midnight-endtime
--V3.3.2
-- renamed all variables for more readability
--V3.3.0
-- Fixed Override bug (no sleep time between lights)
--V3.2.3
-- added sunset shifting possibility (add or remove minutes to startime
-- added time stamp to push messages
-- formated messages
-- optimisation
-- cleanup
--V3.1.0
-- "complete" rewriting with unix times
-- modified end time notification impacted by random and smooth TurnOff (End_simulation_time impact)
-- exit is now exactly at End_simulation_time
-- added smooth cut off of lights at ending time (function not triggered with deactivation)
--V2.6.6
-- clean up debug messages
-- added free sms notifications
-- second fix to looping days bug
--V2.6.0 to V2.6.5
-- Fixed bug when Random_max_TurnOff_duration = 0
-- Probably fixed End_simulation_time bug calculation when looping for days du to days are shorter now than the previous day
-- Fixed bug not turning on Lights_On_at_end_Simulation when exiting Simulation
-- added random end time + small stability changes and cleaning
-- Added array of lights to turn on after Simulation, ONLY if Simu_presence = 1 (normal ending, not ended by setting Simu_presence to 0)
-- Added the possibility to not have an always on lamp
-- Added naming of devices in the debug during Simulation
-- Added the possibility to select always on light during Simulation
--V2.2.0 to 2.5.0
-- fixed Simulation starting if restarted between End_simulation_time & midnight
-- fixed big bug Simulation restarting after end time
-- small notification and debug changes
-- Rewriting the engine
-- now relaunch automatically the next day, even if Simu_presence has not changed
-- Added Manual Stop variable
-- added list of mobiles
if (fibaro:countScenes() > 1) then
	fibaro:debug("Scene already active! Aborting this new instance !!");
	fibaro:abort();
--------------------- USER SETTINGS --------------------------------
local id = {
	LAMPE_SALON_SPOT	= 855,
    LAMPE_TOILETTE		= 544,
	LAMPE_TABLE			= 197,
	LAMPE_CUISINE		= 813,
    LAMPE_HALL			= 878,
    LAMPE_LED_SALON		= 890,
	LAMPE_ESCALIER		= 213,
	PHONE_PAPA			= 713,
	LAMPE_GARAGE		= 826
local Stop_hour = "01";					-- Hour when you want Simulation to stop
local Stop_minute = "30";				-- Minute of the hour you want Simulation to stop
-- note 1: the script will not exit while waiting the random time of the last light turned on. So end time can be longer than specified end time. (even more with var Random_max_TurnOff_duration)
-- note 2: if the global variable changes during the same wait time as above, it will exit immediately (when back home while Simulation runs)
local Sunset_offset = -15				-- number of minutes before or after sunset to activate Simulation
local Random_max_duration = 30;			-- random time of light change in minutes --> here each device is on maximum 30min
local Random_max_TurnOff_duration = 25;	-- random time to add at the stop hour+stop minute so the Simulation can be more variable (0 to deactivate)
local Lights_always_on = {} -- IDs of lights who will always stay on during Simulation - leave empty array if none -> {}
local Random_lights = {id["LAMPE_GARAGE"],id["LAMPE_SALON_SPOT"],id["LAMPE_TABLE"],id["LAMPE_TOILETTE"],id["LAMPE_CUISINE"],id["LAMPE_ESCALIER"],id["LAMPE_HALL"],id["LAMPE_LED_SALON"]} -- IDs of lights to use in Simulation
--local Random_lights = {id["LAMPE_HALL"],id["LAMPE_CELLIER"],id["LAMPE_CH_AMIS"]} -- Reduced set for test purposes
local Lights_On_at_end_Simulation = 0;	-- If next line is commented, no light will turn on after Simulation ends
-- local Lights_On_at_end_Simulation = id["LAMPE_COULOIR"]; -- ID of a light (Only One) to turn on after Simulation ends (at specified Stop_hour & Stop_minute). Comment this line to turn off this feature
local Lights_On_if_Simulation_deactivated = 0; -- If next line is commented, no light will turn on after Simulation is stopped (by putting Simu_presence to 0)
local Lights_On_if_Simulation_deactivated = id["LAMPE_HALL"]; -- ID of a light (Only One) to turn on after Simulation is stopped (Simulation_). Comment this line to turn off this feature
YAPS_Engine = {};
	YAPS_Engine.notifications = true;					-- send notifications
	YAPS_Engine.notificationTypes = {"push", "email"};	--notification types {"push", "email", "sms"} but they are overriden in the code
	YAPS_Engine.Activate_FreeSms = false;				-- activate push with Activate_FreeSms (Activate_Push must be true also)
	YAPS_Engine.smartphoneID = {id["PHONE_PAPA"]};		-- Smartphone Id to send push to. {id1, id2, id3}
	YAPS_Engine.userID = {id["ADMIN"]};					-- User Id to send email to. {id1, id2, id3}
	YAPS_Engine.sms = {
		["VD_ID"] = 0,									-- Virtual Device ID
		["VD_Button"] = "1",							-- Virtual Device Button
		["VG_Name"] = "SMS"};							-- Global Variable Name
--------------------- USER SETTINGS END ----------------------------
----------------------ADVANCED SETTINGS-----------------------------
local Show_standard_debug = true;	-- Debug displayed in white
local Show_extra_debug = true;		-- Debug displayed in orange
-------------------- DO NOT CHANGE CODE BELOW ----------------------
local Number_of_lights = #Random_lights;						-- numbers of light devices listed above
local Simulation = fibaro:getGlobal("Simu_presence");			--value of the global value: Simulation is on or off
local Manual_overide = fibaro:getGlobal("overideSimuSunset");	-- if = 1 then the Simulation is forced
local Start_simulation_time = fibaro:getValue(1, "sunsetHour");	--Start Simulation when sunset
local End_simulation_time,Sunrise_unix_hour,Sunset_unix_hour,Converted_var,Midnight,End_simulation_time_with_random_max_TurnOff,Sleep_between_TurnOff;
local Is_first_launch = true;
local NotifLoop = 0;
function Debug(color, message)
		fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, os.date("%a %d/%m", os.time()).." "..message, "span"));
function ExtraDebug(debugMessage)
	if ( Show_extra_debug ) then
		Debug( "orange", debugMessage);
function StandardDebug(debugMessage)
	if ( Show_standard_debug ) then
		Debug( "white", debugMessage);
function round(num, idp)
	local mult = 10^(idp or 0)
	return math.floor(num * mult + 0.5) / mult
function YAPS_Engine:notification(message, subject, param)
	local message = os.date("%H:%M", os.time()).." "..message or "<vide>";
	if YAPS_Engine.debug_messages then
		ExtraDebug("yellow", "Notification : "..message);
		if Activate_FreeSms then
			fibaro:setGlobal("Activate_FreeSms", message)
			ExtraDebug("Message ("..message..") sent to Activate_FreeSms");
	if param then
		for _, notif in ipairs(param) do
				ExtraDebug("grey", notif);
			-- Envoi Push
			if notif == "push" and YAPS_Engine.smartphoneID then
				for _, id in ipairs(YAPS_Engine.smartphoneID) do
						ExtraDebug("grey", "Send Push smartphone ID : "..id);
					fibaro:call(id, "sendPush", message);
			-- Envoi Email
			elseif notif == "email" and YAPS_Engine.userID then
				for _, id in ipairs(YAPS_Engine.userID) do
						ExtraDebug("grey", "Send Email user ID : "..id);
					fibaro:call(id, "sendEmail", subject, message);
			-- Envoi SMS
			elseif notif == "sms" and YAPS_Engine.sms then
					ExtraDebug("grey", "Send SMS : VD_ID="..(YAPS_Engine.sms["VD_ID"] or 0).." VD_Button="..(YAPS_Engine.sms["VD_Button"] or "0").." VG_Name="..(YAPS_Engine.sms["VG_Name"] or ""));
				fibaro:setGlobal(YAPS_Engine.sms["VG_Name"], message);
				if YAPS_Engine.sms["VD_ID"] and tonumber(YAPS_Engine.sms["VD_ID"])>0 and YAPS_Engine.sms["VD_Button"] and tonumber(YAPS_Engine.sms["VD_Button"])>0 then
					fibaro:call(YAPS_Engine.sms["VD_ID"], "pressButton", YAPS_Engine.sms["VD_Button"]);
	else
		Debug("orange", "Warning : no notification options given");
function YAPS_Engine:UnixTimeCalc(Converted_var, hour, min)
	local time = os.time();
	local date = os.date("*t", time);
	local year = date.year;
	local month = date.month;
	local day = date.day;
	unix_hour = os.time{year=year, month=month, day=day, hour=hour, min=min, sec=sec};
	ExtraDebug("converted "..Converted_var..": "..hour..":"..min.." to Unix Time: "..unix_hour..")")
	return unix_hour
function YAPS_Engine:ReverseUnixTimeCalc(Converted_var,hour)
	reverse_unix = os.date("%H:%M", hour)
	ExtraDebug("Reverse converted Unix Time of "..Converted_var.." : "..hour.." To: "..reverse_unix)
	return reverse_unix
function YAPS_Engine:EndTimeCalc()
	local hour,min
	ExtraDebug ("Current Unix Time: "..os.time())
	End_simulation_time = YAPS_Engine:UnixTimeCalc("Original planed End_simulation_time", Stop_hour, Stop_minute); -- generate End_simulation_time (changes at midnight) will not change during Simulation, only when ended
	Midnight = YAPS_Engine:UnixTimeCalc("Midnight", 00, 00);
	Sunset_unix_hour = fibaro:getValue(1,'sunsetHour');
	hour = string.sub(Sunset_unix_hour, 1 , 2);
	min = string.sub(Sunset_unix_hour,4);
	Sunset_unix_hour = (YAPS_Engine:UnixTimeCalc("Sunset", hour, min))+Sunset_offset*60;
	-- if stop hour is between 00 and 12h then add 24 hours to End_simulation_time
	if tonumber(Stop_hour) <= 12 and (os.time() >= End_simulation_time) then
		End_simulation_time = End_simulation_time + 24*60*60
		ExtraDebug ("stop hour <= 12, Added 24H to End_simulation_time (End_simulation_time is ending after midnignt)");
		ExtraDebug ("New End_simulation_time: "..End_simulation_time);
	if Random_max_TurnOff_duration ~= 0 and Number_of_lights > 1 then   -- if Simulation = 1 then slow turn off, else turn off all immediately
		Sleep_between_TurnOff = round((math.random(Random_max_TurnOff_duration)/(Number_of_lights-1)),1);
		Sleep_between_TurnOff = math.random(Random_max_TurnOff_duration)/(Number_of_lights-1);
		ExtraDebug("Calculated sleeping between each turn off: "..Sleep_between_TurnOff.." min");
	else
		Sleep_between_TurnOff = 0;
		ExtraDebug("No sleeping between turn off");
	End_simulation_time_with_random_max_TurnOff = End_simulation_time + ((Sleep_between_TurnOff*(Number_of_lights-1))*60)
	ExtraDebug("End_simulation_time_with_random_max_TurnOff: "..End_simulation_time_with_random_max_TurnOff);
	if ((os.time() < End_simulation_time) and (Sunset_unix_hour - End_simulation_time > 0) and (Is_first_launch == true)) then -- if calculation is done between midnight and End_simulation_time and sunset is wrongly calculated after endtime (at first start only)
		Sunset_unix_hour = Sunset_unix_hour - (24*60*60) + 70; -- remove 24h58m50s of sunsettime
		ExtraDebug ("launch after Midnight and before End_simulation_time, removed 24H to Sunset_unix_hour (Only at the first start)");
		ExtraDebug ("New SunsetTime: "..Sunset_unix_hour);
	Is_first_launch = false
-- Presence Simulation actions Main loop
function YAPS_Engine:Launch()
	YAPS_Engine:notification("Presence Simulation started. Will stop at: "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time", End_simulation_time).." + rand("..Random_max_TurnOff_duration.."min) : "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time_with_random_max_TurnOff", End_simulation_time_with_random_max_TurnOff), "Presence Simulator", {"push"}); -- push only
	StandardDebug("Presence Simulation started. Will stop at: "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time", End_simulation_time).." + rand("..Random_max_TurnOff_duration.."min) : "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time_with_random_max_TurnOff", End_simulation_time_with_random_max_TurnOff));
	if Lights_always_on[1] ~= nil then YAPS_Engine:TurnOn(Lights_always_on); end
	while ((os.time() <= End_simulation_time) and (Simulation == "1")) or ((Manual_overide == "1")) do
		local random_light = tonumber(Random_lights[math.random(Number_of_lights)]) --choose a random light in the list
		local lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light in the list
		-- turn on the light if off or turn off if on
		if tonumber(lightstatus) == 0 then fibaro:call(random_light, 'turnOn') else fibaro:call(random_light, 'turnOff') end
		fibaro:sleep(1000); -- necessary to get back the new status, because HC2 is too fast :-)
		lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light after his update
		StandardDebug('light ID:'.. fibaro:getName(random_light) ..' status:'..lightstatus);
		local sleeptime = math.random(Random_max_duration*60000) --random sleep
		StandardDebug("Entering loop of " .. round(sleeptime/60000,2) .. " minutes");
		-- Allows to exit the scene if the Simu_presence global var changes to 0 during the random  sleep
			local counterexitSimulation = 200
				while (counterexitSimulation > 0) and ((os.time() <= End_simulation_time) or Manual_overide == "1") do
					counterexitSimulation = counterexitSimulation - 1;
					test_presence_state = fibaro:getGlobal("Simu_presence");
					Simulation = tonumber(test_presence_state); --verify the global value, if the virtual device is deactivated, the loop stops.
					--fibaro:debug("Simulation var state : " .. Simulation.." override var state : " .. Manual_overide);
					if Simulation == 0 then
						Manual_overide = fibaro:getGlobalValue("overideSimuSunset");
						if Simulation == 0 or Manual_overide == "0" then
						counterexitSimulation = 0
				fibaro:sleep(sleeptime/200);
			ExtraDebug("Exiting loop of "..round(sleeptime/60000,2).." minutes");
		local sleeptimemin = math.abs(sleeptime/60000)
		Simulation = fibaro:getGlobal("Simu_presence"); --verify the global value, if the virtual device is deactivated, the scene stops.
	if (Simulation == "1") then
		Debug("yellow","Presence Simulation will restart tomorrow.");
		Debug("yellow","Sunset is around "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time around "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
		YAPS_Engine:notification("Presence Simulation will restart tomorrow. Sunset is around "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time around "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour), "Presence Simulator", {"push"}); -- push only
	NotifLoop = 0; -- will force main loop notifications at end of Simulation
function YAPS_Engine:ExitSimulation()
	--YAPS_Engine:notification("Presence Simulation is terminated", "Presence Simulator", {"push"}); -- push only
	Debug("red","Simu_presence = 0, Aborting Simulation scene");
	fibaro:abort();
function YAPS_Engine:TurnOff(group,group2)
	Debug("red","TurnOff All Simulation lights!");
	local name, id2;
	local ID_devices_group = group;
	if ID_devices_group ~= 0 then
		for i=1, #ID_devices_group do
			Simulation = fibaro:getGlobal("Simu_presence"); --verify the global value, if Simulation presence is deactivated
			if Simulation == "0" then	Sleep_between_TurnOff = 0; end; -- if Simulation ended before End_simulation_time, then no turn off delay
			if i > 1 then -- wait Number of lights -1 (do not need to wait for the first TurnOff)
				StandardDebug("Sleeping "..Sleep_between_TurnOff.." minute(s) before next TurnOff");
				fibaro:sleep(Sleep_between_TurnOff*60000);
			id2 = tonumber(ID_devices_group[i]);
			fibaro:call(id2, "turnOff");
			name = fibaro:getName(id2);
			if (name == nil or name == string.char(0)) then
				name = "Unknown"
			StandardDebug("Device: "..name.." Off ");
	Debug("red","TurnOff All Always_On lights!");
	local ID_devices_group = group2;
					name = "Unknown"
	if Lights_On_at_end_Simulation ~= 0 and Simulation == "1" then
		fibaro:call(Lights_On_at_end_Simulation, "turnOn");
		name = fibaro:getName(Lights_On_at_end_Simulation);
				name = "Unknown"
		Debug("red","Turned On light Lights_On_at_end_Simulation:");
		Debug("white", name);
	if Lights_On_if_Simulation_deactivated ~= 0 and Simulation == "0" then
		fibaro:call(Lights_On_if_Simulation_deactivated, "turnOn");
		name = fibaro:getName(Lights_On_if_Simulation_deactivated);
				name = "Unknown"
		Debug("red","Turned On light Lights_On_if_Simulation_deactivated:");
function YAPS_Engine:TurnOn(group)
	Debug("red","Turning On Always_On lights:");
	local name, id2;
		fibaro:call(id2, "turnOn");
			name = "Unknown"
		StandardDebug("Device: "..name.." Turned On ");
	Debug("red","Now randomizing other lights...");
Debug("green", "Presence Simulation | v" .. version .. " Starting up");
Debug("green", "--------------------------------------------------------------------------");
------------------------ Main Loop ----------------------------------
-- first start notifications
YAPS_Engine:EndTimeCalc();
YAPS_Engine:notification("Scheduled presence Simulation at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour).." (Sunset: "..fibaro:getValue(1, "sunsetHour")..")", "Presence Simulator", {"email"}); -- mail only
Debug("green","Sunset is at "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
Debug("green","End of Simulation: "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time).." + random of "..Random_max_TurnOff_duration.."min");
Debug("green", "Checking for actions every minute.");
while true do -- Infinite loop of actions checking, hours calculations, notifications
	-- local Sunset_unix_hour = Midnight  -- un-comment this line when testing to force a start hour (or use Sunset_offset)
	if os.time() >= Sunset_unix_hour then -- define if nighttime (sunset = 1)
		sunset = 1
	else
		sunset = 0
		if sunset == 1 and (os.time() <= End_simulation_time) then
			Debug("yellow", "It's sunset time -> Simulation ON");
			YAPS_Engine:Launch();
			YAPS_Engine:EndSimulation();
		if Manual_overide == "1" then
			Debug("yellow", "Manual Override Activated -> Simulation ON");
		if Manual_overide == "0" and sunset == 0 and NotifLoop == 0 then
			Debug("yellow", "Sunset is at "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
			Debug("yellow", "End of Simulation: "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time).." + random of "..Random_max_TurnOff_duration.."min = "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time_with_random_max_TurnOff));
	if (Simulation == "0") then -- Condition to end Simulation
		YAPS_Engine:ExitSimulation();
	if NotifLoop <= 120 then --a waiting xx times the fibaro sleep below (2 hours) before resetting counter (and notifying)
		if NotifLoop == 120 then NotifLoop = 0 end
		if NotifLoop == 0 then
		ExtraDebug("Now, checking for actions every minute. Next notify: in 2 hours");
	fibaro:sleep(1*60*1000); -- wait 1 minutes before testing again the global vars below
	NotifLoop = NotifLoop + 1;
Les ID's et Local Names sont juste. Que est-ce que j'ai fait de faux?
  • 9 mois après...
Le 13/12/2021 à 09:36, speedoxx007 a dit :
Hello,
Quelqu'un à un YAPS qui fonctionne bien avec les Hue? Si oui, quelqu'un peut partager son code LUA de la scène?
Personne à YAPS à partager avec le Philips Hue qui fonctionne bien? Juste la scène LUA? :(
  • 3 mois après...
Il y a 21 heures, Dragoniacs a dit :
Ça ne fonctionne pas tel quel, il faut l'adapter.
Envoyé de mon M2012K11AG en utilisant Tapatalk
je  n'y connais rien en HC3, donc si tu as commencé, continue, surtout que de mes souvenirs, ce n'est pas un code piqué des verts (et comme je l'ait dans ma re-présentation, je vais commencer par être un horrible profiteur ...)
Il y a 20 heures, mprinfo a dit :
N'achète pas une hc3 on a plus chats noirs depuis que tu es parti emoji1787.pngemoji1787.png
je ne m'inquiète pas, car comme tu ré-inclueras tout, tu le feras sans les chats ;-)
Il y a 22 heures, Did a dit :
 Merci, j'étais passé à côté.
Ça fait mal aux fesses quand même vu le prix de la bête et le temps que tu en a profité sans encombres.
oui, en effet. Mais ne dit rien à ma femme, car en plus d'avoir mal aux fesses, j'aurais mal aux coui...
